Stable update 2023-03-31: Kernel 5.15.99+
Seeing the issues about stable update 2023-03-31 I’m concerned, as actually I’m using Kernel Version: 5.15.102-1-MANJARO (64-bit), which is listed there:
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
What do you recommend:
  • Run the update right away?
  • Change the kernel first?
  • Anything else?
Thank you!
its fixed, since you are already running the kernel that was affected:
so continue with the update…
That issue was fixed. You can run the update just fine.
Think the date is wrong it should be 2023-04-02
