[Stable Update] 2026-02-01 - Kernels, COSMIC, Plasma, GNOME, Mesa
Prior to this update my system would suspend fine, but now suspend results in systemd-sleep[51430]: Failed to freeze unit 'user.slice': Connection timed out error and the system failing to suspend. There was no such error prior to this update, but I’m at a loss as to which update would affect this since systemd itself wasn’t upgraded. Any ideas?
journalctl --since today | grep sleep
Feb 06 11:53:08 Muskox systemd-sleep[51379]: Failed to freeze unit 'user.slice': Connection timed out
Feb 06 11:53:08 Muskox systemd-sleep[51379]: Performing sleep operation 'suspend'...
Feb 06 11:53:49 Muskox systemd-sleep[51379]: Failed to put system to sleep. System resumed again: Device or resource busy
Feb 06 11:53:49 Muskox systemd-sleep[51379]: Successfully thawed unit 'user.slice'.
Feb 06 11:53:49 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] system is resuming
Feb 06 11:53:49 Muskox NetworkManager[588]: <info>  [1770341029.2105] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Feb 06 11:53:49 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] system is about to suspend
Feb 06 11:53:49 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
Feb 06 11:53:49 Muskox NetworkManager[588]: <info>  [1770341029.4145] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Feb 06 11:54:49 Muskox systemd-sleep[51430]: Failed to freeze unit 'user.slice': Connection timed out
Feb 06 11:54:49 Muskox systemd-sleep[51430]: Performing sleep operation 'suspend'...
Feb 06 11:55:30 Muskox systemd-sleep[51430]: Failed to put system to sleep. System resumed again: Device or resource busy
Feb 06 11:55:30 Muskox systemd-sleep[51430]: Successfully thawed unit 'user.slice'.
Feb 06 11:55:30 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] system is resuming
Feb 06 11:55:30 Muskox NetworkManager[588]: <info>  [1770341130.0565] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Feb 06 11:55:30 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] system is about to suspend
Feb 06 11:55:30 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
Feb 06 11:55:30 Muskox kwin_wayland[1240]: Failed to delay sleep: The operation inhibition has been requested for is already running
Feb 06 11:55:30 Muskox NetworkManager[588]: <info>  [1770341130.3226] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Feb 06 11:56:30 Muskox systemd-sleep[51467]: Failed to freeze unit 'user.slice': Connection timed out
Feb 06 11:56:30 Muskox systemd-sleep[51467]: Performing sleep operation 'suspend'...
Feb 06 11:57:11 Muskox systemd-sleep[51467]: Failed to put system to sleep. System resumed again: Device or resource busy
Feb 06 11:57:11 Muskox systemd-sleep[51467]: Successfully thawed unit 'user.slice'.
Feb 06 11:57:11 Muskox ModemManager[667]: <msg> [sleep-monitor-systemd] system is resuming
Feb 06 11:57:11 Muskox NetworkManager[588]: <info>  [1770341231.3101] manager: sleep: wake requested (sleeping: yes  enabled: yes)
inxi -zv8
  Kernel: 6.18.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=ca0fb9dc-ae10-46f2-a467-6c788f67cecc rw rootflags=subvol=@
    quiet splash resume=UUID=a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
    wm: kwin_wayland with: krunner vt: 2 dm: N/A Distro: Manjaro
    base: Arch Linux
  Type: Convertible System: Dell product: XPS 15 9575 v: N/A
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: Dell model: 0C32VW v: A00 serial: <superuser required> part-nu: 080D
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.28.0
    date: 07/11/2023
  ID-1: BAT0 charge: 44.4 Wh (100%) condition: 44.4/75 Wh (59.2%) volts: 12.47
    min: 11.4 model: BYD DELL TMFYT8C type: Li-poly serial: <filter> charging:
    status: full type: custom avail: adaptive,custom,fast,standard,trickle
    cycles: N/A
  System RAM: total: 16 GiB available: 15.46 GiB used: 11.04 GiB (71.4%)
  Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
  Device-1: Motherboard type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMAA51S6AMR6N-UH serial: N/A
  Info: model: Intel Core i7-8705G bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3000 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3000 2: 3000 3: 3000 4: 3000 5: 3000 6: 3000
    7: 3000 8: 3000 bogomips: 49599
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel Kaby Lake-H GT2 [HD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
    M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
    temp: 52.0 C
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 2560x1440
    hz: 60 scale: 125% (1.25) to: 2048x1152 dpi: 284 gamma: 1.2 chroma: red:
    x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
    x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 3840x2160
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:591b memory: 15.1 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.335 layers: 9 device: 0 type: integrated-gpu name: Intel
    HD Graphics 630 (KBL GT2) driver: mesa intel v: 25.3.4-arch1.1
    device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu name: AMD
    Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
    v: 25.3.4-arch1.1 device-ID: 1002:694e surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  API: ALSA v: k6.18.8-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
    class-ID: 0280 temp: 47.0 C
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u2u2 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0489:e0a2
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 81.26 GiB (4.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T710SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: PBCR5103 temp: 38.9 C
    scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 81.18 GiB (4.4%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
    uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
    used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: FF0B-6823
  ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
    used: 81.18 GiB (4.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Manjaro uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
  ID-4: /home/<filter>/mnt/Dropbox raw-size: N/A size: 2.01 TiB
    used: 338.45 GiB (16.4%) fs: fuse.rclone remote: Dropbox:
  ID-5: /home/<filter>/mnt/GDrive raw-size: N/A size: 102 GiB
    used: 24.06 GiB (23.6%) fs: fuse.rclone remote: GDrive:
  ID-6: /home/<filter>/mnt/OneDrive raw-size: N/A size: 205 GiB
    used: 143.2 GiB (69.9%) fs: fuse.rclone remote: OneDrive:
  ID-7: /var/cache raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-8: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-1: swap-1 type: partition size: 17.58 GiB used: 88.4 MiB (0.5%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
  Device-1: 1-1:2 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
    serial: <filter>
  Hub-2: 1-2:3 info: VIA Labs VL820 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
  Device-1: 1-2.1:6 info: Bizlink DELL DA300 type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 06c4:c412 class-ID: 0300
    serial: <filter>
  Device-2: 1-2.3:8 info: Lite-On USB Multimedia Keyboard type: keyboard,HID
    chip-ID: 04ca:0027 class-ID: 0300
  Device-3: 1-6:4 info: Foxconn / Hon Hai type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0489:e0a2 class-ID: e001
  Device-4: 1-10:5 info: Shenzhen Goodix Fingerprint Reader
    type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
    chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
  Device-5: 1-11:7 info: Logitech G502 Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07d class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-4: 2-2:2 info: VIA Labs VL820 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0820
  Device-1: 2-2.2:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1696 libs: 445 tools: pamac pm: flatpak pkgs: 0
    1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    3: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    4: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    5: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    6: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    7: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 322
  1: cpu: 7.3% command: librewolf pid: 2298 mem: 1933.8 MiB (12.2%)
  2: cpu: 5.7% command: librewolf pid: 2035 mem: 1190.2 MiB (7.5%)
  3: cpu: 3.3% command: librewolf pid: 2292 mem: 267.9 MiB (1.6%)
  4: cpu: 3.0% command: librewolf pid: 52142 mem: 470.5 MiB (2.9%)
  5: cpu: 2.4% command: kwin_wayland pid: 1240 mem: 285.1 MiB (1.8%)
  Memory top: 5 of 322
  1: mem: 1933.8 MiB (12.2%) command: librewolf pid: 2298 cpu: 7.3%
  2: mem: 1190.2 MiB (7.5%) command: librewolf pid: 2035 cpu: 5.7%
  3: mem: 781.3 MiB (4.9%) command: librewolf pid: 23472 cpu: 1.4%
  4: mem: 601.7 MiB (3.8%) command: plasmashell pid: 1426 cpu: 0.6%
  5: mem: 553.0 MiB (3.4%) command: librewolf pid: 26795 cpu: 0.3%
  Processes: 322 Power: uptime: 1d 2h 15m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 fails: 22 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.16 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
A post was split to a new topic: RAM filling up after video comparison post 2026.02.01 Stable Update
7 posts were split to a new topic: Cpupower configuration file was deleted after 2026.02..01 stable update
Today, I booted and logged in to my GNOME desktop, only to find a strange window on my taskbar. I can’t “open” it, quitting doesn’t appear to do anything, and I don’t see any unusual processes running.
The only new thing I did, a day before, was updating gnome-shell-extension-gtk4-desktop-icons-ng (1:100.14-1 → 1:100.15-1).
Any idea what this is?
2 posts were split to a new topic: Lost my package repositories after 2026.02.01 Stable Update
After the stable update on February 1, 2026, my laptop no longer boots to the system. The boot process hangs at: “Reached target Graphical Interface”. I could only log into my system with the Cinnamon desktop via the tty.
The problem was caused by Optimus Manager and Nvidia Prime.
Solution: After removing the files “/etc/lightdm/lightdm.conf.d/20-optimus-manager.conf” and “/sbin/prime-offload /sbin/prime-switch”, Lightdm started normally again and the system booted normally.
sudo pacman -Runc sddm-breath-theme
checking dependencies...
Packages (2) manjaro-kde-settings-20241119-1  sddm-breath-theme-24.0.0-6
Total Removed Size:  0.17 MiB
:: Do you want to remove these packages? [Y/n] n
maybe still keep manjaro-kde-settings for something else?
It’s listing manjaro-kde-settings as a package to remove because you used the -c (cascade) option. But if you want to keep it, then best would be to mark that package as explicitly installed. :backhand_index_pointing_down:
sudo pacman -D --asexplicit manjaro-kde-settings
not only, but also because ‘manjaro-kde-settings’ has hard dependency ‘sddm-breath-theme’.
Mark them both as explicitly installed.
I’ve made sddm-breath-theme an optional dependency with manjaro-kde-settings 20260210-2.
# pacman -Syu
 core is up to date
 extra is up to date
 multilib is up to date
warning: btrfsmaintenance: local (1:0.5.2-1) is newer than extra (0.5.2-3)
:: Replace lib32-vulkan-mesa-device-select with multilib/lib32-vulkan-mesa-implicit-layers? [Y/n]
:: Replace libappindicator-gtk3 with extra/libappindicator? [Y/n]
:: Replace libindicator-gtk3 with extra/libindicator? [Y/n]
:: Replace linux54 with core/linux-lts-meta? [Y/n]
:: Replace linux54-headers with core/linux-lts-headers-meta? [Y/n]
:: Replace linux54-nvidia with extra/linux-lts-nvidia-meta? [Y/n]
:: Replace vi with extra/ex-vi-compat? [Y/n]
:: Replace vulkan-mesa-device-select with extra/vulkan-mesa-implicit-layers? [Y/n]
resolving dependencies...
:: removing linux54-headers breaks dependency 'linux54-headers' required by linux-lts-headers
I get the same error if I try removing the 5.4 kernel with Manjaro settings. What should I do?
Remove the linux-lts-headerspackage first before trying to remove linux54.
Thanks a lot. That’s what I usually do in these cases but being a kernel packaged I was afraid to break something big.
Anyway, I can’t update because of (invalid or corrupted package (PGP signature)) errors. I have tried everything that is listed here but it didn’t work. Can you please link me the right procedure I should follow?
The kernel headers are only plain text files with C code functions, so that the compiler would be able to include the correct system calls in kernel modules that need to be compiled from sources against the installed kernel.
Concretely, in the event of Nvidia drivers, the part that gets compiled is the interface between the proprietary driver blob and the kernel, so that the module can be loaded into the kernel.
This is a problem that has been popping up all over the forum in the last couple of days, which definitely warrants investigation. :thinking:
This is what happens:
[manjaro-su ~]# sudo pacman-key --populate archlinux manjaro
gpg: problem with fast path key listing: No such file or directory - ignored
==> ERROR: There is no secret key available to sign with.
==> Use 'pacman-key --init' to generate a default secret key.
[manjaro-su ~]# sudo pacman-key --init
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: agent_genkey failed: No such file or directory
gpg: key generation failed: No such file or directory
gpg: Done
==> Updating trust database...
gpg: no need for a trustdb check
[manjaro-su ~]# sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
 core is up to date
 extra is up to date
Packages (3) archlinux-keyring-20260206-1  gnupg-2.4.9-1  manjaro-keyring-20251003-1
Total Installed Size:  12,08 MiB
Net Upgrade Size:       0,23 MiB
(3/3) checking keys in keyring        [#######################################################################################################################] 100%
(3/3) checking package integrity        [#######################################################################################################################] 100%
error: gnupg: signature from "David Runge <dvzrv@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/gnupg-2.4.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: archlinux-keyring: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/archlinux-keyring-20260206-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-keyring: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-keyring-20251003-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Hmm… I am seeing several mirrors that aren’t up-to-date for the Stable branch. That shouldn’t be happening anymore this long after a Stable Update. :face_with_raised_eyebrow:
Pretty much only the global mirrors and easyname are fully uptodate.
All but one of the USA-based mirrors are up-to-date as well.
I’ve just downgraded archlinux-keyring to 20260107-2.0 which should fix the issues. Once your mirror(s) is synced, install it with either:
sudo pacman -Sy archlinux-keyring && sudo pacman -Su
or
sudo pacman -Syuu
