[Stable Update] 2026-02-01 - Kernels, COSMIC, Plasma, GNOME, Mesa
@philm can you add this small patch to the 6.19 kernel.
I think so too, the text is outdated… probably a info for people who missed the last few stable release updates. Idk
A small addition to what Daniel wrote:
i would rather use something like cat /var/log/pacman.log | tail -1000 | less to scroll the log. You can also do this from another tty, since ttys cannot be scrolled back. It does not update automagically, unfortunately.
Note that some stuff does not get logged in that file and is only visible on the fly. Comments from package developers for example, and those are often important.
Otherwise, pretty much the same routine is in my personal cheatsheet. It even works on a tty.
Some un-necessary stuff there.
tail -1000 /var/log/pacman.log | less
Indeed. Each tail has a cat attached to it anyway, no need for a second cat. :rofl:
:cat:
I have plasma-login-manager as well, but it does not behave on my system as per what you describe. As the matter of fact, it behaves just like sddm would.
Ergo, it must be something specific to your system. :man_shrugging:
Not just in Germany. It’s that friggin’ A.I. mania. :man_facepalming:
It’s supposed to be the (recommended) default in Plasma 6.6. For now it’s still only a release candidate.
Besides, plasma-login-manager depends on systemd, which means that it’s not usable in FreeBSD/NetBSD/OpenBSD, and for those people, sddm is still the recommended display manager.
It’s not going to go away any day soon. :wink:
Take out your Nvidia card and put in an AMD card, or an Intel Arc. :wink:
:backhand_index_pointing_down:
UUoC (Useless Use of cat). :wink: :backhand_index_pointing_down:
…Or… :backhand_index_pointing_down:
paclog | tail -1000 | less
:wink:
scheduled for upcoming releases of 6.18 and 6.19 …
I can’t open Spectacle anymore (KDE), if I run pacman -Syyu nothing updates. This is the error from Spectacle:
spectacle: symbol lookup error: /usr/lib/libglslang.so.16: undefined symbol: spvValidatorOptionsSetAllowOffsetTextureOperand
Versions:
  • glslang 1:1.4.335.0-1
  • spectacle 1:6.5.5-1
Interesting… I’d never come across paclog before. And after a quick look at the manpage:
paclog --after=2026-02-05 | more
(more because personally I prefer it to less)
Nvidia + KDE Plasma user here, switched to Wayland about a year ago. Works just fine. What’s holding you back?
What annoys me is that you still can’t load Nvidia drivers within the initramfs without breaking hibernation, but that’s a different story.
Right after this update i got Kernel Panic while playing a (Flatpack) game
Edit:
It looks it is cpupower package related.
With Wayland, no option’s around Nvidia X Server Settings, no color profile, no way to disable g-sync.
Bash scripts related to Nvidia X Server Settings also no longer working under Wayland.
Kate also has graphic bugs under Wayland with nvidia.
Hi @philm
Will there be some fresh iso’s 26.02 available ?
New ISOs should be released soon
Manjaro 2026-02-01 - Stable Update
                         PACKAGE             20260113             20260201
                 manjaro-release             26.0.1-1             26.0.2-1
You’re mentioning Flatpak and appimage… I’m curious if you’re playing other games successfully… like via steam?
The power management feature that used to blank my monitor after 10 minutes of inactivity no longer works with Plasma Login Manager (switched from SDDM on KDE Plasma).
Check the settings for your Activities. Even if you did not create any, you will still have one (default) Activity. Whether the power management can turn off the monitor must also be set in the Activity settings. I got bitten by that too.
Since updating, steam friends & chat applet is invisible.
Setup: KDE Wayland with Nvidia proprietary drivers loaded.
EDIT: And after a while, it is back for no apparent reason at all…
RE: KDE/Wayland. I started using Wayland under KDE over a year ago. In case of issues I also have Xorg and run Openbox desktop. This way updating will never remove either, because each is a prerequisite for a intentionally installed package. Also, if one borks I can log into the other for troubleshooting.
This is probably not a recommended configuration, but it works for me.
The credentials etc. not showing after keypresses except enter was a bug with Plasma 6.5 version of plasma-login-manager. It’s fixed in Plasma 6.6 version it seems.
Fixed by removing spirv-tools-git (AUR, don’t remember installing) and installing spirv-tools
