Hello developers.
As the title says there is some strange beep coming from motherboard (at least from inside the box of the PC).
The topic is similar to this one:
I have tried what they comment on that topic with the command echo -e "\a" but I hear no sound from motherboard, but it is true that I see nothing related to terminal bell in konsole neither in Yakuake.
In my case I only hear the sound when I press delete key if I am typing on the browse option (the lens) on the pamac gui (Add/Remove software) and there is nothing written on it.
For example, if I browse the package ink, when I type ink I hear no beep, If I press delete 3 times, I hear no beep either, if I press it more times I hear the beep on each press (it is as fast as my finger, doesn’t seem to have any cool-down).
I don’t think this should happen and I don’t think any software should interfere with the motherboard beeps, just the BIOS.
The beep is hard to describe. The boot beep is high pitched and penetrating, but the one I am experiencing is more like an error.
In this video, despite being continuous and being some error about something, the pitch is like the boot beep, this strange one is not like this.
https://www.reddit.com/r/pcmasterrace/comments/pp6coc/motherboard_makes_loud_beeping_sound_when/
Thanks in advance.
inxi -Aazy
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 1102:0012 class-ID: 0403
API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off tools: jack_control,qjackctl
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Maybe you see this post duplicated, I misclicked and delete my previous, sorry.
