Steam crashes when idling for a while
I was downloading a game with steam in the background,
Spotify was also open.
I afk’ed for like 30 minutes, came back and saw
Steam was not running and had to relaunch it,
It happened like 3 times now.
Maybe the thing is automatic sleep/suspend, while steam does not forcibly keep awake?
(sorry - kind of difficult to test on this end)
Alright this time I launched steam from the terminal and yes it closed this time too here is the log seems like a crash
Running Steam on manjarolinux 21.1.6 64-bit
STEAM_RUNTIME is enabled automatically
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/k0mp1exd/.local/share/Steam/ubuntu12_32/steam
[2021-11-09 13:52:15] Startup - updater built Oct 13 2021 19:47:06
Installing breakpad exception handler for appid(steam)/version(1634158817)
[2021-11-09 13:52:16] Loading cached metrics from disk (/home/k0mp1exd/.local/share/Steam/package/steam_client_metrics.bin)
[2021-11-09 13:52:16] Using the following download hosts for Public, Realm steamglobal
[2021-11-09 13:52:16] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-11-09 13:52:16] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-11-09 13:52:16] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-11-09 13:52:16] Verifying installation...
[2021-11-09 13:52:16] Verification complete
Loaded SDL version 2.0.17-6744061
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:7680): Gtk-WARNING **: 13:52:16.598: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
Runtime for steamwebhelper: defaulting to /home/k0mp1exd/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
CAppInfoCacheReadFromDiskThread took 42 milliseconds to initialize
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
(steam:7680): Gtk-WARNING **: 13:52:20.534: gtk_disable_setlocale() must be called before gtk_init()
roaming config store loaded successfully - 495 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 9ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/k0mp1exd/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 9.62 seconds
BuildCompleteAppOverviewChange: 105
RegisterForAppOverview 1: 7ms
RegisterForAppOverview 2: 8ms
ExecuteSteamURL: "steam://open/downloads"
[730]Non-Steam Controller Configs Enabled: 1
DBG DBG 6 OTHER Steam Executable Crash
crash_20211109140919_41.dmp[8314]: Uploading dump (out-of-process)
/tmp/dumps/crash_20211109140919_41.dmp
crash_20211109140919_41.dmp[8314]: Finished uploading minidump (out-of-process): success = yes
crash_20211109140919_41.dmp[8314]: response: CrashID=bp-27d9fdd7-0162-4309-90de-c8dc72211109
crash_20211109140919_41.dmp[8314]: file ''/tmp/dumps/crash_20211109140919_41.dmp'', upload yes: ''CrashID=bp-27d9fdd7-0162-4309-90de-c8dc72211109''
/home/k0mp1exd/.local/share/Steam/steam.sh: line 785:  7680 Aborted                 (core dumped) $STEAM_DEBUGGER $DEBUGGER_ARGS "$STEAMROOT/$STEAMEXEPATH" "$@"
okey doke…
Well, if it isnt something as simple as ‘the app has a setting’ … then we should probably start here:
Ah here is the inxi
  Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=f6b9a400-1237-4409-9b76-fd380685ff37 rw quiet apparmor=1
  security=apparmor resume=UUID=50088973-fc7f-4489-9f95-6a0885543328
  udev.log_priority=3
  Console: pty pts/3 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
  base: Arch Linux
  Type: Laptop System: ASUSTeK product: P553UJ v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: P553UJ v: 1.0 serial: <filter> UEFI: ASUSTeK
  v: P553UJ.303 date: 01/25/2017
  ID-1: BAT0 charge: 41.2 Wh (99.3%) condition: 41.5/48.2 Wh (86.0%)
  volts: 14.4 min: 14.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Charging cycles: 69
  RAM: total: 3.73 GiB used: 1.71 GiB (45.8%)
  Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
  note: est.
  Device-1: ChannelA-DIMM0 size: No Module Installed
  Device-2: ChannelB-DIMM0 size: 4 GiB speed: 2133 MT/s type: DDR4
  detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
  part-no: M471A5244CB0-CRC serial: <filter>
  Info: Dual Core model: Intel Core i5-6200U socket: U3E1 bits: 64
  type: MT MCP arch: Skylake family: 6 model-id: 4E (78) stepping: 3
  microcode: EA cache: L1: 128 KiB L2: 3 MiB L3: 3 MiB bogomips: 19204
  Speed: 500 MHz min/max: 400/2800 MHz base/boost: 2200/8300 volts: 0.8 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: NVIDIA GK208BM [GeForce 920M] vendor: ASUSTeK driver: nvidia
  v: 390.144 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1299
  class-ID: 0302
  Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
  Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP-1-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d70 class-ID: 0403
  Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
  Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  vendor: ASUSTeK driver: r8169 v: kernel modules: r8168 port: d000
  bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: AzureWave driver: ath10k_pci v: kernel bus-ID: 03:00.0
  chip-ID: 168c:0042 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
  chip-ID: 13d3:3491 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 465.76 GiB used: 32.99 GiB (7.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS545050A7E680
  family: HGST Travelstar Z5K500 size: 465.76 GiB block-size: physical: 4096 B
  logical: 512 B sata: 2.6 speed: 6.0 Gb/s type: HDD rpm: 5400
  serial: <filter> rev: A3B0 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 225d 10h cycles: 1446
  Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XAA1
  dev-links: cdrom
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 14.28 GiB (14.6%)
  fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: Root
  uuid: f6b9a400-1237-4409-9b76-fd380685ff37
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
  used: 288 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda3 maj-min: 8:3
  label: BOOT uuid: 4D27-92E2
  ID-3: /home raw-size: 360.76 GiB size: 354.03 GiB (98.13%)
  used: 18.56 GiB (5.2%) fs: ext4 block-size: 4096 B dev: /dev/sda4
  maj-min: 8:4 label: Home uuid: de101f46-07e7-45b8-a052-7ffb0212020c
  ID-1: swap-1 type: partition size: 4 GiB used: 153.1 MiB (3.7%) priority: -2
  dev: /dev/sda1 maj-min: 8:1 label: Swap
  uuid: 50088973-fc7f-4489-9f95-6a0885543328
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:2 info: CASUE USB KB type: Keyboard,HID
  power: 100mA chip-ID: 2a7a:938f class-ID: 0300
  Device-2: 1-5:3 info: Chicony USB2.0 VGA UVC WebCam type: Video
  Device-3: 1-7:4 info: A4Tech 2.4G Wireless Mouse type: Mouse,Keyboard
  power: 100mA chip-ID: 09da:010e class-ID: 0301
  Device-4: 1-8:5 info: IMC Networks type: Bluetooth driver: btusb
  interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 13d3:3491
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 50 C
  Fan Speeds (RPM): cpu: 2600
  Processes: 223 Uptime: 3h 48m wakeups: 2 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1368
  pacman: 1361 lib: 392 flatpak: 0 snap: 7 Shell: Zsh (sudo) v: 5.8
  default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
So what now
I don’t know the exact solution, but that does not prevent me from Googling™
https://bbs.archlinux.org/viewtopic.php?id=242367
thanks I will read these and see if any of these fixes my issue
Ty alkl the The 1st Link , links to a Link which has the solution.
Basically you gotta delete Steam/steamapps/libraryfolders.vdf and Steam/config/config.vdf and steam now stopped crashing for me
