The permissions should be 755. ![]()
You can, but it’s advised to follow the recommendation. It’s not uncommon for permissions to change but may require manual intervention for that to happen because the folder exists already. No idea why it can’t be automated alongside the upgrade, in theory it should be possible but I guess warning will allow users that do intentional change to keep the change as is (yes, there are such users who know what they’re doing and are aware of any possible risks) while other users can simply follow the suggestions.
I believe that the filesystem package does this. But this package is not included with every major update. ![]()
[ALPM] warning: directory permissions differ on /opt/onlyoffice/
filesystem: 775 package: 755
So
sudo chmod 755 /opt/onlyoffice/
I guess I’m leaving this here, for others.
filesystem update would fix that maybe with the next upgrade for other others…
Dankjewel!
Do you have the
kvantum-theme-matchamatheme installed?
No, I don’t, so I don’t think this is the problem.
That being the case, then you’re correct, it’s not.
The issue is with thunar-archive-plugin. It has been reported to xfce and the fix should be coming soon:
I meant to come back to this earlier, if only to say that I appreciated the humour (and the link), while some others clearly lacked the capacity. Cheers.
8 posts were split to a new topic: After this update espeak stopped working
NVIDIA 535.129.03 production branch release and 470.223.02 legacy for GKxxx “Kepler” GPUs are out with a security bulletin. Packages are coming along shortly.
If you’re using linux66 6.6.0rc4-1, you’ll have to try nvidia-470xx-dkms for now or switch to the testing or unstable branch which includes the mainline 6.6.0 release.
The NVIDIA 390.* legacy driver series is no longer being maintained. Please see Support timeframes for Unix legacy GPU releases for more details. However, we will still package it as long as it’s still possible.
Note that the EOL (End Of Life) linux64 & linux64-rt kernels are now removed.
I have had an error as folows during this update.
sudo pacman -S archlinux-keyring manjaro-keyring
sudo pacman -Syyuu
or
sudo pacma -Syu
Status Legend:
(OK):download completed.
error: ruby-rexml: signature from "Ike Devolder <ike.devolder@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/ruby-rexml-3.2.6-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package)
The package was corrupted. Did you delete it?
Try -Syu:
sudo pacman -Syu archlinux-keyring manjaro-keyring
Thank you for your reply.
I can not find your way, and it sounds good.
But I have tried your way.
That dose not work.
See last part.
I do update keyring as follow, and I can update my system without error.
refrence page.
https://zenn.dev/miwarin/articles/e0ca2e9d78a1614fe296
find key
pacman-key --list-sigs | fgrep "Ike Devolder"
fgrep: warning: fgrep is obsolescent; using grep -F
gpg: 注意: 信用データベースが、書き込み不能です
uid [まぁまぁ] Ike Devolder <ike.devolder@gmail.com>
sig 3 DB323392796CA067 2011-11-03 Ike Devolder <ike.devolder@gmail.com>
sig DB323392796CA067 2011-11-03 Ike Devolder <ike.devolder@gmail.com>
sig DB323392796CA067 2012-04-03 Ike Devolder <ike.devolder@gmail.com>
uid [期限切れ] Ike Devolder <ike.devolder@archlinux.org>
sig 3 E1E3CF0539448BFF 2021-10-30 Ike Devolder <ike.devolder@archlinux.org>
sig DB323392796CA067 2021-11-01 Ike Devolder <ike.devolder@gmail.com>
sign.
sudo pacman-key --lsign-key E1E3CF0539448BFF
-> 1 キーにローカルで署名しました。
==> 信頼データベースを更新...
gpg: 次回の信用データベース検査は、2023-11-09です
refresh.
sudo pacman-key -r E1E3CF0539448BFF
gpg: 鍵E1E3CF0539448BFF: "Ike Devolder <ike.devolder@archlinux.org>" 新しい署名を2個
gpg: 鍵E1E3CF0539448BFF: "Ike Devolder <ike.devolder@archlinux.org>" 1個の署名をきれいにしました
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
gpg: 公開鍵DB323392796CA067は、署名よりも3037日、新しいものです
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: 深さ: 0 有効性: 1 署名: 25 信用: 0-, 0q, 0n, 0m, 0f, 1u
gpg: 深さ: 1 有効性: 25 署名: 97 信用: 0-, 0q, 0n, 25m, 0f, 0u
gpg: 深さ: 2 有効性: 70 署名: 28 信用: 70-, 0q, 0n, 0m, 0f, 0u
gpg: 処理数の合計: 1
gpg: 新しい署名: 2
gpg: 掃除された署名: 1
finally update keyring again
I have tried your way for my another computer.
That dose not work.
I delete this pkg, but have same error…
LANG=C yay -S ruby-rexml
Sync Explicit (1): ruby-rexml-3.2.6-1
resolving dependencies...
Packages (1) ruby-rexml-3.2.6-1
Total Download Size: 0.09 MiB
Total Installed Size: 0.43 MiB
Net Upgrade Size: 0.04 MiB
Pipewire is at 0.3.81 in stable btw: Packages
I pushed now also the modules for 6.6 series to stable branch.
I installed today nvidia driver 535.129.03 and the flickering that im experience with my 2080Ti and my 144Hz Display (since April) is finally solved.
Then I would continue using it. I have good experience with it. Or is it recommended switching to nouveau now? 470 is prbb. for later-than-my-2012 card (GF119M).
[edited]
To be honest, I still have problems with my audio, even with the new Pipewire 0.3.81 package.
Quite often I have no sound when playing a song via Firefox/ Spotify/ Chromium and sometimes even the whole sound card disappears, so that there is no volume control at all available in the Gnome quick and normal settings.
I had no time to see what is going wrong, but here are the system logs:
22:18:19 bluetoothd: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
22:18:11 systemd-coredum: Process 15853 (pipewire) of user 1000 dumped core.
Stack trace of thread 15853:
#0 0x00007fb36cc0bdb0 snd_pcm_sw_params (libasound.so.2 + 0x7bdb0)
#1 0x00007fb36ccf0e2e n/a (libspa-alsa.so + 0x3ce2e)
#2 0x00007fb36ccf540d n/a (libspa-alsa.so + 0x4140d)
#3 0x00007fb36cd47734 n/a (libspa-alsa.so + 0x93734)
#4 0x00007fb36cd47788 n/a (libspa-alsa.so + 0x93788)
#5 0x00007fb36cd011b8 n/a (libspa-alsa.so + 0x4d1b8)
#6 0x00007fb36cce75fb n/a (libspa-alsa.so + 0x335fb)
#7 0x00007fb36d5aa3bf n/a (libspa-audioconvert.so + 0x1e3bf)
#8 0x00007fb36f3d3c21 n/a (libpipewire-0.3.so.0 + 0x69c21)
#9 0x00007fb36f3f88d4 n/a (libpipewire-0.3.so.0 + 0x8e8d4)
#10 0x00007fb36f466a09 n/a (libspa-support.so + 0x6a09)
#11 0x00007fb36f4685b6 n/a (libspa-support.so + 0x85b6)
#12 0x00007fb36f3cd954 pw_main_loop_run (libpipewire-0.3.so.0 + 0x63954)
#13 0x000055e61c77c2f1 n/a (pipewire + 0x12f1)
#14 0x00007fb36f1afcd0 n/a (libc.so.6 + 0x27cd0)
#15 0x00007fb36f1afd8a __libc_start_main (libc.so.6 + 0x27d8a)
#16 0x000055e61c77c4a5 n/a (pipewire + 0x14a5)
Stack trace of thread 15861:
#0 0x00007fb36f298bf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x00007fb36f475d99 n/a (libspa-support.so + 0x15d99)
#2 0x00007fb36f4684fd n/a (libspa-support.so + 0x84fd)
#3 0x00007fb36f3afc92 n/a (libpipewire-0.3.so.0 + 0x45c92)
#4 0x00007fb36f2149eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007fb36f298654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 15858:
#3 0x00007fb36f3f60bd n/a (libpipewire-0.3.so.0 + 0x8c0bd)
Stack trace of thread 15875:
#0 0x00007fb36f28b4c6 ppoll (libc.so.6 + 0x1034c6)
#1 0x00007fb36c8ca636 _ZN9libcamera19EventDispatcherPoll4pollEPSt6vectorI6pollfdSaIS2_EE (libcamera-base.so.0.1 + 0x16636)
#2 0x00007fb36c8cc1e3 _ZN9libcamera19EventDispatcherPoll13processEventsEv (libcamera-base.so.0.1 + 0x181e3)
#3 0x00007fb36c8c9e3f _ZN9libcamera6Thread4execEv (libcamera-base.so.0.1 + 0x15e3f)
#4 0x00007fb36c946ae4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.1 + 0x6bae4)
#5 0x00007fb36c6e1943 execute_native_thread_routine (libstdc++.so.6 + 0xe1943)
#6 0x00007fb36f2149eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007fb36f298654 __clone (libc.so.6 + 0x110654)
22:17:31 bluetoothd: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 00:E0:4C:D2:C9:09: Host is down (112)
22:17:12 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
22:17:08 systemd-coredum: Process 15310 (pipewire) of user 1000 dumped core.
Stack trace of thread 15310:
#0 0x00007f343d7ffdb0 snd_pcm_sw_params (libasound.so.2 + 0x7bdb0)
#1 0x00007f343d8e4e2e n/a (libspa-alsa.so + 0x3ce2e)
#2 0x00007f343d8e940d n/a (libspa-alsa.so + 0x4140d)
#3 0x00007f343d93b734 n/a (libspa-alsa.so + 0x93734)
#4 0x00007f343d93b788 n/a (libspa-alsa.so + 0x93788)
#5 0x00007f343d8f51b8 n/a (libspa-alsa.so + 0x4d1b8)
#6 0x00007f343d8db5fb n/a (libspa-alsa.so + 0x335fb)
#7 0x00007f343e19e3bf n/a (libspa-audioconvert.so + 0x1e3bf)
#8 0x00007f343ff7ac21 n/a (libpipewire-0.3.so.0 + 0x69c21)
#9 0x00007f343ff9f8d4 n/a (libpipewire-0.3.so.0 + 0x8e8d4)
#10 0x00007f344000da09 n/a (libspa-support.so + 0x6a09)
#11 0x00007f344000f5b6 n/a (libspa-support.so + 0x85b6)
#12 0x00007f343ff74954 pw_main_loop_run (libpipewire-0.3.so.0 + 0x63954)
#13 0x0000556a352d72f1 n/a (pipewire + 0x12f1)
#14 0x00007f343fd56cd0 n/a (libc.so.6 + 0x27cd0)
#15 0x00007f343fd56d8a __libc_start_main (libc.so.6 + 0x27d8a)
#16 0x0000556a352d74a5 n/a (pipewire + 0x14a5)
Stack trace of thread 15312:
#0 0x00007f343fe3fbf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x00007f344001cd99 n/a (libspa-support.so + 0x15d99)
#2 0x00007f344000f4fd n/a (libspa-support.so + 0x84fd)
#3 0x00007f343ff9d0bd n/a (libpipewire-0.3.so.0 + 0x8c0bd)
#4 0x00007f343fdbb9eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007f343fe3f654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 15314:
#3 0x00007f343ff56c92 n/a (libpipewire-0.3.so.0 + 0x45c92)
Stack trace of thread 15328:
#0 0x00007f343fe324c6 ppoll (libc.so.6 + 0x1034c6)
#1 0x00007f343d4e0636 _ZN9libcamera19EventDispatcherPoll4pollEPSt6vectorI6pollfdSaIS2_EE (libcamera-base.so.0.1 + 0x16636)
#2 0x00007f343d4e21e3 _ZN9libcamera19EventDispatcherPoll13processEventsEv (libcamera-base.so.0.1 + 0x181e3)
#3 0x00007f343d4dfe3f _ZN9libcamera6Thread4execEv (libcamera-base.so.0.1 + 0x15e3f)
#4 0x00007f343d55cae4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.1 + 0x6bae4)
#5 0x00007f343d2e1943 execute_native_thread_routine (libstdc++.so.6 + 0xe1943)
#6 0x00007f343fdbb9eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007f343fe3f654 __clone (libc.so.6 + 0x110654)
20:30:04 bluetoothd: profiles/audio/avdtp.c:avdtp_connect_cb() connect to D8:37:3B:4E:1D:B6: Host is down (112)
20:30:03 systemd-coredum: Process 15026 (signal-desktop) of user 1000 dumped core.
Stack trace of thread 15026:
#0 0x000055d7d6520675 n/a (signal-desktop + 0x5603675)
#1 0x000055d7d583d847 n/a (signal-desktop + 0x4920847)
#2 0x000055d7d583aa26 n/a (signal-desktop + 0x491da26)
#3 0x000055d7d583983b n/a (signal-desktop + 0x491c83b)
#4 0x000055d7d5844b12 n/a (signal-desktop + 0x4927b12)
#5 0x000055d7d5845f94 n/a (signal-desktop + 0x4928f94)
#6 0x000055d7d568111f n/a (signal-desktop + 0x476411f)
#7 0x000055d7d56ea903 n/a (signal-desktop + 0x47cd903)
#8 0x000055d7d56eabfa n/a (signal-desktop + 0x47cdbfa)
#9 0x000055d7d656d3ed n/a (signal-desktop + 0x56503ed)
#10 0x000055d7d658b5b5 n/a (signal-desktop + 0x566e5b5)
#11 0x000055d7d658afc9 n/a (signal-desktop + 0x566dfc9)
#12 0x000055d7d658bd15 n/a (signal-desktop + 0x566ed15)
#13 0x000055d7d65ecceb n/a (signal-desktop + 0x56cfceb)
#14 0x00007feaa530df19 n/a (libglib-2.0.so.0 + 0x59f19)
#15 0x00007feaa536c2b7 n/a (libglib-2.0.so.0 + 0xb82b7)
#16 0x00007feaa530c112 g_main_context_iteration (libglib-2.0.so.0 + 0x58112)
#17 0x000055d7d65ec43c n/a (signal-desktop + 0x56cf43c)
#18 0x000055d7d658c07c n/a (signal-desktop + 0x566f07c)
#19 0x000055d7d654e0d1 n/a (signal-desktop + 0x56310d1)
#20 0x000055d7d569d14f n/a (signal-desktop + 0x478014f)
#21 0x000055d7d569ef32 n/a (signal-desktop + 0x4781f32)
#22 0x000055d7d569a779 n/a (signal-desktop + 0x477d779)
#23 0x000055d7d3475694 n/a (signal-desktop + 0x2558694)
#24 0x000055d7d3476f1e n/a (signal-desktop + 0x2559f1e)
#25 0x000055d7d3476d38 n/a (signal-desktop + 0x2559d38)
#26 0x000055d7d3474675 n/a (signal-desktop + 0x2557675)
#27 0x000055d7d3474765 n/a (signal-desktop + 0x2557765)
#28 0x000055d7d31b1eed n/a (signal-desktop + 0x2294eed)
#29 0x00007feaa3e27cd0 n/a (libc.so.6 + 0x27cd0)
#30 0x00007feaa3e27d8a __libc_start_main (libc.so.6 + 0x27d8a)
#31 0x000055d7d2e1002a _start (signal-desktop + 0x1ef302a)
Stack trace of thread 15061:
#0 0x00007feaa3e894ae n/a (libc.so.6 + 0x894ae)
#1 0x00007feaa3e8bd40 pthread_cond_wait (libc.so.6 + 0x8bd40)
#2 0x000055d7d65bf26a n/a (signal-desktop + 0x56a226a)
#3 0x000055d7d65e8f16 n/a (signal-desktop + 0x56cbf16)
#4 0x000055d7d656a1f2 n/a (signal-desktop + 0x564d1f2)
#5 0x000055d7d652a306 n/a (signal-desktop + 0x560d306)
#6 0x000055d7d658c07c n/a (signal-desktop + 0x566f07c)
#7 0x000055d7d654e0d1 n/a (signal-desktop + 0x56310d1)
#8 0x000055d7d65acac8 n/a (signal-desktop + 0x568fac8)
#9 0x000055d7d65acc68 n/a (signal-desktop + 0x568fc68)
#10 0x000055d7d65bfac5 n/a (signal-desktop + 0x56a2ac5)
#11 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#12 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15070:
#2 0x000055d7d31ac9b9 uv_cond_wait (signal-desktop + 0x228f9b9)
#3 0x000055d7da44ec4e n/a (signal-desktop + 0x9531c4e)
#4 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15056:
#0 0x00007feaa3f10bf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x000055d7d6709fb4 n/a (signal-desktop + 0x57ecfb4)
#2 0x000055d7d6707cdf n/a (signal-desktop + 0x57eacdf)
#3 0x000055d7d65e3737 n/a (signal-desktop + 0x56c6737)
#4 0x000055d7d658c07c n/a (signal-desktop + 0x566f07c)
#5 0x000055d7d654e0d1 n/a (signal-desktop + 0x56310d1)
#6 0x000055d7d65acac8 n/a (signal-desktop + 0x568fac8)
#7 0x000055d7d6594fbd n/a (signal-desktop + 0x5677fbd)
#8 0x000055d7d65acc68 n/a (signal-desktop + 0x568fc68)
#9 0x000055d7d65bfac5 n/a (signal-desktop + 0x56a2ac5)
#10 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#11 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15069:
#1 0x000055d7d31af5c5 n/a (signal-desktop + 0x22925c5)
#2 0x000055d7d31a10a6 uv_run (signal-desktop + 0x22840a6)
#3 0x000055d7da451072 n/a (signal-desktop + 0x9534072)
Stack trace of thread 15049:
#0 0x00007feaa3f02f6f __poll (libc.so.6 + 0x102f6f)
#1 0x000055d7d5cee634 n/a (signal-desktop + 0x4dd1634)
#2 0x000055d7d65bfac5 n/a (signal-desktop + 0x56a2ac5)
#3 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#4 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15072:
Stack trace of thread 15099:
#3 0x000055d7d65e3679 n/a (signal-desktop + 0x56c6679)
#7 0x000055d7d65acc68 n/a (signal-desktop + 0x568fc68)
#8 0x000055d7d65bfac5 n/a (signal-desktop + 0x56a2ac5)
#9 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#10 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15059:
#4 0x000055d7d656a35e n/a (signal-desktop + 0x564d35e)
#5 0x000055d7d65a4b69 n/a (signal-desktop + 0x5687b69)
#6 0x000055d7d65a5778 n/a (signal-desktop + 0x5688778)
#7 0x000055d7d65a53fd n/a (signal-desktop + 0x56883fd)
#8 0x000055d7d65a52ea n/a (signal-desktop + 0x56882ea)
Stack trace of thread 15071:
Stack trace of thread 15081:
#3 0x000055d7da3215d4 _ZN4node13SpinEventLoopEPNS_11EnvironmentE (signal-desktop + 0x94045d4)
#4 0x000055d7da4b58b1 n/a (signal-desktop + 0x95988b1)
#5 0x000055d7da4b8fd2 n/a (signal-desktop + 0x959bfd2)
#6 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15082:
Stack trace of thread 15092:
#1 0x00007feaa536c206 n/a (libglib-2.0.so.0 + 0xb8206)
#2 0x00007feaa530eb47 g_main_loop_run (libglib-2.0.so.0 + 0x5ab47)
#3 0x00007feaa51ed0bc n/a (libgio-2.0.so.0 + 0x1120bc)
#4 0x00007feaa533f9a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
#5 0x00007feaa3e8c9eb n/a (libc.so.6 + 0x8c9eb)
#6 0x00007feaa3f107cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 15103:
#7 0x000055d7d65a53cd n/a (signal-desktop + 0x56883cd)
#8 0x000055d7d65a52e0 n/a (signal-desktop + 0x56882e0)
Stack trace of thread 15112:
#1 0x000055d7d33523ad n/a (signal-desktop + 0x24353ad)
#2 0x000055d7d331e057 n/a (signal-desktop + 0x2401057)
Stack trace of thread 15089:
#0 0x00007feaa3f0e73d syscall (libc.so.6 + 0x10e73d)
#1 0x00007feaa5367247 g_cond_wait (libglib-2.0.so.0 + 0xb3247)
#2 0x00007feaa52d91b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x00007feaa5341a2e n/a (libglib-2.0.so.0 + 0x8da2e)
Stack trace of thread 15101:
Stack trace of thread 15057:
#1 0x00007feaa3e8c055 pthread_cond_timedwait (libc.so.6 + 0x8c055)
#2 0x000055d7d65bf380 n/a (signal-desktop + 0x56a2380)
#3 0x000055d7d65e8f27 n/a (signal-desktop + 0x56cbf27)
#5 0x000055d7d65a4b16 n/a (signal-desktop + 0x5687b16)
Stack trace of thread 15093:
#2 0x00007feaa530c112 g_main_context_iteration (libglib-2.0.so.0 + 0x58112)
#3 0x00007feaa2417fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 15106:
Stack trace of thread 15108:
#7 0x000055d7d65a542d n/a (signal-desktop + 0x568842d)
#8 0x000055d7d65a52f4 n/a (signal-desktop + 0x56882f4)
Stack trace of thread 15107:
#6 0x000055d7d65a556c n/a (signal-desktop + 0x568856c)
Stack trace of thread 15090:
#3 0x00007feaa530c162 n/a (libglib-2.0.so.0 + 0x58162)
Stack trace of thread 15105:
#1 0x000055d7d65c2701 n/a (signal-desktop + 0x56a5701)
Stack trace of thread 15060:
#7 0x000055d7d569fd4f n/a (signal-desktop + 0x4782d4f)
Stack trace of thread 15100:
#0 0x00007feaa3ed57f5 clock_nanosleep (libc.so.6 + 0xd57f5)
#1 0x00007feaa3ee78c7 __nanosleep (libc.so.6 + 0xe78c7)
#2 0x00007feaa3ef882e sleep (libc.so.6 + 0xf882e)
#3 0x000055d7d334432d n/a (signal-desktop + 0x242732d)
#4 0x000055d7d65bfac5 n/a (signal-desktop + 0x56a2ac5)
Stack trace of thread 15114:
#3 0x000055d7d319d7c8 n/a (signal-desktop + 0x22807c8)
Stack trace of thread 15109:
#3 0x000055d7d7744a9d n/a (signal-desktop + 0x6827a9d)
Stack trace of thread 15115:
Stack trace of thread 15102:
Stack trace of thread 15111:
Stack trace of thread 15117:
Stack trace of thread 15104:
Stack trace of thread 15058:
Stack trace of thread 15116:
Stack trace of thread 15157:
Stack trace of thread 15126:
20:29:59 bluetoothd: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 00:E0:4C:D2:C9:09: Host is down (112)
20:29:44 kernel: Bluetooth: hci0: command 0x0408 tx timeout
20:29:44 bluetoothd: Failed to remove UUID: Authentication Failed (0x05)
20:29:42 kernel: Bluetooth: hci0: command 0x0408 tx timeout
20:29:42 bluetoothd: Failed to remove UUID: Authentication Failed (0x05)
20:29:39 systemd-coredum: Process 15265 (pipewire) of user 1000 dumped core.
Stack trace of thread 15265:
#0 0x00007ff560b63db0 snd_pcm_sw_params (libasound.so.2 + 0x7bdb0)
#1 0x00007ff560c48e2e n/a (libspa-alsa.so + 0x3ce2e)
#2 0x00007ff560c4d40d n/a (libspa-alsa.so + 0x4140d)
#3 0x00007ff560c9f734 n/a (libspa-alsa.so + 0x93734)
#4 0x00007ff560c9f788 n/a (libspa-alsa.so + 0x93788)
#5 0x00007ff560c591b8 n/a (libspa-alsa.so + 0x4d1b8)
#6 0x00007ff560c3f5fb n/a (libspa-alsa.so + 0x335fb)
#7 0x00007ff5615023bf n/a (libspa-audioconvert.so + 0x1e3bf)
#8 0x00007ff56332ac21 n/a (libpipewire-0.3.so.0 + 0x69c21)
#9 0x00007ff56334f8d4 n/a (libpipewire-0.3.so.0 + 0x8e8d4)
#10 0x00007ff5633bda09 n/a (libspa-support.so + 0x6a09)
#11 0x00007ff5633bf5b6 n/a (libspa-support.so + 0x85b6)
#12 0x00007ff563324954 pw_main_loop_run (libpipewire-0.3.so.0 + 0x63954)
#13 0x000055e4247a02f1 n/a (pipewire + 0x12f1)
#14 0x00007ff563106cd0 n/a (libc.so.6 + 0x27cd0)
#15 0x00007ff563106d8a __libc_start_main (libc.so.6 + 0x27d8a)
#16 0x000055e4247a04a5 n/a (pipewire + 0x14a5)
Stack trace of thread 15267:
#0 0x00007ff5631efbf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x00007ff5633ccd99 n/a (libspa-support.so + 0x15d99)
#2 0x00007ff5633bf4fd n/a (libspa-support.so + 0x84fd)
#3 0x00007ff56334d0bd n/a (libpipewire-0.3.so.0 + 0x8c0bd)
#4 0x00007ff56316b9eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007ff5631ef654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 15283:
#0 0x00007ff5631e24c6 ppoll (libc.so.6 + 0x1034c6)
#1 0x00007ff560822636 _ZN9libcamera19EventDispatcherPoll4pollEPSt6vectorI6pollfdSaIS2_EE (libcamera-base.so.0.1 + 0x16636)
#2 0x00007ff5608241e3 _ZN9libcamera19EventDispatcherPoll13processEventsEv (libcamera-base.so.0.1 + 0x181e3)
#3 0x00007ff560821e3f _ZN9libcamera6Thread4execEv (libcamera-base.so.0.1 + 0x15e3f)
#4 0x00007ff56089eae4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.1 + 0x6bae4)
#5 0x00007ff5604e1943 execute_native_thread_routine (libstdc++.so.6 + 0xe1943)
#6 0x00007ff56316b9eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007ff5631ef654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 15271:
#3 0x00007ff563306c92 n/a (libpipewire-0.3.so.0 + 0x45c92)
19:43:30 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
19:43:09 bluetoothd: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 00:E0:4C:D2:C9:09: Host is down (112)
19:42:46 systemd-coredum: Process 5288 (pipewire) of user 1000 dumped core.
Stack trace of thread 5288:
#0 0x00007f262696adb0 snd_pcm_sw_params (libasound.so.2 + 0x7bdb0)
#1 0x00007f2626a4fe2e n/a (libspa-alsa.so + 0x3ce2e)
#2 0x00007f2626a5440d n/a (libspa-alsa.so + 0x4140d)
#3 0x00007f2626aa6734 n/a (libspa-alsa.so + 0x93734)
#4 0x00007f2626aa6788 n/a (libspa-alsa.so + 0x93788)
#5 0x00007f2626a601b8 n/a (libspa-alsa.so + 0x4d1b8)
#6 0x00007f2626a465fb n/a (libspa-alsa.so + 0x335fb)
#7 0x00007f26273093bf n/a (libspa-audioconvert.so + 0x1e3bf)
#8 0x00007f2629134c21 n/a (libpipewire-0.3.so.0 + 0x69c21)
#9 0x00007f26291598d4 n/a (libpipewire-0.3.so.0 + 0x8e8d4)
#10 0x00007f26291c7a09 n/a (libspa-support.so + 0x6a09)
#11 0x00007f26291c95b6 n/a (libspa-support.so + 0x85b6)
#12 0x00007f262912e954 pw_main_loop_run (libpipewire-0.3.so.0 + 0x63954)
#13 0x00005620721902f1 n/a (pipewire + 0x12f1)
#14 0x00007f2628f10cd0 n/a (libc.so.6 + 0x27cd0)
#15 0x00007f2628f10d8a __libc_start_main (libc.so.6 + 0x27d8a)
#16 0x00005620721904a5 n/a (pipewire + 0x14a5)
Stack trace of thread 5290:
#0 0x00007f2628ff9bf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x00007f26291d6d99 n/a (libspa-support.so + 0x15d99)
#2 0x00007f26291c94fd n/a (libspa-support.so + 0x84fd)
#3 0x00007f26291570bd n/a (libpipewire-0.3.so.0 + 0x8c0bd)
#4 0x00007f2628f759eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007f2628ff9654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 5292:
#3 0x00007f2629110c92 n/a (libpipewire-0.3.so.0 + 0x45c92)
Stack trace of thread 5306:
#0 0x00007f2628fec4c6 ppoll (libc.so.6 + 0x1034c6)
#1 0x00007f262664b636 _ZN9libcamera19EventDispatcherPoll4pollEPSt6vectorI6pollfdSaIS2_EE (libcamera-base.so.0.1 + 0x16636)
#2 0x00007f262664d1e3 _ZN9libcamera19EventDispatcherPoll13processEventsEv (libcamera-base.so.0.1 + 0x181e3)
#3 0x00007f262664ae3f _ZN9libcamera6Thread4execEv (libcamera-base.so.0.1 + 0x15e3f)
#4 0x00007f26266c7ae4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.1 + 0x6bae4)
#5 0x00007f26262e1943 execute_native_thread_routine (libstdc++.so.6 + 0xe1943)
#6 0x00007f2628f759eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007f2628ff9654 __clone (libc.so.6 + 0x110654)
19:42:46 bluetoothd: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
19:42:45 pipewire: pw.node: (bluez_output.BC_F2_92_0C_61_BF.1-106) running -> error (Received error event)
19:18:20 systemd-coredum: Process 9732 (gnome-character) of user 1000 dumped core.
Stack trace of thread 9732:
#0 0x00007f05508ac83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f055085c668 raise (libc.so.6 + 0x3e668)
#2 0x00007f05508444b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f05510970ee n/a (libglib-2.0.so.0 + 0x1e0ee)
#4 0x00007f05510f8180 g_assertion_message_expr (libglib-2.0.so.0 + 0x7f180)
#5 0x00007f0546e51c77 n/a (libgtk-4.so.1 + 0x451c77)
#6 0x00007f05510397e3 g_object_unref (libgobject-2.0.so.0 + 0x227e3)
#7 0x00007f055122495e n/a (libgjs.so.0 + 0x5f95e)
#8 0x00007f0551226e30 n/a (libgjs.so.0 + 0x61e30)
#9 0x00007f0551291886 n/a (libgjs.so.0 + 0xcc886)
#10 0x00007f0551224b62 n/a (libgjs.so.0 + 0x5fb62)
#11 0x00007f05500afd97 n/a (libmozjs-102.so + 0x16afd97)
#12 0x00007f05500ae87a n/a (libmozjs-102.so + 0x16ae87a)
#13 0x00007f055046e162 n/a (libmozjs-102.so + 0x1a6e162)
#14 0x00007f055046d2f7 n/a (libmozjs-102.so + 0x1a6d2f7)
#15 0x00007f054fee43f9 n/a (libmozjs-102.so + 0x14e43f9)
#16 0x00007f054fee10b2 n/a (libmozjs-102.so + 0x14e10b2)
#17 0x00007f054fedcf1b n/a (libmozjs-102.so + 0x14dcf1b)
#18 0x00007f054fedbf77 n/a (libmozjs-102.so + 0x14dbf77)
#19 0x00007f05500c1cd6 n/a (libmozjs-102.so + 0x16c1cd6)
#20 0x00007f055124e897 n/a (libgjs.so.0 + 0x89897)
#21 0x00007f05510397e3 g_object_unref (libgobject-2.0.so.0 + 0x227e3)
#22 0x000055563289ca22 n/a (gjs-console + 0x2a22)
#23 0x00007f0550845cd0 n/a (libc.so.6 + 0x27cd0)
#24 0x00007f0550845d8a __libc_start_main (libc.so.6 + 0x27d8a)
#25 0x000055563289d475 n/a (gjs-console + 0x3475)
Stack trace of thread 9744:
#0 0x00007f05508a74ae n/a (libc.so.6 + 0x894ae)
#1 0x00007f05508a9d40 pthread_cond_wait (libc.so.6 + 0x8bd40)
#2 0x00007f054ff75a01 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x1575a01)
#3 0x00007f054ff758f3 n/a (libmozjs-102.so + 0x15758f3)
#4 0x00007f055013725b n/a (libmozjs-102.so + 0x173725b)
#5 0x00007f05508aa9eb n/a (libc.so.6 + 0x8c9eb)
#6 0x00007f055092e7cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 9746:
Stack trace of thread 9742:
Stack trace of thread 9734:
#0 0x00007f055092c73d syscall (libc.so.6 + 0x10e73d)
#1 0x00007f055112c247 g_cond_wait (libglib-2.0.so.0 + 0xb3247)
#2 0x00007f055109e1b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x00007f0551106a2e n/a (libglib-2.0.so.0 + 0x8da2e)
#4 0x00007f05511049a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
Stack trace of thread 9735:
#0 0x00007f0550920f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f0551131206 n/a (libglib-2.0.so.0 + 0xb8206)
#2 0x00007f05510d1112 g_main_context_iteration (libglib-2.0.so.0 + 0x58112)
#3 0x00007f05510d1162 n/a (libglib-2.0.so.0 + 0x58162)
Stack trace of thread 9748:
Stack trace of thread 9741:
Stack trace of thread 9743:
Stack trace of thread 9843:
#2 0x00007f05286c78dc n/a (iris_dri.so + 0xc78dc)
#3 0x00007f05287147ec n/a (iris_dri.so + 0x1147ec)
#4 0x00007f05508aa9eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007f055092e7cc n/a (libc.so.6 + 0x1107cc)
Stack trace of thread 9848:
Stack trace of thread 9839:
Stack trace of thread 9824:
#1 0x00007f055112cc23 g_cond_wait_until (libglib-2.0.so.0 + 0xb3c23)
#2 0x00007f055109e185 n/a (libglib-2.0.so.0 + 0x25185)
#3 0x00007f05511074db n/a (libglib-2.0.so.0 + 0x8e4db)
Stack trace of thread 9800:
#3 0x00007f05460cafde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 9747:
Stack trace of thread 9840:
Stack trace of thread 9838:
Stack trace of thread 9736:
#2 0x00007f05510d3b47 g_main_loop_run (libglib-2.0.so.0 + 0x5ab47)
#3 0x00007f0550f500bc n/a (libgio-2.0.so.0 + 0x1120bc)
Stack trace of thread 9845:
Stack trace of thread 9841:
Stack trace of thread 9873:
Stack trace of thread 9745:
Stack trace of thread 9847:
Stack trace of thread 9842:
Stack trace of thread 9844:
Stack trace of thread 9867:
Stack trace of thread 9846:
Stack trace of thread 9857:
Stack trace of thread 9858:
Stack trace of thread 9862:
Stack trace of thread 9878:
Stack trace of thread 9866:
Stack trace of thread 9863:
Stack trace of thread 9872:
Stack trace of thread 9877:
19:15:14 polkit-agent-he: PAM adding faulty module: /usr/lib/security/pam_fprintd.so
19:11:43 bluetoothd: profiles/audio/avdtp.c:avdtp_connect_cb() connect to D8:37:3B:4E:1D:B6: Host is down (112)
19:11:19 systemd-coredum: Process 3962 (pipewire) of user 1000 dumped core.
Stack trace of thread 3962:
#0 0x00007fd90694edb0 snd_pcm_sw_params (libasound.so.2 + 0x7bdb0)
#1 0x00007fd906a33e2e n/a (libspa-alsa.so + 0x3ce2e)
#2 0x00007fd906a3840d n/a (libspa-alsa.so + 0x4140d)
#3 0x00007fd906a8a734 n/a (libspa-alsa.so + 0x93734)
#4 0x00007fd906a8a788 n/a (libspa-alsa.so + 0x93788)
#5 0x00007fd906a441b8 n/a (libspa-alsa.so + 0x4d1b8)
#6 0x00007fd906a2a5fb n/a (libspa-alsa.so + 0x335fb)
#7 0x00007fd9072ed3bf n/a (libspa-audioconvert.so + 0x1e3bf)
#8 0x00007fd9090cac21 n/a (libpipewire-0.3.so.0 + 0x69c21)
#9 0x00007fd9090ef8d4 n/a (libpipewire-0.3.so.0 + 0x8e8d4)
#10 0x00007fd90915da09 n/a (libspa-support.so + 0x6a09)
#11 0x00007fd90915f5b6 n/a (libspa-support.so + 0x85b6)
#12 0x00007fd9090c4954 pw_main_loop_run (libpipewire-0.3.so.0 + 0x63954)
#13 0x000055f0bd9cd2f1 n/a (pipewire + 0x12f1)
#14 0x00007fd908ea6cd0 n/a (libc.so.6 + 0x27cd0)
#15 0x00007fd908ea6d8a __libc_start_main (libc.so.6 + 0x27d8a)
#16 0x000055f0bd9cd4a5 n/a (pipewire + 0x14a5)
Stack trace of thread 3966:
#0 0x00007fd908f8fbf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x00007fd90916cd99 n/a (libspa-support.so + 0x15d99)
#2 0x00007fd90915f4fd n/a (libspa-support.so + 0x84fd)
#3 0x00007fd9090a6c92 n/a (libpipewire-0.3.so.0 + 0x45c92)
#4 0x00007fd908f0b9eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007fd908f8f654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 3964:
#3 0x00007fd9090ed0bd n/a (libpipewire-0.3.so.0 + 0x8c0bd)
Stack trace of thread 3980:
#0 0x00007fd908f824c6 ppoll (libc.so.6 + 0x1034c6)
#1 0x00007fd90662f636 _ZN9libcamera19EventDispatcherPoll4pollEPSt6vectorI6pollfdSaIS2_EE (libcamera-base.so.0.1 + 0x16636)
#2 0x00007fd9066311e3 _ZN9libcamera19EventDispatcherPoll13processEventsEv (libcamera-base.so.0.1 + 0x181e3)
#3 0x00007fd90662ee3f _ZN9libcamera6Thread4execEv (libcamera-base.so.0.1 + 0x15e3f)
#4 0x00007fd9066abae4 _ZN9libcamera13CameraManager7Private3runEv (libcamera.so.0.1 + 0x6bae4)
#5 0x00007fd9062e1943 execute_native_thread_routine (libstdc++.so.6 + 0xe1943)
#6 0x00007fd908f0b9eb n/a (libc.so.6 + 0x8c9eb)
#7 0x00007fd908f8f654 __clone (libc.so.6 + 0x110654)
19:11:04 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
16:21:15 pipewire: pw.node: (bluez_output.BC_F2_92_0C_61_BF.1-101) idle -> error (Received error event)
16:21:15 bluetoothd: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
16:01:46 systemd-coredum: Process 1757 (pipewire) of user 1000 dumped core.
Stack trace of thread 1757:
#0 0x00007fd62eaf6db0 snd_pcm_sw_params (libasound.so.2 + 0x7bdb0)
#1 0x00007fd62ebdbe2e n/a (libspa-alsa.so + 0x3ce2e)
#2 0x00007fd62ebe040d n/a (libspa-alsa.so + 0x4140d)
#3 0x00007fd62ec32734 n/a (libspa-alsa.so + 0x93734)
#4 0x00007fd62ec32788 n/a (libspa-alsa.so + 0x93788)
#5 0x00007fd62ebec1b8 n/a (libspa-alsa.so + 0x4d1b8)
#6 0x00007fd62ebd25fb n/a (libspa-alsa.so + 0x335fb)
#7 0x00007fd62f4953bf n/a (libspa-audioconvert.so + 0x1e3bf)
#8 0x00007fd6352c1c21 n/a (libpipewire-0.3.so.0 + 0x69c21)
#9 0x00007fd6352e68d4 n/a (libpipewire-0.3.so.0 + 0x8e8d4)
#10 0x00007fd635354a09 n/a (libspa-support.so + 0x6a09)
#11 0x00007fd6353565b6 n/a (libspa-support.so + 0x85b6)
#12 0x00007fd6352bb954 pw_main_loop_run (libpipewire-0.3.so.0 + 0x63954)
#13 0x000055ba96d342f1 n/a (pipewire + 0x12f1)
#14 0x00007fd63509dcd0 n/a (libc.so.6 + 0x27cd0)
#15 0x00007fd63509dd8a __libc_start_main (libc.so.6 + 0x27d8a)
#16 0x000055ba96d344a5 n/a (pipewire + 0x14a5)
Stack trace of thread 1778:
#0 0x00007fd635186bf6 epoll_wait (libc.so.6 + 0x110bf6)
#1 0x00007fd635363d99 n/a (libspa-support.so + 0x15d99)
#2 0x00007fd6353564fd n/a (libspa-support.so + 0x84fd)
#3 0x00007fd63529dc92 n/a (libpipewire-0.3.so.0 + 0x45c92)
#4 0x00007fd6351029eb n/a (libc.so.6 + 0x8c9eb)
#5 0x00007fd635186654 __clone (libc.so.6 + 0x110654)
Stack trace of thread 1773:
#3 0x00007fd6352e40bd n/a (libpipewire-0.3.so.0 + 0x8c0bd)
16:00:28 bluetoothd: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 00:E0:4C:D2:C9:09: Host is down (112)
16:00:13 kernel: Bluetooth: hci0: Opcode 0x c24 failed: -110
16:00:13 bluetoothd: Failed to remove UUID: Authentication Failed (0x05)
16:00:10 gdm-session-wor: gkr-pam: unable to locate daemon control file
16:00:05 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
16:00:00 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
15:59:58 kernel: DMAR: [DMA Read NO_PASID] Request device [00:02.0] fault addr 0x61f40000 [fault reason 0x06] PTE Read access is not set
Full logs: 22:23:32 touchegg: Reconnecting in 5 seconds...22:23:30 gnome-shell: Can't upd - Pastebin.com
Hi guys, it looks like there’s a problem with the palemoon update that came out I think yesterday:
core is up to date
extra is up to date
multilib is up to date
warning: cannot resolve "palemoon>=32.5.0", a dependency of "palemoon-i18n-en-gb"
warning: cannot resolve "palemoon>=32.5.0", a dependency of "palemoon-i18n-it"
:: The following packages cannot be upgraded due to unresolvable dependencies:
palemoon-i18n-en-gb palemoon-i18n-it
:: Do you want to skip the above packages for this upgrade? [y/N]
:: unable to satisfy dependency 'palemoon>=32.5.0' required by palemoon-i18n-en-gb
:: unable to satisfy dependency 'palemoon>=32.5.0' required by palemoon-i18n-it
