Hello!
I have been doing some research concerning the above failure message on a friends machine, resulting in not being able to boot. The problem arose after the last bigger stable update. After typing in the encryption password there’s the usual delay, then the process gets stuck at the above message.
Past forum posts recommend to modify the systemd pkgfile database update timer. I could not reach a TTY, so:
In order to reach the file I have been trying to manjaro-chroot -a into the system, then realising it is encrypted. Then I followed number five in [Fix] Can’t login - black screen & chroot guide but I am unable to figure out what to enter, having the following configuration (from USB live image):
lsblk -fa
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squash 4.0 0 100% /run/miso/sfs/livefs
loop1 squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squash 4.0 0 100% /run/miso/sfs/rootfs
loop4
loop5
loop6
loop7
sda iso966 Jolie MANJARO_KDE_2137
2022-08-16-12-52-10-00 0 100% /run/miso/bootmnt
├─sda1 iso966 Jolie MANJARO_KDE_2137
│ 2022-08-16-12-52-10-00
└─sda2 vfat FAT12 MISO_EFI C80E-8B3F
nvme0n1
├─nvme0n1p1
│ vfat FAT32 NO_LABEL CFC4-1913
├─nvme0n1p2
│ crypto 1 0be5674b-0561-4adb-928b-4551ab96e609
└─nvme0n1p3
crypto 1 5c38374d-faee-4f4f-a2ba-7bd74541089b
I’d be grateful for any hints.
The machine itself, if that matters, is:
inxi -v7azy
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
tz=Europe/Berlin misobasedir=manjaro misolabel=MANJARO_KDE_2137 quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TUXEDO product: TUXEDO Aura 15 Gen1 v: N/A
Mobo: NB01 model: NL5xRU serial: <superuser required> UEFI: INSYDE
v: 1.07.08TTR3 date: 03/18/2021
ID-1: BAT0 charge: 25.3 Wh (56.5%) condition: 44.8/48.3 Wh (92.9%)
volts: 15.0 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging
RAM: total: 7.14 GiB used: 1.45 GiB (20.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 3 4300U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1397 min/max: 1400/2700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397 3: 1397
4: 1397 bogomips: 21564
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: CLEVO/KAPOK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x40ba built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.60-1-MANJARO) v: 4.6
Mesa 22.1.6 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: CLEVO/KAPOK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: CLEVO/KAPOK
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
Local Storage: total: 480.2 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Verbatim model: STORE N GO
size: 14.44 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
Message: No partition data found.
ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 300 MiB fs: vfat label: NO_LABEL
uuid: CFC4-1913
ID-2: /dev/sda1 maj-min: 8:1 size: 3.32 GiB fs: iso9660
ID-3: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:3 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c63 class-ID: 0000
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Verbatim Flash Drive (StorenGo) type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 504mA
chip-ID: 18a5:0243 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 3-4:3 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
class-ID: 0e02
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 28.5 C mobo: N/A gpu: amdgpu temp: 28.0 C
Processes: 199 Uptime: 46m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1209 lib: 318 flatpak: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.20
