Sublime text also doesn’t seem to detect the dark/light theme anymore on GNOME, it always displays the light theme.
Okay, solution for this one:
Sublime is a “legacy GTK application”, and it will try and get the used theme from the “Legacy applications”, trying to see if it’s a dark or light theme:
If you have the Night theme switcher extension installed, set the following to run upon theme change, since it doesn’t support changing the “legacy GTK theme” anymore:
Set commands to run on changing:
Sunrise:
gsettings set org.gnome.desktop.interface gtk-theme <your-preferred-light-theme>
Sunset:
gsettings set org.gnome.desktop.interface gtk-theme <your-preferred-dark-theme>
This will make sublime start changing its theme again.
