Note: The topic is only for suspend/sleep. I don’t have hibernation configured.
Recently I moved entire disc (NVMe) to a different laptop with different CPU and GPU hardware. Now I’m ironing out issues that came out of that relocation.
Suspending/sleep doesn’t work, or at least not fully. There is no Sleep action in power menu (KDE Plasma), although it was available under the previous laptop. It doesn’t work fully when I close the lid, it seems as sleep is successful, but then it’s impossible to wake the laptop up, and I have to force shutdown/reboot.
On old laptop, suspend worked, so all settings should be there, in theory.
On another disc, there is TUXEDO OS and suspend works there without problem, so this is not a hardware issue, but certainly some bad configs on my Manjaro system that is not re-configured to the new hardware properly.
Here is the hardware:
inxi --full --admin --filter --width
Kernel: 6.7.0-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=05f58c13-0021-44f7-abc9-05a091c4535b rw rhgb quiet
mitigations=off quiet splash loglevel=3 udev.log_priority=3
vt.global_cursor_default=0 resume_offset=1363968
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.113.0 wm: kwin_wayland with: latte-dock vt: 1 dm: SDDM
Type: Laptop System: TUXEDO product: TUXEDO Sirius 16 Gen1 v: N/A
Mobo: NB04 model: APX958 serial: <superuser required> part-nu: SIRIUS1601
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.00A00_20240108
date: 01/08/2024
ID-1: BAT0 charge: 73.7 Wh (92.0%) condition: 80.1/80.1 Wh (100.0%)
volts: 17.2 min: N/A model: AMD Battery Li-ion Real Battery type: Li-ion
serial: <filter> status: charging
Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x74 (116) stepping: 1 microcode: 0xA704103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 768 high: 1459
min/max: 400/5137:6080:5764:5293:5449:5608:5924 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 1399
4: 1370 5: 400 6: 400 7: 400 8: 1459 9: 400 10: 1307 11: 400 12: 400
13: 400 14: 400 15: 1357 16: 1396 bogomips: 121416
Type: spec_rstack_overflow status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: Emdoor Digital driver: amdgpu v: kernel arch: RDNA-3 code: Navi-33
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 8 ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 03:00.0 chip-ID: 1002:7480
class-ID: 0300
Device-2: AMD Phoenix1 vendor: Emdoor Digital driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4,
DP-5, DP-6, DP-7, DP-8, DP-9 bus-ID: 69:00.0 chip-ID: 1002:15bf
class-ID: 0300 temp: 36.0 C
Device-3: Microdia Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0c45:6362
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: eDP-2 res: 1969x1108 size: N/A modes: N/A
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1
gfx1103_r1 LLVM 16.0.6 DRM 3.56 6.7.0-0-MANJARO) device-ID: 1002:15bf
memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 7600M XT (RADV NAVI33) driver: mesa radv v: 23.3.3-manjaro1.1
device-ID: 1002:7480 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV GFX1103_R1)
driver: mesa radv v: 23.3.3-manjaro1.1 device-ID: 1002:15bf
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 69:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Emdoor Digital
driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 69:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Emdoor Digital
bus-ID: 69:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.0-0-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 0e8d:0608
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 2.73 TiB used: 340.39 GiB (12.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC2500M82000G
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S7781101 temp: 31.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 31.9 C
scheme: GPT
ID-1: / raw-size: 100.59 GiB size: 98.82 GiB (98.25%) used: 43.9 GiB (44.4%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:3
ID-2: /home raw-size: 1.72 TiB size: 1.69 TiB (98.42%)
used: 296.49 GiB (17.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:1
Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: zram size: 6.12 GiB used: 14.2 MiB (0.2%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 39.8 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 37.0 C watts: 7.23 device: amdgpu temp: 40.0 C
mem: 47.0 C fan: 0
Memory: total: 32 GiB note: est. available: 30.58 GiB used: 7.96 GiB (26.0%)
Processes: 399 Power: uptime: 24m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform avail: shutdown,reboot,suspend,test_resume
image: 12.21 GiB daemons: upowerd, org_kde_powerdevil,
power-profiles-daemon Init: systemd v: 255 default: graphical
tool: systemctl
Packages: 2119 pm: pacman pkgs: 2100 libs: 561 tools: pamac,yay pm: flatpak
pkgs: 12 pm: snap pkgs: 7 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash
v: 5.2.21 running-in: konsole inxi: 3.3.32
Here is journald info:
journalctl -b -1 -g suspend
lut 14 19:37:46 alienware-PC kernel: Low-power S0 idle used by default for system suspend
lut 14 19:37:46 alienware-PC kernel: nvme 0000:08:00.0: platform quirk: setting simple suspend
lut 14 19:37:46 alienware-PC kernel: nvme 0000:04:00.0: platform quirk: setting simple suspend
lut 14 19:37:53 alienware-PC kded5[5944]: kscreen.kded: PowerDevil SuspendSession action not available!
lut 14 19:40:08 alienware-PC systemd-logind[761]: The system will suspend now!
lut 14 19:40:08 alienware-PC ModemManager[838]: <msg> [sleep-monitor-systemd] system is about to suspend
lut 14 19:40:09 alienware-PC systemd[1]: Starting System Suspend...
lut 14 19:40:10 alienware-PC systemd-sleep[39018]: Performing sleep operation 'suspend'...
There is never wake up data, because system never wakes up. I have to long-power press to boot the system again.
Any idea where to beging?
