Missing GNOME Control Center menu
gnome-control-center > privacy > Diganostics
there is no such menu…
what package do I need?
You’re right. :wink:
Are you thinking of maybe Privacy > Device Security?
Tip: Always check optional dependencies:
pacman -Qi gnome-control-center | less -p 'Optional Deps'
No.
None. It does not show up, maybe it is hidden by default, I don’t know. However, you can search for “diagnostics” in Gnome Settings and a open this menu page.
That’s odd. It does not appear for me unless I search for it. I didn’t even know it existed on Manjaro. :exploding_head:
@pch76 The Diagnostics menu appears in your screenshot. :wink:
Why are you asking and what do you hope to accomplish?
We should not have to poke and prod you. Please see:
This is not my screenshot, I don’t have such a menu, that’s why I asked what kind of package I need to install in order to have diagnostics
I get a feeling that’s not gnome, or part of it. And obviously not of Manjaro. So I think you’d need to find out from whoevers screenshot that is, what package it belongs to. And if it’s applicable to you.
Edit:
a Very quick search lead me to this page, that states:
@raggesilver - I was able to resolve this issue by running:
sudo pacman -S gnome-firmware
This package will depend on fwupd and should fetch all the necessary dependencies.
And gnome-firmware is in the extra repository:
$ pamac search gnome-firmware
gnome-firmware-git  3.36.0.r40.g96cc9e4-1        AUR
GNOME application to update, reinstall and downgrade firmware on devices supported by fwupd
gnome-firmware  43.2-1        extra
Manage firmware on devices supported by fwupd
So you could try that and see if it helps:
pamac install gnome-firmware
If not,
:man_shrugging:
But I hope it helps!
That’s only related to the Device Security panel and all that is required is fwupd. :wink:
As far as the Diagnostics panel, I believe it’s hidden by default as Manjaro does not have anything setup for problem reporting like Ubuntu and Fedora does.
Cool. Thanks!
:+1:
