I recently shifted from Windows to Linux and using manjaro to learn basics of Linux.
Till yesterday everything was fine a pop up appeared saying to update I did the update now today when I powered on my laptop it get stuck at boot and not starting.
My laptop is a bit old. I was using manjaro kde plasma version and kernel was like 5.19 something.
Can you post the output, when the computer stucks ?
do you have installed a different kernel? if yes try booting with it instead of the 5.19 …
in the stuck screen can you enter TTY: ctrl+alt+f2 or f1-f6, enter your username/password, rerun update again:
sudo pacman -Syu
and if there are no errors and you are up to date, type:
startx
and post picture of that
in the startx it says something about vesa, so post output from:
mhwd -li -l
find /etc/X11/ -name "*.conf"
Can you start the computer with kernel 4.19 ?
Kernel 5.19 is EOL.
No sir
Thanks for your help but I switch to other distro.
Can you try to complete the update with chroot ?
I tried but it says nothing to update then I reboot same Issue. I did little forum search and come to know its video driver issue.
Then post /var/log/Xorg.0.log.
I deleted manjaro and now using another arch based garuda linux
