Can’t boot into
- linux60 6.0.14
- linux61 6.1.0
anymore. 5.15 LTS still works. I have a nvidia 2080 and I did an pamac upgrade
before the issues
Can’t boot into
before the issues
Currently the update was at part 17 of 24(? don’t remember) post transaction hooks and it has frozen and I can’t do anything in that session (blank screen currently). I can get to other accounts on the system and the terminal (Ctrl+alt+f4). This has never happened to me before, I don’t want to just force a reboot and make it inoperable.
Any useful suggestions would be greatly appreciated
UPDATE - I rebooted from the terminal and it appears to be running fine, no hiccups yet
…yes, same here on TP P16s amd (pretty much the same machine). Looks as linux61 6.1.0 is not ready for us. Only working kernel for now is 6.0.14-1
Top job, thanks !
xfce 4.18 ok, Kernel 6.1 ok
~]$ inxi -Fazi
Kernel: 6.1.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=78fe8df9-a5da-4f7c-9ec3-52993d393e57 rw quiet
udev.log_priority=3
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel, plank
wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
Mobo: HP model: 8934 v: 80.72 serial: <superuser required> UEFI: AMI
v: F.13 date: 02/14/2022
ID-1: BAT0 charge: 61.6 Wh (99.5%) condition: 61.9/61.9 Wh (100.0%)
volts: 16.9 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: not charging cycles: 41
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1226 high: 1397 min/max: 1200/4280 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1322 2: 1200
3: 1200 4: 1200 5: 1200 6: 1200 7: 1397 8: 1200 9: 1200 10: 1200 11: 1197
12: 1200 bogomips: 79080
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:7340
class-ID: 0380
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1
bus-ID: 09:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: xfwm v: 4.18.0 driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1606 built: 2019
res: 1920x1080 hz: 60 dpi: 137 gamma: 1.2 size: 355x199mm (13.98x7.83")
diag: 407mm (16") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.0-1-MANJARO) direct render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 09:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k6.1.0-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.63 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8852
class-ID: 0280
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: veth2004722 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 1.38 TiB used: 619.92 GiB (44.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
rev: HPS2 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Crucial model: CT1000P5SSD8
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 376.3 GiB size: 369.32 GiB (98.15%) used: 77.2 GiB (20.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 86.9 MiB (34.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 542.64 GiB (59.3%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:7
Kernel: swappiness: 5 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 57.6 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
GPU: device: amdgpu temp: 49.0 C device: amdgpu temp: 47.0 C mem: 0.0 C
fan: 65535 watts: 4.00
Processes: 387 Uptime: 12m wakeups: 4 Memory: 14.97 GiB
used: 7.27 GiB (48.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2714
pm: pacman pkgs: 2639 libs: 484 tools: pamac,yay pm: flatpak pkgs: 75
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
No issue at all with XFCE 4.18, thank you guys
The update seemed to go smoothly using frameworks 5.101 but holding back on plasma and running 5.24.7 LTS. I was not using the Kate widget.
With Kernel 6.1 on XFCE with AMD graphics my additional laptops via Docking Station did not work.
Works fine with 6.0.
Desktop with I7 6700 and Nvidia RTX 2060 fails to boot with Kernel 6.1, Stops at blinking Cursors and have to TTY (CTRL-ALT-F3) then sudo reboot, Works fine on Kernel 6.0.
UPDATE:
Removed Kernel 6.1, left it for a few hours and tried installing 6.1 again using Manjaro Settings Manager/Kernels, This time it’s working fine and booting up normal again.
gnome-shell-extension-gtk4-desktop-icons-ng and gnome-shell-extension-desktop-icons-ng are in conflict (gnome-shell-extension-desktop-icons). Remove gnome-shell-extension-desktop-icons-ng? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Should I remove the mentioned package above? is this error normal to have?
Updating to kernel 6.1 I lost the wallpaper on both screens in KDE 5.24.7, but I easily re-added it. Otherwise, seems good…
Yes, gnome-shell-extension-gtk4-desktop-icons-ng
has replaced gnome-shell-extension-desktop-icons-ng
If you press Enter or N, yes. So press Y.
update went smooth but firefox will not start.
I can see the processes in btop, but no window is opening.
Journalctl says only:
Dez 20 19:47:26 alexander-ms7589 firefox[5339]: Failed to load module "appmenu-gtk-module"
I tried to reinstall with pamac, but wont work.
installed appmenu-gtk-module, reboot…nope
Any hints?
Kernel: 6.0.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=e1875968-aed1-42d3-b90c-be51960c7910 rw
resume=UUID=e1875968-aed1-42d3-b90c-be51960c7910 resume_offset=29833216
quiet apparmor=1 security=apparmor udev.log_priority=3
sysrq_always_enabled=1 radeon.dpm=0 usbcore.autosuspend=-1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Desktop Mobo: MSI model: P55-GD55 (MS-7589) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 1.9
date: 03/02/2011
RAM: total: 7.75 GiB used: 5.06 GiB (65.2%)
Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1401 high: 2801 min/max: 1200/2801 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1203 2: 1200
3: 1203 4: 1203 5: 1200 6: 2801 7: 1200 8: 1203 bogomips: 44933
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Juniper XT [Radeon HD 5770] vendor: Hightech Information System
driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2 code: Evergreen
process: TSMC 32-40nm built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: DVI-I-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 1002:68b8 class-ID: 0300 temp: 53.0 C
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_wayland driver: X: loaded: radeon dri: r600 gpu: radeon
display-ID: 0
Monitor-1: DVI-I-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.5 Mesa 22.3.1 renderer: AMD JUNIPER (DRM 2.50.0 /
6.0.14-1-MANJARO LLVM 14.0.6) direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 2-1.1:3
chip-ID: 0c76:1617 bus-ID: 00:1b.0 class-ID: 0300 chip-ID: 8086:3b56
class-ID: 0403 serial: <filter>
Device-2: AMD Juniper HDMI Audio [Radeon HD 5700 Series] vendor: Hightech
Information System driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa58 class-ID: 0403
Device-3: JMTek LLC. Lioncast_LX60_USB_Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.0.14-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 180.16 GiB (6.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SJ size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 00E4 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS5C3020ALA632
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5940 serial: <filter> rev: A580 scheme: MBR
ID-1: / raw-size: 585.94 GiB size: 575.67 GiB (98.25%)
used: 180.16 GiB (31.3%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: e1875968-aed1-42d3-b90c-be51960c7910
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 11 GiB used: 8.3 MiB (0.1%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert
uuid: 583E97273E96FD66
ID-2: /dev/sda2 maj-min: 8:2 size: 199.39 GiB fs: ntfs label: System
uuid: 0A12C25D12C24CFF
ID-3: /dev/sda3 maj-min: 8:3 size: 527 MiB fs: ntfs label: N/A
uuid: 34862028861FE95E
ID-4: /dev/sda4 maj-min: 8:4 size: 731.51 GiB fs: ntfs label: Daten
uuid: 7024BEAB24BE73A6
ID-5: /dev/sdb1 maj-min: 8:17 size: 1.15 TiB fs: ntfs label: Daten3
uuid: 86E470A6E47099DF
ID-6: /dev/sdb2 maj-min: 8:18 size: 100.18 GiB fs: ext4 label: Backup
uuid: ff56fbe9-6e09-4569-8fa8-8b97d1c923f1
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.5:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 2516:0042 class-ID: 0301
Device-2: 1-1.6:4 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: JMTek LLC. Lioncast_LX60_USB_Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0c76:1617 class-ID: 0300
serial: <filter>
Device-2: 2-1.3:4 info: Genesys Logic USB 2.0 Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05e3:070e class-ID: 0806 serial: <filter>
System Temperatures: cpu: 41.0 C mobo: 33.0 C gpu: radeon temp: 53.0 C
Fan Speeds (RPM): cpu: 1066 fan-1: 832 fan-3: 923
Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.28
Processes: 248 Uptime: 1h 4m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1727 pm: pacman pkgs: 1718 libs: 476 tools: pamac,yay pm: flatpak
pkgs: 9 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.24
Dez 20 20:41:22 alexander-ms7589 kernel: core: CPUID marked event: 'bus cycles' unavailable
Dez 20 20:41:22 alexander-ms7589 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dez 20 20:41:22 alexander-ms7589 kernel: #5 #6 #7
Dez 20 20:41:22 alexander-ms7589 kernel: pnp 00:06: disabling [mem 0x000c0000-0x000cffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0x000c0000-0x000dffff]
Dez 20 20:41:22 alexander-ms7589 kernel: resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000dffff window]
Dez 20 20:41:22 alexander-ms7589 kernel: caller pci_map_rom+0x69/0x190 mapping multiple BARs
Dez 20 20:41:29 alexander-ms7589 kernel: ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20220331/utaddress-204)
Dez 20 20:41:29 alexander-ms7589 kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Dez 20 20:41:29 alexander-ms7589 kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Dez 20 20:41:29 alexander-ms7589 kernel: kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
Dez 20 20:41:29 alexander-ms7589 kernel: usb 2-1.1: Warning! Unlikely big volume range (=1008), cval->res is probably wrong.
Dez 20 20:41:29 alexander-ms7589 kernel: usb 2-1.1: [49] FU [PCM Playback Volume] ch = 2, val = -16129/-1/16
Dez 20 20:41:29 alexander-ms7589 kernel: usb 2-1.1: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
Dez 20 20:41:29 alexander-ms7589 kernel: usb 2-1.1: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
Dez 20 20:41:29 alexander-ms7589 kernel: kauditd_printk_skb: 55 callbacks suppressed
Dez 20 20:41:30 alexander-ms7589 kernel: f71882fg f71882fg.2560: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Dez 20 20:41:36 alexander-ms7589 kernel: kauditd_printk_skb: 12 callbacks suppressed
Dez 20 20:41:42 alexander-ms7589 kernel: kauditd_printk_skb: 1 callbacks suppressed
Dez 20 20:41:49 alexander-ms7589 kernel: kauditd_printk_skb: 154 callbacks suppressed
Dez 20 20:41:53 alexander-ms7589 kernel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
Dez 20 20:41:56 alexander-ms7589 kernel: kvm: KVM_SET_TSS_ADDR need to be called before entering vcpu
Dez 20 20:42:02 alexander-ms7589 sddm-greeter[728]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffdfc11f610), parent's thread is QThread(0x55728fdb56a0), current thread is QThread(0x55728fef9ff0)
Dez 20 20:42:02 alexander-ms7589 sddm-greeter[728]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Dez 20 20:42:05 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/Main.qml:440:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 20 20:42:05 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/VirtualKeyboard.qml:23:1: Type InputPanel unavailable
Dez 20 20:42:05 alexander-ms7589 sddm-greeter[728]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Dez 20 20:42:05 alexander-ms7589 sddm-greeter[728]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Dez 20 20:42:05 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/Login.qml:92:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 20 20:42:06 alexander-ms7589 sddm-greeter[728]: Cannot watch QRC-like path ":/icons/hicolor/index.theme"
Dez 20 20:42:07 alexander-ms7589 kernel: kauditd_printk_skb: 2 callbacks suppressed
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/Main.qml:415: TypeError: Cannot read property 'smallSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/ActionButton.qml:64: TypeError: Cannot read property 'smallSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/ActionButton.qml:34: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/SessionManagementScreen.qml:83: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/SessionManagementScreen.qml:112: TypeError: Cannot read property 'smallSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/SessionManagementScreen.qml:98: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/SessionManagementScreen.qml:99: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/SessionManagementScreen.qml:89: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserDelegate.qml:118: TypeError: Cannot read property 'largeSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserDelegate.qml:84: TypeError: Cannot read property 'largeSpacing' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserDelegate.qml:110: TypeError: Cannot read property 'gridUnit' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserDelegate.qml:90: TypeError: Cannot read property 'longDuration' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/Main.qml:202: TypeError: Cannot read property 'longDuration' of null
Dez 20 20:42:15 alexander-ms7589 sddm-greeter[728]: file:///usr/share/sddm/themes/sweet/Main.qml:420: TypeError: Cannot read property 'longDuration' of null
Dez 20 20:42:16 alexander-ms7589 systemd-xdg-autostart-generator[750]: /home/alexander/.config/autostart/org.moson.matray.desktop: not generating unit, error parsing Exec= line: No such file or directory
Dez 20 20:42:19 alexander-ms7589 systemd-xdg-autostart-generator[775]: /home/alexander/.config/autostart/org.moson.matray.desktop: not generating unit, error parsing Exec= line: No such file or directory
Dez 20 20:42:21 alexander-ms7589 kwin_wayland[781]: No backend specified, automatically choosing drm
Dez 20 20:42:21 alexander-ms7589 kwin_wayland[781]: kwin_wayland_drm: drmSetClientCap for Atomic Mode Setting failed. Using legacy mode on GPU "/dev/dri/card0"
Dez 20 20:42:22 alexander-ms7589 kernel: kauditd_printk_skb: 11 callbacks suppressed
Dez 20 20:42:23 alexander-ms7589 kwin_wayland[781]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Dez 20 20:42:23 alexander-ms7589 kwin_wayland[781]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Dez 20 20:42:30 alexander-ms7589 ksmserver[866]: Qt: Session management error: networkIdsList argument is NULL
Dez 20 20:42:33 alexander-ms7589 backlighthelper[949]: org.kde.powerdevil: no kernel backlight interface found
Dez 20 20:42:33 alexander-ms7589 org_kde_powerdevil[910]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dez 20 20:42:33 alexander-ms7589 org_kde_powerdevil[910]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Dez 20 20:42:35 alexander-ms7589 pipewire[964]: mod.rt: Can't find xdg-portal: (null)
Dez 20 20:42:35 alexander-ms7589 pipewire[964]: mod.rt: found session bus but no portal
Dez 20 20:42:35 alexander-ms7589 pipewire-media-session[965]: mod.rt: Can't find xdg-portal: (null)
Dez 20 20:42:35 alexander-ms7589 pipewire-media-session[965]: mod.rt: found session bus but no portal
Dez 20 20:42:35 alexander-ms7589 org_kde_powerdevil[910]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dez 20 20:42:35 alexander-ms7589 org_kde_powerdevil[910]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Dez 20 20:42:35 alexander-ms7589 systemd[743]: app-ssh\x2dadd@autostart.service: Failed with result 'exit-code'.
Dez 20 20:42:35 alexander-ms7589 org_kde_powerdevil[910]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dez 20 20:42:40 alexander-ms7589 kded5[868]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
Dez 20 20:42:43 alexander-ms7589 kded5[868]: org.kde.plasma.appmenu: Got an error
Dez 20 20:42:46 alexander-ms7589 kwin_wayland[781]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Dez 20 20:42:50 alexander-ms7589 plasmashell[887]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Dez 20 20:42:50 alexander-ms7589 plasmashell[887]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Dez 20 20:42:56 alexander-ms7589 plasmashell[887]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Dez 20 20:43:00 alexander-ms7589 plasmashell[887]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Dez 20 20:43:00 alexander-ms7589 plasmashell[887]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Dez 20 20:43:02 alexander-ms7589 pulseaudio[1198]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Dez 20 20:43:04 alexander-ms7589 plasmashell[887]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5621c5c023e0) QQmlContext(0x5621c55ae7d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dez 20 20:43:04 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dez 20 20:43:04 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dez 20 20:43:04 alexander-ms7589 plasmashell[887]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dez 20 20:43:04 alexander-ms7589 plasmashell[887]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dez 20 20:43:04 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/PopupDialog.qml:188: TypeError: Cannot call method 'destroy' of null
Dez 20 20:43:05 alexander-ms7589 plasmashell[887]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dez 20 20:43:06 alexander-ms7589 plasmashell[887]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dez 20 20:43:06 alexander-ms7589 pulseaudio[1198]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Dez 20 20:43:06 alexander-ms7589 kded5[868]: kf.bluezqt: PendingCall Error: "Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)"
Dez 20 20:43:07 alexander-ms7589 plasmashell[887]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dez 20 20:43:07 alexander-ms7589 baloo_file[783]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.37'
Dez 20 20:43:08 alexander-ms7589 plasmashell[887]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5621c6810470) QQmlContext(0x5621c55ae7d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dez 20 20:43:08 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dez 20 20:43:08 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dez 20 20:43:10 alexander-ms7589 plasmashell[887]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dez 20 20:43:10 alexander-ms7589 plasmashell[887]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dez 20 20:43:10 alexander-ms7589 plasmashell[887]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Dez 20 20:43:11 alexander-ms7589 plasmashell[887]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dez 20 20:43:53 alexander-ms7589 msm_kde_notifier[991]: QProcess: Destroyed while process ("pacman") is still running.
Dez 20 20:44:36 alexander-ms7589 plasmashell[887]: trying to show an empty dialog
Dez 20 20:44:37 alexander-ms7589 plasmashell[887]: kf.plasma.quick: Couldn't create KWindowShadow for ToolTipDialog(0x5621c519bd80)
Dez 20 20:44:57 alexander-ms7589 plasmashell[887]: kf.plasma.quick: Couldn't create KWindowShadow for ToolTipDialog(0x5621c519bd80)
Dez 20 20:44:58 alexander-ms7589 plasmashell[887]: kf.plasma.quick: Couldn't create KWindowShadow for PlasmaQuick::Dialog_QML_77(0x5621c5442c70, name="popupWindow")
Dez 20 20:45:03 alexander-ms7589 systemd[1]: libvirtd.service: Found left-over process 676 (dnsmasq) in control group while starting unit. Ignoring.
Dez 20 20:45:03 alexander-ms7589 systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Dez 20 20:45:03 alexander-ms7589 systemd[1]: libvirtd.service: Found left-over process 677 (dnsmasq) in control group while starting unit. Ignoring.
Dez 20 20:45:03 alexander-ms7589 plasmashell[887]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5621c7b4ace0) QQmlContext(0x5621c55ae7d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dez 20 20:45:03 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dez 20 20:45:03 alexander-ms7589 plasmashell[887]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dez 20 20:45:11 alexander-ms7589 kernel: kauditd_printk_skb: 108 callbacks suppressed
Dez 20 20:45:12 alexander-ms7589 virtlogd[1897]: Client hit max requests limit 1. This may result in keep-alive timeouts. Consider tuning the max_client_requests server parameter
Dez 20 20:45:13 alexander-ms7589 libvirtd[1745]: g_hash_table_unref: assertion 'hash_table != NULL' failed
Dez 20 20:45:22 alexander-ms7589 kernel: kauditd_printk_skb: 24 callbacks suppressed
Dez 20 20:45:36 alexander-ms7589 plasmashell[887]: kf.plasma.quick: Couldn't create KWindowShadow for ToolTipDialog(0x5621c519bd80)
Dez 20 20:45:48 alexander-ms7589 plasmashell[887]: kf.plasma.quick: Couldn't create KWindowShadow for ToolTipDialog(0x5621c519bd80)
Everything is going good so far. I might be testing this no-sound-via-usbc-dock issue later since I own a Thinkpad which I occasionally plug into my external monitor via USB-C, we will see.
One question though: Linux 6.1 is not marked as LTS in the manjaro kernel tool, but it is an LTS kernel, isn’t it? Is this on purpose oder did I miss something?
Xfce: desktop right-click menu doesn’t work now.
This is my second try. Closed the first window by accident. I think with the first try it updated archlinux keyring.
Had yubikey-manager as ignored package before, because there was some issue with it. Then tried to update incl. yubikey-manager, but no luck.
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: mesa will be installed before its libglvnd dependency
Warning: xorg-server will be installed before its libglvnd dependency
Warning: lib32-mesa will be installed before its lib32-libglvnd dependency
Checking keyring...
Downloading required keys...
Error: keyring is not writable
Error: required key missing from keyring
Failed to commit transaction
Searching around I found this: Signature is invalid. Would that be a viable solution?
You may want to look here :
Firefox runs without interface
After the update, I will probably have again this problem
No major problems with the upgrade to XFCE 4.18 but:
custom formats for the panel clock are not working properly (custom fonts are ignored)
(I think it has already been fixed so it should work properly after the next update)
screenshooter is still not working properly for me (Bug #89)
(it isn’t taking screenshots of the top most window)
– isn’t anyone else having this problem? (it seems to be related to Arch/Manjaro)
– is there a configuration file I can delete to “reset” it (haven’t found one yet)
I found it - Noto Sans Bold
Ok, i fixed following that guide
Thnx…i tried
firefox --new-window about:support
same as before. firefox is starting but no window.
But i found two lines in jounrnalctrl
Dez 20 21:03:37 alexander-ms7589 kded5[868]: org.kde.plasma.appmenu: Got an error
