Let me give some background
After trying to run i3 and failing, I decided to restart my system. This is when the bootup got stuck aylt a command and nearly took 5 mins to show the login screen. Then I used systemd-analyze blame to che k and it showed the boot time is supposed to be around 1s. I thought there were some issues with lightdm and then I uninstalled and re-installed them. After restarting hence, it’s stuck in a login loop with the 5 min wait time still persisting. Logging into tty still works tho
Welcome to Manjaro!
- Please read this:
How to provide good information
and press the three dots … below your post and press the
to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you want to notify me that you did provide this information, please
this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
