Suddenly, the icons in dash disappear and pc stops responding correctly
I’ve been using manjaro gnome for a few month and it works almost perfeclty because i’m facing this issue randomly:
Suddenly, the icons in dash disappear even if it keeps displaying the running indicator, like this:
Mod edit:- Please avoid posting unnecessary images.
I’m using dash to panel, but it also happens with the regular dock without the extension.
Also when this happens, i can no longer open apps, in fact, if i try to open the apps that running, they close immediately and i’m not able to open new apps, it keeps displaying the desktop environment but it is useless.
If i leave the pc alone for a few minutes, the screen turns black and does nothing(neither shuts down nor restarts) and if i quick press the power button it shows this:
Mod edit:- Please avoid posting images of textual content when a brief description will suffice. Transposing the information to text and posting in a preformatted text box is also an option. Like this;
?? [1841]: (msg) caught signal, shutting down...
??" [1841]: (msg) ModemManager is shut down
??-generate-shutdown-ramfs.service: Unable to locate executable '/ust/bin/mkinitcpio': Input/output error
??-generate-shutdown-ramfs.service: Failed at step EXEC spawning /ust/bin/mkinitcpio: Input/output error
?? Failed to start Generate shutdown-ramfs.
?? Failed to start Show Plymouth Power Off Screen
?? Failed unmounting /boot/efi.
?? Failed unmounting /home.
?? Failed unmounting /tmp.
?? Failed unmounting /run/user/1000/gvfs.
?? Failed unmounting /var/cache.
?? Failed unmounting /var/log.
?? Failed unmounting /run/user/1000.
?? Failed deactivating swap /swap/swapfile.
Now, that information is searchable, and others can copy/paste portions if needed to search for possibly related information.
In future, images may be deleted without warning.
So i have to hold down the power button to turn it off.
Here is some information from neofetch:
OS: Manjaro Linux x86_64
Host: 21M8CTO1WW ThinkPad E14 Gen 6
Kernel: 6.14.0-1-MANJARO
Uptime: 2 hours, 54 mins
Packages: 1402 (pacman)
Shell: bash 5.2.37
Resolution: 1920x1080
DE: GNOME 48.0
WM: Mutter
WM Theme: Mint-Y
Theme: Mint-L-Dark-Teal [GTK2/3]
Icons: Papirus-Adapta-Nokto-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: Intel Ultra 7 155H (22) @ 4.500GHz
GPU: Intel Arc Graphics]
Memory: 8414MiB / 31555MiB
mod edit:- Information from *-fetch type applications might be fine for someone wishing to buy your computer, but for Support purposes, asking your system directly with an inxi command (as you have done, thank you) produces far more useful results.
inxi output:
  Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    root=UUID=562f6830-f6ce-4645-baf3-32182f1eeaec rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3 panic=10
    drm.debug=0x1e sysrq_always_enabled=1
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell with: Docker
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21M8CTO1WW v: ThinkPad E14 Gen 6
  Mobo: LENOVO model: 21M8CTO1WW v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21M8_BU_Think_FM_ThinkPad
    E14 Gen 6 uuid: <superuser required> UEFI: LENOVO v: R2JET39W(1.16 )
    date: 12/23/2024
  ID-1: BAT0 charge: 46.0 Wh (79.3%) condition: 58.0/57.0 Wh (101.7%)
    volts: 12.1 min: 11.3 model: Sunwoda L23D3PG2 type: Li-poly serial: <filter>
    status: not charging cycles: 3
  System RAM: total: 32 GiB available: 30.82 GiB used: 15.58 GiB (50.6%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 16 GiB speed: 5600 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M425R2GA3PB0-CWMOL
    serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
    serial: <filter>
  Info: model: Intel Core Ultra 7 155H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
    KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4500:4800:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    bogomips: 131788
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: DP-5,DP-6,eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 174f:1820
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9.4.4:7
    chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-5 model: AOC 2269W serial: <filter> built: 2016
    res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
    x: 0.325 y: 0.612 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x720,
    1024x768, 832x624, 800x600, 720x480, 640x480, 720x400
  Monitor-2: DP-6 model: AOC 2269W serial: <filter> built: 2016
  Monitor-3: eDP-1 model: InfoVision Optronics/Kunshan 0x8c45 built: 2020
    res: 2240x1400 dpi: 188 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 302x188mm (11.89x7.4") diag: 356mm (14") ratio: 16:10
    modes: 2240x1400
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 15.05 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.14.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Intel vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:550b class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.4.2:4
    chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
  IF: eth0 state: up speed: 1000 Mbps duplex: half mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 1.86 TiB used: 573.39 GiB (30.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung
    model: MZAL81T0HDLB-00BLL size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 7L2QKXD7 temp: 50.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate
    model: XPG GAMMIX S70 BLADE size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 3.2.J.JE temp: 51.9 C scheme: GPT
  ID-1: / raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
    used: 74.69 GiB (42.5%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
    label: N/A uuid: 562f6830-f6ce-4645-baf3-32182f1eeaec
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 588 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A
    uuid: 2D27-F8E5
  ID-3: /home raw-size: 777.09 GiB size: 763.82 GiB (98.29%)
    used: 498.7 GiB (65.3%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
    label: N/A uuid: 1df91b1c-764b-4867-8e7d-52a295f753f2
  ID-4: /var/cache raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
  ID-5: /var/log raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 260 MiB fs: vfat label: SYSTEM
    uuid: EC27-BE31
  ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 951.65 GiB fs: ntfs
    label: Windows uuid: 84F229E7F229DDE4
  ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 1.95 GiB fs: ntfs
    label: WinRE_DRV uuid: 4A622A20622A116D
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 2-3:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 05e3:0625
  Hub-4: 2-3.4:3 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Device-1: 2-3.4.2:4 info: ASIX AX88179 Gigabit Ethernet
    type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c8c class-ID: 0000
  Device-2: 3-7:3 info: Syntek Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:1820 class-ID: fe01
    serial: <filter>
  Hub-6: 3-9:4 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-7: 3-9.4:6 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 3-9.4.4:7 info: Logitech C920 HD Pro Webcam type: video,audio
  Device-2: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 67.0 C mobo: 59.5 C
  Fan Speeds (rpm): fan-1: 3600 fan-2: 3600
  Packages: pm: pacman pkgs: 1402 libs: 421 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
    1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    6: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 525
  1: cpu: 533% command: qemu-system-x86_64 pid: 949165
    mem: 5310.0 MiB (16.8%)
  2: cpu: 211% command: pycharm pid: 933760 mem: 2681.4 MiB (8.4%)
  3: cpu: 20.9% command: chrome pid: 950580 mem: 306.2 MiB (0.9%)
  4: cpu: 10.8% command: gnome-terminal-server pid: 952961
    mem: 64.1 MiB (0.2%)
  5: cpu: 8.8% command: virtiofsd pid: 949163 mem: 81.4 MiB (0.2%)
  Memory top: 5 of 525
  1: mem: 5310.0 MiB (16.8%) command: qemu-system-x86_64 pid: 949165
    cpu: 533%
  2: mem: 2681.4 MiB (8.4%) command: pycharm pid: 933760 cpu: 211%
  3: mem: 823.7 MiB (2.6%) command: chrome pid: 793704 cpu: 7.2%
  4: mem: 382.6 MiB (1.2%) command: chrome pid: 793782 cpu: 5.0%
  5: mem: 380.0 MiB (1.2%) command: gnome-shell pid: 2408 cpu: 2.3%
  Processes: 525 Power: uptime: 3h 9m states: freeze,mem,disk suspend: s2idle
    image: 12.31 GiB services: gsd-power, power-profiles-daemon, upowerd
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: gnome-terminal
    inxi: 3.3.37
Update:
I tried to open terminal with ctrl+alt+f3 to restart gnome-shell from terminal but i’m not able to type anything in the console, So i have to hold down the power button to turn it off.
This message also appeared when i tried to save something in sublime text:
failed: Neither /usr/bin/gksudo nor /usr/bin/pkexec are available
And i wasn’t able to see the files in nautilus, also this message appeared:
Error when getting information for file ‘/home/user/downloads’: Input/output error
I ran smartctl for the disk and i got this:
=== START OF INFORMATION SECTION ===
Model Number:                       XPG GAMMIX S70 BLADE
Serial Number:                      2O382L1G91FE
Firmware Version:                   3.2.J.JE
PCI Vendor/Subsystem ID:            0x1cc1
IEEE OUI Identifier:                0x707c18
Total NVM Capacity:                 1 024 209 543 168 [1.02 TB]
Unallocated NVM Capacity:           0
Controller ID:                      0
NVMe Version:                       1.4
Number of Namespaces:               1
Namespace 1 Size/Capacity:          1 024 209 543 168 [1.02 TB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            707c18 1b38005a32
Local Time is:                      Wed Apr  9 18:38:39 2025 CST
Firmware Updates (0x1e):            7 Slots, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0014):     DS_Mngmt Sav/Sel_Feat
Log Page Attributes (0x0e):         Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     100 Celsius
Critical Comp. Temp. Threshold:     110 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     3.50W       -        -    0  0  0  0        5       5
 1 +     3.30W       -        -    1  1  1  1       50     100
 2 +     2.80W       -        -    2  2  2  2       50     200
 3 -   0.1500W       -        -    3  3  3  3      500    5000
 4 -   0.0200W       -        -    4  4  4  4     2000   85000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        49 Celsius
Available Spare:                    100%
Available Spare Threshold:          25%
Percentage Used:                    0%
Data Units Read:                    6 892 136 [3.52 TB]
Data Units Written:                 10 808 237 [5.53 TB]
Host Read Commands:                 65 888 414
Host Write Commands:                210 642 957
Controller Busy Time:               74
Power Cycles:                       58
Power On Hours:                     206
Unsafe Shutdowns:                   42
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               49 Celsius
Temperature Sensor 2:               39 Celsius
Thermal Temp. 1 Transition Count:   4
Thermal Temp. 1 Total Time:         2634
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
Read Self-test Log failed: Invalid Field in Command (0x002)
It’s possible your ISO was damaged in transit. You could try downloading a fresh ISO and verifying it against the checksum file (also provided on the download page).
Of course, that is only one possibility among many.
I’m sure someone will help further when they are able.
I note the following
  • dual boot windows
  • manjaro uses btrfs
btrfs is a filesystem which is gaining a lot of momentum due to the features it provides.
Upon filesystem damage, btrfs will lock the file system, to prevent further damage.
To recover you will need to boot from a live system. Please see Basic Manjaro Linux Recovery for instructions on how to reach the damaged filesystem.
Then see the relevant sections on Manjaro Wiki
See → Btrfs - Maintenance
See → Btrfs - Solving Problems
Thanks, i can access to manjaro after restarting the pc but i’ll check the links. I guess i need a live cd to repair the filesystem.
Update:
It happened again and tried to reboot it with REISUB, it failed but it show me a few new messages:
Mod edit:- Image removed.
Yes, the Manjaro ISOs live environment will no doubt be useful; make sure to check the ISO for consistency against the checksum file.
If you’re not already using Ventoy as a bootable ISO solution, you might give it some serious consideration. I recently authored a guide on how to create a Ventoy USB which you will likely find useful.
The following tutorial might also be helpful;
Please provide logs rather than photos of the screen;
journalctl --boot=-1 --no-pager
The -1 will produce logs from the last boot, -2 from the one before, and so on.
The output is large, like 700Mb, is there anything i can do to reduce the log?
These should help;
This seems unlikely, but I suppose not impossible.
Generally logs can be pasted to the forum in a preformatted text box, but if it is particularly long, perhaps a pastebin type service would be more practical.
Thanks for your help, i followed the steps in the links you shared, but everything seems to be correct with filesystem and disk :confused:, also checked the ram, here are the logs:
lsblk -f
NAME       FSTYPE FSVER  LABEL              UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0      squash 4.0        0   100% /run/miso/sfs/livefs
loop1      squash 4.0        0   100% /run/miso/sfs/mhwdfs
loop2      squash 4.0        0   100% /run/miso/sfs/desktopfs
loop3      squash 4.0        0   100% /run/miso/sfs/rootfs
sda        iso966 Joliet MANJARO_GNOME_2421 2024-12-16-11-22-51-00                     0   100% /run/miso/bootmnt
├─sda1     iso966 Joliet MANJARO_GNOME_2421 2024-12-16-11-22-51-00
└─sda2     vfat   FAT12  MISO_EFI           990A-716C
nvme1n1
├─nvme1n1p1
│          vfat   FAT32  SYSTEM             EC27-BE31
├─nvme1n1p2
├─nvme1n1p3
│          ntfs          Windows            84F229E7F229DDE4
└─nvme1n1p4
           ntfs          WinRE_DRV          4A622A20622A116D
nvme0n1
├─nvme0n1p1
│          btrfs                            562f6830-f6ce-4645-baf3-32182f1eeaec
├─nvme0n1p2
│          ext4   1.0                       1df91b1c-764b-4867-8e7d-52a295f753f2
└─nvme0n1p3
           vfat   FAT32                     2D27-F8E5
sudo smartctl -a /dev/nvme0n1
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.4-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Total NVM Capacity:                 1,024,209,543,168 [1.02 TB]
Controller ID:                      0
NVMe Version:                       1.4
Namespace 1 Size/Capacity:          1,024,209,543,168 [1.02 TB]
Local Time is:                      Thu Apr 10 17:02:07 2025 UTC
 0 +     512       0         0
Temperature:                        35 Celsius
Percentage Used:                    0%
Data Units Read:                    7,078,788 [3.62 TB]
Data Units Written:                 10,867,950 [5.56 TB]
Host Read Commands:                 66,401,068
Host Write Commands:                211,466,459
Controller Busy Time:               75
Power Cycles:                       61
Power On Hours:                     207
Unsafe Shutdowns:                   44
Temperature Sensor 1:               35 Celsius
Temperature Sensor 2:               34 Celsius
No Errors Logged
sudo btrfs check --readonly /dev/nvme0n1p1
Opening filesystem to check...
Checking filesystem on /dev/nvme0n1p1
UUID: 562f6830-f6ce-4645-baf3-32182f1eeaec
[1/8] checking log skipped (none written)
[2/8] checking root items
[3/8] checking extents
[4/8] checking free space tree
[5/8] checking fs roots
[6/8] checking only csums items (without verifying data)
[7/8] checking root refs
[8/8] checking quota groups skipped (not enabled on this FS)
found 76664233984 bytes used, no error found
total csum bytes: 65109492
total tree bytes: 704839680
total fs tree bytes: 585547776
total extent tree bytes: 43712512
btree space waste bytes: 111966472
file data blocks allocated: 112514007040
 referenced 117888028672
sudo memtester 4G 1
memtester version 4.6.0 (64-bit)
Copyright (C) 2001-2020 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffffffffffff000
want 4096MB (4294967296 bytes)
got  4096MB (4294967296 bytes), trying mlock ...locked.
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
  Compare DIV         : ok
  Compare OR          : ok
  Compare AND         : ok
  Sequential Increment: ok
  Solid Bits          : ok
  Block Sequential    : ok
  Checkerboard        : ok
  Bit Spread          : ok
  Bit Flip            : ok
  Walking Ones        : ok
  Walking Zeroes      : ok
  8-bit Writes        : ok
  16-bit Writes       : ok
sudo mount /dev/nvme0n1p1 /mnt
sudo btrfs scrub start /mnt
scrub started on /mnt, fsid 562f6830-f6ce-4645-baf3-32182f1eeaec (pid=3755)
Starting scrub on devid 1
sudo btrfs scrub status /mnt
Scrub started:    Thu Apr 10 17:00:15 2025
Status:           finished
Duration:         0:00:54
Total to scrub:   72.05GiB
Rate:             1.33GiB/s
Error summary:    no errors found
sudo btrfs balance start -dusage=90 /mnt
Done, had to relocate 13 out of 81 chunks
sudo badblocks -v /dev/nvme0n1 -v
Checking blocks 0 to 1000204631
Checking for bad blocks (read-only test): done
Pass completed, 0 bad blocks found. (0/0/0 errors)
Since the NVME is ok and the filesystem is fine,I would say it is this kind of issue:
https://wiki.archlinux.org/title/Solid_state_drive/NVMe#Controller_failure_due_to_broken_APST_support
Thanks, i downgraded from kernel 6.14.0-1 to 6.12.21-4 and it seems to be working, no crashes yet. If it happens again, i’ll try disabling apst.
This still happens with kernel 6.13 and 6.14, but 6.15 seems to work correctly.
Although I couldn’t find anything in the messages related to APST, adding this solved the problem:
nvme_core.default_ps_max_latency_us=0
The reason for this is basically that different NVME hardware sometimes has slightly different implementations and quirks that are not taken into account by the universal driver under Linux. Drivers from the manufacturer take this into account. You would have to find out which timing for the power saving function is optimal for the NVME and enter this accordingly, or dispense with power saving at this point.
Take a look at this output:
sudo nvme id-ctrl /dev/nvme0
to get the right timing (enlat: and exlat:).
thank you, this is the output but i don’t understand what i’m seeing there:
NVME Identify Controller:
vid       : 0x1cc1
ssvid     : 0x1cc1
sn        : 2O382L1G91FE
mn        : XPG GAMMIX S70 BLADE
fr        : 3.2.J.JE
rab       : 2
ieee      : 707c18
cmic      : 0
mdts      : 9
cntlid    : 0
ver       : 0x10400
rtd3r     : 0x186a0
rtd3e     : 0x1e8480
oaes      : 0x100
ctratt    : 0
rrls      : 0
cntrltype : 1
fguid     : 00000000-0000-0000-0000-000000000000
crdt1     : 0
crdt2     : 0
crdt3     : 0
nvmsr     : 0
vwci      : 0
mec       : 0
oacs      : 0x17
acl       : 3
aerl      : 3
frmw      : 0x1e
lpa       : 0xe
elpe      : 63
npss      : 4
avscc     : 0
apsta     : 0x1
wctemp    : 373
cctemp    : 383
mtfa      : 0
hmpre     : 0
hmmin     : 0
tnvmcap   : 1024209543168
unvmcap   : 0
rpmbs     : 0
edstt     : 23
dsto      : 1
fwug      : 1
kas       : 0
hctma     : 0x1
mntmt     : 318
mxtmt     : 393
sanicap   : 0x80000003
hmminds   : 0
hmmaxd    : 0
nsetidmax : 0
endgidmax : 0
anatt     : 0
anacap    : 0
anagrpmax : 0
nanagrpid : 0
pels      : 0
domainid  : 0
megcap    : 0
tmpthha   : 0
sqes      : 0x66
cqes      : 0x44
maxcmd    : 0
nn        : 1
oncs      : 0x14
fuses     : 0
fna       : 0x4
vwc       : 0x7
awun      : 1
awupf     : 0
icsvscc   : 1
nwpc      : 0
acwu      : 0
ocfs      : 0
sgls      : 0x70000
mnan      : 0
maxdna    : 0
maxcna    : 0
oaqd      : 0
subnqn    : ADATA:2O382L1G91FE
ioccsz    : 0
iorcsz    : 0
icdoff    : 0
fcatt     : 0
msdbd     : 0
ofcs      : 0
ps      0 : mp:3.50W operational enlat:5 exlat:5 rrt:0 rrl:0
            rwt:0 rwl:0 idle_power:- active_power:-
            active_power_workload:-
ps      1 : mp:3.30W operational enlat:50 exlat:100 rrt:1 rrl:1
            rwt:1 rwl:1 idle_power:- active_power:-
ps      2 : mp:2.80W operational enlat:50 exlat:200 rrt:2 rrl:2
            rwt:2 rwl:2 idle_power:- active_power:-
ps      3 : mp:0.1500W non-operational enlat:500 exlat:5000 rrt:3 rrl:3
            rwt:3 rwl:3 idle_power:- active_power:-
ps      4 : mp:0.0200W non-operational enlat:2000 exlat:85000 rrt:4 rrl:4
            rwt:4 rwl:4 idle_power:- active_power:-
These states are normally not a problem, but they are slight slow. My NVME can switch at 0s here. Anyway…
These conditions can be problematic. The kernel relies on the timings reported by the firmware. But if there’s a needed delay or the NVMe wakes up slower than expected, it might not wake up properly and produce I/O errors. So I would suggest:
nvme_core.default_ps_max_latency_us=500
It only disables PS3 and PS4.
Ideally there would be a firmware update or kernel quirk, but disabling deeper states is a workaround.
