My laptop (Lenovo Legion 5) gets stuck on dev/nvme0np5: clean, x/x files, x/x blocks for ~2mins every time I boot it.
It also has other problems (mainly with suspending) that probably come from the same cause, which I strongly suspect to be the NVidia driver (as always)…
I have had this issue for around 1 month now and I have tried to resolve it on:
linux515/manjaro stable
linux516/manjaro stable
linux517/manjaro stable
linux517/manjaro testing
linux518/manjaro testing
On all these configs the issue continues to occur…
I have tried this solution already, just if anyone tries to redirect me there.
All packages are up to date (pamac).
mhwd -l:
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:2560) Display controller nVidia Corporation:
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
mhwd -li:
[kendlbat@oxygen ~]$ mhwd -li
> Installed PCI configs:
I really want to thank everyone who reads through this post and I appreciate y’all!
you could go to etc/default/grub and from GRUB_CMDLINE_LINUX_DEFAULT remove ‘quiet’ , save and exit the file, run sudo update-grub reboot and see on what its stuck exactly…
Ok, after doing that and rebooting, the “more concise” version says:
A start job is running for /dev/disk/by-uuid (xs / 1min 30s)
The output from journalctl --boot=-1 --priority=3 --catalog is:
Mai 08 17:25:26 oxygen kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PB2], AE_NOT_>
Mai 08 17:25:26 oxygen kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20211217/psobject->
Mai 08 17:25:26 oxygen systemd-fstab-generator[326]: Failed to create unit file /run/systemd/generator/>
Mai 08 17:25:26 oxygen systemd[317]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed >
Mai 08 17:25:26 oxygen systemd-modules-load[346]: Failed to find module 'vboxdrv'
Mai 08 17:25:26 oxygen systemd-modules-load[346]: Failed to find module 'vboxnetadp'
Mai 08 17:25:26 oxygen systemd-modules-load[346]: Failed to find module 'vboxnetflt'
Mai 08 17:25:26 oxygen kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD.>
Mai 08 17:25:26 oxygen kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous >
Mai 08 17:26:56 oxygen systemd[1]: Timed out waiting for device /dev/disk/by-uuid.
░░ Subject: A start job for unit dev-disk-by\x2duuid.device has failed
░░ Defined-By: systemd
░░ A start job for unit dev-disk-by\x2duuid.device has finished with a failure.
░░ The job identifier is 66 and the job result is timeout.
Mai 08 17:26:58 oxygen systemd[1]: Failed to start Service for snap application anbox.container-manager.
░░ Subject: A start job for unit snap.anbox.container-manager.service has failed
░░ A start job for unit snap.anbox.container-manager.service has finished with a failure.
░░ The job identifier is 1526 and the job result is failed.
Mai 08 17:27:01 oxygen gnome-session-binary[1070]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error >
Mai 08 17:27:07 oxygen gdm-password][1328]: gkr-pam: unable to locate daemon control file
Mai 08 17:27:11 oxygen systemd[1339]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 442 and the job result is failed.
░░ The job identifier is 454 and the job result is failed.
░░ The job identifier is 422 and the job result is failed.
Mai 08 17:27:14 oxygen gdm-launch-environment][962]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJE>
Mai 08 18:23:54 oxygen gdm[831]: Gdm: Failed to contact accountsservice: Error calling StartServiceByNa>
Mai 08 18:23:56 oxygen systemd[1339]: Failed to start Portal service (GTK/GNOME implementation).
░░ The job identifier is 893 and the job result is failed.
Mai 08 18:23:57 oxygen kernel: watchdog: watchdog0: watchdog did not stop!
( “Mai” is just the german word for May, even though the system is set to English, it still uses German here for some reason…?; “oxygen” is the name of my Computer if anyone’s wondering)
Reinstalling gnome-shell, gnome-session and gdm-plymouth didn’t help
There are “-- No entries --” from journalctl for the devices @maycne.sonahoz suggested
So we’re basically back to exactly where we started…
Still gets stuck at A start job is running for /dev/disk/by-uuid (xs / 1min 30s).
It just sits there, counts up to 1:30 and then boots instantly. Maybe I can somehow shorten the timeout to like .1sec?
I just uninstalled it as I don’t really use it anyway and still just hangs…
The current output from journalctl --boot=-1 --unit=gnome-session-binary is:
Mai 08 19:11:54 oxygen kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PB2], AE_NOT_FOUND (20211217/dswload2-162)
Mai 08 19:11:54 oxygen kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20211217/psobject-220)
Mai 08 19:11:54 oxygen systemd-fstab-generator[324]: Failed to create unit file /run/systemd/generator/dev-disk-by\x2duuid.swap, as it already exists. Duplicate entry in /etc/fstab?
Mai 08 19:11:54 oxygen systemd[317]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Mai 08 19:11:54 oxygen systemd-modules-load[342]: Failed to find module 'vboxdrv'
Mai 08 19:11:54 oxygen systemd-modules-load[342]: Failed to find module 'vboxnetadp'
Mai 08 19:11:54 oxygen systemd-modules-load[342]: Failed to find module 'vboxnetflt'
Mai 08 19:11:54 oxygen kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20211217/psargs-330)
Mai 08 19:11:54 oxygen kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
Mai 08 19:13:24 oxygen systemd[1]: Timed out waiting for device /dev/disk/by-uuid.
░░ The job identifier is 62 and the job result is timeout.
Mai 08 19:13:28 oxygen gnome-session-binary[817]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
Mai 08 19:13:40 oxygen gdm-password][1076]: gkr-pam: unable to locate daemon control file
Mai 08 19:13:45 oxygen systemd[1087]: Failed to start Application launched by gnome-session-binary.
Mai 08 19:13:47 oxygen gnome-session-binary[817]: GLib-CRITICAL: g_hash_table_foreach_remove_or_steal: assertion 'version == hash_table->version' failed
Mai 08 19:13:47 oxygen gdm-launch-environment][768]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mai 08 19:22:30 oxygen systemd-fstab-generator[2391]: Failed to create unit file /run/systemd/generator/dev-disk-by\x2duuid.swap, as it already exists. Duplicate entry in /etc/fstab?
Mai 08 19:22:30 oxygen systemd[2384]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Mai 08 19:22:38 oxygen sudo[2420]: pam_unix(sudo:auth): conversation failed
Mai 08 19:22:38 oxygen sudo[2420]: pam_unix(sudo:auth): auth could not identify password for [kendlbat]
Mai 08 19:22:43 oxygen gdm[737]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Mai 08 19:22:45 oxygen kernel: watchdog: watchdog0: watchdog did not stop!
