Hi I am trying to install xfce on manjaro but it seems it is stuck on graphical interface. I am a newbie please help. I am running amd cpu 5950 and Radeon 6700xt gpu.
Please detail.
OK sorry about that. It’s in the boot screen after the reached target graphical interface message it is stuck. I have access to the terminal if I press ctrl alt f1. Any more info required?
Have you tried suggestions from similar threads?
https://forum.manjaro.org/search?q=Reached%20target%20Graphical%20Interface
This will likely require the 5.13 kernel. You can grab the 21.1 ISO:
If you don’t know what to do, you basically download the two part zip file, then extract it in the same directory!
For example, this is for KDE:
You download these two files in a folder, extract them both!
Thank yes kernel 5.13 solved the issue
