A post was split to a new topic: Cyberpunk 2077 native crashed since the Update
It does effect encoding, I cannot use hevc_vaapi to encode a video so I’ve switched to Arch ![]()
You can build your own mesa package, it takes less than 5 min when using a good CPU, done.
If you switched to Arch, but you would build and compile many other AUR source packages (e.g: zfs-utils), their build-processes take longer. But they are already in Manjaro repos, no need to build them.
A post was merged into an existing topic: [ARM Stable Update] 2022-12-11 - PlaMo Gear 22.11, Cinnamon 5.6, LXQT 1.2, OpenSSL 3.0 and Kernels
Following @marlop instructions I get hardware decoding working again in mesa:
git clone https://gitlab.manjaro.org/packages/extra/mesa.git
cd mesa
kate PKGBUILD
Add "-D video-codecs=vc1dec,h264dec,h264enc,h265dec,h265enc \" after "-D microsoft-clc=disabled \"
Save and exit from kate
makepkg -si --skippgpcheck
Thank you marlop
Finally struck down with plasma woes - all has been good until this update
I’ve survived the whole upgrade sequence 5.24 to 5.25 to 5.26.2 to 5.26.3 without a hitch
Not sure if it’s the upgrade to 5.26.4 or the plasma-frameworks upgrade which cause the problem …
Specific issues
- plasma crashes when trying to open launcher
- seg fault when running systemsettings5
- today plasma crashes on its own and tries to restore every few seconds until I kill it
I’ve been following the plasma stability threads on the forum.
Can’t seem to find any solution except
- set up a new user
- downgrade to 5.24.7 LTS
I guess I could just remove the 5.26.4 update and see what happens …
Anyone who still has the strength to talk about this …?
Ah, and also, no sound …
Is this Manjaro 22.x or 21.3.7-220816? Came 22.x or new Install ISOs this year? @philm
OpenVPN stopped working - I had to downgrade the packages:
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.5.7-1-x86_64.pkg.tar.zst
sudo pacman -U /var/cache/pacman/pkg/networkmanager-openvpn-1.10.0-1-x86_64.pkg.tar.zst
I think it’s a networkmanager-openvpn problem though. I don’t have time to troubleshoot any further. I just thought I’d let you people know ![]()
The shortcut to open my “home” folder (using SUPER+E here) open the folder in Visual Studio Code (AUR), and mess up all my settings inside VS.
The fix was deactivate the shortcut, and make a new custom shortcut, with the command “nautilus”. Using GNOME here, latest update
Same issue here. It helps restarting pulseaudio - but it seems that applications needs to be restarted in order to output any sounds. This is a real hassle when happening in video calls. Are there any real fix for this ?
And I want to report (in a different post, to not mess the thread) that libx11 is still freezing Firefox tabs.
It’s kind of boring have to downgrade every time that I need to install or update a package.
This package should be downgraded from repo while it don’t get fixed, because the only fix to the 1.8.2 version is installing a AUR package, which don’t have support by Manjaro team.
I updated yesterday.
Today I suddenly noticed that when I start a Jetbrains product, the Xorg process starts grabbing all my systems memory (22GB) and eventually X crashes.
When I run VSCode, my memory usage remains fine, but the Xorg process consumes a full CPU core at 100%.
Note that I use Manjaro as a guest OS in VirtualBox on Windows. Since the issue seems graphics related I tried the following:
- Restart, but without 3d acceleration active in VBox
- Switching from lightdm to ly, to confirm lightdm is not causing the problem
- Switching from kernel 5.10 to 5.4 (since those are the kernels I have at the moment)
No success with those steps.
Any suggestions what I can do next? Is there something I can revert, as this VM is now close to unusable?
Just noticed the message from @rizuhaso , and saw we both use picom (I use it on i3, but same deal).
I killed picom and all is back to normal, so there might have been an issue introduced there.
edit:
There is already an issue open on picom side: A huge performance decrease after v. 10 · Issue #967 · yshui/picom · GitHub
Seems to be introduced in picom 10, which was part of this manjaro update.
It’s now fixed upstream with v107.
Toggling the Firefox GNOME Theme option in Layouts settings will pull the latest release.
Seems the UK mirror is too slow to handle the update
Total ( 8/866) 2.0 GiB 5.14 MiB/s 06:44 [######################] 100%
error: failed retrieving file 'linux-firmware-20221109.60310c2-2-any.pkg.tar.zst' from mirror.cyberhost.uk : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
warning: failed to retrieve some files
error: failed to commit transaction (unexpected error)
You can use pacman-mirrors to let it choose another one.
I had problems a while ago with systemsettings segfaulting on startup. It turned out to be that the theme I was using was buggy and was making some call or other that had been deprecated for a long while. (If memory serves correctly).
I can’t remember how I changed the theme without access to systemsettings, but presumably it was just an edit of one of the config files (possibly ~/.config/kwinrc).
Better check this:
