I need some help. This has gotta be something obvious I am missing. I am new to Arch/Manjaro but not to Linux or 'nix in general. [Queue up resume here, or … not.] Suffice to say I have a long history with the BSD world and a shorter one with Linux, but some mileage.
I have Manjaro Gnome installed in a VM that I am using to self-teach and also directly on an HP laptop I use for customer support. My daily driver [for now] is Mint/Cinammon but I am headed this way for a lot of reasons.
Weird problem. Here’s what I need: If I open a terminal and then >sudo login different_user Manjaro just closes the session, no excuses and no polite goodbye. But to be clear, I can sudo plenty of other stuff, indeed all of the regular functions as one would need. So sudo itself is not my problem.
I have been used to doing this for years in maintaining several servers and client workstations. Simply move from one user to another in this way without first logging out. But Manjaro is not letting me do that. Can someone explain why, or what I am missing?
Thanks in advance! [I did search for help on this. Didn’t find anything. But then, perhaps I just don’t do keywords right. ;)]
Thank you very much for your help. Interesting suggestions, the learning continues.
First, Bash behaves the same way. I tried it just as you suggested, bash and then sudo login, same results. Then just for fun I tried >sudo bash first and then login other_user. Same behavior.
I then installed qterminal and exactly the same behavior, also doing it both ways.
Oh, by the way [didn’t mention this earlier] I have a third computer in the house set up as a media machine. Kodi, etc. It’s running Manjaro also. Never had an occasion to try a different user there, but just for fun I did. Same deal.
Looking forward to further suggestions. Much appreciated.
Kudos to SLaitEr and also AlbertoSalviaNovella. Problem solved!
Now, to be fair I did see in another thread the matter of using su … but I completely misunderstood what was going on there. I get it now. I think I was stumbling over something that went on in a former life under BSD where su was indeed the command to elevate oneself to root.
What I have done here is simply su -l different_user and there we go! Of course su also exists in the Debian/Mint world but I just never used it before because I was not required to do so. Honestly to me this seems better.
