Hi, when I close the laptop and reopen it takes too long to “wake up”, sometimes I have to click the power button on the pc. Is the current setting sleep after 15 minutes, should I hibernate for him to wake up faster, or is this some other issue? The system is updated to the latest release. Thank you.
Can you clarify what your current setting is?
screen dimming - after 5 minutes
energy saving - turns off after 10 minutes
suspend session - automatically - suspend after 15 minutes
Button event handling - when laptop screen is closed - suspend
Please provide system information as linked above.
export LANG=C ✔
~ inxi --admin --verbosity=7 --filter --width ✔
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e2d644a1-ab18-4dac-b5a9-96861caceac2 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Vostro 3558 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 05W6N2 v: A00 serial: <superuser required> UEFI: Dell
v: A17 date: 09/11/2020
RAM: total: 7.67 GiB used: 3.37 GiB (43.9%)
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 924 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1900 2: 500 3: 500 4: 798
bogomips: 15968
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 2-5:3 chip-ID: 0c45:6710 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 built: 2014 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
bus-ID: 2-6:4 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 238.47 GiB used: 11.32 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD Sata III
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4A0 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
ID-1: / raw-size: 30 GiB size: 29.36 GiB (97.87%) used: 10.01 GiB (34.1%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: Manjaro
uuid: e2d644a1-ab18-4dac-b5a9-96861caceac2
used: 464 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 5FCA-4D6E
ID-3: /home raw-size: 35 GiB size: 34.15 GiB (97.58%) used: 1.31 GiB (3.8%)
fs: ext4 dev: /dev/sda10 maj-min: 8:10 label: Manjaro_Home
uuid: 0e830398-b334-43da-a792-a6acccfb7b36
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: e9fe1e37-91cc-4933-8ab7-2dba61c68e4f
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 8415-4124
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 58.85 GiB fs: ntfs label: N/A
uuid: FA3A68C23A687D8F
ID-4: /dev/sda4 maj-min: 8:4 size: 521 MiB fs: ntfs label: N/A
uuid: 5C4A12DA4A12B12E
ID-5: /dev/sda7 maj-min: 8:7 size: 108.43 GiB fs: ext4 label: N/A
uuid: 1aa8d530-b0d6-450a-b51f-6130ad7b7619
ID-6: /dev/sda9 maj-min: 8:9 size: 1.06 GiB fs: ntfs label: DELLSUPPORT
uuid: 30BAFF28BAFEE8EC
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 2-5:3 info: Microdia Integrated Webcam type: Video
Device-3: 2-6:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 2-8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0 fan-2: 0 fan-3: 0
Processes: 185 Uptime: 56m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1207 libs: 334 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
- How long does it take to wake up?
- Does this consistently happen? Is the timing consistent?
- Are you able to see a cursor on screen? If not, does the backlight appear to be on even though the screen is black?
- Did this start recently or has it been happening the whole time you used Manjaro?
- How long did it take to wake up from sleep on your previous OS, and what OS was that?
- Much more than normal, I have to click enter, power key and wait, not 10 minutes but about 1 minute
-Every time I close the screen and reopen, sometimes for coffee, sometimes the following day.
-I don’t see the cursor, the backlight is not on.
-I’ve always had this problem.
With endeavour there was no problem.
Does this happen if you let your computer idle sleep instead of closing it? To quickly test instead of having to wait the full 15 minutes, you can temporarily set it to suspend after about 1 minute.
It also happens when idle, without closing the screen.
Right after waking the computer up, please execute the following command:
journalctl > ~/journalctl
In your home, you will find a file called journalctl. Look at it, starting from the end, and post every line starting with a timestamp from after you tried to wake up your computer. You may want to look at the time down to the second on your phone when you open it.
~ journalctl > ~/Desktop/journalctl ✔
zsh: no such file or directory: /home/eduardolp3/Desktop/journalctl
My bad. As @omano pointed out, your system is not set to English, so you won’t have a ~/Desktop directory. Please use the revised instructions I just edited in.
Scuseme
What do you mean?
~ export LANG=C 1 ✘
I have a Desktop directory
Can you paste the output of the following?
ls ~
apr 29 22:41:00 eduardolp3-Manjaro rtkit-daemon[674]: Supervising 13 threads of 8 processes of 1 users.
apr 29 22:41:01 eduardolp3-Manjaro ModemManager[403]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:06:00.0': not supported by any plugin
apr 29 22:41:01 eduardolp3-Manjaro ModemManager[403]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.3/0000:07:00.0': not supported by any plugin
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9267] policy: auto-activating connection 'Redmi' (0a9bf68d-3d48-4d59-9355-7952da9a34e5)
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9274] device (wlp6s0): Activation: starting connection 'Redmi' (0a9bf68d-3d48-4d59-9355-7952da9a34e5)
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9275] device (wlp6s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9279] manager: NetworkManager state is now CONNECTING
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9285] device (wlp6s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9291] device (wlp6s0): Activation: (wifi) access point 'Redmi' has security, but secrets are required.
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9293] device (wlp6s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9310] device (wlp6s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9315] device (wlp6s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9319] device (wlp6s0): Activation: (wifi) connection 'Redmi' has security, and secrets exist. No new secrets needed.
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9319] Config: added 'ssid' value 'Redmi'
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9320] Config: added 'scan_ssid' value '1'
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9320] Config: added 'bgscan' value 'simple:30:-70:86400'
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9320] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9320] Config: added 'auth_alg' value 'OPEN'
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9320] Config: added 'psk' value '<hidden>'
apr 29 22:41:02 eduardolp3-Manjaro kdeconnectd[933]: "L'oggetto non esiste nel percorso «/org/freedesktop/NetworkManager/ActiveConnection/2»"
apr 29 22:41:02 eduardolp3-Manjaro kded5[684]: "L'oggetto non esiste nel percorso «/org/freedesktop/NetworkManager/ActiveConnection/2»"
apr 29 22:41:02 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: SME: Trying to authenticate with d2:24:dd:20:74:aa (SSID='Redmi' freq=2412 MHz)
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: authenticate with d2:24:dd:20:74:aa
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: 80 MHz not supported, disabling VHT
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: send auth to d2:24:dd:20:74:aa (try 1/3)
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9595] device (wlp6s0): supplicant interface state: disconnected -> authenticating
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9596] device (p2p-dev-wlp6s0): supplicant management interface state: disconnected -> authenticating
apr 29 22:41:02 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: Trying to associate with d2:24:dd:20:74:aa (SSID='Redmi' freq=2412 MHz)
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9609] device (wlp6s0): supplicant interface state: authenticating -> associating
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9610] device (p2p-dev-wlp6s0): supplicant management interface state: authenticating -> associating
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: authenticated
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: associate with d2:24:dd:20:74:aa (try 1/3)
apr 29 22:41:02 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: Associated with d2:24:dd:20:74:aa
apr 29 22:41:02 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: RX AssocResp from d2:24:dd:20:74:aa (capab=0x411 status=0 aid=1)
apr 29 22:41:02 eduardolp3-Manjaro kernel: wlp6s0: associated
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9766] device (wlp6s0): supplicant interface state: associating -> associated
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9767] device (p2p-dev-wlp6s0): supplicant management interface state: associating -> associated
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9820] device (wlp6s0): supplicant interface state: associated -> 4way_handshake
apr 29 22:41:02 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800862.9820] device (p2p-dev-wlp6s0): supplicant management interface state: associated -> 4way_handshake
apr 29 22:41:03 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: WPA: Key negotiation completed with d2:24:dd:20:74:aa [PTK=CCMP GTK=CCMP]
apr 29 22:41:03 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: CTRL-EVENT-CONNECTED - Connection to d2:24:dd:20:74:aa completed [id=0 id_str=]
apr 29 22:41:03 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-28 noise=9999 txrate=1000
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0308] device (wlp6s0): supplicant interface state: 4way_handshake -> completed
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0308] device (wlp6s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Redmi"
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0308] device (p2p-dev-wlp6s0): supplicant management interface state: 4way_handshake -> completed
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0310] device (wlp6s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0316] dhcp4 (wlp6s0): activation: beginning transaction (timeout in 45 seconds)
apr 29 22:41:03 eduardolp3-Manjaro kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp6s0: link becomes ready
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0513] dhcp4 (wlp6s0): state changed new lease, address=192.168.7.241
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0517] policy: set 'Redmi' (wlp6s0) as default for IPv4 routing and DNS
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0599] device (wlp6s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0636] device (wlp6s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0640] device (wlp6s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0644] manager: NetworkManager state is now CONNECTED_SITE
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.0654] device (wlp6s0): Activation: successful, device activated.
apr 29 22:41:03 eduardolp3-Manjaro wpa_supplicant[484]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-28 noise=9999 txrate=72200
apr 29 22:41:03 eduardolp3-Manjaro NetworkManager[391]: <info> [1682800863.1701] manager: NetworkManager state is now CONNECTED_GLOBAL
apr 29 22:41:04 eduardolp3-Manjaro systemd[1]: systemd-rfkill.service: Deactivated successfully.
apr 29 22:41:04 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 29 22:41:04 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682800864.676:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 29 22:41:05 eduardolp3-Manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
apr 29 22:41:05 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 29 22:41:05 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682800865.816:148): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 29 22:41:05 eduardolp3-Manjaro audit[9360]: USER_AUTH pid=9360 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="eduardolp3" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 29 22:41:05 eduardolp3-Manjaro kernel: audit: type=1100 audit(1682800865.923:149): pid=9360 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="eduardolp3" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 29 22:41:11 eduardolp3-Manjaro rtkit-daemon[674]: Supervising 13 threads of 8 processes of 1 users.
This is all there was during the wake-up process? That’s curious. Pretty much everything here is just about wifi, which I’m not really sure why it would come into play if your computer is still waking up. A bit of a long-shot, but what happens if you disable wifi before sleeping? Also, I forgot to ask this before, but does anything change if you sleep directly using systemctl suspend? I assume nothing will change, but I’d like to cover some bases.
I redid the procedure you asked me first, since, the system went into suspension at 19:26:20.
apr 30 19:26:20 eduardolp3-Manjaro systemd-logind[349]: The system will suspend now!
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.6262] manager: sleep: sleep requested (sleeping: no enabled: yes)
apr 30 19:26:20 eduardolp3-Manjaro ModemManager[386]: <info> [sleep-monitor-systemd] system is about to suspend
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.6263] device (enp7s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.6363] device (p2p-dev-wlp6s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.6367] manager: NetworkManager state is now ASLEEP
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.6369] device (wlp6s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:26:20 eduardolp3-Manjaro kded5[678]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
apr 30 19:26:20 eduardolp3-Manjaro dbus-daemon[347]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=364 comm="/usr/bin/NetworkManager --no-daemon")
apr 30 19:26:20 eduardolp3-Manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
apr 30 19:26:20 eduardolp3-Manjaro dbus-daemon[347]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
apr 30 19:26:20 eduardolp3-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:26:20 eduardolp3-Manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
apr 30 19:26:20 eduardolp3-Manjaro kernel: audit: type=1130 audit(1682875580.671:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:26:20 eduardolp3-Manjaro kernel: wlp6s0: deauthenticating from d2:24:dd:20:74:aa by local choice (Reason: 3=DEAUTH_LEAVING)
apr 30 19:26:20 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-DISCONNECTED bssid=d2:24:dd:20:74:aa reason=3 locally_generated=1
apr 30 19:26:20 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
apr 30 19:26:20 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8131] device (wlp6s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8138] dhcp4 (wlp6s0): canceled DHCP transaction
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8138] dhcp4 (wlp6s0): activation: beginning transaction (timeout in 45 seconds)
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8139] dhcp4 (wlp6s0): state changed no lease
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8332] device (wlp6s0): set-hw-addr: set MAC address to FE:55:FF:AF:72:22 (scanning)
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8605] device (wlp6s0): supplicant interface state: completed -> disconnected
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.8619] device (wlp6s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:26:20 eduardolp3-Manjaro kscreenlocker_greet[1864]: Qt: Session management error: networkIdsList argument is NULL
apr 30 19:26:20 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875580.9097] device (wlp6s0): set-hw-addr: reset MAC address to A0:D3:7A:8A:76:04 (unmanage)
apr 30 19:26:20 eduardolp3-Manjaro wpa_supplicant[458]: p2p-dev-wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
apr 30 19:26:20 eduardolp3-Manjaro wpa_supplicant[458]: nl80211: deinit ifname=p2p-dev-wlp6s0 disabled_11b_rates=0
apr 30 19:26:20 eduardolp3-Manjaro wpa_supplicant[458]: nl80211: deinit ifname=wlp6s0 disabled_11b_rates=0
apr 30 19:26:21 eduardolp3-Manjaro kscreenlocker_greet[1864]: kf.kirigami: Failed to find a Kirigami platform plugin
apr 30 19:26:22 eduardolp3-Manjaro systemd[1]: Reached target Sleep.
apr 30 19:26:22 eduardolp3-Manjaro kscreenlocker_greet[1864]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "it_IT" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
apr 30 19:26:22 eduardolp3-Manjaro systemd[1]: Starting System Suspend...
apr 30 19:26:22 eduardolp3-Manjaro systemd-sleep[1906]: Entering sleep state 'suspend'...
apr 30 19:26:22 eduardolp3-Manjaro kernel: PM: suspend entry (deep)
apr 30 19:27:01 eduardolp3-Manjaro kernel: Filesystems sync: 0.009 seconds
apr 30 19:27:01 eduardolp3-Manjaro kernel: Freezing user space processes
apr 30 19:27:01 eduardolp3-Manjaro kernel: Freezing user space processes completed (elapsed 0.002 seconds)
apr 30 19:27:01 eduardolp3-Manjaro kernel: OOM killer disabled.
apr 30 19:27:01 eduardolp3-Manjaro kernel: Freezing remaining freezable tasks
apr 30 19:27:01 eduardolp3-Manjaro kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
apr 30 19:27:01 eduardolp3-Manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
apr 30 19:27:01 eduardolp3-Manjaro kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
apr 30 19:27:01 eduardolp3-Manjaro kernel: sd 0:0:0:0: [sda] Stopping disk
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: EC: interrupt blocked
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: PM: Preparing to enter system sleep state S3
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: EC: event blocked
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: EC: EC stopped
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: PM: Saving platform NVS memory
apr 30 19:27:01 eduardolp3-Manjaro kernel: Disabling non-boot CPUs ...
apr 30 19:27:01 eduardolp3-Manjaro kernel: smpboot: CPU 1 is now offline
apr 30 19:27:01 eduardolp3-Manjaro kernel: smpboot: CPU 2 is now offline
apr 30 19:27:01 eduardolp3-Manjaro kernel: smpboot: CPU 3 is now offline
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: PM: Low-level resume complete
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: EC: EC started
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: PM: Restoring platform NVS memory
apr 30 19:27:01 eduardolp3-Manjaro kernel: Enabling non-boot CPUs ...
apr 30 19:27:01 eduardolp3-Manjaro kernel: x86: Booting SMP configuration:
apr 30 19:27:01 eduardolp3-Manjaro kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
apr 30 19:27:01 eduardolp3-Manjaro kernel: CPU1 is up
apr 30 19:27:01 eduardolp3-Manjaro kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
apr 30 19:27:01 eduardolp3-Manjaro kernel: CPU2 is up
apr 30 19:27:01 eduardolp3-Manjaro kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
apr 30 19:27:01 eduardolp3-Manjaro kernel: CPU3 is up
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: PM: Waking up from system sleep state S3
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: EC: interrupt unblocked
apr 30 19:27:01 eduardolp3-Manjaro kernel: ACPI: EC: event unblocked
apr 30 19:27:01 eduardolp3-Manjaro kernel: sd 0:0:0:0: [sda] Starting disk
apr 30 19:27:01 eduardolp3-Manjaro kernel: usb 2-8: reset high-speed USB device number 5 using xhci_hcd
apr 30 19:27:01 eduardolp3-Manjaro kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
apr 30 19:27:01 eduardolp3-Manjaro kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
apr 30 19:27:01 eduardolp3-Manjaro kernel: ata1.00: configured for UDMA/133
apr 30 19:27:01 eduardolp3-Manjaro kernel: ata2.00: configured for UDMA/100
apr 30 19:27:01 eduardolp3-Manjaro kernel: usb 2-6: reset full-speed USB device number 4 using xhci_hcd
apr 30 19:27:01 eduardolp3-Manjaro kernel: usb 2-5: reset high-speed USB device number 3 using xhci_hcd
apr 30 19:27:01 eduardolp3-Manjaro kernel: usb 2-2: reset full-speed USB device number 2 using xhci_hcd
apr 30 19:27:01 eduardolp3-Manjaro kernel: OOM killer enabled.
apr 30 19:27:01 eduardolp3-Manjaro kernel: Restarting tasks ... done.
apr 30 19:27:01 eduardolp3-Manjaro kernel: random: crng reseeded on system resumption
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_hq
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_sq
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_mq
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aptx_hd
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_hd
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_453
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_453
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_512
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_512
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_552
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_552
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Starting Load/Save RF Kill Switch Status...
apr 30 19:27:01 eduardolp3-Manjaro systemd-sleep[1906]: System returned from sleep state.
apr 30 19:27:01 eduardolp3-Manjaro kernel: PM: suspend exit
apr 30 19:27:01 eduardolp3-Manjaro kernel: pci_bus 0000:04: Allocating resources
apr 30 19:27:01 eduardolp3-Manjaro kernel: pci_bus 0000:06: Allocating resources
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 06] add_size 1000
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 06] add_size 200000 add_align 100000
apr 30 19:27:01 eduardolp3-Manjaro kernel: pci_bus 0000:07: Allocating resources
apr 30 19:27:01 eduardolp3-Manjaro kernel: pci_bus 0000:08: Allocating resources
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.4: bridge window [io 0x1000-0x0fff] to [bus 08] add_size 1000
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 08] add_size 200000 add_align 100000
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff] to [bus 08] add_size 200000 add_align 100000
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.2: BAR 15: assigned [mem 0xdfc00000-0xdfdfffff 64bit pref]
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.4: BAR 14: assigned [mem 0xdfe00000-0xdfffffff]
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.4: BAR 15: assigned [mem 0xf0100000-0xf02fffff 64bit pref]
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.2: BAR 13: assigned [io 0x3000-0x3fff]
apr 30 19:27:01 eduardolp3-Manjaro kernel: pcieport 0000:00:1c.4: BAR 13: assigned [io 0x4000-0x4fff]
apr 30 19:27:01 eduardolp3-Manjaro kernel: audit: type=1130 audit(1682875621.326:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:01 eduardolp3-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Started Load/Save RF Kill Switch Status.
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: systemd-suspend.service: Deactivated successfully.
apr 30 19:27:01 eduardolp3-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:01 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Finished System Suspend.
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Stopped target Sleep.
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Reached target Suspend.
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Stopped target Suspend.
apr 30 19:27:01 eduardolp3-Manjaro systemd-logind[349]: Operation 'sleep' finished.
apr 30 19:27:01 eduardolp3-Manjaro kernel: audit: type=1130 audit(1682875621.349:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:01 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682875621.349:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.3625] manager: sleep: wake requested (sleeping: yes enabled: yes)
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.3627] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:27:01 eduardolp3-Manjaro ModemManager[386]: <info> [sleep-monitor-systemd] system is resuming
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Stopped target Bluetooth Support.
apr 30 19:27:01 eduardolp3-Manjaro kernel: Generic FE-GE Realtek PHY r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
apr 30 19:27:01 eduardolp3-Manjaro plasmashell[739]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.5793] device (wlp6s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.5814] device (p2p-dev-wlp6s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:27:01 eduardolp3-Manjaro kernel: r8169 0000:07:00.0 enp7s0: Link is Down
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.5823] manager: NetworkManager state is now DISCONNECTED
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6196] device (wlp6s0): supplicant interface state: internal-starting -> disconnected
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6197] device (p2p-dev-wlp6s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6207] Wi-Fi P2P device controlled by interface wlp6s0 created
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6211] manager: (p2p-dev-wlp6s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6214] device (p2p-dev-wlp6s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6221] device (wlp6s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
apr 30 19:27:01 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875621.6228] device (p2p-dev-wlp6s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:01 eduardolp3-Manjaro systemd[1]: Reached target Bluetooth Support.
apr 30 19:27:01 eduardolp3-Manjaro systemd[583]: Reached target Bluetooth.
apr 30 19:27:01 eduardolp3-Manjaro kernel: Bluetooth: hci0: Legacy ROM 2.5 revision 0.0 build 1 week 45 2013
apr 30 19:27:01 eduardolp3-Manjaro kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
apr 30 19:27:01 eduardolp3-Manjaro kernel: Bluetooth: hci0: Intel BT fw patch 0x27 completed & activated
apr 30 19:27:01 eduardolp3-Manjaro kernel: Bluetooth: MGMT ver 1.22
apr 30 19:27:01 eduardolp3-Manjaro pulseaudio[1089]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_hq
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_sq
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_mq
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aptx_hd
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_hd
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_453
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_453
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_512
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_512
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_552
apr 30 19:27:01 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_552
apr 30 19:27:03 eduardolp3-Manjaro ModemManager[386]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:06:00.0': not supported by any plugin
apr 30 19:27:03 eduardolp3-Manjaro ModemManager[386]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.3/0000:07:00.0': not supported by any plugin
apr 30 19:27:04 eduardolp3-Manjaro dbus-daemon[347]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.77' (uid=1000 pid=1864 comm="/usr/lib/kscreenlocker_greet --immediateLock --gra")
apr 30 19:27:04 eduardolp3-Manjaro dbus-daemon[347]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
apr 30 19:27:04 eduardolp3-Manjaro kscreenlocker_greet[1864]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9435] policy: auto-activating connection 'Redmi' (0a9bf68d-3d48-4d59-9355-7952da9a34e5)
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9442] device (wlp6s0): Activation: starting connection 'Redmi' (0a9bf68d-3d48-4d59-9355-7952da9a34e5)
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9444] device (wlp6s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9448] manager: NetworkManager state is now CONNECTING
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9452] device (wlp6s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9459] device (wlp6s0): Activation: (wifi) access point 'Redmi' has security, but secrets are required.
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9459] device (wlp6s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9481] device (wlp6s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9486] device (wlp6s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9495] device (wlp6s0): Activation: (wifi) connection 'Redmi' has security, and secrets exist. No new secrets needed.
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9495] Config: added 'ssid' value 'Redmi'
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9495] Config: added 'scan_ssid' value '1'
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9496] Config: added 'bgscan' value 'simple:30:-70:86400'
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9496] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9496] Config: added 'auth_alg' value 'OPEN'
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9496] Config: added 'psk' value '<hidden>'
apr 30 19:27:04 eduardolp3-Manjaro kded5[678]: "L'oggetto non esiste nel percorso «/org/freedesktop/NetworkManager/ActiveConnection/2»"
apr 30 19:27:04 eduardolp3-Manjaro kdeconnectd[927]: "L'oggetto non esiste nel percorso «/org/freedesktop/NetworkManager/ActiveConnection/2»"
apr 30 19:27:04 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: SME: Trying to authenticate with d2:24:dd:20:74:aa (SSID='Redmi' freq=2412 MHz)
apr 30 19:27:04 eduardolp3-Manjaro kernel: wlp6s0: authenticate with d2:24:dd:20:74:aa
apr 30 19:27:04 eduardolp3-Manjaro kernel: wlp6s0: 80 MHz not supported, disabling VHT
apr 30 19:27:04 eduardolp3-Manjaro kernel: wlp6s0: send auth to d2:24:dd:20:74:aa (try 1/3)
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9781] device (wlp6s0): supplicant interface state: disconnected -> authenticating
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9782] device (p2p-dev-wlp6s0): supplicant management interface state: disconnected -> authenticating
apr 30 19:27:04 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: Trying to associate with d2:24:dd:20:74:aa (SSID='Redmi' freq=2412 MHz)
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9816] device (wlp6s0): supplicant interface state: authenticating -> associating
apr 30 19:27:04 eduardolp3-Manjaro kernel: wlp6s0: authenticated
apr 30 19:27:04 eduardolp3-Manjaro kernel: wlp6s0: associate with d2:24:dd:20:74:aa (try 1/3)
apr 30 19:27:04 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875624.9816] device (p2p-dev-wlp6s0): supplicant management interface state: authenticating -> associating
apr 30 19:27:04 eduardolp3-Manjaro kernel: wlp6s0: RX AssocResp from d2:24:dd:20:74:aa (capab=0x411 status=0 aid=1)
apr 30 19:27:05 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: Associated with d2:24:dd:20:74:aa
apr 30 19:27:05 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
apr 30 19:27:05 eduardolp3-Manjaro kernel: wlp6s0: associated
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0138] device (wlp6s0): supplicant interface state: associating -> 4way_handshake
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0139] device (p2p-dev-wlp6s0): supplicant management interface state: associating -> 4way_handshake
apr 30 19:27:05 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: WPA: Key negotiation completed with d2:24:dd:20:74:aa [PTK=CCMP GTK=CCMP]
apr 30 19:27:05 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-CONNECTED - Connection to d2:24:dd:20:74:aa completed [id=0 id_str=]
apr 30 19:27:05 eduardolp3-Manjaro kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp6s0: link becomes ready
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0679] device (wlp6s0): supplicant interface state: 4way_handshake -> completed
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0679] device (wlp6s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Redmi"
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0679] device (p2p-dev-wlp6s0): supplicant management interface state: 4way_handshake -> completed
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0681] device (wlp6s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0687] dhcp4 (wlp6s0): activation: beginning transaction (timeout in 45 seconds)
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0898] dhcp4 (wlp6s0): state changed new lease, address=192.168.7.241
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0902] policy: set 'Redmi' (wlp6s0) as default for IPv4 routing and DNS
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.0974] device (wlp6s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.1008] device (wlp6s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.1011] device (wlp6s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.1016] manager: NetworkManager state is now CONNECTED_SITE
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.1026] device (wlp6s0): Activation: successful, device activated.
apr 30 19:27:05 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=72200
apr 30 19:27:05 eduardolp3-Manjaro NetworkManager[364]: <info> [1682875625.2273] manager: NetworkManager state is now CONNECTED_GLOBAL
apr 30 19:27:06 eduardolp3-Manjaro systemd[1]: systemd-rfkill.service: Deactivated successfully.
apr 30 19:27:06 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:06 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682875626.659:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:07 eduardolp3-Manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
apr 30 19:27:07 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:07 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682875627.699:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:08 eduardolp3-Manjaro audit[1978]: USER_AUTH pid=1978 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="eduardolp3" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 30 19:27:08 eduardolp3-Manjaro kernel: audit: type=1100 audit(1682875628.446:80): pid=1978 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="eduardolp3" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
NO wifi
apr 30 19:43:54 eduardolp3-Manjaro systemd-logind[349]: The system will suspend now!
apr 30 19:43:54 eduardolp3-Manjaro ModemManager[386]: <info> [sleep-monitor-systemd] system is about to suspend
apr 30 19:43:54 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876634.0715] manager: sleep: sleep requested (sleeping: no enabled: yes)
apr 30 19:43:54 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876634.0716] device (enp7s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:43:54 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876634.0792] device (wlp6s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:43:54 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876634.0996] device (wlp6s0): set-hw-addr: reset MAC address to A0:D3:7A:8A:76:04 (unmanage)
apr 30 19:43:54 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876634.1051] device (p2p-dev-wlp6s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
apr 30 19:43:54 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876634.1058] manager: NetworkManager state is now ASLEEP
apr 30 19:43:54 eduardolp3-Manjaro wpa_supplicant[458]: p2p-dev-wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
apr 30 19:43:54 eduardolp3-Manjaro wpa_supplicant[458]: nl80211: deinit ifname=p2p-dev-wlp6s0 disabled_11b_rates=0
apr 30 19:43:54 eduardolp3-Manjaro wpa_supplicant[458]: wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
apr 30 19:43:54 eduardolp3-Manjaro wpa_supplicant[458]: nl80211: deinit ifname=wlp6s0 disabled_11b_rates=0
apr 30 19:43:54 eduardolp3-Manjaro kscreenlocker_greet[2945]: Qt: Session management error: networkIdsList argument is NULL
apr 30 19:43:55 eduardolp3-Manjaro kscreenlocker_greet[2945]: kf.kirigami: Failed to find a Kirigami platform plugin
apr 30 19:43:55 eduardolp3-Manjaro systemd[1]: Reached target Sleep.
apr 30 19:43:55 eduardolp3-Manjaro systemd[1]: Starting System Suspend...
apr 30 19:43:55 eduardolp3-Manjaro kscreenlocker_greet[2945]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "it_IT" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
apr 30 19:43:55 eduardolp3-Manjaro systemd-sleep[2981]: Entering sleep state 'suspend'...
apr 30 19:43:55 eduardolp3-Manjaro kernel: PM: suspend entry (deep)
apr 30 19:44:21 eduardolp3-Manjaro kernel: Filesystems sync: 0.007 seconds
apr 30 19:44:21 eduardolp3-Manjaro kernel: Freezing user space processes
apr 30 19:44:21 eduardolp3-Manjaro kernel: Freezing user space processes completed (elapsed 0.002 seconds)
apr 30 19:44:21 eduardolp3-Manjaro kernel: OOM killer disabled.
apr 30 19:44:21 eduardolp3-Manjaro kernel: Freezing remaining freezable tasks
apr 30 19:44:21 eduardolp3-Manjaro kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
apr 30 19:44:21 eduardolp3-Manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
apr 30 19:44:21 eduardolp3-Manjaro kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
apr 30 19:44:21 eduardolp3-Manjaro kernel: sd 0:0:0:0: [sda] Stopping disk
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: EC: interrupt blocked
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: PM: Preparing to enter system sleep state S3
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: EC: event blocked
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: EC: EC stopped
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: PM: Saving platform NVS memory
apr 30 19:44:21 eduardolp3-Manjaro kernel: Disabling non-boot CPUs ...
apr 30 19:44:21 eduardolp3-Manjaro kernel: smpboot: CPU 1 is now offline
apr 30 19:44:21 eduardolp3-Manjaro kernel: smpboot: CPU 2 is now offline
apr 30 19:44:21 eduardolp3-Manjaro kernel: smpboot: CPU 3 is now offline
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: PM: Low-level resume complete
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: EC: EC started
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: PM: Restoring platform NVS memory
apr 30 19:44:21 eduardolp3-Manjaro kernel: Enabling non-boot CPUs ...
apr 30 19:44:21 eduardolp3-Manjaro kernel: x86: Booting SMP configuration:
apr 30 19:44:21 eduardolp3-Manjaro kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
apr 30 19:44:21 eduardolp3-Manjaro kernel: CPU1 is up
apr 30 19:44:21 eduardolp3-Manjaro kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
apr 30 19:44:21 eduardolp3-Manjaro kernel: CPU2 is up
apr 30 19:44:21 eduardolp3-Manjaro kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
apr 30 19:44:21 eduardolp3-Manjaro kernel: CPU3 is up
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: PM: Waking up from system sleep state S3
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: EC: interrupt unblocked
apr 30 19:44:21 eduardolp3-Manjaro kernel: ACPI: EC: event unblocked
apr 30 19:44:21 eduardolp3-Manjaro kernel: sd 0:0:0:0: [sda] Starting disk
apr 30 19:44:21 eduardolp3-Manjaro kernel: usb 2-2: reset full-speed USB device number 2 using xhci_hcd
apr 30 19:44:21 eduardolp3-Manjaro kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
apr 30 19:44:21 eduardolp3-Manjaro kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
apr 30 19:44:21 eduardolp3-Manjaro kernel: ata2.00: configured for UDMA/100
apr 30 19:44:21 eduardolp3-Manjaro kernel: ata1.00: configured for UDMA/133
apr 30 19:44:21 eduardolp3-Manjaro kernel: usb 2-8: reset high-speed USB device number 5 using xhci_hcd
apr 30 19:44:21 eduardolp3-Manjaro kernel: usb 2-6: reset full-speed USB device number 4 using xhci_hcd
apr 30 19:44:21 eduardolp3-Manjaro kernel: usb 2-5: reset high-speed USB device number 3 using xhci_hcd
apr 30 19:44:21 eduardolp3-Manjaro kernel: OOM killer enabled.
apr 30 19:44:21 eduardolp3-Manjaro kernel: Restarting tasks ...
apr 30 19:44:21 eduardolp3-Manjaro kernel: pci_bus 0000:04: Allocating resources
apr 30 19:44:21 eduardolp3-Manjaro kernel: pci_bus 0000:06: Allocating resources
apr 30 19:44:21 eduardolp3-Manjaro kernel: pci_bus 0000:07: Allocating resources
apr 30 19:44:21 eduardolp3-Manjaro kernel: pci_bus 0000:08: Allocating resources
apr 30 19:44:21 eduardolp3-Manjaro kernel: done.
apr 30 19:44:21 eduardolp3-Manjaro kernel: random: crng reseeded on system resumption
apr 30 19:44:21 eduardolp3-Manjaro kernel: PM: suspend exit
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_hq
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Starting Load/Save RF Kill Switch Status...
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_sq
apr 30 19:44:21 eduardolp3-Manjaro systemd-sleep[2981]: System returned from sleep state.
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_mq
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aptx_hd
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_hd
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_453
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_453
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_512
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_512
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_552
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_552
apr 30 19:44:21 eduardolp3-Manjaro kernel: Bluetooth: hci0: Legacy ROM 2.5 revision 0.0 build 1 week 45 2013
apr 30 19:44:21 eduardolp3-Manjaro kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: systemd-suspend.service: Deactivated successfully.
apr 30 19:44:21 eduardolp3-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:21 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Finished System Suspend.
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Stopped target Sleep.
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Reached target Suspend.
apr 30 19:44:21 eduardolp3-Manjaro kernel: audit: type=1130 audit(1682876661.403:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:21 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682876661.403:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Stopped target Suspend.
apr 30 19:44:21 eduardolp3-Manjaro systemd-logind[349]: Operation 'sleep' finished.
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.4145] manager: sleep: wake requested (sleeping: yes enabled: yes)
apr 30 19:44:21 eduardolp3-Manjaro ModemManager[386]: <info> [sleep-monitor-systemd] system is resuming
apr 30 19:44:21 eduardolp3-Manjaro systemd[583]: Stopped target Bluetooth.
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Stopped target Bluetooth Support.
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.4214] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:44:21 eduardolp3-Manjaro systemd[583]: Reached target Bluetooth.
apr 30 19:44:21 eduardolp3-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:21 eduardolp3-Manjaro kernel: audit: type=1130 audit(1682876661.433:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Started Load/Save RF Kill Switch Status.
apr 30 19:44:21 eduardolp3-Manjaro systemd[1]: Reached target Bluetooth Support.
apr 30 19:44:21 eduardolp3-Manjaro kernel: Generic FE-GE Realtek PHY r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
apr 30 19:44:21 eduardolp3-Manjaro plasmashell[739]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
apr 30 19:44:21 eduardolp3-Manjaro kernel: Bluetooth: hci0: Intel BT fw patch 0x27 completed & activated
apr 30 19:44:21 eduardolp3-Manjaro kernel: Bluetooth: MGMT ver 1.22
apr 30 19:44:21 eduardolp3-Manjaro pulseaudio[1089]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_hq
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_sq
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/ldac_mq
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aptx_hd
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx_hd
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_453
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_453
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_512
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_512
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_552
apr 30 19:44:21 eduardolp3-Manjaro bluetoothd[432]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_552
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6485] device (wlp6s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:44:21 eduardolp3-Manjaro kernel: r8169 0000:07:00.0 enp7s0: Link is Down
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6504] device (p2p-dev-wlp6s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6508] manager: NetworkManager state is now DISCONNECTED
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6906] device (wlp6s0): supplicant interface state: internal-starting -> disconnected
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6906] device (p2p-dev-wlp6s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6917] Wi-Fi P2P device controlled by interface wlp6s0 created
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6923] manager: (p2p-dev-wlp6s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/6)
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6929] device (p2p-dev-wlp6s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6939] device (wlp6s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
apr 30 19:44:21 eduardolp3-Manjaro NetworkManager[364]: <info> [1682876661.6954] device (p2p-dev-wlp6s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
apr 30 19:44:23 eduardolp3-Manjaro dbus-daemon[347]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.109' (uid=1000 pid=2945 comm="/usr/lib/kscreenlocker_greet --immediateLock --gra")
apr 30 19:44:23 eduardolp3-Manjaro dbus-daemon[347]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
apr 30 19:44:23 eduardolp3-Manjaro kscreenlocker_greet[2945]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
apr 30 19:44:23 eduardolp3-Manjaro ModemManager[386]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:06:00.0': not supported by any plugin
apr 30 19:44:23 eduardolp3-Manjaro ModemManager[386]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.3/0000:07:00.0': not supported by any plugin
apr 30 19:44:26 eduardolp3-Manjaro systemd[1]: systemd-rfkill.service: Deactivated successfully.
apr 30 19:44:26 eduardolp3-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:26 eduardolp3-Manjaro kernel: audit: type=1131 audit(1682876666.463:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:30 eduardolp3-Manjaro audit[3069]: USER_AUTH pid=3069 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="eduardolp3" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:30 eduardolp3-Manjaro kernel: audit: type=1100 audit(1682876670.309:92): pid=3069 uid=1000 auid=1000 ses=3 msg='op=PAM:unix_chkpwd acct="eduardolp3" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 30 19:44:30 eduardolp3-Manjaro kwin_x11[679]: kwin_core: XCB error: 3 (BadWindow), sequence: 14952, resource id: 14680084, major code: 129 (SHAPE), minor code: 6 (Input)
