[Stable Update] 2022-09-12 - Kernels, LibreOffice, KDE Gear, KDE Frameworks, Firefox, Thunderbird, Pipewire, Mesa
Answer = The time it takes!..! :smile:
Maybe setting autoswitch profiles in the config helps?
The important line in the config is marked bold
Otherwise try to close your software because it’s still reporting as using the device in communications mode?
Modprobe nouveau did not work?
We’re all pretty bored with these questions. A few people actually left because of the delay for 5.25 - and that’s good. We don’t want to be hurried - most people who tried or are using 5.25 agree that it’s pretty buggy and unstable. The benefits far outweighed by the issues it brought - so much so that many people restored snapshots and are still rocking the LTS 5.24.
Meanwhile everyone gets excited about bleeding edge - and you can have that by switching. If you go to Stable, you don’t get excited or look forwards to new stuff. You wait until it’s polished enough for the team to mutually agree that it’s not going to cause instability.
So the answer is: Nobody has a clue, and nobody interested in ā€˜Stable’ really gives a toss :wink:
From my side I will wait as much as possible; I just hope @Philm will give us ā€œrenegadesā€ a reminder when it is the most mandatory time to update.
Regards
You’ll need to reconfigure Samba.
In my case, since 3 or 4 updates ago I lost the functionality and configuration of Samba; it was working fine before that (at work and home).
To date I have managed to ā€œfix itā€ but not 100%.
I had to download a Samba configuration file; but I don’t remember if it was from a how to or from the Samba project and tuned it until I could have something functional (at work).
At home, I only used it to share files with other computers but due to ā€œlack of interestā€ on my part I haven’t tried to fix it anymore.
Regards
Thank you very much for your interest. I did provide a clean smb.cnf , now the smb y nmd services are running but I cannot manually share a folder. It shows this error:
when I give a Read Only permit to Everyone and full control to my user and try to share from Dolphin menu.
Like you, that’s exactly why I don’t have 100% corrected my problem. :frowning_face:
I can create the shared folders, but I can’t access them… I can think of something, if it works I’ll let you know.
I’m following this wiki, but it hasn’t worked for me yet.
https://wiki.archlinux.org/title/Samba
I have Manjaro KDE with 9/12 update on two machines, both are fine, just as stable as before.
I only had one issue, which was with autostart - easily resolved (after understanding the issue) by removing ā€œsleep 5 &&ā€ type shell commands from the ā€œExec=ā€ line (in my case I called a script instead).
I do not expect this to change over time. Source:
