Stuck at clean... files ... blocks
Hello Guys,
So i tried the following:
pacman-mirros -f 5
pacman -Syyu
didnt help
so i read abut thats a problem reletated to nvidia.
So i tired
sudo pacman -Rs nvidia-utils and all those packages which hat dependencies
then i reinstalled them with -S
didnt help
so now i just removed them completly (i guess)
with
-Rncs parameter
nothing changed im still stucked at the same screen.
Does anyone knows how to fix that?
Hi,
Almost nothing about that methodology is correct.
I worry you may have removed core components …
but, if we assume the issue I am thinking of … it should have gone something like this:
mhwd -l -d
sudo mhwd -r pci video-nvidia
sudo mhwd -f -i pci video-nvidia-470xx
systemctl reboot
still stuck at the same screen. i have a 1080 if thst helps in any way to figure out the problem
Can you give information about he system ?
and which information would be usefull for you? i know shit so i srsly dont know what kind of information you need. the 1080 gets detected by the first command and until yesterday everything was fine. After shutdown the system it kind of get stuck while shuting down and the same screen (clean, files, blocks) so after some time i just shut down it manually. What for some reason which is unknown to me caused the problem?
Like inxi -Fza on console.
Can you post var/log/Xorg.0.log?
So the last couple of linex after usb live came device removed got added while the system got rebooted. After that i startet my windows 10 and access with that this file
[     4.362] (--) Log file renamed from "/var/log/Xorg.pid-644.log" to "/var/log/Xorg.0.log"
[     4.364]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[     4.364]
X.Org X Server 1.21.1.1
[     4.364] Current Operating System: Linux eisbergsalt-pc 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64
[     4.364] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=8cc82d02-d01a-4479-ac45-7479efe1c45f rw quiet apparmor=1 security=apparmor udev.log_priority=3
[     4.364]
[     4.364] Current version of pixman: 0.40.0
[     4.364] 	Before reporting problems, check http://wiki.x.org
[     4.364] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.364] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec  7 15:05:52 2021
[     4.366] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.366] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.367] (==) ServerLayout "layout"
[     4.367] (**) |-->Screen "Screen0" (0)
[     4.367] (**) |   |-->Monitor "Monitor0"
[     4.367] (**) |   |-->Device "Device0"
[     4.367] (==) Automatically adding devices
[     4.367] (==) Automatically enabling devices
[     4.367] (==) Automatically adding GPU devices
[     4.367] (==) Automatically binding GPU devices
[     4.367] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.369] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.369] 	Entry deleted from font path.
[     4.369] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.369] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     4.369] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     4.369] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     4.369] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.369] (**) Extension "COMPOSITE" is enabled
[     4.369] (II) The server relies on udev to provide the list of input devices.
[     4.369] (II) Module ABI versions:
[     4.369] 	X.Org ANSI C Emulation: 0.4
[     4.369] 	X.Org Video Driver: 25.2
[     4.369] 	X.Org XInput driver : 24.4
[     4.369] 	X.Org Server Extension : 10.0
[     4.370] (++) using VT number 1
[     4.370] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.370] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.370] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:2b:00.0/drm/card0
[     4.371] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.371] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.372] (--) PCI:*(43@0:0:0) 10de:1b80:3842:6183 rev 161, Mem @ 0xfb000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[     4.372] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.372] (II) LoadModule: "glx"
[     4.373] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.380] (II) Module glx: vendor="X.Org Foundation"
[     4.380] 	compiled for 1.21.1.1, module version = 1.0.0
[     4.380] 	ABI class: X.Org Server Extension, version 10.0
[     4.380] (II) LoadModule: "nvidia"
[     4.380] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     4.386] (II) Module nvidia: vendor="NVIDIA Corporation"
[     4.386] 	compiled for 1.6.99.901, module version = 1.0.0
[     4.386] 	Module class: X.Org Video Driver
[     4.386] (II) NVIDIA dlloader X Driver  470.86  Tue Oct 26 21:53:29 UTC 2021
[     4.386] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     4.388] (II) Loading sub module "fb"
[     4.388] (II) LoadModule: "fb"
[     4.388] (II) Module "fb" already built-in
[     4.388] (II) Loading sub module "wfb"
[     4.388] (II) LoadModule: "wfb"
[     4.388] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     4.388] (II) Module wfb: vendor="X.Org Foundation"
[     4.388] 	compiled for 1.21.1.1, module version = 1.0.0
[     4.388] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.388] (II) Loading sub module "ramdac"
[     4.388] (II) LoadModule: "ramdac"
[     4.388] (II) Module "ramdac" already built-in
[     4.421] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     4.421] (==) NVIDIA(0): RGB weight 888
[     4.421] (==) NVIDIA(0): Default visual is TrueColor
[     4.421] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.421] (**) Option "AllowNVIDIAGpuScreens"
[     4.422] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     4.422] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     4.422] (**) NVIDIA(0): Enabling 2D acceleration
[     4.422] (II) Loading sub module "glxserver_nvidia"
[     4.422] (II) LoadModule: "glxserver_nvidia"
[     4.422] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     4.480] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     4.480] 	compiled for 1.6.99.901, module version = 1.0.0
[     4.480] 	Module class: X.Org Server Extension
[     4.480] (II) NVIDIA GLX Module  470.86  Tue Oct 26 21:51:04 UTC 2021
[     4.481] (II) NVIDIA: The X server supports PRIME Render Offload.
[     5.225] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:43:0:0
[     5.225] (--) NVIDIA(0):     DFP-0
[     5.225] (--) NVIDIA(0):     DFP-1 (boot)
[     5.225] (--) NVIDIA(0):     DFP-2
[     5.225] (--) NVIDIA(0):     DFP-3
[     5.225] (--) NVIDIA(0):     DFP-4
[     5.225] (--) NVIDIA(0):     DFP-5
[     5.225] (--) NVIDIA(0):     DFP-6
[     5.225] (--) NVIDIA(0):     DFP-7
[     5.225] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1080 (GP104-A) at PCI:43:0:0
[     5.225] (II) NVIDIA(0):     (GPU-0)
[     5.225] (--) NVIDIA(0): Memory: 8388608 kBytes
[     5.225] (--) NVIDIA(0): VideoBIOS: 86.04.3b.00.82
[     5.225] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     5.225] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     5.225] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     5.225] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     5.268] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): connected
[     5.268] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): Internal TMDS
[     5.268] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): 600.0 MHz maximum pixel clock
[     5.268] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     5.268] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[     5.268] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[     5.268] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     5.268] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[     5.268] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[     5.268] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     5.268] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[     5.268] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[     5.269] (--) NVIDIA(GPU-0): DFP-5: disconnected
[     5.269] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[     5.269] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[     5.269] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     5.269] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[     5.269] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[     5.269] (--) NVIDIA(GPU-0): DFP-7: disconnected
[     5.269] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[     5.269] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[     5.273] (==) NVIDIA(0):
[     5.273] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[     5.274] (==) NVIDIA(0):     will be used as the requested mode.
[     5.274] (II) NVIDIA(0): Validated MetaModes:
[     5.274] (II) NVIDIA(0):     "DFP-1:nvidia-auto-select"
[     5.274] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[     5.278] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[     5.278] (--) NVIDIA(0):     option
[     5.279] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[     5.279] (II) NVIDIA:     access.
[     5.280] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     5.280] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     5.280] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     5.280] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     5.280] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     5.280] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     5.280] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     5.280] (II) NVIDIA(0):     Config Options in the README.
[     5.579] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select"
[     5.609] (==) NVIDIA(0): Disabling shared memory pixmaps
[     5.609] (==) NVIDIA(0): Backing store enabled
[     5.609] (==) NVIDIA(0): Silken mouse enabled
[     5.609] (**) NVIDIA(0): DPMS enabled
[     5.610] (WW) NVIDIA(0): Option "NoLogo" is not used
[     5.610] (II) Loading sub module "dri2"
[     5.610] (II) LoadModule: "dri2"
[     5.610] (II) Module "dri2" already built-in
[     5.610] (II) NVIDIA(0): [DRI2] Setup complete
[     5.610] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     5.610] (II) Initializing extension Generic Event Extension
[     5.610] (II) Initializing extension SHAPE
[     5.611] (II) Initializing extension MIT-SHM
[     5.611] (II) Initializing extension XInputExtension
[     5.611] (II) Initializing extension XTEST
[     5.611] (II) Initializing extension BIG-REQUESTS
[     5.611] (II) Initializing extension SYNC
[     5.611] (II) Initializing extension XKEYBOARD
[     5.611] (II) Initializing extension XC-MISC
[     5.611] (II) Initializing extension SECURITY
[     5.611] (II) Initializing extension XFIXES
[     5.611] (II) Initializing extension RENDER
[     5.611] (II) Initializing extension RANDR
[     5.611] (II) Initializing extension COMPOSITE
[     5.611] (II) Initializing extension DAMAGE
[     5.611] (II) Initializing extension MIT-SCREEN-SAVER
[     5.611] (II) Initializing extension DOUBLE-BUFFER
[     5.611] (II) Initializing extension RECORD
[     5.611] (II) Initializing extension DPMS
[     5.611] (II) Initializing extension Present
[     5.611] (II) Initializing extension DRI3
[     5.611] (II) Initializing extension X-Resource
[     5.612] (II) Initializing extension XVideo
[     5.612] (II) Initializing extension XVideo-MotionCompensation
[     5.612] (II) Initializing extension GLX
[     5.612] (II) Indirect GLX disabled.
[     5.612] (II) GLX: Another vendor is already registered for screen 0
[     5.612] (II) Initializing extension XFree86-VidModeExtension
[     5.612] (II) Initializing extension XFree86-DGA
[     5.612] (II) Initializing extension XFree86-DRI
[     5.612] (II) Initializing extension DRI2
[     5.612] (II) Initializing extension NV-GLX
[     5.612] (II) Initializing extension NV-CONTROL
[     5.612] (II) Initializing extension XINERAMA
[     5.729] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     5.729] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.729] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.729] (**) Power Button: Applying InputClass "system-keyboard"
[     5.729] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     5.729] (II) LoadModule: "libinput"
[     5.730] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     5.733] (II) Module libinput: vendor="X.Org Foundation"
[     5.733] 	compiled for 1.21.1, module version = 1.2.0
[     5.733] 	Module class: X.Org XInput Driver
[     5.733] 	ABI class: X.Org XInput driver, version 24.4
[     5.733] (II) Using input driver 'libinput' for 'Power Button'
[     5.733] (**) Power Button: always reports core events
[     5.733] (**) Option "Device" "/dev/input/event1"
[     5.734] (**) Option "_source" "server/udev"
[     5.737] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.737] (II) event1  - Power Button: device is a keyboard
[     5.737] (II) event1  - Power Button: device removed
[     5.764] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     5.764] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     5.764] (**) Option "xkb_layout" "de"
[     5.765] (**) Option "xkb_variant" "nodeadkeys"
[     5.765] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.777] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.777] (II) event1  - Power Button: device is a keyboard
[     5.777] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     5.777] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.777] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.777] (**) Power Button: Applying InputClass "system-keyboard"
[     5.777] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     5.777] (II) Using input driver 'libinput' for 'Power Button'
[     5.777] (**) Power Button: always reports core events
[     5.777] (**) Option "Device" "/dev/input/event0"
[     5.777] (**) Option "_source" "server/udev"
[     5.777] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.777] (II) event0  - Power Button: device is a keyboard
[     5.777] (II) event0  - Power Button: device removed
[     5.818] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     5.818] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     5.818] (**) Option "xkb_layout" "de"
[     5.818] (**) Option "xkb_variant" "nodeadkeys"
[     5.818] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.818] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.818] (II) event0  - Power Button: device is a keyboard
[     5.819] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event3)
[     5.819] (II) No input driver specified, ignoring this device.
[     5.819] (II) This device may have been added with another device file.
[     5.819] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event4)
[     5.819] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event5)
[     5.819] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event6)
[     5.820] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event7)
[     5.820] (II) No input driver specified, ignoring this device.
[     5.820] (II) This device may have been added with another device file.
[     5.820] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event8)
[     5.820] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event9)
[     5.820] (II) config/udev: Adding input device Logitech Logi TKL Mechanical Keyboard (/dev/input/event17)
[     5.820] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.820] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.820] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "system-keyboard"
[     5.820] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "Keyboard Defaults"
[     5.820] (II) Using input driver 'libinput' for 'Logitech Logi TKL Mechanical Keyboard'
[     5.820] (**) Logitech Logi TKL Mechanical Keyboard: always reports core events
[     5.820] (**) Option "Device" "/dev/input/event17"
[     5.820] (**) Option "_source" "server/udev"
[     5.821] (II) event17 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     5.821] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     5.822] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device removed
[     5.844] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2d:00.3/usb3/3-3/3-3:1.0/0003:046D:C345.0001/input/input17/event17"
[     5.844] (II) XINPUT: Adding extended input device "Logitech Logi TKL Mechanical Keyboard" (type: KEYBOARD, id 8)
[     5.844] (**) Option "xkb_layout" "de"
[     5.844] (**) Option "xkb_variant" "nodeadkeys"
[     5.844] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.846] (II) event17 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     5.846] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     5.846] (II) config/udev: Adding input device Logitech Logi TKL Mechanical Keyboard (/dev/input/event18)
[     5.846] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.846] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.846] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "system-keyboard"
[     5.846] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "Keyboard Defaults"
[     5.846] (II) Using input driver 'libinput' for 'Logitech Logi TKL Mechanical Keyboard'
[     5.846] (**) Logitech Logi TKL Mechanical Keyboard: always reports core events
[     5.846] (**) Option "Device" "/dev/input/event18"
[     5.846] (**) Option "_source" "server/udev"
[     5.847] (II) event18 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     5.848] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     5.848] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device removed
[     5.884] (II) libinput: Logitech Logi TKL Mechanical Keyboard: needs a virtual subdevice
[     5.884] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2d:00.3/usb3/3-3/3-3:1.1/0003:046D:C345.0002/input/input18/event18"
[     5.884] (II) XINPUT: Adding extended input device "Logitech Logi TKL Mechanical Keyboard" (type: MOUSE, id 9)
[     5.884] (**) Option "AccelerationScheme" "none"
[     5.884] (**) Logitech Logi TKL Mechanical Keyboard: (accel) selected scheme none/0
[     5.884] (**) Logitech Logi TKL Mechanical Keyboard: (accel) acceleration factor: 2.000
[     5.884] (**) Logitech Logi TKL Mechanical Keyboard: (accel) acceleration threshold: 4
[     5.885] (II) event18 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     5.885] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     5.886] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event10)
[     5.886] (II) No input driver specified, ignoring this device.
[     5.886] (II) This device may have been added with another device file.
[     5.886] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event11)
[     5.886] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event12)
[     5.886] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event13)
[     5.886] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event14)
[     5.887] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event15)
[     5.887] (II) No input driver specified, ignoring this device.
[     5.887] (II) This device may have been added with another device file.
[     5.887] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event16)
[     5.887] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[     5.890] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.890] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.890] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "system-keyboard"
[     5.890] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "Keyboard Defaults"
[     5.890] (II) Using input driver 'libinput' for 'Logitech Logi TKL Mechanical Keyboard'
[     5.890] (**) Logitech Logi TKL Mechanical Keyboard: always reports core events
[     5.890] (**) Option "Device" "/dev/input/event18"
[     5.890] (**) Option "_source" "_driver/libinput"
[     5.890] (II) libinput: Logitech Logi TKL Mechanical Keyboard: is a virtual subdevice
[     5.890] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2d:00.3/usb3/3-3/3-3:1.1/0003:046D:C345.0002/input/input18/event18"
[     5.890] (II) XINPUT: Adding extended input device "Logitech Logi TKL Mechanical Keyboard" (type: KEYBOARD, id 10)
[     5.890] (**) Option "xkb_layout" "de"
[     5.890] (**) Option "xkb_variant" "nodeadkeys"
[     5.890] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.934] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): connected
[     5.934] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): Internal TMDS
[     5.934] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): 600.0 MHz maximum pixel clock
[     5.978] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): connected
[     5.978] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): Internal TMDS
[     5.978] (--) NVIDIA(GPU-0): BenQ GW2780 (DFP-1): 600.0 MHz maximum pixel clock
[     5.978] (II) config/udev: removing device Logitech Logi TKL Mechanical Keyboard
[     5.978] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device removed
[     6.004] (II) UnloadModule: "libinput"
[     6.005] (II) config/udev: Adding input device Logitech Logi TKL Mechanical Keyboard (/dev/input/event17)
[     6.005] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.005] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.005] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "system-keyboard"
[     6.005] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "Keyboard Defaults"
[     6.005] (II) Using input driver 'libinput' for 'Logitech Logi TKL Mechanical Keyboard'
[     6.005] (**) Logitech Logi TKL Mechanical Keyboard: always reports core events
[     6.005] (**) Option "Device" "/dev/input/event17"
[     6.005] (**) Option "_source" "server/udev"
[     6.005] (II) event17 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     6.005] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     6.006] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device removed
[     6.031] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2d:00.3/usb3/3-3/3-3:1.0/0003:046D:C345.0001/input/input17/event17"
[     6.031] (II) XINPUT: Adding extended input device "Logitech Logi TKL Mechanical Keyboard" (type: KEYBOARD, id 8)
[     6.031] (**) Option "xkb_layout" "de"
[     6.031] (**) Option "xkb_variant" "nodeadkeys"
[     6.031] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.032] (II) event17 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     6.032] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     6.032] (II) config/udev: removing device Logitech Logi TKL Mechanical Keyboard
[     6.032] (II) UnloadModule: "libinput"
[     6.032] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device removed
[     6.058] (II) UnloadModule: "libinput"
[     6.058] (II) config/udev: Adding input device Logitech Logi TKL Mechanical Keyboard (/dev/input/event18)
[     6.058] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.058] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.058] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "system-keyboard"
[     6.058] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "Keyboard Defaults"
[     6.058] (II) Using input driver 'libinput' for 'Logitech Logi TKL Mechanical Keyboard'
[     6.058] (**) Logitech Logi TKL Mechanical Keyboard: always reports core events
[     6.058] (**) Option "Device" "/dev/input/event18"
[     6.058] (**) Option "_source" "server/udev"
[     6.059] (II) event18 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     6.059] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     6.059] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device removed
[     6.084] (II) libinput: Logitech Logi TKL Mechanical Keyboard: needs a virtual subdevice
[     6.084] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2d:00.3/usb3/3-3/3-3:1.1/0003:046D:C345.0002/input/input18/event18"
[     6.084] (II) XINPUT: Adding extended input device "Logitech Logi TKL Mechanical Keyboard" (type: MOUSE, id 9)
[     6.084] (**) Option "AccelerationScheme" "none"
[     6.084] (**) Logitech Logi TKL Mechanical Keyboard: (accel) selected scheme none/0
[     6.084] (**) Logitech Logi TKL Mechanical Keyboard: (accel) acceleration factor: 2.000
[     6.084] (**) Logitech Logi TKL Mechanical Keyboard: (accel) acceleration threshold: 4
[     6.085] (II) event18 - Logitech Logi TKL Mechanical Keyboard: is tagged by udev as: Keyboard
[     6.085] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device is a keyboard
[     6.086] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.086] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.086] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "system-keyboard"
[     6.086] (**) Logitech Logi TKL Mechanical Keyboard: Applying InputClass "Keyboard Defaults"
[     6.086] (II) Using input driver 'libinput' for 'Logitech Logi TKL Mechanical Keyboard'
[     6.086] (**) Logitech Logi TKL Mechanical Keyboard: always reports core events
[     6.086] (**) Option "Device" "/dev/input/event18"
[     6.086] (**) Option "_source" "_driver/libinput"
[     6.086] (II) libinput: Logitech Logi TKL Mechanical Keyboard: is a virtual subdevice
[     6.086] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:2d:00.3/usb3/3-3/3-3:1.1/0003:046D:C345.0002/input/input18/event18"
[     6.086] (II) XINPUT: Adding extended input device "Logitech Logi TKL Mechanical Keyboard" (type: KEYBOARD, id 10)
[     6.086] (**) Option "xkb_layout" "de"
[     6.086] (**) Option "xkb_variant" "nodeadkeys"
[     6.086] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.367] (II) config/udev: Adding input device Logitech USB Laser Mouse (/dev/input/event19)
[     7.367] (**) Logitech USB Laser Mouse: Applying InputClass "evdev pointer catchall"
[     7.367] (**) Logitech USB Laser Mouse: Applying InputClass "libinput pointer catchall"
[     7.367] (II) Using input driver 'libinput' for 'Logitech USB Laser Mouse'
[     7.367] (**) Logitech USB Laser Mouse: always reports core events
[     7.367] (**) Option "Device" "/dev/input/event19"
[     7.367] (**) Option "_source" "server/udev"
[     7.422] (II) event19 - Logitech USB Laser Mouse: is tagged by udev as: Mouse
[     7.422] (II) event19 - Logitech USB Laser Mouse: device set to 1000 DPI
[     7.422] (II) event19 - Logitech USB Laser Mouse: device is a pointer
[     7.422] (II) event19 - Logitech USB Laser Mouse: device removed
[     7.485] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-6/1-6:1.0/0003:046D:C069.0004/input/input19/event19"
[     7.485] (II) XINPUT: Adding extended input device "Logitech USB Laser Mouse" (type: MOUSE, id 11)
[     7.485] (**) Option "AccelerationScheme" "none"
[     7.485] (**) Logitech USB Laser Mouse: (accel) selected scheme none/0
[     7.485] (**) Logitech USB Laser Mouse: (accel) acceleration factor: 2.000
[     7.485] (**) Logitech USB Laser Mouse: (accel) acceleration threshold: 4
[     7.542] (II) event19 - Logitech USB Laser Mouse: is tagged by udev as: Mouse
[     7.542] (II) event19 - Logitech USB Laser Mouse: device set to 1000 DPI
[     7.542] (II) event19 - Logitech USB Laser Mouse: device is a pointer
[     7.543] (II) config/udev: Adding input device Logitech USB Laser Mouse (/dev/input/mouse0)
[     7.543] (II) No input driver specified, ignoring this device.
[     7.543] (II) This device may have been added with another device file.
[     7.543] (II) config/udev: Adding input device MSI MYSTIC LIGHT  (/dev/input/event20)
[     8.474] (II) config/udev: Adding input device USB Live camera : USB Live came (/dev/input/event21)
[     8.474] (**) USB Live camera : USB Live came: Applying InputClass "evdev keyboard catchall"
[     8.474] (**) USB Live camera : USB Live came: Applying InputClass "libinput keyboard catchall"
[     8.474] (**) USB Live camera : USB Live came: Applying InputClass "system-keyboard"
[     8.474] (**) USB Live camera : USB Live came: Applying InputClass "Keyboard Defaults"
[     8.474] (II) Using input driver 'libinput' for 'USB Live camera : USB Live came'
[     8.474] (**) USB Live camera : USB Live came: always reports core events
[     8.474] (**) Option "Device" "/dev/input/event21"
[     8.474] (**) Option "_source" "server/udev"
[     8.475] (II) event21 - USB Live camera : USB Live came: is tagged by udev as: Keyboard
[     8.475] (II) event21 - USB Live camera : USB Live came: device is a keyboard
[     8.475] (II) event21 - USB Live camera : USB Live came: device removed
[     8.565] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-9/1-9.3/1-9.3:1.0/input/input21/event21"
[     8.565] (II) XINPUT: Adding extended input device "USB Live camera : USB Live came" (type: KEYBOARD, id 12)
[     8.565] (**) Option "xkb_layout" "de"
[     8.565] (**) Option "xkb_variant" "nodeadkeys"
[     8.565] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.566] (II) event21 - USB Live camera : USB Live came: is tagged by udev as: Keyboard
[     8.566] (II) event21 - USB Live camera : USB Live came: device is a keyboard
[     9.091] (II) event1  - Power Button: device removed
[     9.111] (II) event0  - Power Button: device removed
[     9.138] (II) event17 - Logitech Logi TKL Mechanical Keyboard: device removed
[     9.178] (II) event18 - Logitech Logi TKL Mechanical Keyboard: device removed
[     9.204] (II) event19 - Logitech USB Laser Mouse: device removed
[     9.271] (II) event21 - USB Live camera : USB Live came: device removed
[   375.967] (II) UnloadModule: "libinput"
[   376.000] (II) NVIDIA(GPU-0): Deleting GPU-0
[   376.000] (II) Server terminated successfully (0). Closing log file.
Whats the status of the system?
What is displayed last ?
what do you mean by that? the last line as a cat /var/log…
was
Thats whats shown if a reboot by command
Any idea?
The idea is pretty much whats shown there … that ‘oldroot’ partition is funked up and having trouble mounting … whatever that is, get rid of it, unplug it, etc.
