Static noise in microphone
I use a laptop and when I unplug the adapter the static noise increases in volume
the output of inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.2-1-rt19-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
  root=UUID=1879a9bc-9724-4229-90d7-11032c83cc4f rw quiet apparmor=1
  security=apparmor resume=UUID=932e7671-d655-4418-91d8-b989dbc91473
  udev.log_priority=3
  Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
  base: Arch Linux
  Type: Laptop System: ASUSTeK product: P553UJ v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: P553UJ v: 1.0 serial: <filter> UEFI: ASUSTeK
  v: P553UJ.305 date: 04/20/2019
  ID-1: BAT0 charge: 40.0 Wh (96.4%) condition: 41.5/48.2 Wh (86.0%)
  volts: 14.4 min: 14.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Not charging cycles: 70
  RAM: total: 3.73 GiB used: 1.73 GiB (46.4%)
  Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
  note: est.
  Device-1: ChannelA-DIMM0 size: No Module Installed
  Device-2: ChannelB-DIMM0 size: 4 GiB speed: 2133 MT/s type: DDR4
  detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
  part-no: M471A5244CB0-CRC serial: <filter>
  Info: Dual Core model: Intel Core i5-6200U socket: U3E1 bits: 64
  type: MT MCP arch: Skylake family: 6 model-id: 4E (78) stepping: 3
  microcode: EA cache: L1: 128 KiB L2: 3 MiB L3: 3 MiB bogomips: 19200
  Speed: 1900 MHz min/max: 400/2800 MHz base/boost: 2200/8300 volts: 0.8 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 1900 2: 1900 3: 2063 4: 1900
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: NVIDIA GK208BM [GeForce 920M] vendor: ASUSTeK driver: nvidia
  v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1299
  class-ID: 0302
  Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
  Display: server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP-1-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: NVIDIA GeForce 920M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.86
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d70 class-ID: 0403
  Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
  Sound Server-1: ALSA v: k5.15.2-1-rt19-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  vendor: ASUSTeK driver: r8169 v: kernel modules: r8168 port: d000
  bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: AzureWave driver: ath10k_pci v: kernel modules: wl bus-ID: 03:00.0
  chip-ID: 168c:0042 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
  chip-ID: 13d3:3491 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 465.76 GiB used: 50.55 GiB (10.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS545050A7E680
  family: HGST Travelstar Z5K500 size: 465.76 GiB block-size: physical: 4096 B
  logical: 512 B sata: 2.6 speed: 6.0 Gb/s type: HDD rpm: 5400
  serial: <filter> rev: A3B0 temp: 39 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 231d 1h cycles: 1492
  Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XAA1
  dev-links: cdrom
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 14.77 GiB (15.1%)
  fs: ext4 block-size: 4096 B dev: /dev/sda3 maj-min: 8:3 label: Root
  uuid: 1879a9bc-9724-4229-90d7-11032c83cc4f
  ID-2: /boot/efi raw-size: 512 MiB size: 510.9 MiB (99.80%)
  used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  label: BOOT uuid: F967-FA9D
  ID-3: /home raw-size: 361.26 GiB size: 354.52 GiB (98.13%)
  used: 35.78 GiB (10.1%) fs: ext4 block-size: 4096 B dev: /dev/sda4
  maj-min: 8:4 label: Home uuid: 3d3cf2b0-6ab4-496c-8fcb-0f4641335c5a
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda2 maj-min: 8:2 label: Swap
  uuid: 932e7671-d655-4418-91d8-b989dbc91473
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:2 info: CASUE USB KB type: Keyboard,HID
  power: 100mA chip-ID: 2a7a:938f class-ID: 0300
  Device-2: 1-5:3 info: Chicony USB2.0 VGA UVC WebCam type: Video
  Device-3: 1-7:4 info: A4Tech 2.4G Wireless Mouse type: Mouse,Keyboard
  power: 100mA chip-ID: 09da:010e class-ID: 0301
  Device-4: 1-8:5 info: IMC Networks type: Bluetooth driver: btusb
  interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 13d3:3491
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 62 C
  Fan Speeds (RPM): cpu: 3100
  Processes: 222 Uptime: 16m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1319 lib: 392 flatpak: 0
  Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8 running-in: yakuake
  inxi: 3.3.08
You should consider updating system BIOS
https://www.asus.com/us/supportonly/P553UJ/HelpDesk_BIOS/
System data shows 2 sound servers running
did
pamac install manjaro-pipewire
rebooted cause why not,
mic volume 47%
when the adapter is plugged in, the noise is not that loud and my voice can be heard quite clearly
when unplugged, the noise is very loud and my voice is barely audible.
alright updated bios and the output of inxi above
also did
systemctl --user disable --now pipewire.socket pipewire.service && systemctl --user mask pipewire.socket
on the live environment didn’t work
Since no more replies, here’s the solution I found
Echo Cancellation: PulseAudio - ArchWiki
Lower mic volume
