Please start a new support thread, and supply your full system information with inxi -zv8 copy the output from the CLI and post it using the </> button in the editor menu.
The solution wipes all keys, so I had to re-add one that I have for a warp-terminal repository.
2 posts were split to a new topic: LUKS-related boot issue following {Stable Update} 2026-02-13
Installed some updates 2026-03-11 and all My DirectX games just instantly crashed.
Reinstalled some packets and after reboot everything is now working again.
I ran:
sudo pacman -S vulkan-icd-loader vulkan-tools
sudo pacman -S nvidia-utils lib32-nvidia-utils
sudo reboot
First time in pharhaps a full year I’ve had any issues updating my manjaro os.
Gj all even tho this was a inconvenience.
All went well, but it looks like I don’t have the normal cursors anymore.
When hovering over links in browsers, the mouse cursor should be the ‘pointing hand’ type (I checked to make sure this is on a div with css property cursor: pointer).
In Thunar, when waiting for something to load, this used to be a spinning circle. Now it’s a 90s style wristwatch icon (presumably a default fallback cursor).
Any ideas?
The name of the theme breeze was changed so you are falling bach to the default 90s style hardcoded mouse theme.
Go to the Settings and manually select some outher cursor theme.
That fixed it, thank you. (It’s worth noting that there are two places for themes. One is the XFCE configuration for light / dark colour schemes, which also includes a tab for icon sets, the other one is found under ‘mouse / touchpad’, it’s the latter theme that needs changing)
