Recently switched over to Manjaro KDE from Windows. So far very little problems but I’m running into a strange flickering and screen tearing problem in firefox and other 3rd party applications. I’ve installed the latest prime hybrid drivers and updated kernel and all other applications. Is this a common problem with older GTX series NVIDIA cards on MSI laptops? How can I fix this problem?
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=a5ed1c83-424d-4a0c-8d1a-f23b2ed0b263 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GF63 8RD v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16R1 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16R1IMS.108 date: 09/13/2018
ID-1: BAT1 charge: 48.7 Wh (97.8%) condition: 49.8/51.3 Wh (97.1%)
volts: 12.8 min: 11.4 model: MSI Corp. MS-16R1 type: Li-ion serial: N/A
status: Unknown
RAM: total: 15.48 GiB used: 3.46 GiB (22.3%)
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Max-Q] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8f class-ID: 0302
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-2 res: 1920x1080 hz: 60 dpi: 55 size: 880x490mm (34.6x19.3")
diag: 1007mm (39.7")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 1969:10a1
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.82 TiB used: 505.99 GiB (27.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
type: HDD rpm: 7200 serial: <filter> rev: SDM1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba
model: External USB 3.0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 5438 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 24.38 GiB (2.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a5ed1c83-424d-4a0c-8d1a-f23b2ed0b263
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: ABF3-9183
ID-3: /run/media/shae/EXTERNALHDD raw-size: 931.5 GiB
size: 931.5 GiB (100.00%) used: 481.61 GiB (51.7%) fs: ntfs dev: /dev/sdb2
maj-min: 8:18 label: EXTERNALHDD uuid: 8AB0C2DCB0C2CDBF
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-4:2 info: Toshiba America Canvio Advance Disk type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0820 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 297 Uptime: 5h 29m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1269 lib: 387
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
