Steam doesn't start, says trouble connecting to steam servers
Hello there, since I updated the system yesterday my steam keeps saying that I have no internet when I clearly do, I tried some things from ArchWiki - Steam/Troubleshooting but it still doesn’t work, also tried seeing if something was blocking it but nothing came to mind since I didn’t change anything and it worked yesterday.
Steam output:
Running Steam on manjarolinux 20.2.1 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
/home/tract/.local/share/Steam/ubuntu12_32/steam
[2021-02-13 13:12:13] Startup - updater built Oct 28 2020 23:34:22
Installing breakpad exception handler for appid(steam)/version(1612493737)
[2021-02-13 13:12:13] Loading cached metrics from disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 13:12:13] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-02-13 13:12:13] Using the following download hosts for Public, Realm steamglobal
[2021-02-13 13:12:13] 1. http://client-download.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'baked in'
[2021-02-13 13:12:13] 2. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-02-13 13:12:13] Verifying installation...
[2021-02-13 13:12:13] BVerifyInstalledFiles: steam.sh is 21462 bytes, expected 21871
[2021-02-13 13:12:13] BVerifyInstalledFiles: ubuntu12_32/steam is 4846248 bytes, expected 4784831
[2021-02-13 13:12:13] Verification complete
[2021-02-13 13:12:13] Downloading update...
[2021-02-13 13:12:13] Checking for available updates...
[2021-02-13 13:12:13] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 13:12:14] Download failed: http error 0 (client-download.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 13:12:14] Downloading manifest: media.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 13:12:14] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 13:12:14] DownloadManifest - exhausted list of download hosts
[2021-02-13 13:12:14] failed to load manifest from buffer.
[2021-02-13 13:12:14] Failed to load manifest
[2021-02-13 13:12:14] Error: Download failed: http error 0
[2021-02-13 13:12:14] Saving metrics to disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 13:12:14] BRepairInstalledFiles: ignoring bootstrap file ubuntu12_32/steam
[2021-02-13 13:12:14] BRepairInstalledFiles: ignoring bootstrap file steam.sh
Loaded SDL version 2.0.15-6352068
(steam:14599): Gtk-WARNING **: 13:12:14.558: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Gruvbox-Material-Dark/gtk-2.0/main.rc:790: error: unexpected identifier 'direction', expected character '}'
(steam:14599): Gtk-WARNING **: 13:12:14.560: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Gruvbox-Material-Dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[0213/131215.225038:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0213/131215.247400:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/131215.247444:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/131215.247449:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/131215.247455:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/131215.280867:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/131215.280917:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/131215.280921:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/131215.280925:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/131215.281374:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
[0213/131215.617929:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/131215.617975:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/131215.617996:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/131215.618000:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/131215.618540:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CApplicationManagerPopulateThread took 273 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Found no supported CDM versions, using last known good version 4.10.1440.19
Proceed to auto login
No cached credentials
[2021-02-13 13:12:16] Error: Failed to determine download location for universe 1
src/clientdll/cminterface.cpp (2861) : Assertion Failed: m_VecNetAdrNetFilterCMs.Count() > 0
assert_20210213131225_19.dmp[14703]: Uploading dump (out-of-process)
/tmp/dumps/assert_20210213131225_19.dmp
assert_20210213131225_19.dmp[14703]: Finished uploading minidump (out-of-process): success = no
assert_20210213131225_19.dmp[14703]: error: Couldn't resolve host name
assert_20210213131225_19.dmp[14703]: file ''/tmp/dumps/assert_20210213131225_19.dmp'', upload no: ''Couldn't resolve host name''
LogonFailure 3
LogonFailure 3
Exiting workitem thread
[2021-02-13 13:12:36] Shutdown
I would appreciate any help and I will provide anything needed.
Thank you in advance.
Hi and welcome to the forum :wave:
Before you get all the same tips and solutions, can you specify what you have tried?
Hi @Tractor,
Could you please provide the output of
ping -c 4 8.8.8.8
as well as
ping -c 4 google.com
and
traceroute steampowered.com
I don’t know if it’s causing the problem, but it does seem that there is some kind of DNS resolution problem.
Hello, I tried:
Steam fails to start correctly: steam-runtime --reset
Also the Missing libc because it said something about that which it doesn’t say anymore so I assume it fixed it.
Thanks.
Hello here are the outputs:
tract in ~ ❯ ping -c 4 8.8.8.8        13:44:49
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=119 time=55.3 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=119 time=25.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=119 time=45.0 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=119 time=36.0 ms
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 25.559/40.466/55.331/10.989 ms
tract in ~ ❯ ping -c 4 google.com        ✘ INT  13:47:23
PING google.com (172.217.19.206) 56(84) bytes of data.
64 bytes from ams16s31-in-f14.1e100.net (172.217.19.206): icmp_seq=1 ttl=116 time=42.4 ms
64 bytes from ams16s31-in-f14.1e100.net (172.217.19.206): icmp_seq=2 ttl=116 time=47.7 ms
64 bytes from ams16s31-in-f14.1e100.net (172.217.19.206): icmp_seq=3 ttl=116 time=57.5 ms
64 bytes from ams16s31-in-f14.1e100.net (172.217.19.206): icmp_seq=4 ttl=116 time=49.9 ms
--- google.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 42.419/49.378/57.524/5.427 ms
tract in ~ ❯ traceroute steampowered.com        13:47:48
traceroute to steampowered.com (2.17.182.211), 30 hops max, 60 byte packets
 1  _gateway (192.168.1.1)  0.637 ms  0.876 ms  1.136 ms
 2  * * *
 3  172.29.16.97 (172.29.16.97)  20.706 ms  20.941 ms  21.476 ms
 4  gte01-hdr11-3.ip.t-com.hr (195.29.3.194)  21.161 ms gte01-hdr11-2.ip.t-com.hr (195.29.240.94)  21.431 ms gte01-hdr11-3.ip.t-com.hr (195.29.3.194)  21.694 ms
 5  zgb-b1-link.telia.net (62.115.183.214)  30.383 ms  30.621 ms  30.934 ms
 6  zgb-b2-link.ip.twelve99.net (62.115.122.173)  42.163 ms  47.370 ms  46.960 ms
 7  win-bb3-link.ip.twelve99.net (62.115.122.174)  57.401 ms win-bb4-link.ip.twelve99.net (62.115.122.176)  54.361 ms win-bb3-link.ip.twelve99.net (62.115.122.174)  58.024 ms
 8  ffm-bb2-link.ip.twelve99.net (62.115.138.22)  55.013 ms  56.135 ms ffm-bb1-link.ip.twelve99.net (62.115.137.202)  58.702 ms
 9  ffm-b11-link.ip.twelve99.net (62.115.124.119)  56.386 ms  56.360 ms ffm-b11-link.ip.twelve99.net (62.115.124.117)  59.653 ms
10  akamai-ic-341387-ffm-b1.c.telia.net (62.115.169.187)  151.046 ms  151.030 ms  149.583 ms
11  ae2.r02.fra03.icn.netarch.akamai.com (23.210.54.40)  136.131 ms  151.053 ms  150.641 ms
12  ae2.r01.fra01.ien.netarch.akamai.com (23.223.60.39)  151.673 ms  149.204 ms  152.027 ms
13  ae4.decix-fra5.netarch.akamai.com (23.223.60.129)  132.041 ms  129.142 ms  128.660 ms
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
Thanks.
A thing to try:
Rename your ~/.steam/ folder to something other then ~/.steam/ and see if that fixes it. If that fixes it there is something corrupt in there. Trash the old folder and start again. steam will download all your stuff. There might be some save files there? careful with trashing if you miss something.
Thank you.
Seeing as these all seem fine and doesn’t have a problem, it would seem your steam client is for some reason not able to utilize your internet connection. Questions to ask now:
  • Did it work?
  • Did something change?
  • If so, then what?
The reason I’m asking, is to me it looks like a proxy server was suddenly configured for steam, and it can’t use that.
I don’t really know any more than what I’ve just mentioned, but that is what it looks like to me, from here.
I just tried it, it created another .steam folder but it’s still giving me the same message. Picture of message included.
imgur
.com/a/Wk9WwJ2
(I can’t post links or embed images, most likely because it’s a new account)
Also the output:
Repairing installation, linking /home/tract/.steam/steam to /home/tract/.local/share/Steam
Pins up-to-date!
[2021-02-13 13:59:53] Startup - updater built Oct 28 2020 23:34:22
[2021-02-13 13:59:53] Loading cached metrics from disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 13:59:53] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-02-13 13:59:53] Using the following download hosts for Public, Realm steamglobal
[2021-02-13 13:59:53] 1. http://client-download.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'baked in'
[2021-02-13 13:59:53] 2. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-02-13 13:59:53] Verifying installation...
[2021-02-13 13:59:53] BVerifyInstalledFiles: steam.sh is 21462 bytes, expected 21871
[2021-02-13 13:59:53] BVerifyInstalledFiles: ubuntu12_32/steam is 4846248 bytes, expected 4784831
[2021-02-13 13:59:53] Verification complete
[2021-02-13 13:59:53] Downloading update...
[2021-02-13 13:59:53] Checking for available updates...
[2021-02-13 13:59:53] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 13:59:53] Download failed: http error 0 (client-download.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 13:59:53] Downloading manifest: media.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 13:59:54] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 13:59:54] DownloadManifest - exhausted list of download hosts
[2021-02-13 13:59:54] failed to load manifest from buffer.
[2021-02-13 13:59:54] Failed to load manifest
[2021-02-13 13:59:54] Error: Download failed: http error 0
[2021-02-13 13:59:54] Saving metrics to disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 13:59:54] BRepairInstalledFiles: ignoring bootstrap file ubuntu12_32/steam
[2021-02-13 13:59:54] BRepairInstalledFiles: ignoring bootstrap file steam.sh
(steam:26853): Gtk-WARNING **: 13:59:54.349: Unable to locate theme engine in module_path: "adwaita",
(steam:26853): Gtk-WARNING **: 13:59:54.350: Unable to locate theme engine in module_path: "adwaita",
[0213/135955.184181:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0213/135955.209027:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/135955.209142:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/135955.209153:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/135955.209160:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/135955.250102:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/135955.250161:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/135955.250166:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/135955.250170:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/135955.250762:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0213/135955.670621:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/135955.670668:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/135955.670672:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/135955.670676:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/135955.671148:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CApplicationManagerPopulateThread took 422 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
[2021-02-13 13:59:56] Error: Failed to determine download location for universe 1
assert_20210213140006_19.dmp[26976]: Uploading dump (out-of-process)
/tmp/dumps/assert_20210213140006_19.dmp
assert_20210213140006_19.dmp[26976]: Finished uploading minidump (out-of-process): success = no
assert_20210213140006_19.dmp[26976]: error: Couldn't resolve host name
assert_20210213140006_19.dmp[26976]: file ''/tmp/dumps/assert_20210213140006_19.dmp'', upload no: ''Couldn't resolve host name''
LogonFailure 3
LogonFailure 3
LogonFailure 3
LogonFailure 3
[2021-02-13 14:01:50] Shutdown
Edit: Just realised that in the first line of the log the folder for steam is in ~/.local/share/Steam
I renamed that folder and got this output:
tract in ~ ❯ steam        14:01:51
Setting up Steam content in /home/tract/.local/share/Steam
Pins potentially out-of-date, rebuilding...
Can't find 'steam-runtime-check-requirements', continuing anyway
[2021-02-13 14:06:03] Startup - updater built Oct 28 2020 23:34:22
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
Installing breakpad exception handler for appid(steam)/version(0)
[2021-02-13 14:06:03] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-02-13 14:06:03] Using the following download hosts for Public, Realm steamglobal
[2021-02-13 14:06:03] 1. http://client-download.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'baked in'
[2021-02-13 14:06:03] 2. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
Installing breakpad exception handler for appid(steam)/version(1.0)
[2021-02-13 14:06:03] Verifying installation...
[2021-02-13 14:06:03] Unable to read and verify install manifest /home/tract/.local/share/Steam/package/steam_client_ubuntu12.installed
[2021-02-13 14:06:03] Verification complete
[2021-02-13 14:06:03] Downloading Update...
[2021-02-13 14:06:03] Checking for available update...
[2021-02-13 14:06:03] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:06:03] Download failed: http error 0 (client-download.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:06:03] Downloading manifest: media.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:06:03] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:06:03] DownloadManifest - exhausted list of download hosts
[2021-02-13 14:06:03] failed to load manifest from buffer.
[2021-02-13 14:06:03] Failed to load manifest
[2021-02-13 14:06:03] Error: Download failed: http error 0
[2021-02-13 14:06:03] Saving metrics to disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 14:06:03] Error: Steam needs to be online to update.	Please confirm your network connection and try again.
Did it work?
A: It worked before (yesterday) but now it’s just saying that I have no internet.
A: I updated the system yesterday with sudo pacman -Syu
If so, then what?
A: Most likely either steam or it’s dependency updated which broke it, still don’t know what or why.
Hmm, reinstall steam perhaps?
You are not alone: Steam not starting at all - #10 by Blyaticon
This might be a solution: https://www.gamingonlinux.com/forum/topic/4641/post_id=30320
Hi, so I did:
try completely removing steam-runtime dir from the same folder in ~/.steam/steam/ubuntu12_32 and in ~/.local/share/Steam/ubuntu12_32
steam --reset
and launching again.
from the second link and also after that reinstalled steam with sudo pacman -S steam and it still doesn’t work, also I’ve tried reinstalling the nvidia driver and the 32 bit version of it but I still get:
tract in ~ ❯ steam        14:21:32
Forced use of runtime version for 32-bit libdbus-1.so.3. Host: 3.19.13 Runtime: 3.5.8
Found newer runtime version for 32-bit libGLU.so.1. Host: 1.3.1 Runtime: 1.3.8004
Forced use of runtime version for 32-bit libcurl.so.4. Host: 4.7.0 Runtime: 4.2.0
Found newer runtime version for 32-bit libjack.so.0. Host: 0.0.28 Runtime: 0.1.0
Found newer runtime version for 64-bit libGLU.so.1. Host: 1.3.1 Runtime: 1.3.8004
Found newer runtime version for 64-bit libdbusmenu-glib.so.4. Host: 4.0.12 Runtime: 4.0.13
Forced use of runtime version for 64-bit libcurl.so.4. Host: 4.7.0 Runtime: 4.2.0
Found newer runtime version for 64-bit libjack.so.0. Host: 0.0.28 Runtime: 0.1.0
[2021-02-13 14:21:54] Startup - updater built Oct 28 2020 23:34:22
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2021-02-13 14:21:55] Loading cached metrics from disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 14:21:55] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-02-13 14:21:55] Using the following download hosts for Public, Realm steamglobal
[2021-02-13 14:21:55] 1. http://client-download.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'baked in'
[2021-02-13 14:21:55] 2. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-02-13 14:21:55] Checking for update on startup
[2021-02-13 14:21:55] Checking for available updates...
[2021-02-13 14:21:55] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:21:55] Download failed: http error 0 (client-download.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:21:55] Downloading manifest: media.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:21:55] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:21:55] DownloadManifest - exhausted list of download hosts
[2021-02-13 14:21:55] failed to load manifest from buffer.
[2021-02-13 14:21:55] Failed to load manifest
[2021-02-13 14:21:55] Error: Download failed: http error 0
[2021-02-13 14:21:55] Saving metrics to disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 14:21:55] Error: Failed to determine download location for universe 1
[2021-02-13 14:21:55] Verifying installation...
[2021-02-13 14:21:55] Performing checksum verification of executable files
[2021-02-13 14:21:55] BVerifyInstalledFiles: bad CRC on linux32/steamerrorreporter (fae3f1bc expected, 237916c3 actual)
[2021-02-13 14:21:55] BVerifyInstalledFiles: steam.sh is 21462 bytes, expected 21871
[2021-02-13 14:21:55] BVerifyInstalledFiles: ubuntu12_32/steam is 4846248 bytes, expected 4784831
[2021-02-13 14:21:56] Verification complete
[2021-02-13 14:21:56] Downloading update...
[2021-02-13 14:21:56] Checking for available updates...
[2021-02-13 14:21:56] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:21:56] Download failed: http error 0 (client-download.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:21:56] Downloading manifest: media.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:21:56] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:21:56] DownloadManifest - exhausted list of download hosts
[2021-02-13 14:21:56] failed to load manifest from buffer.
[2021-02-13 14:21:56] Failed to load manifest
[2021-02-13 14:21:56] Error: Download failed: http error 0
[2021-02-13 14:21:56] Saving metrics to disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-13 14:21:56] BRepairInstalledFiles: ignoring bootstrap file ubuntu12_32/steam
[2021-02-13 14:21:56] BRepairInstalledFiles: ignoring bootstrap file steam.sh
(steam:69223): Gtk-WARNING **: 14:22:02.361: Unable to locate theme engine in module_path: "adwaita",
(steam:69223): Gtk-WARNING **: 14:22:02.362: Unable to locate theme engine in module_path: "adwaita",
[0213/142202.996122:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0213/142203.018410:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/142203.018467:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/142203.018471:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/142203.018475:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/142203.050614:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/142203.050660:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/142203.050664:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/142203.050668:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/142203.051110:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0213/142203.404841:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/142203.404883:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1612491850
[0213/142203.404887:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/142203.404892:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/142203.405340:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CApplicationManagerPopulateThread took 1574 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
[2021-02-13 14:22:05] Error: Failed to determine download location for universe 1
LogonFailure 3
LogonFailure 3
LogonFailure 3
LogonFailure 3
LogonFailure 3
LogonFailure 3
[2021-02-13 14:27:05] Error: Failed to determine download location for universe 1
[2021-02-13 14:27:17] Background update loop checking for update. . .
[2021-02-13 14:27:17] Downloading manifest: client-download.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:27:17] Download failed: http error 0 (client-download.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:27:17] Downloading manifest: media.steampowered.com/client/steam_client_ubuntu12
[2021-02-13 14:27:17] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-02-13 14:27:17] DownloadManifest - exhausted list of download hosts
[2021-02-13 14:27:17] failed to load manifest from buffer.
[2021-02-13 14:27:17] Failed to load manifest
[2021-02-13 14:27:17] Error: Download failed: http error 0
[2021-02-13 14:27:17] Saving metrics to disk (/home/tract/.local/share/Steam/package/steam_client_metrics.bin)
LogonFailure 85
[2021-02-13 14:32:05] Error: Failed to determine download location for universe 1
[2021-02-13 14:37:05] Error: Failed to determine download location for universe 1
[2021-02-13 14:42:05] Error: Failed to determine download location for universe 1
[2021-02-13 14:47:05] Error: Failed to determine download location for universe 1
[2021-02-13 14:52:05] Error: Failed to determine download location for universe 1
[2021-02-13 14:57:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:02:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:07:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:12:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:17:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:22:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:27:05] Error: Failed to determine download location for universe 1
[2021-02-13 15:32:06] Error: Failed to determine download location for universe 1
[2021-02-13 15:37:06] Error: Failed to determine download location for universe 1
[2021-02-13 15:42:06] Error: Failed to determine download location for universe 1
LogonFailure 3
[2021-02-13 15:43:47] Shutdown
Since steam complains that the error is from client-download.steampowered.com I tried putting it in two ‘is it down’ type of websites and both of them say that it is down so it seems that it’s valve’s fault but that still doesn’t make sense because wouldn’t there be more people with this issue then?
Is maybe the link it’s trying to reach wrong?
What happens when you manualy paste this in a browser:
http://client-download.steampowered.com/client/steam_client_ubuntu12
on my side it downloads a manifest, lets peal the union where it go’s wrong
It downloads the manifest for me as well.
At least in the browser.
Comparing your startup to mine I also see
After witch the client starts so I assume it has nothing to do with drivers or libraries.
Maybe there is some DNS issue as @Mirdarthos mentioned, or a steam/akamai problem.
Those can be hard to solve since you can’t do anything about that. The DNS resolves to a few servers, yours might differ depending on your location.
;; ANSWER SECTION:
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.228
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.233
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.232
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.226
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.231
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.229
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.227
origin-ip-selector.steampipe.steamcontent.akadns.net. 29 IN A 205.196.6.230
Give your DNS server/internet router a reboot if you have access to it?
Do you have a DNS resolver running locally or a pihole running of some kind?
Hi, so I do have the same servers that the DNS resolves to, same IP adresses.
I’ve tried pinging all of the addresses and none of them returned anything, 100% packet loss to them.
I don’t have any pihole, and I didn’t touch any DNS settings anywhere so every part of my network should be on default including my pc.
The router I’ve restarted and steam still says no internet.
Another thing to try: make a new user, log in with that user, start steam to check if it is something of the user or the system.
I changed to a new account and it also didn’t work, it didn’t even give me a popup to enter my email and password. It just showed a popup with steam saying that a connection can’t be made.
Here’s the log from other user:
Pins up-to-date!
/home/NVMeData/Steam/ubuntu12_32/steam
[2021-02-13 16:58:41] Startup - updater built Oct 28 2020 23:34:22
/tmp/dumps is not owned by us - delete and recreate
Unable to delete /tmp/dumps. Continuing anyway.
Installing breakpad exception handler for appid(steam)/version(1603992987)
[2021-02-13 16:58:41] Loading cached metrics from disk (/home/NVMeData/Steam/package/steam_client_metrics.bin)
[2021-02-13 16:58:41] Using the following download hosts for Public, Realm steamglobal
[2021-02-13 16:58:41] 1. http://media4.steampowered.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-02-13 16:58:41] Verifying installation...
[2021-02-13 16:58:41] Verification complete
Loaded SDL version 2.0.13-6142881
(steam:147434): Gtk-WARNING **: 16:58:42.159: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Dracula-Pink-Slim/gtk-2.0/main.rc:727: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Dracula-Pink-Slim/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
/usr/share/themes/Dracula-Pink-Slim/gtk-2.0/apps/xfce.rc:77: error: invalid string constant "entry", expected valid string constant
[0213/165842.458992:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0213/165842.477203:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/165842.477248:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1603928085
[0213/165842.477251:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/165842.477254:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
/usr/lib/gio/modules/libdconfsettings.so: undefined symbol: g_log_structured_standard
Failed to load module: /usr/lib/gio/modules/libdconfsettings.so
GLib-GIO-Message: Using the 'memory' GSettings backend.  Your settings will not be saved or shared with other applications.
[0213/165842.545762:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/165842.545807:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1603928085
[0213/165842.545811:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/165842.545814:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/165842.546299:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0213/165842.648606:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0213/165842.648653:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1603928085
[0213/165842.648656:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0213/165842.648659:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0213/165842.649130:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CApplicationManagerPopulateThread took 0 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Warning: failed to set thread priority: set failed for 8: -1: setpriority() failed
Warning: failed to set thread priority: set failed for priority 8
Warning: support for elevated priorities is most likely unavailable, suppressing future warnings
CAppInfoCacheReadFromDiskThread took 122 milliseconds to initialize
** (steam:147434): WARNING **: 16:58:43.003: Unknown device type 13
** (steam:147434): WARNING **: 16:58:43.003: Could not create object for /org/freedesktop/NetworkManager/Devices/3: unknown object type
** (steam:147434): WARNING **: 16:58:43.003: handle_property_changed: failed to update property 'devices' of object type NMActiveConnection.
** (steam:147434): WARNING **: 16:58:43.004: Unknown device type 14
** (steam:147434): WARNING **: 16:58:43.004: Could not create object for /org/freedesktop/NetworkManager/Devices/1: unknown object type
** (steam:147434): WARNING **: 16:58:43.004: Unknown device type 13
** (steam:147434): WARNING **: 16:58:43.004: Could not create object for /org/freedesktop/NetworkManager/Devices/3: unknown object type
Opted-in Controller Mask for AppId 0: 0
** (steam:147434): WARNING **: 16:58:43.371: Ignoring invalid property 'autoconnect-priority'
** (steam:147434): WARNING **: 16:58:43.371: Ignoring invalid property 'interface-name'
** (steam:147434): WARNING **: 16:58:43.371: Unknown setting 'proxy'
** (steam:147434): WARNING **: 16:58:43.371: Ignoring invalid property 'address-data'
** (steam:147434): WARNING **: 16:58:43.371: Ignoring invalid property 'route-data'
** (steam:147434): WARNING **: 16:58:43.371: Ignoring invalid property 'dns-priority'
** (steam:147434): WARNING **: 16:58:43.371: Unknown setting 'bridge'
** (steam:147434): WARNING **: 16:58:43.371: replace_settings: error updating connection /org/freedesktop/NetworkManager/Settings/3 settings: (3) type
(steam:147434): Gtk-WARNING **: 16:58:43.451: gtk_disable_setlocale() must be called before gtk_init()
LogonFailure 3
LogonFailure 3
[2021-02-13 16:58:50] Shutdown
I’m kinda out of solutions, you might have other issues besides steam since there are some weird things in the log, maybe a partial update or a package that conflicts
What does this give for output?
sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu
For reference this is my steam boot up:
Summary
Found newer runtime version for 32-bit libudev.so.0. Host: 0.0.9999 Runtime: 0.13.0
Found newer runtime version for 64-bit libudev.so.0. Host: 0.0.9999 Runtime: 0.13.0
Forced use of runtime version for 32-bit libdbusmenu-glib.so.4. Host: 4.0.12 Runtime: 4.0.13
Forced use of runtime version for 32-bit libdbusmenu-gtk.so.4. Host: 4.0.12 Runtime: 4.0.13
Forced use of runtime version for 32-bit libgtk-x11-2.0.so.0. Host: 0.2400.33 Runtime: 0.2400.10
Found newer runtime version for 64-bit libdbusmenu-gtk.so.4. Host: 4.0.12 Runtime: 4.0.13
/home/USER/.local/share/Steam/ubuntu12_32/steam
Hi, it could be something wrong with the packages but I wouldn’t know how to fix it.
Here is the output:
tract in ~ ❯ sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu        17:02:06
[sudo] password for root:
::INFO Branch in config is changed
::INFO Protocols in config is changed
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  1.445 Australia      : https://manjaro.lucassymons.net/
  ..... Australia      : https://mirror.aarnet.edu.au/pub/manjaro/
  1.924 Australia      : http://mirror.aarnet.edu.au/pub/manjaro/
  0.222 Austria        : http://mirror.inode.at/manjaro/
  0.373 Austria        : http://mirror.easyname.at/manjaro/
  0.707 Austria        : ftp://mirror.easyname.at/manjaro/
  1.179 Bangladesh     : http://mirror.xeonbd.com/manjaro/
  0.552 Belarus        : http://mirror.datacenter.by/pub/mirrors/manjaro/
  0.429 Belgium        : https://mirror.futureweb.be/manjaro/
  0.320 Belgium        : http://mirror.futureweb.be/manjaro/
  2.629 Brazil         : https://manjaro.c3sl.ufpr.br/
  ..... Brazil         : http://linorg.usp.br/manjaro/
  2.710 Brazil         : https://www.caco.ic.unicamp.br/manjaro/
  0.635 Bulgaria       : https://mirrors.netix.net/manjaro/
  0.546 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  0.475 Bulgaria       : http://manjaro.telecoms.bg/
  2.174 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  1.163 Canada         : https://osmirror.org/manjaro/
  ..... Chile          : http://manjaro.dcc.uchile.cl/
  3.504 Chile          : https://mirror.ufro.cl/manjaro/
  1.796 Chile          : https://mirror1.cl.netactuate.com/manjaro/
  1.598 Chile          : http://mirror1.cl.netactuate.com/manjaro/
  ..... Chile          : ftp://mirror1.cl.netactuate.com/manjaro/
  ..... China          : https://mirrors.huaweicloud.com/manjaro/
  ..... China          : http://mirrors.huaweicloud.com/manjaro/
  1.392 China          : https://mirrors.aliyun.com/manjaro/
  ..... China          : https://mirrors.ustc.edu.cn/manjaro/
  3.444 China          : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
  3.097 China          : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
  3.941 China          : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
  1.811 Costa_Rica     : https://mirrors.ucr.ac.cr/manjaro/
  1.434 Czech          : https://mirror.dkm.cz/manjaro/
  0.535 Denmark        : https://mirrors.dotsrc.org/manjaro/
  1.316 Denmark        : https://www.uex.dk/public/manjaro/
  0.628 France         : https://mirror.oldsql.cc/manjaro/
  0.503 France         : https://manjaro.mcofficer.me/
  0.423 France         : https://manjaro.ynh.ovh/
  0.680 France         : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.703 France         : ftp://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.733 France         : http://kibo.remi.lu/
  0.819 Georgia        : https://manjaro.grena.ge/
  0.549 Georgia        : http://manjaro.grena.ge/
  0.436 Germany        : https://mirror.alpix.eu/manjaro/
  0.407 Germany        : https://manjaro.re/
  0.269 Germany        : http://manjaro.re/
  0.454 Germany        : https://mirror.atysleaks.org/manjaro/
  0.420 Germany        : http://mirror.atysleaks.org/manjaro/
  0.356 Germany        : https://mirror.23media.com/manjaro/
  0.268 Germany        : http://mirror.23media.com/manjaro/
  0.437 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  0.845 Germany        : ftp://ftp.halifax.rwth-aachen.de/manjaro/
  0.529 Germany        : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.767 Germany        : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.477 Germany        : https://mirror.netcologne.de/manjaro/
  0.329 Germany        : https://manjaro.moson.eu/
  0.247 Germany        : http://manjaro.moson.eu/
  0.346 Germany        : https://manjaro.moson.org/
  0.252 Germany        : http://manjaro.moson.org/
  0.528 Greece         : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  0.398 Greece         : http://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  0.907 Greece         : ftp://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  1.764 Hong_Kong      : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/
  ..... Hong_Kong      : ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/
  0.557 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.328 Hungary        : http://quantum-mirror.hu/mirrors/pub/manjaro/
  0.661 Iceland        : https://mirrors.opensource.is/manjaro/
  0.790 Iceland        : http://mirrors.opensource.is/manjaro/
  ..... Iceland        : ftp://mirrors.opensource.is/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://mirrors.opensource.is/manjaro/'
  1.711 India          : https://mirrors.piconets.webwerks.in/manjaro-mirror/
  1.037 India          : http://mirrors.piconets.webwerks.in/manjaro-mirror/
  1.860 Indonesia      : https://mirror.deace.id/manjaro/
  1.250 Indonesia      : http://mirror.deace.id/manjaro/
  ..... Indonesia      : http://kartolo.sby.datautama.net.id/manjaro/
  1.022 Iran           : https://repo.iut.ac.ir/repo/manjaro/
  ..... Iran           : http://repo.iut.ac.ir/repo/manjaro/
  0.776 Italy          : https://manjaro.mirror.garr.it/manjaro/
  0.747 Italy          : https://ba.mirror.garr.it/mirrors/manjaro/
  0.725 Italy          : https://ct.mirror.garr.it/mirrors/manjaro/
  ..... Japan          : http://ftp.riken.jp/Linux/manjaro/
  ..... Japan          : ftp://ftp.riken.jp/Linux/manjaro/
::ERROR ftp error: timeout('timed out') 'ftp://ftp.riken.jp/Linux/manjaro/'
  ..... Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  1.860 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  1.254 Kenya          : http://manjaro.mirror.liquidtelecom.com/
  0.661 Netherlands    : https://manjaro.mirrors.lavatech.top/
  0.306 Netherlands    : http://manjaro.mirrors.lavatech.top/
  0.440 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.682 Netherlands    : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.356 Netherlands    : http://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.678 Netherlands    : ftp://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.422 Netherlands    : https://mirror.koddos.net/manjaro/
  ..... New_Zealand    : http://manjaro.mirrors.theom.nz/
  0.544 Norway         : http://mirror.terrahost.no/linux/manjaro/
  1.900 Pakistan       : https://repo.inara.pk/manjaro/
  1.128 Pakistan       : http://repo.inara.pk/manjaro/
  1.342 Philippines    : http://mirror.rise.ph/manjaro/
  ..... Philippines    : ftp://mirror.rise.ph/manjaro/
  0.528 Poland         : https://mirror.tuchola-dc.pl/manjaro/
  0.510 Poland         : http://ftp.vectranet.pl/manjaro/
  0.917 Poland         : ftp://ftp.vectranet.pl/manjaro/
  0.762 Portugal       : http://ftp.dei.uc.pt/pub/linux/manjaro/
  0.499 Russia         : https://mirror.yandex.ru/mirrors/manjaro/
  1.549 Russia         : https://mirror.truenetwork.ru/manjaro/
  0.682 Russia         : http://mirror.truenetwork.ru/manjaro/
  2.156 Singapore      : https://download.nus.edu.sg/mirror/manjaro/
  1.979 South_Africa   : http://mirror.is.co.za/mirrors/manjaro.org/
  ..... South_Africa   : http://manjaro.mirror.ac.za/
  2.187 South_Korea    : https://mirror.d-tl.com/manjaro/
  1.931 South_Korea    : https://mirror.krmir.org/manjaro/
  ..... South_Korea    : http://mirror.krmir.org/manjaro/
  ..... South_Korea    : ftp://mirror.krmir.org/manjaro/
  1.202 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  0.478 Spain          : http://ftp.caliu.cat/pub/distribucions/manjaro/
  1.596 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  0.936 Sweden         : ftp://ftp.lysator.liu.se/pub/manjaro/
  0.491 Sweden         : https://mirror.zetup.net/manjaro/
  0.451 Switzerland    : https://manjaro.osmir.ch/
  0.284 Switzerland    : http://manjaro.osmir.ch/
  0.381 Switzerland    : https://mirror.init7.net/manjaro/
  0.277 Switzerland    : http://mirror.init7.net/manjaro/
  ..... Taiwan         : http://free.nchc.org.tw/manjaro/
  0.416 Turkey         : http://ftp.linux.org.tr/manjaro/
  0.804 Turkey         : ftp://ftp.linux.org.tr/manjaro/
  1.113 Ukraine        : http://mirrors.colocall.net/manjaro/
  ..... Ukraine        : ftp://mirrors.colocall.net/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://mirrors.colocall.net/manjaro/'
  0.679 Ukraine        : https://fastmirror.pp.ua/manjaro/
  0.358 Ukraine        : http://fastmirror.pp.ua/manjaro/
  0.534 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
  0.663 United_Kingdom : https://uk.mirrors.fossho.st/manjaro/
  0.332 United_Kingdom : http://uk.mirrors.fossho.st/manjaro/
  1.518 United_States  : https://repo.ialab.dsu.edu/manjaro/
  1.137 United_States  : http://repo.ialab.dsu.edu/manjaro/
  0.980 United_States  : http://distro.ibiblio.org/manjaro/
  2.451 United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.956 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  1.117 United_States  : https://mirror.clarkson.edu/manjaro/
  1.184 United_States  : https://mirror.dacentec.com/manjaro/
  1.175 United_States  : https://mirrors.gigenet.com/manjaro/
  0.764 United_States  : http://mirrors.gigenet.com/manjaro/
  1.241 United_States  : https://us.mirrors.fossho.st/manjaro/
  1.023 United_States  : http://us.mirrors.fossho.st/manjaro/
  ..... Uruguay        : https://manjaro.repo.cure.edu.uy/
  1.657 Uruguay        : http://manjaro.repo.cure.edu.uy/
::INFO Writing mirror list
::Austria         : http://mirror.inode.at/manjaro/stable
::Germany         : https://manjaro.moson.eu/stable
::Germany         : https://manjaro.moson.org/stable
::Germany         : https://mirror.23media.com/manjaro/stable
::Germany         : https://manjaro.re/stable
::Switzerland     : https://mirror.init7.net/manjaro/stable
::Switzerland     : https://manjaro.osmir.ch/stable
::Netherlands     : https://manjaro.mirrors.lavatech.top/stable
::Belgium         : https://mirror.futureweb.be/manjaro/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::United_Kingdom  : https://uk.mirrors.fossho.st/manjaro/stable
::Ukraine         : https://fastmirror.pp.ua/manjaro/stable
::Germany         : https://mirror.atysleaks.org/manjaro/stable
::Netherlands     : https://mirror.koddos.net/manjaro/stable
::France          : https://manjaro.ynh.ovh/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::Bulgaria        : http://manjaro.telecoms.bg/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::Sweden          : https://mirror.zetup.net/manjaro/stable
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/stable
::France          : https://manjaro.mcofficer.me/stable
::Poland          : https://mirror.tuchola-dc.pl/manjaro/stable
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/stable
::Norway          : http://mirror.terrahost.no/linux/manjaro/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Georgia         : https://manjaro.grena.ge/stable
::Belarus         : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::France          : https://mirror.oldsql.cc/manjaro/stable
::Bulgaria        : https://mirrors.netix.net/manjaro/stable
::Netherlands     : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::Russia          : https://mirror.truenetwork.ru/manjaro/stable
::France          : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Austria         : http://mirror.easyname.at/manjaro/stable
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/stable
::France          : http://kibo.remi.lu/stable
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Portugal        : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::United_States   : https://mirrors.gigenet.com/manjaro/stable
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Italy           : https://manjaro.mirror.garr.it/manjaro/stable
::Turkey          : http://ftp.linux.org.tr/manjaro/stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Greece          : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::Poland          : http://ftp.vectranet.pl/manjaro/stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::United_States   : http://distro.ibiblio.org/manjaro/stable
::United_States   : https://us.mirrors.fossho.st/manjaro/stable
::India           : https://mirrors.piconets.webwerks.in/manjaro-mirror/stable
::United_States   : https://mirror.clarkson.edu/manjaro/stable
::Pakistan        : https://repo.inara.pk/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::Canada          : https://osmirror.org/manjaro/stable
::Bangladesh      : http://mirror.xeonbd.com/manjaro/stable
::United_States   : https://mirror.dacentec.com/manjaro/stable
::Indonesia       : https://mirror.deace.id/manjaro/stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/stable
::Denmark         : https://www.uex.dk/public/manjaro/stable
::China           : https://mirrors.aliyun.com/manjaro/stable
::Czech           : https://mirror.dkm.cz/manjaro/stable
::Australia       : https://manjaro.lucassymons.net/stable
::Uruguay         : https://manjaro.repo.cure.edu.uy/stable
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/stable
::Australia       : https://mirror.aarnet.edu.au/pub/manjaro/stable
::South_Africa    : http://mirror.is.co.za/mirrors/manjaro.org/stable
::China           : https://mirrors.huaweicloud.com/manjaro/stable
::South_Africa    : http://manjaro.mirror.ac.za/stable
::Singapore       : https://download.nus.edu.sg/mirror/manjaro/stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::South_Korea     : https://mirror.d-tl.com/manjaro/stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/stable
::Chile           : http://manjaro.dcc.uchile.cl/stable
::Iran            : https://repo.iut.ac.ir/repo/manjaro/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::Brazil          : https://www.caco.ic.unicamp.br/manjaro/stable
::Chile           : https://mirror1.cl.netactuate.com/manjaro/stable
::Philippines     : http://mirror.rise.ph/manjaro/stable
::China           : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::Brazil          : http://linorg.usp.br/manjaro/stable
::South_Korea     : https://mirror.krmir.org/manjaro/stable
::Chile           : https://mirror.ufro.cl/manjaro/stable
::New_Zealand     : http://manjaro.mirrors.theom.nz/stable
::Hong_Kong       : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Taiwan          : http://free.nchc.org.tw/manjaro/stable
::Indonesia       : http://kartolo.sby.datautama.net.id/manjaro/stable
::China           : https://mirrors.ustc.edu.cn/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core        167,2 KiB  1429 KiB/s 00:00 [##########################################################################################################] 100%
 extra        1983,7 KiB  1998 KiB/s 00:01 [##########################################################################################################] 100%
 community        6,5 MiB  1998 KiB/s 00:03 [##########################################################################################################] 100%
 multilib        181,3 KiB  2014 KiB/s 00:00 [##########################################################################################################] 100%
warning: gnome-wallpapers: local (20201023-1) is newer than community (20201020-1)
 there is nothing to do
