Stuck on emergency shell with kernel 6.7 - I got it (i think)
Iupdated my system with the last stable update without any issue, my kernel was still version 6.6.19. I rebooted and i was able to do whatever as usual.
Then, i installed kernel 6.7.7 with Manjaro tools, as i always do. Just after rebooting, i get the following message in a black screen right after grub menu :
ERROR: resume: hibernation device 'UUID=<uuid the swap file location> not found
mount: /new_root: can’t find UUID=<uuid of my root partition>
ERROR: Failed to mount ‘UUID=<uuid of my root partition>’ on real root
You are now being dropped intoan emergency shell.
[rootfs ~]#
At this point i do not know what to do, it’s like my ssd is not detected anymore.
Note: i do not have plymouth installed. Also surprisingly, as I had a nvidia GPU, i did not notice any big size diffrence with initramfs-6.6-x86_64 and initramfs-6.6-x86_64-fallback
I could rollback to the most recent btrfs snapshot with kernel 6.6.19, that is why i can write this topic.
Below is the inxi data with my current kernel 6.6.19, not the 6.7.7
inxi -v7azy
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=70853cef-788d-4beb-9c26-56f4fd32adc2 rw rootflags=subvol=@
    rd.driver.pre=vfio-pci quiet udev.log_priority=3
    resume=UUID=e9bdab9b-c172-4b6f-875f-610249007c0e resume_offset=3741018
    ibt=off intel_iommu=on
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver avail: light-locker,xscreensaver
    vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: BIOSTAR model: B660T-SILVER serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.27
    date: 09/12/2023
  System RAM: total: 16 GiB available: 15.47 GiB used: 3.93 GiB (25.4%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 8 GiB speed: 3600 MT/s volts: curr: 1.35 min: 1 max: 1.35 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK16GX4M2D3600C16
    serial: N/A
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
    serial: N/A
  Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x32
    L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
    L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 813 high: 900 min/max: 800/4400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 858 10: 800 11: 800 12: 900 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: NVIDIA TU116 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
    v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:2188
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.11 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: Unknown-1 mapped: DP-0 res: 2560x1440 dpi: 123
    size: 527x296mm (20.75x11.65") modes: 2560x1440
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
    memory: 3.91 GiB
  Device-1: Intel Alder Lake-S HD Audio vendor: Biostar Microtech Intl Corp
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-3: Texas Instruments PCM2704 16-bit stereo audio DAC
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 08bb:2704 class-ID: 0300
  API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Biostar Microtech Intl Corp
    driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000
    bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Local Storage: total: 3.25 TiB used: 2.02 TiB (62.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Mushkin model: MKNSSDVT2TB-D8
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3.H.J.22 temp: 46.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT512MX100SSD1
    size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: MU01 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10TPVT-00U4RT1 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5200 serial: <filter> fw-rev: 01.0 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
    size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: GPT
  ID-1: / raw-size: 40.04 GiB size: 40.04 GiB (100.00%) used: 24.18 GiB (60.4%)
    fs: btrfs dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 70853cef-788d-4beb-9c26-56f4fd32adc2
  ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%)
    used: 24.3 MiB (24.7%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 9B86-7954
  ID-3: /home raw-size: 48.83 GiB size: 48.8 GiB (99.95%)
    used: 27.97 GiB (57.3%) fs: xfs dev: /dev/sda7 maj-min: 8:7 label: N/A
    uuid: e9bdab9b-c172-4b6f-875f-610249007c0e
  ID-4: /mnt/win_C raw-size: 97.1 GiB size: 97.1 GiB (100.00%)
    used: 91.66 GiB (94.4%) fs: ntfs dev: /dev/sda4 maj-min: 8:4 label: win_C
    uuid: C4423D01423CF9AE
  ID-5: /mnt/win_F raw-size: 220.23 GiB size: 220.23 GiB (100.00%)
    used: 211.22 GiB (95.9%) fs: ntfs dev: /dev/sda5 maj-min: 8:5 label: win_F
    uuid: 7202BF2702BEEF6B
  ID-6: /run/media/<user>/Backup raw-size: 1015.84 GiB
    size: 998.83 GiB (98.33%) used: 799.62 GiB (80.1%) fs: ext4
    dev: /dev/nvme0n1p4 maj-min: 259:3 label: Backup
    uuid: a79bb499-61cd-4e22-9131-fbaaac0e4b9d
  ID-7: /run/media/<user>/Data raw-size: 48.83 GiB size: 48.81 GiB (99.95%)
    used: 7.94 GiB (16.3%) fs: xfs dev: /dev/sda8 maj-min: 8:8 label: Data
    uuid: becc0cef-254b-4a92-b183-7a83d60fa593
  ID-8: /run/media/<user>/Games raw-size: 100.12 GiB size: 97.99 GiB (97.87%)
    used: 34.61 GiB (35.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:1
    label: Games uuid: 56976232-bdad-4bf2-bf98-ec4168fb2d9e
  ID-9: /run/media/<user>/Transcend raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 873.24 GiB (93.7%) fs: ntfs dev: /dev/sdb1
    maj-min: 8:17 label: Transcend uuid: B69416F89416BAB7
  ID-10: /var/cache raw-size: 40.04 GiB size: 40.04 GiB (100.00%)
    used: 24.18 GiB (60.4%) fs: btrfs dev: /dev/sda6 maj-min: 8:6 label: N/A
  ID-11: /var/log raw-size: 40.04 GiB size: 40.04 GiB (100.00%)
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /home/<filter>/.swap/swapfile
  ID-1: /dev/nvme0n1p3 maj-min: 259:2 size: 196.38 GiB fs: btrfs label: N/A
    uuid: 7a6d16fd-61c8-43e1-847f-97baf50464a5
  ID-2: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: N/A
    uuid: 20E6B6EBE6B6BFF8
  ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sda9 maj-min: 8:9 size: 21.36 GiB fs: btrfs label: N/A
    uuid: a83c3437-cad4-4206-8174-b8711b110989
  ID-5: /dev/sdc1 maj-min: 8:33 size: 57.27 GiB fs: exfat label: Ventoy
    uuid: 0451-51A2
  ID-6: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: B228-8EFB
  Device-1: 1-1:2 info: ASUSTek ROG STRIX SCOPE RX type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 0b05:1951 class-ID: 0300
    serial: <filter>
  Device-2: 1-2:3 info: Texas Instruments PCM2704 16-bit stereo audio DAC
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 250mA
  Hub-2: 1-6:4 info: Genesys Logic Hub ports: 2 rev: 2.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05e3:0610
  Device-1: 1-6.1:5 info: Razer USA RC30-0305 Gaming Mouse Dongle [Viper
    Ultimate (Wireless)] type: mouse,keyboard driver: razermouse,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 1532:007b class-ID: 0300
  Device-2: 1-6.2:6 info: Razer USA RC30-030502 Mouse Dock
    type: mouse,keyboard driver: razeraccessory,usbhid interfaces: 3 rev: 2.0
    chip-ID: 1532:007e class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  Device-1: 2-9:2 info: ASMedia ASM1051 SATA 3Gb/s bridge type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 174c:5106 class-ID: 0806
    serial: <filter>
  Device-2: 2-10:3 info: SanDisk 3.2Gen1 type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:55a3 class-ID: 0806
    serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 23.0 C mobo: N/A gpu: nvidia temp: 36 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 25%
  Processes: 380 Power: uptime: 20m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1639 libs: 468 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    running-in: xfce4-terminal inxi: 3.3.33
What could be the issue ? Thank you
check your /etc/fstab - from the message you referenced look like text instead of uuid
Hi,
There is literally no difference in /etc/fstab between the subvolume i installed kernel 6.7 on and the previous btrfs snapshot with kernel 6.6. Thus, there is only UUID inside. :cold_sweat:
Is the system encrypted?
Could it be the file /etc/openswap.conf which is not written correctly?
My system is not encrypted at all.
I did a mkinitcpio -P right now with kernel 6.6, there are “missing firmware”, but they are there since years literally, but maybe it causes troubles now with 6.7 :
==> Starting build: '6.6.19-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
  -> Running build hook: [resume]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
No - these warning lines only has meaning if you expect the module to be present - otherwise not.
In your opinion, is it normal that initramfs-6.6-x86_64 and fallback did not grow up because of my nvidia gpu ?
I did not apply the kms hook and i did not see any big size difference, not the 150+ Mo as Philip told us.
I don’t know
    uuid: 9B86-7954
But I do think the location of your swapfile may create issues
If it causes issues, it’s new with 6.7, it always has been there.
What i tried to do when i get grub menu, type “e”, and delete resume=UUID=e9bdab9b-c172-4b6f-875f-610249007c0e resume_offset=3741018,
But it does change anything then, i still got the message starting with mount: /new_root: can’t find UUID=<uuid of my root partition>
A shot in the dark: did you do something to your disk? Repartitioning? Or maybe it has something to do with that warning about the enclosure of the 4th disk, maybe it was a warning on 6.6 and it become an error on 6.7. Or maybe you updated the firmware with some windows tool? That could change the uuid…
Finally, i think i know what the issue is.
I reinstalled Manjaro on a brand new nvme device. It works fine with kernel 6.6 lts, 6.7 or 6.8.
Now, I obtain exactly the same issue if I mount the partitions of my former ssd (a Crucial one) in fstab with kernel 6.7 or 6.8. I end up on an emergency shell. But no issue if I switch to kernel 6.6.
It is possible that since 6.7 my ssd is not recognized anymore by the kernel ? it’s almost 10 years old.
Thanks
Upstream patch ata: ahci: Do not apply Intel PCS quirk on Intel Alder Lake - kernel/git/libata/linux.git - libata development tree solved this issue.
My SATA devices are now detected again, this is an issue with Alder Lake intel cpu.
