After installing nvidia drivers, my pc got stuck at /dev/sdb2 screen. I have installed, removed, and installed nouveau drivers, vesa drives, nvidia drivers using mhwd and nothing works. Does anyone know what to do at this point? (sorry if I sound rude, i have been working on this for a while now)
Output of “inxi --admin --verbosity=7 --filter --width”
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=45eb26c1-85ca-4d97-9940-cbcd7ff04e49 rw quiet apparmor=1
security=apparmor resume=UUID=16fa4317-a427-4a14-9b40-e625866bc2b6
udev.log_priority=3
Console: tty 2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.83
date: 09/24/2021
RAM: total: 15.61 GiB used: 532.1 MiB (3.3%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2278 high: 3581 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2199 2: 2199
3: 2055 4: 2197 5: 2199 6: 2200 7: 3581 8: 2059 9: 2051 10: 2200 11: 2199
12: 2199 bogomips: 86439
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ZOTAC driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: DP-1,DVI-D-1,HDMI-A-1 empty: none
bus-ID: 2b:00.0 chip-ID: 10de:1f82 class-ID: 0300
Device-2: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 1c3f:2002 class-ID: 0102
Display: server: X.org v: 1.21.1.3 driver: gpu: nouveau
note: X driver n/a tty: 240x67
Monitor-1: DP-1 model: Samsung S24E650 built: 2015 res: 1920x1080 dpi: 94
gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
modes: max: 1920x1080 min: 720x400
Monitor-2: DVI-D-1 model: Dell S2440L serial: <filter> built: 2014
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-3: HDMI-A-1 model: LG (GoldStar) MP59HT serial: <filter>
built: 2015 res: 1920x1080 dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63")
diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Message: GL data unavailable in console. Try -G --display
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 2b:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 1-2.1:4 chip-ID: 0bda:8179 class-ID: 0000
serial: <filter>
IF: wlp2s0f0u2u1 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-10.2:8 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.04 TiB used: 21.28 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: GPT
ID-1: / raw-size: 206.1 GiB size: 201.81 GiB (97.92%)
used: 21.28 GiB (10.5%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 45eb26c1-85ca-4d97-9940-cbcd7ff04e49
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: C94C-480D
ID-1: swap-1 type: partition size: 17.17 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 16fa4317-a427-4a14-9b40-e625866bc2b6
ID-1: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
uuid: E756-EC94
ID-2: /dev/sda2 maj-min: 8:2 size: 512 MiB fs: vfat label: N/A
uuid: E756-EC94
ID-3: /dev/sda3 maj-min: 8:3 size: 1.8 TiB fs: ext4 label: New_Media
uuid: f1d7ed3c-4439-4a30-a35f-d809a1ba1552
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.1:4
info: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: Network
driver: r8188eu interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
Device-2: 1-2.4:6 info: Alcor Micro Flash Card Reader/Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 058f:6362 class-ID: 0806
serial: <filter>
Device-3: 1-7:3 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c56 class-ID: 0300 serial: <filter>
Hub-3: 1-10:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-10.1:7 info: GEMBIRD MicroSD Card Reader/Writer
speed: 480 Mb/s power: 150mA chip-ID: 1908:0226 class-ID: 0806
Device-2: 1-10.2:8
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: WCM_USB WEB CAM type: Video,Audio
power: 100mA chip-ID: 1c3f:2002 class-ID: 0102
Device-2: 3-3:3 info: Holtek Gaming keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:a1cd class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nouveau temp: 33.0 C
Processes: 218 Uptime: 6m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1279 pacman: 1273 lib: 341
flatpak: 6 Shell: Bash (login) v: 5.1.16 running-in: tty 2 inxi: 3.3.15
