zepar
7 June 2021 18:08
1
the latest steam beta update needed lib32-pipewire to start, which, if you used the steam-native client wouldnt work because the packages werent on manjaro yet, but it continued to work on the default steam version which included its own runtime.
this update added the lib32-pipewire libraries, which in theory should allow steam-native to work again on the latest steam-beta, but it still doesnt. here is the entire terminal output, trying to start steam-native
steam-runtime continues to work without issue. i dont know how much this is manjaros fault and how much it is steams fault
Have you tried the vanilla steam-runtime, part of the default Manjaro installation, I notice you’re using the steam-native with public-beta opt-in.
[spongebob@krabby-patty ~]$ steam-runtime
Running Steam on manjarolinux 21.0.6 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/spongebob/.local/share/Steam/ubuntu12_32/steam
[2021-06-07 21:28:07] Startup - updater built May 19 2021 01:53:57
Installing breakpad exception handler for appid(steam)/version(1621394999)
[2021-06-07 21:28:07] Loading cached metrics from disk (/home/spongebob/.local/share/Steam/package/steam_client_metrics.bin)
[2021-06-07 21:28:07] Using the following download hosts for Public, Realm steamglobal
[2021-06-07 21:28:07] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-06-07 21:28:07] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-06-07 21:28:07] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-06-07 21:28:07] Verifying installation...
[2021-06-07 21:28:07] Verification complete
Loaded SDL version 2.0.15-6501165
If it’s an issue with the native version then upstream will be the best place to report
PS
straight from Arch: Warning: Using the Steam native runtime is not recommended as it might break some games due to binary incompatibility and it might miss some libraries present in the Steam runtime.
Same here. I can’t launch steam-native.
https://pastebin.com/XDEXebz5
Does this mean we just have to reinstall lib32-pipewire to fix it?
zepar:
steam-runtime worked for me. What to do if this is not recommended?
See:
opened 08:27PM - 25 May 21 UTC
Steam client
#### Your system information
* Steam client version (build number or date):
* Distribution (e.g. Ubuntu): Arch
* Opted into Steam client beta?: Yes
* Have you checked for system updates?: Yes
#### Please describe your issue in as much detail as possible:
Steam does not start up when opting in to beta. Opting out by removing `~/.steam/steam/package/beta` works fine though.
When issue #7807 was raised, I simply installed `lib32-pipewire` from AUR, but since today the Beta seems to be completly broken now. I already uninstalled `lib32-pipewire` again but it resulted in no change to the current issue.
Output:
Running Steam on arch rolling 64-bit
Pins up-to-date!
/opt/games/Steam/ubuntu12_32/steam
[2021-05-25 21:38:35] Startup - updater built May 24 2021 21:28:03
[2021-05-25 21:38:35] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1621893676)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2021-05-25 21:38:35] Loading cached metrics from disk (/opt/games/Steam/package/steam_client_metrics.bin)
[2021-05-25 21:38:35] Using the following download hosts for Public, Realm steamglobal
[2021-05-25 21:38:35] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-05-25 21:38:35] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-05-25 21:38:35] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-05-25 21:38:35] Checking for update on startup
[2021-05-25 21:38:35] Checking for available updates...
[2021-05-25 21:38:35] Downloading manifest: https://cdn.cloudflare.steamstatic.com/client/steam_client_publicbeta_ubuntu12
[2021-05-25 21:38:36] Download skipped by HTTP 304 Not Modified
[2021-05-25 21:38:36] Nothing to do
[2021-05-25 21:38:36] Verifying installation...
[2021-05-25 21:38:36] Performing checksum verification of executable files
[2021-05-25 21:38:36] Verification complete
(steam:4349): Gtk-WARNING **: 21:38:37.107: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Adwaita-dark/gtk-2.0/main.rc:733: error: unexpected identifier 'direction', expected character '}'
(steam:4349): Gtk-WARNING **: 21:38:37.108: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Adwaita-dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
Steam: An X Error occurred
X Error of failed request: BadAtom (invalid Atom parameter)
Major opcode of failed request: 20 (X_GetProperty)
Atom id in failed request: 0x0
Serial number of failed request: 12
xerror_handler: X failed, continuing
Serial number of failed request: 13
Serial number of failed request: 14
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[0525/213837.314203:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0525/213837.342064:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0525/213837.342103:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1621891665
[0525/213837.342108:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0525/213837.342114:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
/usr/lib/gio/modules/libdconfsettings.so: undefined symbol: g_log_structured_standard
Failed to load module: /usr/lib/gio/modules/libdconfsettings.so
GLib-GIO-Message: Using the 'memory' GSettings backend. Your settings will not be saved or shared with other applications.
[0525/213837.369284:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0525/213837.369322:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1621891665
[0525/213837.369329:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0525/213837.369333:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0525/213837.369696:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0525/213837.438210:ERROR:sandbox_linux.cc(372)] InitializeSandbox() called with multiple threads in process gpu-process.
[0525/213837.473047:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0525/213837.473092:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1621891665
[0525/213837.473095:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0525/213837.473101:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0525/213837.473470:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CApplicationManagerPopulateThread took 327 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
CAppInfoCacheReadFromDiskThread took 650 milliseconds to initialize
Proceed to auto login
src/public/tier1/utlmemory.h (176) : Assertion Failed: 0
assert_20210525213838_21.dmp[4602]: Uploading dump (out-of-process)
/tmp/dumps/assert_20210525213838_21.dmp
assert_20210525213835_1.dmp[4607]: Uploading dump (out-of-process)
/tmp/dumps/assert_20210525213835_1.dmp
/opt/games/Steam/steam.sh: Zeile 772: 4349 Speicherzugriffsfehler (Speicherabzug geschrieben) $STEAM_DEBUGGER $DEBUGGER_ARGS "$STEAMROOT/$STEAMEXEPATH" "$@"
Finished uploading minidump (out-of-process): success = yes
assert_20210525213838_21.dmp[4602]: response: CrashID=bp-9f9e3c64-6b54-47f2-9646-d05162210525
assert_20210525213838_21.dmp[4602]: file ''/tmp/dumps/assert_20210525213838_21.dmp'', upload yes: ''CrashID=bp-9f9e3c64-6b54-47f2-9646-d05162210525''
assert_20210525213835_1.dmp[4607]: Finished uploading minidump (out-of-process): success = yes
assert_20210525213835_1.dmp[4607]: response: CrashID=bp-534dd4ca-1602-469d-ad51-299082210525
assert_20210525213835_1.dmp[4607]: file ''/tmp/dumps/assert_20210525213835_1.dmp'', upload yes: ''CrashID=bp-534dd4ca-1602-469d-ad51-299082210525''
And:
FS#71092 - [steam-native-runtime] Steam hangs at login
EDIT: Fixed with steam-native 1.0.0.70-2 in unstable.
Thought I might mention that ‘steam-native’ broke after it self updated the past 3 days.
Error in Terminal:
Installing breakpad exception handler for appid(steam)/version(1623193086)
[2021-06-10 22:01:04] Verifying installation...
[2021-06-10 22:01:04] Verification complete
Failed to load steamui.so - dlerror(): libpipewire-0.3.so.0: cannot open shared object file: No such file or directory
[2021-06-10 22:01:09] Shutdown
You don’t need to install ’ libpipewire-0.3.so.0’, because steam-native will lockup when attempting to login.
You can use steam-runtime to launch steam.
Alternatively some people have removed ‘steam-native’ and replaced it with steam flatpak version
https://flathub.org/apps/details/com.valvesoftware.Steam
(I have not tested this yet) .
Source:
Steam client
Output:
Pins up-to-date!
opened 04:39PM - 09 Jun 21 UTC
* Steam Runtime Version: 0.20210518.3
* Distrib… ution (e.g. Ubuntu 18.04): any
* Link to your full system information: n/a
* Have you checked for system updates?: yes
* Are you using the Steam Linux Runtime compatibility tool?: no
Help -> System Information should check whether `libpipewire-0.3.so.0` is present and can be loaded. At the moment it does not.
#### Steps for reproducing this issue:
~/.steam/root/ubuntu12_32/steam-runtime/setup.sh
~/.steam/root/ubuntu12_32/steam-runtime/run.sh steam-runtime-system-info --verbose > srsi.txt
should print something like this, and the equivalent for x86_64, among other information:
"libpipewire-0.3.so.0" : {
"soname" : "libpipewire-0.3.so.0",
"path" : ".../steam-runtime/usr/lib/i386-linux-gnu/libpipewire-0.3.so.0"
#### Workaround
echo "libpipewire-0.3.so.0 libpipewire-0.3-0 #MINVER#" > ~/.steam/root/ubuntu12_32/steam-runtime/usr/lib/steamrt/expectations/x86_64-linux-gnu/libpipewire-0.3-0.symbols
echo "libpipewire-0.3.so.0 libpipewire-0.3-0 #MINVER#" > ~/.steam/root/ubuntu12_32/steam-runtime/usr/lib/steamrt/expectations/i386-linux-gnu/libpipewire-0.3-0.symbols
NixOS:master ← Artturin:update-steam
opened 12:50AM - 08 Jun 21 UTC
To help with the large amounts of pull requests, we would appreciate your
reviews of other pull requests, especially simple package updates. Just leave a
comment describing what you have tested in the relevant package/service.
Reviewing helps to reduce the average time-to-merge for everyone.
Thanks a lot if you do!
List of open PRs: https://github.com/NixOS/nixpkgs/pulls
Reviewing guidelines: https://nixos.org/manual/nixpkgs/unstable/#chap-reviewing-contributions
###### Motivation for this change
Closes #124308
###### Things done
- [x] Tested using sandboxing ([nix.useSandbox](https://nixos.org/nixos/manual/options.html#opt-nix.useSandbox) on NixOS, or option `sandbox` in [`nix.conf`](https://nixos.org/nix/manual/#sec-conf-file) on non-NixOS linux)
- Built on platform(s)
- [x] NixOS
- [ ] macOS
- [ ] other Linux distributions
- [ ] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [ ] Tested compilation of all pkgs that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review wip"`
- [x] Tested execution of all binary files (usually in `./result/bin/`)
- [21.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/.github/CONTRIBUTING.md#generating-2111-release-notes)
- [ ] (Package updates) Added a release notes entry if the change is major or breaking
- [ ] (Module updates) Added a release notes entry if the change is significant
- [ ] (Module addition) Added a release notes entry if adding a new NixOS module
- [x] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/.github/CONTRIBUTING.md).
opened 07:09PM - 24 May 21 UTC
closed 10:52PM - 24 May 21 UTC
Steam client
runtime
* Distribution (e.g. Ubuntu): Ubuntu 20.04
* Opted into Steam client beta?: [Yes/No] y
* Have you checked for system updates?: [Yes/No] y
You are missing the following 32-bit libraries, and Steam may not run:
And then: Failed to load steamui.so
Not sure if I’m the only one with this issue. Steam runtime works just fine and even launches the native client, but launching directly from the native app causes steam to hang at the connecting to account window.
You’re a little late to the party. See above.
blau
13 June 2021 18:48
11
will this fix stay in unstable? I was wondering if this will also be released in stable or if I have to use unstable for steam-native from now on
No, it will arrive in the other branches like all other software does. See:
Try this:
pacman -Qs nvidia
I tried it and found I had nVidia 4.38 as well as 4.65 installed. Removed the old drivers, rebooted, and Steam started right up and hasn’t crashed. Found this on Reddit.
Is it going to take long ?
You’ll see it in the next stable update. It’s now in the testing branch:
All right. I had Steam running, and it was downloading Vulkan shaders and crashed. It would not start.
I ended up renaming the ~/.steam folder and deleting everything in ~/.local/share/Steam except for the steamapps folder. It reinstalled and ran. Apparently something hinky in the .steam folder.
Note that if you do delete .steam, you’ll need to log in again.
Is it possible to fast-track changes such as this so they get deployed without the need for a new stable update? From what I can tell, this impacts a lot of people.
In this case it’s not that simple as lib32-libnm replaced lib32-libnm-glib which are both synced from Arch.
If you’re brave, you could install the packages manually:
lib32-libnm
steam-native
