Oh boy! After typing all that out, I went back into the system settings → Workspace Behaviour → Screen Edges page. I noticed the Highlight Changed Settings button, clicked that and small red dots appeared at various places.
One of these was the Behaviour setting… ‘Remain active when windows are full-screen’.
So I checked the box, clicked Apply - and it’s all back to normal again! Hurrah!
Just to let you know, the issue is related to hardware-accelerated playback.
If I disable VAAPI support for HEVC in Kodi, or disable hardware-accelerated decoding in VLC, there are no more green artifacts.
The issue is not related to one specific hardware although it might be a AMD/Radeon thing. It occurred on a new Ryzen / Radeon RX 6800 and an old AMD A10 rig. I still need to check on the other hardware.
An issue: after the update: the wifi network didn’t work on my tablet (I didn’t try with a cable connection).
I needed a cold reboot and then it worked.
But note I didn’t update my laptop since June.
I don´t know if it was after this update or the previews ones, but samba is not working anymore. I don´t use it a lot so I hadn´t noticed until this days.
I found that none of my USB thumb drives mounted on being plugged into a running system and two internal partitions that previously mounted automatically on boot and logging in no longer did so either. I have never used /etc/fstab entries for these devices.
I fixed the problem for the internal partitions by going into Settings - RemovableStorage - Removable Devices, and adding a tick next to them for on login. After booting and logging in they now mount properly.
For plugging in USB thumb drives, that was fixed by ticking the on attach option.
Had an issue with X11 and Nouveau drivers after updating from a fresh install switching from grub_bios to UEFI. Installed correctly then performed standard updates and when I rebooted X was unable to detect either of my monitors. I had to switch to tty2 and install the proprietary NV drivers to get X to recover.
Hello, I use Manjaro KDE. Given the problems reported on this forum, I have not yet done the September 12th update. My system works perfectly and I have no urgency to update it. I tell myself that the longer I wait, the more chance I have that the bugs will be fixed and my update will be done without any difficulty. What do you think? Should I wait for the next stable update or would it be better if I tried to apply this update now? I’ll have to do it at some point anyway and I’m not sure what’s more prudent. Thanks for your advice!
updates shown in background of screenshot do not match versions in stable branch
according to mbn
Have you checked packages branch compare - https://packages.manjaro.org ?
