Steam is not starts and not working
After update steam is not working
My distro - Manjaro KDE
My CPU i5-10300H
My GPU nvidia 1650
Drivers prime
output:
((steam:11505): Gtk-WARNING **: 21:05:02.840: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe6757db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe6756500
ComputeStartupMode: found registry default startup mode: 0Installing breakpad exception handler for appid(steam)/version(1671236931)
steamwebhelper.sh[11528]: Runtime for steamwebhelper: defaulting to /home/alexbespik/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[11528]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 47 milliseconds to initialize
src/vstdlib/strtools.cpp (252) : n == 0 || s1 != NULL
assert_20230110210503_21.dmp[11668]: Uploading dump (out-of-process)
/tmp/dumps/assert_20230110210503_21.dmp
assert_20230110210503_21.dmp[11668]: Finished uploading minidump (out-of-process): success = yes
assert_20230110210503_21.dmp[11668]: response: CrashID=bp-8f9eb90a-cdb2-48da-bfe9-38bd92230110
assert_20230110210503_21.dmp[11668]: file ''/tmp/dumps/assert_20230110210503_21.dmp'', upload yes: ''CrashID=bp-8f9eb90a-cdb2-48da-bfe9-38bd92230110''
/home/alexbespik/.local/share/Steam/steam.sh: line 798: 11505 Segmentation fault      (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
    ~  s        )
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
can you report
inxi -Fza
sudo mhwd-kernel -li
sudo mhwd -li
steam --reset
:question:
not worked i need to reboot after it?
Installed PCI configs:
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
When I paste the result of first command, forum tells me that my post including links
Currently running: 5.15.85-1-MANJARO (linux515)
  • linux515
 sudo mhwd -li         ✔  10s 
When I paste the result of first command, forum tells me that my post including links.
Its working thanks!
:arrow_down:
    ~  steam         ✔
steam.sh[16688]: Running Steam on manjarolinux 22.0.0 64-bit
steam.sh[16688]: STEAM_RUNTIME is enabled automatically
setup.sh[16762]: Steam runtime environment up-to-date!
steam.sh[16688]: Steam client's requirements are satisfied
[2023-01-11 00:50:59] Startup - updater built Dec 15 2022 21:26:49
[2023-01-11 00:50:59] Startup - Steam Client launched with: '/home/lucy/.local/share/Steam/ubuntu12_32/steam'
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2023-01-11 00:50:59] Loading cached metrics from disk (/home/lucy/.local/share/Steam/package/steam_client_metrics.bin)
[2023-01-11 00:50:59] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2023-01-11 00:50:59] Using the following download hosts for Public, Realm steamglobal
[2023-01-11 00:50:59] 1. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-01-11 00:50:59] Checking for update on startup
[2023-01-11 00:50:59] Checking for available updates...
[2023-01-11 00:50:59] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
[2023-01-11 00:50:59] Manifest download: send request
[2023-01-11 00:50:59] Manifest download: waiting for download to finish
[2023-01-11 00:50:59] Manifest download: finished
[2023-01-11 00:50:59] Download skipped: /client/steam_client_ubuntu12 version 1671236931, installed version 1671236931, existing pending version 0
[2023-01-11 00:50:59] Nothing to do
[2023-01-11 00:50:59] Verifying installation...
[2023-01-11 00:50:59] Performing checksum verification of executable files
[2023-01-11 00:51:00] Verification complete
Loaded SDL version 2.27.0-p7692409
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf3c87db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf3c86500
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:16822): Gtk-WARNING **: 00:51:00.826: Im Modulpfad »adwaita« konnte keine Themen-Engine gefunden werden,
steamwebhelper.sh[16831]: Runtime for steamwebhelper: defaulting to /home/lucy/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[16831]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
assert_20230111005101_23.dmp[16932]: Uploading dump (out-of-process)
/tmp/dumps/assert_20230111005101_23.dmp
/home/lucy/.local/share/Steam/steam.sh: Zeile 798: 16822 Speicherzugriffsfehler  (Speicherabzug geschrieben) "$STEAMROOT/$STEAMEXEPATH" "$@"
    ~  assert_20230111005101_23.dmp[16932]: Finished uploading minidump (out-of-process): success = yes         ✔  4s 
assert_20230111005101_23.dmp[16932]: response: CrashID=bp-bc9c9f11-d066-4704-8b08-b17a32230110
assert_20230111005101_23.dmp[16932]: file ''/tmp/dumps/assert_20230111005101_23.dmp'', upload yes: ''CrashID=bp-bc9c9f11-d066-4704-8b08-b17a32230110''
Same issue here but command steam --reset not working for me,
got everytime the same console output
Kernel is 6.1.1-1
For me to it helps me only for one day
Steam doesn’t work on my computer, I used command steam restore. It helps, but after some time steam doesn’t work, and I ask you help me
OS-Linux
Distro-Manjaro
CPU-Intel i510300H
GPU-Nvidia gtx 1650
Steam output:
[2023-01-11 22:54:00] Loading cached metrics from disk (/home/alexbespik/.local/share/Steam/package/steam_client_metrics.bin)
[2023-01-11 22:54:00] Using the following download hosts for Public, Realm steamglobal
[2023-01-11 22:54:00] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-01-11 22:54:00] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-01-11 22:54:00] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-01-11 22:54:00] Checking for update on startup
[2023-01-11 22:54:00] Checking for available updates...
[2023-01-11 22:54:00] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-01-11 22:54:00] Manifest download: send request
[2023-01-11 22:54:01] Manifest download: waiting for download to finish
[2023-01-11 22:54:01] Manifest download: finished
[2023-01-11 22:54:01] Download skipped: /steam_client_ubuntu12 version 1671236931, installed version 1671236931, existing pending version 0
[2023-01-11 22:54:01] Nothing to do
[2023-01-11 22:54:01] Verifying installation...
[2023-01-11 22:54:01] Performing checksum verification of executable files
[2023-01-11 22:54:02] Verification complete
(steam:97257): Gtk-WARNING **: 22:54:02.346: Unable to locate theme engine in module_path: "adwaita",
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe5a74db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe5a73500
steamwebhelper.sh[97279]: Runtime for steamwebhelper: defaulting to /home/alexbespik/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[97279]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 45 milliseconds to initialize
assert_20230111225403_21.dmp[97417]: Uploading dump (out-of-process)
/tmp/dumps/assert_20230111225403_21.dmp
assert_20230111225403_21.dmp[97417]: Finished uploading minidump (out-of-process): success = yes
assert_20230111225403_21.dmp[97417]: response: CrashID=bp-59b62cc7-8abe-41ba-8523-5a1a02230111
assert_20230111225403_21.dmp[97417]: file ''/tmp/dumps/assert_20230111225403_21.dmp'', upload yes: ''CrashID=bp-59b62cc7-8abe-41ba-8523-5a1a02230111''
/home/alexbespik/.local/share/Steam/steam.sh: line 798: 97257 Segmentation fault      (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
You have openrgb ?
Kill openrgb and start steam
kill: illegal pid: openrgb
Maybe no in the past I tried to install open RGB, but it’s not worked :frowning:
Please do not create duplicate topics.
Please see:
