Sticky volume keys
Sometimes when I press the volume keys on my laptop (Lenovo ThinkPad 13s AMD G3) they just hold until I press another key. My volume keys work just fine on my Windows 10 partition, so this must be a linux, manjaro or kde issue.
I’ve looked at some solutions online but they seem to be laptop-specific and I haven’t found any solutions that work for me yet.
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=b6b0b3dd-ffd0-4234-b182-36de5a489779 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 mem_sleep_default=deep
    resume=UUID=6beb96de-655c-43c7-bbdd-eed553f5d74c
  Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: latte-dock
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 20YA v: ThinkBook 13s G3 ACN
    serial: <superuser required> Chassis: type: 10 v: ThinkBook 13s G3 ACN
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: GMCN21WW date: 04/07/2021
  ID-1: BAT0 charge: 51.6 Wh (99.6%) condition: 51.8/56.0 Wh (92.4%)
    volts: 17.3 min: 15.4 model: Celxpert L19C4PDD type: Li-poly
    serial: <filter> status: discharging cycles: 125
  RAM: total: 13.6 GiB used: 4.5 GiB (33.1%)
  RAM Report:
  Info: model: AMD Ryzen 7 5800U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000B
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1779 high: 3550 min/max: 1600/4505 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2183 2: 1397
    3: 2659 4: 1396 5: 1397 6: 1397 7: 2419 8: 1993 9: 1397 10: 1397 11: 1397
    12: 1446 13: 1452 14: 1554 15: 1444 16: 3550 bogomips: 60716
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling
  Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300
  Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:2
    chip-ID: 5986:212a class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x13b0 built: 2019
    res: 2560x1600 hz: 60 dpi: 227 gamma: 1.2 size: 286x178mm (11.26x7.01")
    diag: 337mm (13.3") ratio: 16:10 modes: max: 2560x1600 min: 640x480
  OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.32-1-MANJARO LLVM 13.0.1)
    v: 4.6 Mesa 21.3.8 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
  Report: rfkill ID: hci0 rfk-id: 23 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 68.17 GiB (14.3%)
    model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 21160001 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 255.8 GiB size: 250.79 GiB (98.04%)
    used: 66.29 GiB (26.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: b6b0b3dd-ffd0-4234-b182-36de5a489779
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 29.3 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM_DRV uuid: 0AC2-ACA7
  ID-1: swap-1 type: partition size: 23.44 GiB used: 1.86 GiB (7.9%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 6beb96de-655c-43c7-bbdd-eed553f5d74c
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 196.45 GiB fs: ntfs
    label: Windows-SSD uuid: 7E5EC42C5EC3DAD3
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: 3868C4DC68C49A50
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-4:2 info: Acer Integrated Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:212a
    class-ID: 0e02
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:23 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 04f3:0c4b class-ID: 0000
  Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 56.0 C mobo: 33.0 C
  Processes: 381 Uptime: 13d 7h 39m wakeups: 31951 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1483
  pacman: 1480 lib: 397 flatpak: 3 Shell: Zsh v: 5.8.1 running-in: terminator
  inxi: 3.3.15
I have the same issue on my intel thinkbook. I thought it was likely a Lenovo/HW issue, but as you’ve tested on win10, that doesn’t seem to be the case.
  Type: Laptop System: LENOVO product: 20V9 v: ThinkBook 13s G2 ITL
#xinput list
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ MSFT0001:00 04F3:3141 Touchpad            id=9    [slave  pointer  (2)]
⎜   ↳ MSFT0001:00 04F3:3141 Mouse               id=10   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Integrated Camera: Integrated C           id=8    [slave  keyboard (3)]
    ↳ Ideapad extra buttons                     id=11   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=12   [slave  keyboard (3)]
#xinput test 12
key release 36
key press   123
key release 123
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key release 122
key press   122
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   123
key release 123
key press   37
key press   54
^C
Hey, i have the same problem, inxi dump is down below.
also xev -event keyboard will change its output if the repeated key is interupted by a volume key.
The last 4 means a volume down key the 8 is for volume up and the 12 apears right after a key was sticky and then interupted. Also untill the the other volume key is pressed the 12 will still apear and only change back to the original value if the other key was pressed.
xev -event keyboard:
KeymapNotify event, serial 28, synthetic NO, window 0x0,
    keys:  49  0   0   0   0   0   0   0   0   0   0   0   0   0   0   4
           0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
    keys:  49  0   0   0   0   0   0   0   0   0   0   0   0   0   0   8
    keys:  49  0   0   0   0   0   0   0   0   0   0   0   0   0   0   12
inxi dump:
system:
  Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=d32b95ea-7d1b-4538-9fa5-7fdceef149c7 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Convertible System: LENOVO product: 82DE v: Yoga 9 15IMH5
    serial: <superuser required> Chassis: type: 31 v: Yoga 9 15IMH5
  Mobo: LENOVO model: Corvette v: SDK0R32862 WIN serial: <superuser required>
    UEFI: LENOVO v: EPCN29WW date: 09/14/2022
  ID-1: BAT0 charge: 26.8 Wh (43.6%) condition: 61.5/69.0 Wh (89.2%)
    volts: 15.1 min: 15.4 model: Sunwoda L18D4PF1 type: Li-poly serial: <filter>
    status: discharging cycles: 279
  RAM: total: 15.3 GiB used: 2.96 GiB (19.3%)
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
    driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
    built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1f95 class-ID: 0302
  Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2
    chip-ID: 5986:2115 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x096a built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics (CML GT2)
    direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-cnl
    alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:06c8 class-ID: 0401
  Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
    chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 953.87 GiB used: 126.45 GiB (13.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 3L1QEXF7 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 16.55 GiB (16.9%)
    fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: d32b95ea-7d1b-4538-9fa5-7fdceef149c7
    used: 28.7 MiB (11.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM_DRV uuid: E033-80BC
  ID-3: /run/media/Daten raw-size: 752.62 GiB size: 752.62 GiB (100.00%)
    used: 109.87 GiB (14.6%) fs: ntfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: Daten uuid: 0A406C97406C8B71
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 100 GiB fs: ntfs label: Windows
    uuid: AE323439323408BB
  ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: 447834B37834A618
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-8:2 info: Acer Integrated Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:2115
    class-ID: 0e02
  Device-2: 1-9:3 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00be
    class-ID: ff00 serial: <filter>
  Device-3: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  System Temperatures: cpu: 40.0 C pch: 36.0 C mobo: N/A
  Processes: 280 Uptime: 3h 22m wakeups: 3980 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1245 libs: 318 tools: pamac,yaourt pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
  inxi: 3.3.23
Hy again as a quick workaround one can assign a different button for volume up / down. For example one could use Numpad +(,-). On my NB i can Disable the hotkey function and then i can use the FN keys which seem to have no sticky problem.Thus I simply assigned f3 to volume up and f2 to volume down. In KDE this overwrites two things i didn’t use yet.
Im pretty sure that the problem atleast in my case is a driver thats not working properly…
Another workaround i think is nicer than using a different key is to use a udev rule.
Make a file 70-keyboard-fix.hwdb and place it in /lib/udev/hwdb.d/70-keyboard.hwdb
Content of file:
evdev:atkbd:dmi:*
 KEYBOARD_KEY_ae=!volumedown
 KEYBOARD_KEY_b0=!volumeup
The Keyboard keys should be the same in most cases. If not u need to check what the key code u get when u press the volume button. To do that simply use “evtest” which one might need to run with sudo.
If you are doing that you should get some output like this when pressing the volume key.
Event: time 1669304321.742435, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1669304321.742435, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1669304321.742435, -------------- SYN_REPORT ------------
Event: time 1669304321.742448, type 4 (EV_MSC), code 4 (MSC_SCAN), value b0
Event: time 1669304321.742448, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
the value for EV_MSC is the code after KEYBOARD_KEY.
Also evdev:atkbd:dmi:* is applying the fix for ALL keyboards. Since this might be bad in some cases (eg. if the keykode is not for vol changing) this might introduce some unwanted behavior.
Best wishes :slight_smile:
