Hi,
I’m using stadia but due to lack of vp9 support it seems I can’t stream the games in 4k. I tryed several addons like stadia+ but they did not work either. Does someone have a proper solution how to get 4k resolution in manjaro with chrome?
Hi,
For 4K you’ll need the Stadia Pro version. Also make sure Hardware Video Accelleration is working in Chromium (the GPU needs to support decoding VP9).
Please post your system information:
I do have the pro version and can play in 4k with windows.
### Graphics Feature Status
* Canvas: Hardware accelerated
* Compositing: Hardware accelerated
* Multiple Raster Threads: Enabled
* Out-of-process Rasterization: Disabled
* OpenGL: Enabled
* Hardware Protected Video Decode: Unavailable
* Rasterization: Software only. Hardware acceleration disabled
* Skia Renderer: Enabled
* Video Decode: Software only. Hardware acceleration disabled
* Vulkan: Disabled
* WebGL: Hardware accelerated
* WebGL2: Hardware accelerated
is from chrome://gpu
and I use the nvidia driver:
filename: /lib/modules/5.8.18-1-MANJARO/extramodules/nvidia-drm.ko.gz
version: 455.45.01
and also original google chrome
Do you have libva-vdpau-driver-chromium package installed?
Please check these instructions in order to enable video hw accel:
https://wiki.archlinux.org/index.php/Chromium#Hardware_video_acceleration
Try chromium instead. That is working for me.
Again, please post your system information via inxi -Fazy
Also post output of vainfo
btw.: you also might want to install “Stadia Enhanced” chrome plugin. It’ll give you some more abilities to tweak streaming settings and show which codes, resolution, etc is used.
But first you should get hw accel running…
https://chrome.google.com/webstore/detail/stadia-enhanced/ldeakaihfnkjmelifgmbmjlphdfncbfg
I had not the libva-vdpau-driver-chromium installed. I added to my
│~/.config/chromium
└─> cat chromium-flags.conf
--ignore-gpu-blocklist
--enable-gpu-rasterization
--enable-zero-copy
Still got no hw decoding in chrome://gpu
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.8-x86_64
root=UUID=1431cec6-8e5c-4873-b9a9-d2d0265c34a2 rw
cryptdevice=UUID=d36082e7-c43a-4944-a6e3-6f856bb0ec08:cryptroot quiet
udev.log_priority=3
Desktop: MATE 1.24.1 info: mate-panel wm: marco 1.24.1 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: X470 GAMING PLUS (MS-7B79) v: 2.0
serial: <filter> UEFI: American Megatrends v: A.40 date: 06/28/2018
Info: 6-Core model: AMD Ryzen 5 2600X socket: AM4 bits: 64 type: MT MCP
arch: Zen+ family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D
L1 cache: 576 KiB L2 cache: 3072 KiB L3 cache: 15.6 MiB
bogomips: 86427
Speed: 1896 MHz min/max: 2200/3600 MHz base/boost: 3600/4250 boost: enabled
volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1925 2: 2299 3: 1890
4: 2147 5: 1810 6: 1808 7: 1817 8: 1812 9: 2172 10: 2192 11: 2171 12: 2174
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 1d:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.10 compositor: marco v: 1.24.1
driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x572mm (80.0x22.5")
s-diag: 2111mm (83.1")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 90 size: 544x303mm (21.4x11.9")
diag: 623mm (24.5")
Monitor-2: DP-1 res: 1920x1080 hz: 60 dpi: 34 size: 1440x810mm (56.7x31.9")
diag: 1652mm (65")
Monitor-3: DP-2 res: 3840x2160 hz: 60 dpi: 163 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 1d:00.1 chip ID: 10de:10f0
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 1f:00.3 chip ID: 1022:1457
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus ID: 1-13:3 chip ID: 046d:085c
serial: <filter>
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 18:00.0
chip ID: 10ec:8168
IF: enp24s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.55 TiB used: 309.90 GiB (6.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 1B2QEXE7 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD40EFRX-68N32N0
size: 3.64 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0A82 scheme: GPT
ID-1: / raw size: 931.01 GiB size: 915.40 GiB (98.32%)
used: 309.79 GiB (33.8%) fs: ext4 block size: 4096 B dev: /dev/dm-0
ID-2: /boot raw size: 512.0 MiB size: 511.0 MiB (99.80%)
used: 110.9 MiB (21.7%) fs: vfat block size: 512 B dev: /dev/nvme0n1p1
System Temperatures: cpu: 40.8 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Processes: 321 Uptime: 4m Memory: 15.65 GiB used: 1.42 GiB (9.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1484 lib: 430
flatpak: 0 Shell: Bash (su) v: 5.0.18 running in: mate-terminal inxi: 3.1.08
and
vainfo: VA-API version: 1.9 (libva 2.9.1)
vainfo: Driver version: Splitted-Desktop Systems VDPAU backend for VA-API - 0.7.4
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG4Simple : VAEntrypointVLD
VAProfileMPEG4AdvancedSimple : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264Main : VAEntrypointVLD
VAProfileH264High : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
You’ll need to install Chromium as Google Chrome isn’t built with support.
