Go to the package manager, and reinstall MHWD you just broke it by uninstalling its required system packages.
From beginning I told you to use the graphical interface (Manjaro Setting Manager apparently on XFCE) for Kernal and Video drivers, if you had read and followed to the letter you would be fine since long time. I followed along as you wanted to use terminal but let go the easy way if youāre not confident.
So reinstall mhwd and maybe mhwd-db to repair MHWD, then use the graphical interface to remove, and install the hybrid drivers. // EDIT: not the package manager, but the tool specifically made to manage video drivers, Manjaro Settings Manager ā Hardware.
My manjaro settings manager shows video-nvidia-450xx is installed. There is no option there to install hybrid drivers. only to uninstall/reinstall
on reinstall:
Starting
Honestly I donāt know what you did (for sure you not doing as said as here again I see you install the RT (Real Time) kernel when I told you to install the LTS kernel), you broke some things by removing some packages. If this is a fresh install I would say stop wasting time to troubleshoot and fix the installation, download current ISO, and reinstall properly, then update, reboot, and go to the Manjaro Settings Manager and see the situation. Stop removing things youāre not 100% sure you should remove also. And important, read carefully what people tell you because not only mine, but sawdoctor message you replied by ignoring half of his message.
I have never used lutris before. This rig was working before the format on steam. I tried my best to read what I was told, but then had to search most of how to do what I was told to do it. I am a noob Im sorry. Iāll just reformat with the latest manjaro download and if I canāt get it back to where it was Iāll just give up and go back to windows so I donāt waste anyones time.
If the thread is still open reply back when you have a fresh system reinstalled. No problem you learn from the mistakes you make, it is just frustrating when youāre telling ādo thisā and people ādo thatā and then you have issue piling up because user also does things on his own without telling.
