Stuck at boot screen _
Having an issue with a friend’s manjaro installation.
It gets stuck at the _ screen a boot.
I tried quite a lot of things so far, nothing worked.
I used chroot with a live usb to :
  • install latest kernel (6.6)
  • remove older kernels
  • reinstall nvidia
  • grub update
nothing works so far.
so I thought to post here, maybe someone can tell me what is wrong.
I suspect it’s an nvidia issue, but I might be wrong.
Anyway to debug this?
a bit of information I can get via chroot :
(1/1) checking keys in keyring        [#############################################################################] 100%
/ > mhwd-kernel -li && mhwd -l -li        root@manjaro-i3
Currently running: 6.5.3-1-MANJARO (linux65)
   * linux66
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-470xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-470xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-470xx-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-390xx-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/local/pci/video-nvidia/MHWDCONFIG' is invalid!
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
> 0000:02:00.0 (0300:10de:1cb6) Display controller nVidia Corporation:
> 0000:01:00.0 (0300:10de:1cb6) Display controller nVidia Corporation:
/ > inxi --admin --verbosity=7 --filter --width        root@manjaro-i3
12System:
  12Kernel 6.5.3-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1
    12clocksource tsc 12available hpet,acpi_pm
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_I3_2301 quiet systemd.show_status=1
    apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  12Desktop i3 12v 4.23 12info i3bar 12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12System ASUS 12product N/A 12v N/A 12serial N/A
  12Mobo ASUSTeK 12model PRIME Z390-A 12v Rev 1.xx 12serial <filter>
    12UEFI American Megatrends 12v 1802 12date 12/01/2020
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12System RAM 12total 64 GiB 12available 62.72 GiB 12used 4.35 GiB (6.9%)
  12Array-1 12capacity 64 GiB 12slots 4 12modules 4 12EC None 12max-module-size 16 GiB
    12note est.
  12Device-1 ChannelA-DIMM1 12type DDR4 12detail synchronous 12size 16 GiB
    12speed 2400 MT/s 12volts 12curr 1.2 12width (bits) 12data 64 12total 64
    12manufacturer Corsair 12part-no CMK32GX4M2A2400C16 12serial N/A
  12Device-2 ChannelA-DIMM2 12type DDR4 12detail synchronous 12size 16 GiB
  12Device-3 ChannelB-DIMM1 12type DDR4 12detail synchronous 12size 16 GiB
  12Device-4 ChannelB-DIMM2 12type DDR4 12detail synchronous 12size 16 GiB
12CPU:
  12Info 12model Intel Core i7-9700K 12socket LGA1151 12bits 64 12type MCP
    12arch Coffee Lake 12gen core 9 12level v3 12note check 12built 2018 12process Intel 14nm
    12family 6 12model-id 0x9E (158) 12stepping 0xD (13) 12microcode 0xFA
  12Topology 12cpus 1x 12cores 8 12smt <unsupported> 12cache 12L1 512 KiB
    12desc d-8x32 KiB; i-8x32 KiB 12L2 2 MiB 12desc 8x256 KiB 12L3 12 MiB 12desc 1x12 MiB
  12Speed (MHz) 12avg 800 12min/max 800/4900 12base/boost 3600/8300 12scaling
    12driver intel_pstate 12governor powersave 12volts 0.9 V 12ext-clock 100 MHz 12cores
    121 800 122 800 123 800 124 800 125 800 126 800 127 800 128 800 12bogomips 57616
  12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  12Vulnerabilities
  12Type gather_data_sampling 12mitigation Microcode
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type mmio_stale_data 12mitigation Clear CPU buffers; SMT disabled
  12Type retbleed 12mitigation Enhanced IBRS
  12Type spec_rstack_overflow 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  12Type srbds 12mitigation Microcode
  12Type tsx_async_abort 12mitigation TSX disabled
12Graphics:
  12Device-1 NVIDIA GP107GL [Quadro P620] 12driver nvidia 12v 535.104.05
    12non-free 545.xx+ 12status current (as of 2023-11; EOL~2026-12-xx) 12arch Pascal
    12code GP10x 12process TSMC 16nm 12built 2016-2021 12pcie 12gen 3 12speed 8 GT/s
    12lanes 8 12link-max 12lanes 16 12bus-ID 01:00.0 12chip-ID 10de:1cb6 12class-ID 0300
  12Device-2 NVIDIA GP107GL [Quadro P620] 12driver nvidia 12v 535.104.05
    12code GP10x 12process TSMC 16nm 12built 2016-2021 12pcie 12gen 1 12speed 2.5 GT/s
    12lanes 8 12link-max 12gen 3 12speed 8 GT/s 12lanes 16 12bus-ID 02:00.0
  12Display 12server X.Org 12v 21.1.8 12compositor Picom 12v git-b700a 12driver 12X
    12loaded nvidia 12gpu nvidia,nvidia 12display-ID :0 12screens 1
  12Screen-1 0 12s-res 7680x1080 12s-dpi 92 12s-size 2120x301mm (83.46x11.85")
    12s-diag 2141mm (84.3")
  12Monitor-1 DP-1 12pos center-l 12res 1920x1080 12hz 60 12dpi 93
    12size 527x296mm (20.75x11.65") 12diag 604mm (23.8") 12modes N/A
  12Monitor-2 DP-1-1 12size-res N/A 12modes N/A
  12Monitor-3 DP-1-3 12size-res N/A 12modes N/A
  12Monitor-4 DP-3 12pos primary,left 12res 1920x1080 12hz 60 12dpi 93
  12Monitor-5 DP-5 12pos center-r 12res 1920x1080 12hz 60 12dpi 93
  12Monitor-6 DP-7 12pos right 12res 1920x1080 12hz 60 12dpi 93
  12API OpenGL 12Message Unable to show GL data. glxinfo is missing.
12Audio:
  12Device-1 Intel Cannon Lake PCH cAVS 12vendor ASUSTeK 12driver snd_hda_intel
    12v kernel 12bus-ID 00:1f.3 12chip-ID 8086:a348 12class-ID 0403
  12Device-2 NVIDIA GP107GL High Definition Audio 12driver snd_hda_intel 12v kernel
    12pcie 12gen 3 12speed 8 GT/s 12lanes 8 12link-max 12lanes 16 12bus-ID 01:00.1
    12chip-ID 10de:0fb9 12class-ID 0403
  12Device-3 NVIDIA GP107GL High Definition Audio 12driver snd_hda_intel 12v kernel
    12pcie 12gen 1 12speed 2.5 GT/s 12lanes 8 12link-max 12gen 3 12speed 8 GT/s 12lanes 16
    12bus-ID 02:00.1 12chip-ID 10de:0fb9 12class-ID 0403
  12API ALSA 12v k6.5.3-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
  12Server-2 PipeWire 12v 1.0.0 12status off 12tools pw-cli
  12Server-3 PulseAudio 12v 16.1 12status off 12tools pacat,pactl,pavucontrol
12Network:
  12Device-1 Intel Ethernet I219-V 12vendor ASUSTeK 12driver e1000e 12v kernel 12port N/A
    12bus-ID 00:1f.6 12chip-ID 8086:15bc 12class-ID 0200
  12IF eno1 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12Device-2 Realtek RTL8153 Gigabit Ethernet Adapter 12driver r8152 12type USB
    12rev 2.1 12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-13.4:9 12chip-ID 0bda:8153
    12class-ID 0000 12serial <filter>
  12IF enp0s20f0u13u4 12state down 12mac <filter>
  12WAN IP <filter>
12Bluetooth:
  12Message No bluetooth data found.
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 705.86 GiB 12used 150.38 GiB (21.3%)
  12SMART Message Required tool smartctl not installed. Check --recommends
  12ID-1 /dev/sda 12maj-min 8:0 12vendor Crucial 12model CT500MX500SSD1
    12size 465.76 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s
    12tech SSD 12serial <filter> 12fw-rev 023
  12ID-2 /dev/sdb 12maj-min 8:16 12vendor Crucial 12model CT250MX500SSD1
    12size 232.89 GiB 12block-size 12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s
  12ID-3 /dev/sdc 12maj-min 8:32 12model USB DISK 2.0 12size 7.21 GiB 12block-size
    12physical 512 B 12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0
    12tech N/A 12serial <filter> 12fw-rev PMAP
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 107.42 GiB 12size 105.18 GiB (97.91%) 12used 34.21 GiB (32.5%)
    12fs ext4 12block-size 4096 B 12dev /dev/sda1 12maj-min 8:1 12label N/A
    12uuid ade3c1e9-d2c2-414a-9768-53221160ad5d
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 296 MiB (98.67%) 12used 25.7 MiB (8.7%)
    12fs vfat 12block-size 512 B 12dev /dev/sda4 12maj-min 8:4 12label EFIBOOTMS
    12uuid D838-5469
  12ID-3 /home 12raw-size 296.52 GiB 12size 290.8 GiB (98.07%)
    12used 116.14 GiB (39.9%) 12fs ext4 12block-size 4096 B 12dev /dev/sda2 12maj-min 8:2
    12label N/A 12uuid d2cb9f7a-de76-4a45-8469-9959c6a604a6
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/sda3 12maj-min 8:3 12size 61.52 GiB 12fs swap 12label N/A
    12uuid b775e558-e79c-419b-9921-057005aada91
  12ID-2 /dev/sdb1 12maj-min 8:17 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-3 /dev/sdb2 12maj-min 8:18 12size 232.87 GiB 12fs ntfs 12label N/A
    12uuid C210505E10505C0B
  12ID-4 /dev/sdc1 12maj-min 8:33 12size 3.33 GiB 12fs N/A 12label MANJARO_I3_2301
    12uuid 2023-09-21-13-55-27-00
  12ID-5 /dev/sdc2 12maj-min 8:34 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 61D0-1C83
12USB:
  12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 16 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-1:2 12info Razer USA BlackWidow Elite 12type keyboard,mouse
    12driver hid-generic,usbhid 12interfaces 3 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s)
    12lanes 1 12mode 1.1 12power 500mA 12chip-ID 1532:0228 12class-ID 0300
  12Device-2 1-3:3 12info Microsoft Xbox360 Controller 12type <vendor specific>
    12driver xpad 12interfaces 1 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1
    12power 500mA 12chip-ID 045e:028e 12class-ID ff00 12serial <filter>
  12Hub-2 1-6:4 12info Genesys Logic Hub 12ports 4 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 100mA 12chip-ID 05e3:0610
    12class-ID 0900
  12Device-1 1-6.1:6 12info USB OPTICAL MOUSE 12type mouse
    12driver hid-generic,usbhid 12interfaces 1 12rev 1.1 12speed 1.5 Mb/s (183 KiB/s)
    12lanes 1 12mode 1.0 12power 100mA 12chip-ID 275d:0ba6 12class-ID 0301
  12Device-2 1-6.2:8 12info Phison Flash drive 12type mass storage
    12driver usb-storage 12interfaces 1 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
    12mode 2.0 12power 200mA 12chip-ID 13fe:4100 12class-ID 0806 12serial <filter>
  12Hub-3 1-13:5 12info VIA Labs USB2.0 Hub 12ports 4 12rev 2.1
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 2109:2815 12class-ID 0900
  12Device-1 1-13.4:9 12info Realtek RTL8153 Gigabit Ethernet Adapter
    12type Network 12driver r8152 12interfaces 1 12rev 2.1 12speed 480 Mb/s (57.2 MiB/s)
    12lanes 1 12mode 2.0 12power 200mA 12chip-ID 0bda:8153 12class-ID 0000
    12serial <filter>
  12Device-2 1-14:7 12info Logitech G102/G203 LIGHTSYNC Gaming Mouse
    12type mouse,HID 12driver hid-generic,usbhid 12interfaces 2 12rev 2.0
    12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 300mA 12chip-ID 046d:c092
    12class-ID 0300 12serial <filter>
  12Hub-4 2-0:1 12info super-speed hub 12ports 10 12rev 3.1
    12speed 10 Gb/s (1.16 GiB/s) 12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003
    12class-ID 0900
12Sensors:
  12System Temperatures 12cpu 33.0 C 12mobo N/A 12gpu nvidia 12temp 57 C
  12Fan Speeds (rpm) N/A 12gpu nvidia 12fan 44%
12Info:
  12Processes 232 12Uptime 16m 12wakeups 0 12Init systemd 12v 254 12default graphical
  12tool systemctl 12Compilers 12gcc 13.2.1 12clang 16.0.6 12Packages 12pm pacman 12pkgs 1380
  12libs 417 12tools pamac,yay 12Client Unknown Client: rcu_par_gp 12inxi 3.3.31
/ > cat /etc/default/grub        4s root@manjaro-i3
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 ibt=off"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
/ > pacman -Qs nvidia        root@manjaro-i3
local/egl-wayland 2:1.1.13-1
    EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-2
    Nvidia VDPAU library
local/lib32-nvidia-utils 545.29.06-1
    NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-2
local/libxnvctrl 545.29.06-1
    NVIDIA NV-CONTROL X extension
local/linux66-nvidia 545.29.06-22 (linux66-extramodules)
    NVIDIA drivers for linux
local/nvidia-settings 545.29.06-1
    Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 545.29.06-1
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
    Open Source 3D acceleration driver for nVidia cards
/ > cat /etc/mkinitcpio.conf        root@manjaro-i3
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(piix ide_disk reiserfs)
#MODULES=""
MODULES=(i915 nvidia nvidia_drm nvidia_uvm nvidia_modeset)
So … some odd things.
That of course.
I think this might be related to missing mhwd packages.
And also the fact that mhwd does not mention any nvidia profiles is weird - either installed or offered.
Also … kernel is 6.5 … and you have linux66-nvidia (and not linux65-nvidia)?
Also its version is mismatched as well:
So … how was nvidia installed before ?
In whatever case you should aim to make sure linux66 is installed, boot into it, and remove linux65 as it is end of life (and this will help clear up the mismatching going on)
ex;
update
sudo pacman -Syu
install kernel
sudo mhwd-kernel -i linux66
Reboot.
Select 6.6.
You can verify running kernel with uname -a.
Then remove linux65
sudo mhwd-kernel -r linux65
OR
sudo pacman -Rns $(pacman -Qsq linux65)
Oh and to double check the mhwd thing;
pacman -Qs mhwd
those inconsistencies are definitely from my efforts to fix it.
so, on the first two:
/ > sudo pacman -Syu
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 there is nothing to do
/ > sudo mhwd-kernel -i linux66
 core is up to date
 extra is up to date
error: no targets specified (use -h for help)
there was nvidia for sure. he has 6 monitors and it took us a while to make them work by tinkering the xorg.conf when we first installed manjaro for him. so I’m sure he needs nvidia drivers.
he told me the system got stuck after he was trying to update the kernel and he couldn’t.
so when I chrooted, the first thing I did is -Rdd a package that was stuck with an old dependency.
After that everything updated with pacman. But the problem persisted so I started trying other things.
I hope that makes more sense.
Sure.
linux66 is available on all branches … so maybe try to sort mirrors first;
sudo pacman-mirrors -f && sudo pacman -Syu
Note: It is possible if you have an old mirror pool that it is stuck with very outdated mirrors.
To reset it you can do
sudo pacman-mirrors --country all
Thanks for helping out.
It doesn’t seem to be able to find it.
/ > sudo pacman-mirrors -f && sudo pacman -Syu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.129 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
::INFO Writing mirror list
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/testing/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core is up to date
 extra is up to date
 core is up to date
 extra is up to date
/ > sudo pacman-mirrors --country all        root@manjaro-i3
::INFO Using default mirror file
  3.151 Australia      : https://mirror.aarnet.edu.au/pub/manjaro/
  1.760 Australia      : https://gsl-syd.mm.fcix.net/manjaro/
  0.413 Austria        : https://mirror.easyname.at/manjaro/
  0.502 Austria        : https://mirror.alwyzon.net/manjaro/
  2.929 Bangladesh     : https://bd.mirror.vanehost.com/Manjaro/
  0.246 Belgium        : https://mirror.futureweb.be/manjaro/
  2.558 Brazil         : https://manjaro.c3sl.ufpr.br/
  2.163 Brazil         : https://mirror.ufam.edu.br/manjaro/
  2.028 Brazil         : https://linorg.usp.br/manjaro/
  0.474 Bulgaria       : https://mirrors.netix.net/manjaro/
  0.503 Bulgaria       : https://mirror.telepoint.bg/manjaro/
  2.565 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  1.075 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  0.880 Canada         : https://mirror.xenyth.net/manjaro/
  1.045 Canada         : https://muug.ca/mirror/manjaro/
  2.130 Chile          : https://mirror.ufro.cl/manjaro/
  3.670 China          : https://mirrors.pku.edu.cn/manjaro/
  2.368 China          : https://mirror.nju.edu.cn/manjaro/
  2.980 China          : https://mirrors.ustc.edu.cn/manjaro/
  2.183 China          : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
  ..... China          : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
  2.812 China          : https://mirrors.jlu.edu.cn/manjaro/
  2.729 China          : https://mirror.nyist.edu.cn/manjaro/
  1.113 Colombia       : https://edgeuno-bog2.mm.fcix.net/manjaro/
  1.243 Costa_Rica     : https://mirrors.ucr.ac.cr/manjaro/
  0.925 Czechia        : https://mirror.dkm.cz/manjaro/
  0.753 Czechia        : https://mirrors.nic.cz/manjaro/
  0.872 Czechia        : https://mirror.it4i.cz/manjaro/
  0.467 Denmark        : https://mirrors.dotsrc.org/manjaro/
  0.747 Estonia        : https://mirrors.xtom.ee/manjaro/
  0.327 Finland        : https://manjaro.kyberorg.fi/
  0.536 France         : https://mirror.ibakerserver.pt/manjaro/
  0.413 France         : https://manjaro.ynh.ovh/
  0.264 Germany        : https://mirror.alpix.eu/manjaro/
  0.266 Germany        : https://mirrors.xtom.de/manjaro/
  0.562 Germany        : https://ftp.gwdg.de/pub/linux/manjaro/
  0.345 Germany        : https://mirror.23m.com/manjaro/
  0.587 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  0.306 Germany        : https://mirror.netcologne.de/manjaro/
  0.565 Germany        : https://mirror.seahost.de/manjaro/
  0.435 Germany        : https://manjaro.kurdy.org/
  0.201 Global         : https://mirrors.manjaro.org/repo/
  0.141 Global         : https://mirrors2.manjaro.org/
  0.742 Greece         : https://fosszone.csd.auth.gr/manjaro/
  0.604 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.367 India          : https://mirror.albony.xyz/manjaro/
  1.076 Iran           : https://repo.iut.ac.ir/repo/manjaro/
  1.314 Iran           : https://mirror.bardia.tech/manjaro/
  0.483 Italy          : https://manjaro.mirror.garr.it/manjaro/
  0.598 Italy          : https://ba.mirror.garr.it/mirrors/manjaro/
  0.642 Italy          : https://ct.mirror.garr.it/mirrors/manjaro/
  2.259 Japan          : https://mirrors.xtom.jp/manjaro/
  2.438 Japan          : https://mirror.phoepsilonix.love/manjaro/
  1.187 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  1.540 Mauritius      : https://manjarolinux-mirror.cloud.mu/
  0.335 Netherlands    : https://manjaro.mirror.wearetriple.com/
  0.500 Netherlands    : https://manjaro.mirrors.lavatech.top/
  0.613 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.536 Netherlands    : https://mirror.koddos.net/manjaro/
  2.024 New_Zealand    : https://mirror.2degrees.nz/manjaro/
  0.564 Poland         : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/
  0.759 Poland         : https://ftp.psnc.pl/linux/manjaro/
  0.524 Portugal       : https://mirrors.up.pt/pub/manjaro/
  0.547 Russia         : https://mirror.yandex.ru/mirrors/manjaro/
  1.653 Russia         : https://mirror.kamtv.ru/manjaro/
  0.919 Russia         : https://mirror.truenetwork.ru/manjaro/
  1.325 Singapore      : https://mirror.freedif.org/Manjaro/
  1.965 South_Korea    : https://mirror.funami.tech/manjaro/
  0.109 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  0.558 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  0.841 Sweden         : https://mirror.zetup.net/manjaro/
  0.637 Sweden         : https://ftpmirror1.infania.net/mirror/manjaro/
  0.261 Switzerland    : https://mirror.init7.net/manjaro/
  2.331 Taiwan         : https://mirror.archlinux.tw/Manjaro/
  3.472 Thailand       : https://mirror.kku.ac.th/manjaro/
  1.248 Turkey         : https://ftp.linux.org.tr/manjaro/
  0.531 Ukraine        : https://fastmirror.pp.ua/manjaro/
  0.298 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
  0.400 United_Kingdom : https://mirror.vinehost.net/manjaro/
  0.671 United_States  : https://nnenix.mm.fcix.net/manjaro/
  1.018 United_States  : https://irltoolkit.mm.fcix.net/manjaro/
  0.662 United_States  : https://uvermont.mm.fcix.net/manjaro/
  1.126 United_States  : https://ziply.mm.fcix.net/manjaro/
  1.248 United_States  : https://repo.ialab.dsu.edu/manjaro/
  1.392 United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.882 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  0.762 United_States  : https://mnvoip.mm.fcix.net/manjaro/
  0.614 United_States  : https://forksystems.mm.fcix.net/manjaro/
  0.976 United_States  : https://codingflyboy.mm.fcix.net/manjaro/
  0.627 United_States  : https://coresite.mm.fcix.net/manjaro/
  0.991 United_States  : https://ridgewireless.mm.fcix.net/manjaro/
  1.015 United_States  : https://opencolo.mm.fcix.net/manjaro/
  0.796 United_States  : https://southfront.mm.fcix.net/manjaro/
  0.765 United_States  : https://volico.mm.fcix.net/manjaro/
  0.650 United_States  : https://ohioix.mm.fcix.net/manjaro/
  1.429 United_States  : https://mirrors.sonic.net/manjaro/
  0.972 United_States  : https://mirrors.gigenet.com/manjaro/
  0.847 United_States  : https://nocix.mm.fcix.net/manjaro/
  0.298 United_States  : https://ask4.mm.fcix.net/manjaro/
  1.528 Uruguay        : https://manjaro.repo.cure.edu.uy/
  1.441 Uzbekistan     : https://mirror.dc.uz/manjaro/
::Global          : https://mirrors2.manjaro.org/testing
::Global          : https://mirrors.manjaro.org/repo/testing
::Belgium         : https://mirror.futureweb.be/manjaro/testing
::Switzerland     : https://mirror.init7.net/manjaro/testing
::Germany         : https://mirror.alpix.eu/manjaro/testing
::Germany         : https://mirrors.xtom.de/manjaro/testing
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/testing
::United_States   : https://ask4.mm.fcix.net/manjaro/testing
::Germany         : https://mirror.netcologne.de/manjaro/testing
::Finland         : https://manjaro.kyberorg.fi/testing
::Netherlands     : https://manjaro.mirror.wearetriple.com/testing
::Germany         : https://mirror.23m.com/manjaro/testing
::India           : https://mirror.albony.xyz/manjaro/testing
::United_Kingdom  : https://mirror.vinehost.net/manjaro/testing
::Austria         : https://mirror.easyname.at/manjaro/testing
::France          : https://manjaro.ynh.ovh/testing
::Germany         : https://manjaro.kurdy.org/testing
::Denmark         : https://mirrors.dotsrc.org/manjaro/testing
::Bulgaria        : https://mirrors.netix.net/manjaro/testing
::Italy           : https://manjaro.mirror.garr.it/manjaro/testing
::Netherlands     : https://manjaro.mirrors.lavatech.top/testing
::Austria         : https://mirror.alwyzon.net/manjaro/testing
::Bulgaria        : https://mirror.telepoint.bg/manjaro/testing
::Portugal        : https://mirrors.up.pt/pub/manjaro/testing
::Ukraine         : https://fastmirror.pp.ua/manjaro/testing
::France          : https://mirror.ibakerserver.pt/manjaro/testing
::Netherlands     : https://mirror.koddos.net/manjaro/testing
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/testing
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/testing
::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/testing
::Poland          : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/testing
::Germany         : https://mirror.seahost.de/manjaro/testing
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/testing
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/testing
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/testing
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/testing
::United_States   : https://forksystems.mm.fcix.net/manjaro/testing
::United_States   : https://coresite.mm.fcix.net/manjaro/testing
::Sweden          : https://ftpmirror1.infania.net/mirror/manjaro/testing
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/testing
::United_States   : https://ohioix.mm.fcix.net/manjaro/testing
::United_States   : https://uvermont.mm.fcix.net/manjaro/testing
::United_States   : https://nnenix.mm.fcix.net/manjaro/testing
::Greece          : https://fosszone.csd.auth.gr/manjaro/testing
::Estonia         : https://mirrors.xtom.ee/manjaro/testing
::Czechia         : https://mirrors.nic.cz/manjaro/testing
::Poland          : https://ftp.psnc.pl/linux/manjaro/testing
::United_States   : https://mnvoip.mm.fcix.net/manjaro/testing
::United_States   : https://volico.mm.fcix.net/manjaro/testing
::United_States   : https://southfront.mm.fcix.net/manjaro/testing
::Sweden          : https://mirror.zetup.net/manjaro/testing
::United_States   : https://nocix.mm.fcix.net/manjaro/testing
::Czechia         : https://mirror.it4i.cz/manjaro/testing
::Canada          : https://mirror.xenyth.net/manjaro/testing
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/testing
::Russia          : https://mirror.truenetwork.ru/manjaro/testing
::Czechia         : https://mirror.dkm.cz/manjaro/testing
::United_States   : https://mirrors.gigenet.com/manjaro/testing
::United_States   : https://codingflyboy.mm.fcix.net/manjaro/testing
::United_States   : https://ridgewireless.mm.fcix.net/manjaro/testing
::United_States   : https://opencolo.mm.fcix.net/manjaro/testing
::United_States   : https://irltoolkit.mm.fcix.net/manjaro/testing
::Canada          : https://muug.ca/mirror/manjaro/testing
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/testing
::Iran            : https://repo.iut.ac.ir/repo/manjaro/testing
::Colombia        : https://edgeuno-bog2.mm.fcix.net/manjaro/testing
::United_States   : https://ziply.mm.fcix.net/manjaro/testing
::Kenya           : https://manjaro.mirror.liquidtelecom.com/testing
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/testing
::Turkey          : https://ftp.linux.org.tr/manjaro/testing
::United_States   : https://repo.ialab.dsu.edu/manjaro/testing
::Iran            : https://mirror.bardia.tech/manjaro/testing
::Singapore       : https://mirror.freedif.org/Manjaro/testing
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/testing
::United_States   : https://mirrors.sonic.net/manjaro/testing
::Uzbekistan      : https://mirror.dc.uz/manjaro/testing
::Uruguay         : https://manjaro.repo.cure.edu.uy/testing
::Mauritius       : https://manjarolinux-mirror.cloud.mu/testing
::Russia          : https://mirror.kamtv.ru/manjaro/testing
::Australia       : https://gsl-syd.mm.fcix.net/manjaro/testing
::South_Korea     : https://mirror.funami.tech/manjaro/testing
::New_Zealand     : https://mirror.2degrees.nz/manjaro/testing
::Brazil          : https://linorg.usp.br/manjaro/testing
::Chile           : https://mirror.ufro.cl/manjaro/testing
::Brazil          : https://mirror.ufam.edu.br/manjaro/testing
::China           : https://mirrors.tuna.tsinghua.edu.cn/manjaro/testing
::Japan           : https://mirrors.xtom.jp/manjaro/testing
::Taiwan          : https://mirror.archlinux.tw/Manjaro/testing
::China           : https://mirror.nju.edu.cn/manjaro/testing
::Japan           : https://mirror.phoepsilonix.love/manjaro/testing
::Brazil          : https://manjaro.c3sl.ufpr.br/testing
::Bulgaria        : https://manjaro.ipacct.com/manjaro/testing
::China           : https://mirror.nyist.edu.cn/manjaro/testing
::China           : https://mirrors.jlu.edu.cn/manjaro/testing
::Bangladesh      : https://bd.mirror.vanehost.com/Manjaro/testing
::China           : https://mirrors.ustc.edu.cn/manjaro/testing
::Australia       : https://mirror.aarnet.edu.au/pub/manjaro/testing
::Thailand        : https://mirror.kku.ac.th/manjaro/testing
::China           : https://mirrors.pku.edu.cn/manjaro/testing
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/testing
 core is up to date
 extra is up to date
/ > sudo pacman-mirrors -f && sudo pacman -Syu        root@manjaro-i3
  0.510 Sweden         : https://mirror.zetup.net/manjaro/
 core is up to date
 extra is up to date
I recall mhwd-kernel failing when I was running a custom kernel. Maybe this is a similar situation.
Its of no real matter, at least for now.
You can hopefully still install using pacman;
sudo pacman -Syu linux66 linux66-headers
Ops. Looks like you got it.
I would still like to see the output of
pacman -Qs mhwd
Because I feel some packages are missing.
just to clarify, I’m on the live usb now, and the terminal you see is after doing manjaro-chroot -a.
so when it says “6.5 running” that’s the usb one, right?
The command you gave ran just fine.
Do I try to boot into the normal installation now?
( takes 10 mins for the whole process and for me to get back here on the browser, so I’m careful rebooting now :smiley: )
/ > pacman -Qs mhwd        48s root@manjaro-i3
local/bmenu 0.20-1
    Bash scripts providing a collection of terminal applications in a simple UI
local/mhwd 0.6.5-28
    Manjaro Linux Hardware Detection library and application
local/mhwd-amdgpu 19.1.0-1
    MHWD module-ids for amdgpu
local/mhwd-ati 19.1.0-1
    MHWD module-ids for ati 19.1.0
local/mhwd-db 0.6.5-28
    Manjaro Linux Hardware Detection Database
That would be an issue.
Some core packages are missing.
Ex on my system;
$ pacman -Qs mhwd
local/mhwd 0.6.5-28
local/mhwd-nvidia 545.29.06-1
    MHWD module-ids for nvidia 545.29.06
local/mhwd-nvidia-390xx 390.157-9
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.223.02-1
    MHWD module-ids for nvidia 470.223.02
So you should make sure to install the missing ones, which are namely the nvidia ones.
sudo pacman -Syu $(pacman -Sqs mhwd-nvidia)
I removed those probably, I thought it’s old versions.
And I thought that installing nvidia again would install everything it needs.
Anyway.
So, I ran the command.
This is what I have now:
/ > pacman -Qs mhwd        7s root@manjaro-i3
local/bmenu 0.20-1
local/mhwd 0.6.5-28
Now mhwd might work as expected;
mhwd -li -l
/ > mhwd -li -l        root@manjaro-i3
          video-nvidia            2023.03.23               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
    video-nvidia-390xx            2023.03.23               false            PCI
Great. Now the dance for nvidia
sudo mhwd -i pci video-nvidia
/ > sudo mhwd -i pci video-nvidia
Warning: a version of config 'video-nvidia' is already installed!
Use -f/--force to force installation...
oops, missed the force flag :wink:
sudo mhwd -f -i pci video-nvidia
no worries.
/ > sudo mhwd -f -i pci video-nvidia
> Removing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: removing libxnvctrl breaks dependency 'libxnvctrl' required by conky
:: removing libxnvctrl breaks dependency 'libXNVCtrl.so=0-64' required by conky
Error: pacman failed!
Error: script failed!
I don’t remember using conky, so we can get rid of it. for now at least.
:frowning:
/ > sudo pacman -Rd conky        root@manjaro-i3
:: removing conky breaks dependency 'conky' required by conky-i3
/ > sudo pacman -Rd conky-i3        root@manjaro-i3
:: removing conky-i3 breaks dependency 'conky-i3' required by manjaro-i3-settings
2 d’s to skip all dependency checks.
Normally dont do this … but removing conky really cant hurt, and we can replace it in a moment.
sudo pacman -Rdd conky
I did remove conky, I did ‘sudo mhwd -f -i pci video-nvidia’ , it ran fine and then I rebooted.
Still the same, gets stuck at _
