Steinberg UR22 not recognised
Hi, I have a UR22 that used to work flawlessly with Manjaro, but now nothing is happening. It isn’t even recognised as a USB driver or a sound card.
the sound card is only blinking its led.
inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=c0d1f313-a4c3-49e7-984c-ed0c7e0d22ad rw quiet
    resume=UUID=a9099469-d026-4ac2-972a-13cfbb9f86e1
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: HP-Pavilion product: WC963AA-ABF p6355fr v: N/A
    serial: <superuser required> Chassis: Hewlett-Packard type: 3
  Mobo: MSI model: IONA v: 1.0 serial: <superuser required>
    BIOS: American Megatrends v: 5.11 date: 01/28/2010
  RAM: total: 5.72 GiB used: 3.11 GiB (54.4%)
  RAM Report:
  Info: model: Intel Core i3 530 bits: 64 type: MT MCP arch: Westmere
    gen: core 1 built: 2010-11 process: Intel 32nm family: 6 model-id: 0x25 (37)
    stepping: 2 microcode: 0x11
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1211 high: 1255 min/max: 1200/2933 scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1197 3: 1197
    4: 1255 bogomips: 23416
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu
    fxsr ht ibpb ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl
    nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc vme xtopology
    xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds
    status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Park [Mobility Radeon HD 5430]
    vendor: PC Partner / Sapphire Caicos driver: radeon v: kernel
    arch: TeraScale 2 process: TSMC 32-40nm built: 2009-15 pcie: gen: 2
    speed: 5 GT/s lanes: 16 ports: active: HDMI-A-1 off: DVI-I-1 empty: VGA-1
    bus-ID: 01:00.0 chip-ID: 1002:68e1 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
    loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: DVI-I-1 mapped: DVI-0 note: disabled
    model: ViewSonic VA1916wSERIES serial: <filter> built: 2009 res: N/A dpi: 89
    gamma: 1.2 size: 410x256mm (16.14x10.08") diag: 483mm (19") ratio: 16:10
    modes: max: 1440x900 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-0 pos: primary model: Acer G246HL
    serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel 5 Series/3400 Series High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:3b56 class-ID: 0403
  Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
    vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa68 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-2: JACK v: 1.9.21 running: yes
  Sound Server-4: PipeWire v: 0.3.54 running: yes
    vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: d800 bus-ID: 02:00.0
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: b400
    bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
  Local Storage: total: 1.82 TiB used: 556.34 GiB (29.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EADS-65M2B1 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 0A01
    scheme: MBR
  Optical-1: /dev/sr0 vendor: hp model: DVD-RAM GH40L rev: RB0E
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 922.71 GiB size: 907.15 GiB (98.31%)
    used: 555.8 GiB (61.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: c0d1f313-a4c3-49e7-984c-ed0c7e0d22ad
  ID-1: swap-1 type: partition size: 8.8 GiB used: 555.6 MiB (6.2%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: a9099469-d026-4ac2-972a-13cfbb9f86e1
  ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs label: SYSTEM
    uuid: 4074DE7D74DE755E
  ID-2: /dev/sdb2 maj-min: 8:18 size: 918.76 GiB fs: ntfs label: HP
    uuid: F09ADA949ADA56A6
  ID-3: /dev/sdb4 maj-min: 8:20 size: 12.66 GiB fs: ntfs
    label: FACTORY_IMAGE uuid: 8E96F4F496F4DE21
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.5:3 info: Cherry GmbH Corded Device type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 046a:c098 class-ID: 0300
  Device-2: 2-1.6:4 info: Sunplus Innovation Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
  Device-3: 2-1.7:5 info: Realtek Mass Storage Device (Multicard Reader)
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 0bda:0151 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 48.0 C mobo: 35.5 C gpu: radeon temp: 84.5 C
  Fan Speeds (RPM): cpu: 967 fan-2: 1116 fan-3: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.30
  Processes: 222 Uptime: 2h 8m wakeups: 0 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
  Packages: pacman: 1734 lib: 499 flatpak: 0 Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.19
sudo dmesg | grep usb
[    0.346436] usbcore: registered new interface driver usbfs
[    0.346436] usbcore: registered new interface driver hub
[    0.346436] usbcore: registered new device driver usb
[    0.479877] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    0.479882] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.479885] usb usb1: Product: EHCI Host Controller
[    0.479887] usb usb1: Manufacturer: Linux 5.15.60-1-MANJARO ehci_hcd
[    0.479890] usb usb1: SerialNumber: 0000:00:1a.0
[    0.499832] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    0.499836] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.499839] usb usb2: Product: EHCI Host Controller
[    0.499841] usb usb2: Manufacturer: Linux 5.15.60-1-MANJARO ehci_hcd
[    0.499843] usb usb2: SerialNumber: 0000:00:1d.0
[    0.500419] usbcore: registered new interface driver usbserial_generic
[    0.500426] usbserial: USB Serial support registered for generic
[    0.729788] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    0.749787] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    0.876807] usb 1-1: New USB device found, idVendor=8087, idProduct=0020, bcdDevice= 0.00
[    0.876814] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    0.896974] usb 2-1: New USB device found, idVendor=8087, idProduct=0020, bcdDevice= 0.00
[    0.896982] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.183785] usb 2-1.5: new low-speed USB device number 3 using ehci-pci
[    1.303698] usb 2-1.5: New USB device found, idVendor=046a, idProduct=c098, bcdDevice= 3.03
[    1.303705] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.303709] usb 2-1.5: Product: CHERRY Corded Device
[    1.303712] usb 2-1.5: Manufacturer: Cherry GmbH
[    1.378551] usb 2-1.6: new low-speed USB device number 4 using ehci-pci
[    1.480563] usb 2-1.6: New USB device found, idVendor=1bcf, idProduct=0005, bcdDevice= 0.14
[    1.480571] usb 2-1.6: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    1.480575] usb 2-1.6: Product: USB Optical Mouse
[    1.555220] usb 2-1.7: new high-speed USB device number 5 using ehci-pci
[    1.671459] usb 2-1.7: New USB device found, idVendor=0bda, idProduct=0151, bcdDevice=51.95
[    1.671466] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.671470] usb 2-1.7: Product: USB2.0-CRW
[    1.671472] usb 2-1.7: Manufacturer: Generic
[    1.671474] usb 2-1.7: SerialNumber: 20060413092100000
[    2.861910] usb-storage 2-1.7:1.0: USB Mass Storage device detected
[    2.862461] scsi host6: usb-storage 2-1.7:1.0
[    2.862567] usbcore: registered new interface driver usb-storage
[    2.868102] usbcore: registered new interface driver uas
[    2.870826] input: Cherry GmbH CHERRY Corded Device as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:046A:C098.0001/input/input2
[    2.925481] hid-generic 0003:046A:C098.0001: input,hidraw0: USB HID v1.11 Keyboard [Cherry GmbH CHERRY Corded Device] on usb-0000:00:1d.0-1.5/input0
[    2.934092] input: Cherry GmbH CHERRY Corded Device as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:046A:C098.0002/input/input3
[    2.988837] hid-generic 0003:046A:C098.0002: input,hidraw1: USB HID v1.11 Device [Cherry GmbH CHERRY Corded Device] on usb-0000:00:1d.0-1.5/input1
[    2.991980] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/0003:1BCF:0005.0003/input/input4
[    2.992243] hid-generic 0003:1BCF:0005.0003: input,hidraw2: USB HID v1.10 Mouse [USB Optical Mouse] on usb-0000:00:1d.0-1.6/input0
[    2.992285] usbcore: registered new interface driver usbhid
[    2.992287] usbhid: USB HID core driver
if someone has an idea to how to solve the issue. thanks
Hi @dr_fuzz_muff,
Please see
hi, thanks for your answer
I updated my post
When the interface was working, was the blinking LED always on to show that the USB connection was good ?
If so, try using other available USB sockets on front or rear of system and try a different USB cable
Well, I’m big idiot, either the cable was dead or the USB plug is no good (but it works with other devices).
Could the soundcard be associated with a USB port ?
A USB audio interface should be detected in any USB port, but may not work optimally if it has to share a USB connection with other devices
Considering there are 3 devices detected sharing USB hub 2 (Cherry keyboard, Sunplus mouse and Realtek card reader) you should try to use a USB socket connected to hub 1 with audio interface
sudo echo "options snd slots=snd_usb_audio" > /etc/modprobe.d/alsa-base.conf
