so uninstall the 517:
sudo mhwd-kernel -r linux517-rt
install normal 517:
sudo mhwd-kernel -i linux517
systemctl reboot
and also did you change something in bios?
I installed the linux517 kernel and it still stuck at Reached graphical interface
I did change some stuff in the bios but that was a month ago so i donāt think it matters now
can you check in bios if secure boot is disabled, also disable RAID and enable AHCI ā¦
also what is the output from these commands:
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
Secure boot and raid were already disabled and AHCI was already enabled
For test -d /sys/firmware/efi && echo efi || echo bios
it says efi
For sudo efibootmgr -v
BootCurrent: 0007
Timeout: 1 seconds
BootOrder: 0007,0002,0003
Boot0002* UEFI: PXE IPV4 Realtek PCIe GBE Family Controller PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x2)/Pci(0x9,0x0)/Pci(0x0,0x0)/MAC(2cf05dd12cca,0)/IPv4(0.0.0.00.0.0.0,0,0)..BO
Boot0003* UEFI: PXE IPV6 Realtek PCIe GBE Family Controller PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x2)/Pci(0x9,0x0)/Pci(0x0,0x0)/MAC(2cf05dd12cca,0)/IPv6([::]:<->[::]:,0,0)..BO
Boot0007* UEFI OS HD(1,GPT,e9eeedfc-835a-4649-8ca6-2ecd940dc969,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)..BO
looks good, try deleting the /xauthority file:
rm /home/yourusername/.Xauthority
- replace āyourusernameā with your actual user name, then reboot:
systemctl reboot
that doesnāt have seem to fixed it but I have to go rn, iāll brb in about an hour and 30 mins
all right when you back could you post output from:
journalctl --boot=0 --priority=3 --no-pager
May 15 12:02:52 gabe-pc kernel: usb 3-1: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
May 15 12:02:53 gabe-pc sddm[583]: Failed to read display number from pipe
May 15 12:02:55 gabe-pc sddm[583]: Failed to read display number from pipe
May 15 12:02:57 gabe-pc sddm[583]: Failed to read display number from pipe
May 15 12:02:57 gabe-pc sddm[583]: Could not start Display server on vt 1
and when did it started to happen? did you install something, uninstall, changed settings, etcā¦?
also try running upadate with: pamac update
I installed the NVIDIA drivers and then rebooted. Thatās all I can remember
all right post output from:
find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/20-nouveau.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf
all right so remove these:
sudo rm /etc/X11/xorg.conf
sudo rm /etc/X11/xorg.conf.d/20-nouveau.conf
systemctl reboot
IT WORKS
thanks so much
were not done, now lets install the nvidia drivers again:
sudo mhwd -a pci nonfree 0300
then reboot and post output from:
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
ok since you have only nvidia card use only nvidia drivers, so remove those linux drivers with:
sudo mhwd -r pci video-linux
then reboot
and thats it, youre good to go
cool, thanks for the help
