I tried to boot normally, it doesn’t work. I run journalctl -b-1 -p4 --no-pager
again and I have a different output :
[manjaro /]# journalctl -b-1 -p4 --no-pager
Jan 19 18:34:48 xxx-hplaptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.BCM5], AE_NOT_FOUND (20220331/dswload2-162)
Jan 19 18:34:48 xxx-hplaptop kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20220331/psobject-220)
Jan 19 18:34:48 xxx-hplaptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP1.DEV0], AE_NOT_FOUND (20220331/dswload2-162)
Jan 19 18:34:48 xxx-hplaptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.WLBU._STA.WLVD], AE_NOT_FOUND (20220331/psargs-330)
Jan 19 18:34:48 xxx-hplaptop kernel: ACPI Error: Aborting method \_SB.WLBU._STA due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Jan 19 18:34:48 xxx-hplaptop kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Jan 19 18:34:48 xxx-hplaptop kernel: pci 0000:00:00.2: PCI INT A: not connected
Jan 19 18:34:48 xxx-hplaptop kernel: clocksource: timekeeping watchdog on CPU3: Marking clocksource 'tsc' as unstable because the skew is too large:
Jan 19 18:34:48 xxx-hplaptop kernel: clocksource: 'hpet' wd_nsec: 507153213 wd_now: 1bed1b1 wd_last: 150046a mask: ffffffff
Jan 19 18:34:48 xxx-hplaptop kernel: clocksource: 'tsc' cs_nsec: 506688127 cs_now: 8f4ff2fdf cs_last: 8b5a2b610 mask: ffffffffffffffff
Jan 19 18:34:48 xxx-hplaptop kernel: clocksource: 'tsc' is current clocksource.
Jan 19 18:34:48 xxx-hplaptop kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
Jan 19 18:34:48 xxx-hplaptop kernel: clocksource: Checking clocksource tsc synchronization from CPU 3 to CPUs 0,5.
lspci
output command :
[manjaro /]# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:01.5 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723DE 802.11b/g/n PCIe Adapter
04:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5410 (rev 01)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] (rev c2)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
05:00.7 Non-VGA unclassified device: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61)
For grub, no, grub is not shown during boot
so I can’t choose a different kernel…
