Having a problem with sqlitebrowser after this update.
DB Browser for SQLite Version 3.12.2
Built for x86_64-little_endian-lp64, running on x86_64
Qt Version 5.15.4
SQLCipher Version 4.5.1 community (based on SQLite 3.37.2).
Steps to cause the problem-
Open a database
select a table
Modify Table
The application crashes with-
/usr/include/c++/12.1.0/bits/basic_string.h:1292: std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::const_referenc
e std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::front() const [with _CharT = char; _Traits = std::char_traits<
char>; _Alloc = std::allocator<char>; const_reference = const char&]: Assertion '!empty()' failed.
Aborted (core dumped)
Anyone noticed this or have any help fixing?
system
KDE Plasma Version: 5.24.5
KDE Frameworks Version: 5.94.0
Qt Version: 5.15.4
Kernel Version: 5.15.46-1-MANJARO (64-bit)
Graphics Platform: X11
Just updated to the latest update, and it seems to break compatibility to my wifi dongle (Macbook Air 6,2 with kaput WiFi module)
I’m currently using the Edimax N150 nano. It is detected in lsusb:
Bus 001 Device 011: ID 7392:b811 Edimax Technology Co., Ltd Edimax N150 Adapter
Previously the device was supported in the kernel and was plug and play.
It might be a kernel or linux-header issue? Anyway, went back to kernel LTS and no improvement. Not too experienced with working with the kernel so assistance would appreciated.
LA-MJ
17 June 2022 10:27
155
A stupid question, maybe, but why is akonadi insisting on a ‘proper’ DB anyway? Seems to be user-hostile for me. SQLite would do just fine, I’d bet
(Sorry, I cannot include links so breaking up the links over the following lines.)
https://
techbase.kde.
org/KDE_PIM/Akonadi#Why_not_use_sqlite.3F
Since the last update all of the audio profiles, of which there used to be more than a dozen, both analogue and digital, stereo, surround, with or without input, etc, in pavucontrol, are gone, replaced with just one: “play HiFi quality music” (well two, the other one being off). Now audio still works, so all would be fine except… somehow it defaults to 5 channels, with no way to change this. This means whenever l play multichannel audio, like a movie, some of the audio is completely gone, most notably dialogue in movies. I have a 2.1 speaker system and l used to use the “analogue 2.1 surround output” profile which is now completely gone as stated before.
I have tried switching to pipewire from pulseaudio, but the same issue remains, except now the only option l have is “play HiFi quality music (unavailable)”, which still works the same way as before.
I have also tried downgrading pavucontrol and using the 5.15, 5.17 and 5.18 kernels but the same issue remains across all of these.
Does anyone have the faintest idea what has changed recently that might have caused this issue? I am at a loss.
hm, update today? some Kernel and other stuff?
Just fast-tracked security updates mostly.
donald:
Qt Version 5.15.4
Open a database
select a table
Modify Table
system
Qt Version: 5.15.4
I can confirm this behavior.
Journalctl
Jun 17 22:34:16 Duke-Linux systemd[1]: Started Process Core Dump (PID 551679/UID 0).
Jun 17 22:34:16 Duke-Linux audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-551679-0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 17 22:34:16 Duke-Linux kernel: audit: type=1130 audit(1655498056.860:2824): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-551679-0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 17 22:34:17 Duke-Linux systemd-coredump[551680]: [🡕] Process 551600 (sqlitebrowser) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 6d0076793e703c9023e698b44de04fd89adaa8f4
Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
Module KF5WindowSystemX11Plugin.so with build-id 0f95b9e833f6de379cd74a20fcef66e5a524d34e
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libvulkan.so.1 with build-id 198212a538d4e3b290530d75a0614e803b03d39e
Module libdrm_nouveau.so.2 with build-id b2c524cff6f5c2985e856447f3b043e4fcf0c621
Module libdrm_amdgpu.so.1 with build-id c640056cb2a0368cf57821d3f0536154248ae845
Module libelf.so.1 with build-id c09e357a1a3b061bf219bcfb243ca31b175e77fa
Module libdrm_radeon.so.1 with build-id 8ebce86cd4f588778560618c8861b6d760fcb39a
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-13.so with build-id 90a760361bef9d2de117d7e696dad26fc4cb24f4
Module radeonsi_dri.so with build-id e2e27e10e2097902c17c86abfecafd84982cd15d
Module libxshmfence.so.1 with build-id d9b3ce4edb0b6a0818bcc57dda020d2da5e3c895
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libXxf86vm.so.1 with build-id b8b37b0c66be0a760a8491e3c86a00c4efdc825d
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libdrm.so.2 with build-id 658072e933ab3de11aea1408bdf4e72dd6e80255
Module libglapi.so.0 with build-id a70a43d9f7f14dc475bd3eb8894e06a7bb5b2396
Module libGLX_mesa.so.0 with build-id 39bb8e3d969268ca9ce476e6ae98f401f630ab88
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libqxcb-glx-integration.so with build-id 94a60c6db58e9174d381312b0bcc97a5f7f4c7fd
Module libqnmbearer.so with build-id 556f20487c407c331cfa6257ab01d6f5c4df7929
Module libqgenericbearer.so with build-id 941d14c48c5d7410c15ee0142b014812e68a370f
Module libqconnmanbearer.so with build-id f2d3ea08d258b9ed861c7212b999c3d8b00d2d9b
Module libwebp.so.7 with build-id 0add7a572705244ed810b7e722cce7da0dcfb62c
Module libwebpdemux.so.2 with build-id 7bc15ac239db643015e169a2c6cc822156eb999a
Module libwebpmux.so.3 with build-id 4232d5263a45719ba12f58ed7d8cae3a0fc887de
Module libqwebp.so with build-id 7ce298b0eb70ffcb39feb02a379df70c6ca41c7a
Module libqwbmp.so with build-id 06ec412bb0fe475375958889e7c9a6bb874191bb
Module libtiff.so.5 with build-id 31895d2bd133f34f0cdc2d4ac855ed838ec927b6
Module libqtiff.so with build-id b5209ba8b013de8982ebfc75b4c2578e8a92557a
Module libqsvg.so with build-id 0993859f4fc44079d066000de1a17b7404cd57bd
Module libQt5Pdf.so.5 with build-id a7b200fa44cd69604743d26a07b4f4fe492288aa
Module libqpdf.so with build-id b7f5880b623a78185baff982174fb7eee133111e
Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
Module libqmng.so with build-id 3ba015b119de2676fd247d76ed04f46b8615b219
Module libqjpeg.so with build-id 401ac0afc471d14665b2aa19aced820fe890b1ab
Module libjasper.so.6 with build-id 180a8afe8b317a0c36114a7692a41a7df58cc18a
Module libqjp2.so with build-id 87b413c4a17bebbcb5699218053f77891165735c
Module libqico.so with build-id 5e3c757b84a147c37cc1402eae76ab167ae92ff8
Module libqicns.so with build-id 38229870fe752570e94e04c36d253c4fcf909547
Module libqgif.so with build-id ff017261e688f25986417facf58746b825e26639
Module kimg_xcf.so with build-id 4a72e7475f494ec33065d8be156956442cf1ffaf
Module kimg_tga.so with build-id 44b81daad65b4cf769e45e42fb89339de813d8be
Module kimg_rgb.so with build-id b9b2b5582449206b9b30d62935f98d282b651770
Module kimg_ras.so with build-id 34a19e806dd0eeb1152fab4b33a863dec80339f4
Module kimg_psd.so with build-id c0a875602a81f0bdee38c36c56dc40da31c8a4f7
Module kimg_pic.so with build-id c1aa1ede3f1128d6b7ab73b32683a2efc0807c2b
Module kimg_pcx.so with build-id 87fb9a7db67c29ebc7d0ae537262c2836eab9dc9
Module kimg_ora.so with build-id f9240ba55fb1206d6fbd0bbf39db6cb6a7bd73be
Module kimg_kra.so with build-id 58185acecedecf9de44cc5b07ac9442ee678d560
Module libmvec.so.1 with build-id 2c6aec81c79e91d66940b68be0819fdf780a976c
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libde265.so.0 with build-id 459cf009e847aef8f1589ad39b1573351b6a3b22
Module libheif.so.1 with build-id 64bccee060b5f2b512bc5ab529a4030b4f58ea8b
Module kimg_heif.so with build-id 3e5728db24f1bac2d4b8d6261c5789de1fcbcd84
Module kimg_hdr.so with build-id 25e6128595f247d77ff5f241d2ffd08e39f56feb
Module libIlmThread-3_1.so.30 with build-id fb61aaa8abdf748eb68984c0ef25b0ae85a6565f
Module libIex-3_1.so.30 with build-id 5e8a8f33fa7d4b83185155f19d4604501a86cf62
Module libImath-3_1.so.29 with build-id 4c19b87c4e4467447b18d010cd539647a59d5b69
Module libOpenEXR-3_1.so.30 with build-id 875e7df47bd5ce2de8806bb9fa046061fa43a8ef
Module kimg_exr.so with build-id fbcf5e991a5070a95a4e3fd8179e2fdf2d78f83d
Module kimg_eps.so with build-id c74fc028384030ad507949489dab378f5e5cf473
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libyuv.so with build-id 60a987609f24d8125baf7f8f2a3b288eb465d87e
Module libaom.so.3 with build-id 3c057fe8c5fa7033366274352148acb4dbb42728
Module libSvtAv1Enc.so.0 with build-id e9143f88be53d2aebfa4f9249295869f09e22be4
Module librav1e.so.0 with build-id 5f8fc2c271f0d96480ab1c71447e038a66aa1c57
Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
Module libavif.so.14 with build-id c3f6742d29e2300e3e8137afb9990d29e24d232a
Module kimg_avif.so with build-id cef998479c04761b0f5f3b9ee6bb4cee6f33296e
Module kimg_ani.so with build-id c6f6d543c258f14e4f0ebb7397f3af422fed0f2a
Module libKF5Style.so.5 with build-id 2f783b08f38130cd7505355926c5b1b4f40ffa0d
Module libbreezecommon5.so.5 with build-id 77c790abf2eabfd63a7d7b698fe772ec269ae399
Module breeze.so with build-id 7672b9b70c38d06cc51130e8a3f9543abbb18e3b
Module libcomposeplatforminputcontextplugin.so with build-id 2ab947c17a1c6488b2d323ac2e0225462d519d75
Module libdl.so.2 with build-id 94198b268228074fa9f405bbedbbae94112593ed
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 9577a5fe1921756af97b2af318ff1c9a03f10a84
Module libnettle.so.8 with build-id a2cc6a257b0729585e870b345b83497c478ee28b
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libwayland-cursor.so.0 with build-id 647d92328111682fb15bff1c20a4c9368414857c
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libgnutls.so.30 with build-id a4f42d33fc809cb6f596998001cedc0bce06c751
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libQt5QmlModels.so.5 with build-id 3aca8e95972fa0b56402ca9d5cf2f101ba4fdd1c
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libltdl.so.7 with build-id c4ee3f1ba09fe34163d71ff336756fbecb6f409f
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libKF5DBusAddons.so.5 with build-id f67c4bdbe31ff35dd1e346189c811bf229ab4e1a
Module libQt5WaylandClient.so.5 with build-id 5dd9df738053f852cc9ff2bd24f423e6c77f1306
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libudev.so.1 with build-id bce2b8a5c23fcbcf5542f34b741e18db4452160a
Module libKF5Archive.so.5 with build-id 7f7d5190814159c6d5b8ebbcce35882228189b09
Module libQt5Svg.so.5 with build-id 74fc2741f02d4a0e0f7585a36f607656d18361bb
Module libKF5GlobalAccel.so.5 with build-id 8ee8124cf99d22889be965d3fbc13755322f4883
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libKF5AuthCore.so.5 with build-id 17d36834cf80899ab927f56074161ef188386177
Module libKF5Crash.so.5 with build-id 5793e2b3bf81a9142cfb833115d1bbb7ffaf669d
Module libQt5QuickTemplates2.so.5 with build-id f5f8b20178c9134647997dc37eaea2a7b17329ce
Module libQt5Qml.so.5 with build-id 3302afd50e5fb5cc942267e9cad5746e4c125ce1
Module libQt5Quick.so.5 with build-id e64c8602e59b921835da1ffa74aa5a3bfa52a296
Module libwayland-client.so.0 with build-id 95e7368b400dd57e3db2a5c385de71c7dca08879
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id 35c7f3daf454834acb724e6bd1664b0a2e9a6494
Module libQt5TextToSpeech.so.5 with build-id e5a59ae504c2f3b55b8c881e148a9f4ee5361273
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libKF5Service.so.5 with build-id 12d2ed6e76be6a13381da83759510bf3a6f725ac
Module libKF5Codecs.so.5 with build-id 49750e18a1134ad0d63d678b6ef4cd486b44f483
Module libKF5GuiAddons.so.5 with build-id 45ccfeaacbf8be163b88edab17b62e6c918e7437
Module libKF5ItemViews.so.5 with build-id fab874f5c8eb4f8c4696851adb78f9acf5997886
Module libKF5KIOGui.so.5 with build-id c49f2e1aecdea0eb7735bbd3e149bf70adf70f0f
Module libKF5Solid.so.5 with build-id 145412e41ec1eb1b7fb70653e938232d1216da07
Module libKF5Bookmarks.so.5 with build-id 6d2038950221a930285b15a0742f8d4c7a355b4a
Module libKF5CoreAddons.so.5 with build-id 273e7c5a7cb2fbabf0d895cb82de5e5f191e9f6b
Module libQt5X11Extras.so.5 with build-id cc47e381ac9469803fd53bee418d952ad2782202
Module libKF5WindowSystem.so.5 with build-id b4733339e1c479aa3aeaf0b6a6335509b39f7c61
Module libKF5ConfigCore.so.5 with build-id 834d1bd13d3bbac5fd141fa08b79d19e7727674d
Module libKF5WidgetsAddons.so.5 with build-id 392cedd1407dc850e8676f2315992b4804ccb012
Module libKF5I18n.so.5 with build-id cf7ec4c5553f328a931bf91583809338409c3e52
Module libKF5ConfigGui.so.5 with build-id 1c964c60eba88258e448acd062029a683c48baf1
Module libKF5ConfigWidgets.so.5 with build-id 9698f3a275bfaca7d5d4ecd87594db94cb9daacc
Module libKF5IconThemes.so.5 with build-id 7086d24255d1a52fbc46005df5152910076ae416
Module libKF5XmlGui.so.5 with build-id 0a68991da6374820ab277392432312cc733ac977
Module libKF5Completion.so.5 with build-id 208a4c6a1a1c98a5d1c825761993cfca184ed8db
Module libKF5JobWidgets.so.5 with build-id 9ce0eb2dd536864ec351c4a6035defeaad134638
Module libKF5KIOCore.so.5 with build-id 1a92d633d7ee99315c9ee76b901f05341b7e8663
Module libQt5QuickControls2.so.5 with build-id 10628b28024a67041a939455f6d9d3ad6266cdd7
Module libKF5WaylandClient.so.5 with build-id 1bd92bc82300211faf1ee4642e2c0ee624cdf0b5
Module libKF5Notifications.so.5 with build-id 9346ac445cfb2db35e59320ec9478439078dcd3f
Module libKF5KIOWidgets.so.5 with build-id 36ea01fdfefbeaafe56c011cddce2c186924a28a
Module libKF5KIOFileWidgets.so.5 with build-id 399b54ad854db4f1bcff07c269987cab2d9ea33e
Module KDEPlasmaPlatformTheme.so with build-id 4384f6334c07a5d9594c444c5691fb3d1a23108b
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libuuid.so.1 with build-id 032a21acd159ee3902605e9911be5f86a7df7df9
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libQt5DBus.so.5 with build-id 6f6c582da4c0fed28f1e4595552cf5ee3792447a
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libQt5XcbQpa.so.5 with build-id b9e07e5f5a19ba50b421679c19167f10f8728807
Module libqxcb.so with build-id 73480e75ec0539b1ed9fe019185f47f1d131cfd1
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libX11.so.6 with build-id 310f8f1b8d7457d326407e0eb794353c62769b73
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libresolv.so.2 with build-id 89a368a6ad1b392d126a2a5beb9c2f61ade00279
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 15f223925ef59dee4379ebbc0fcd14eda9ba81a2
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id cc77a742cb62447a53d98285b41558b8acd92866
Module libkrb5.so.3 with build-id 371cc767dacb17cb42c9c44b88eebbed5ee9a756
Module libglib-2.0.so.0 with build-id f1d15261ce1317b9003a1f0957d5a528d063f630
Module libzstd.so.1 with build-id bd9a65f663b7f48e1427c418714eb8d005c37f71
Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libsystemd.so.0 with build-id 6430b2bd03335142b596061e30d2508dc604a1b4
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id c58fe082cbde02fc176e3c3663a6d81386eb5027
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libssl.so.1.1 with build-id 25a55106cb13dec5d495c34ca1caf2c2f3114f11
Module libgssapi_krb5.so.2 with build-id 292f1ce32161c0ecc4a287bc8494d5d7c420a03f
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libm.so.6 with build-id 1b7296ef9fd806e47060788389293c824b09ad72
Module libstdc++.so.6 with build-id b3eaebcb5369487562e52dd8d016c9cd77f80c54
Module libQt5Core.so.5 with build-id 20e730c5e451c6dc0e3d1db771d53ce89097b92e
Module libQt5Gui.so.5 with build-id 95f8814f57816338b77f1ee4e5eefc233c4ac1b7
Module libqscintilla2_qt5.so.15 with build-id ab69eebaf906ca85bf855d79ea5a8fb5af4f3619
Module libqcustomplot.so.2 with build-id b93630e125839ed484261c27a8768652a1734df6
Module libqhexedit.so.4 with build-id fe5336e2033da19da3e10c82df92e0a63c932065
Module libsqlcipher.so.0 with build-id ce4470c8c40c72641a4171f07bd4bb1053d75e5e
Module libQt5Xml.so.5 with build-id 76adbc3352f238c19f022496533dd239a8ad0f78
Module libQt5Network.so.5 with build-id 8dc75aad55d65c8596be9289f9b725e250b9ffb5
Module libQt5Widgets.so.5 with build-id a975fdcde9ab16194afb85f72bdfa36754c221f6
Module libQt5PrintSupport.so.5 with build-id 94d3fc8b99c909e692d302bb71553cefff77795b
Module sqlitebrowser with build-id 6d2f1cef51c9b86db5051e76f3a7d5be47921c16
Stack trace of thread 551600:
#0 0x00007f6090a8e36c n/a (libc.so.6 + 0x8e36c)
#1 0x00007f6090a3e838 raise (libc.so.6 + 0x3e838)
#2 0x00007f6090a28535 abort (libc.so.6 + 0x28535)
#3 0x00007f6090ed2002 _ZSt21__glibcxx_assert_failPKciS0_S0_ (libstdc++.so.6 + 0xd2002)
#4 0x0000559986a34820 _ZN15EditTableDialog14populateFieldsEv (sqlitebrowser + 0xd0820)
#5 0x0000559986a30879 _ZN15EditTableDialogC1ER11DBBrowserDBRKN4sqlb16ObjectIdentifierEbP7QWidget (sqlitebrowser + 0xcc879)
#6 0x0000559986a7a2dc _ZN10MainWindow10editObjectEv (sqlitebrowser + 0x1162dc)
#7 0x00007f60914be288 n/a (libQt5Core.so.5 + 0x2be288)
#8 0x00007f609296be07 _ZN7QAction9triggeredEb (libQt5Widgets.so.5 + 0x16be07)
#9 0x00007f6092971817 _ZN7QAction8activateENS_11ActionEventE (libQt5Widgets.so.5 + 0x171817)
#10 0x00007f6092af38cb n/a (libQt5Widgets.so.5 + 0x2f38cb)
#11 0x00007f6092af39ed n/a (libQt5Widgets.so.5 + 0x2f39ed)
#12 0x00007f60929af677 _ZN7QWidget5eventEP6QEvent (libQt5Widgets.so.5 + 0x1af677)
#13 0x00007f6092978a7c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178a7c)
#14 0x00007f609297e289 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x17e289)
#15 0x00007f609148db28 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28db28)
#16 0x00007f609297c287 _ZN19QApplicationPrivate14sendMouseEventEP7QWidgetP11QMouseEventS1_S1_PS1_R8QPointerIS0_Ebb (libQt5Widgets.so.5 + 0x17c287)
#17 0x00007f60929cd824 n/a (libQt5Widgets.so.5 + 0x1cd824)
#18 0x00007f60929cf0ee n/a (libQt5Widgets.so.5 + 0x1cf0ee)
#19 0x00007f6092978a7c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178a7c)
#20 0x00007f609148db28 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28db28)
#21 0x00007f609193f01c _ZN22QGuiApplicationPrivate17processMouseEventEPN29QWindowSystemInterfacePrivate10MouseEventE (libQt5Gui.so.5 + 0x13f01c)
#22 0x00007f6091928965 _ZN22QWindowSystemInterface22sendWindowSystemEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Gui.so.5 + 0x128965)
#23 0x00007f608d930de0 n/a (libQt5XcbQpa.so.5 + 0x63de0)
#24 0x00007f6090c6ec6b g_main_context_dispatch (libglib-2.0.so.0 + 0x54c6b)
#25 0x00007f6090cc5001 n/a (libglib-2.0.so.0 + 0xab001)
#26 0x00007f6090c6c392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#27 0x00007f60914d827c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d827c)
#28 0x00007f60914862ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2862ec)
#29 0x00007f6092afb168 n/a (libQt5Widgets.so.5 + 0x2fb168)
#30 0x00007f6092afb283 _ZN5QMenu4execERK6QPointP7QAction (libQt5Widgets.so.5 + 0x2fb283)
#31 0x0000559986a745a4 _ZN10MainWindow21createTreeContextMenuERK6QPoint (sqlitebrowser + 0x1105a4)
#32 0x00007f60914be288 n/a (libQt5Core.so.5 + 0x2be288)
#33 0x00007f60929b099a _ZN7QWidget26customContextMenuRequestedERK6QPoint (libQt5Widgets.so.5 + 0x1b099a)
#34 0x00007f60929afa35 _ZN7QWidget5eventEP6QEvent (libQt5Widgets.so.5 + 0x1afa35)
#35 0x00007f6092a53bf3 _ZN6QFrame5eventEP6QEvent (libQt5Widgets.so.5 + 0x253bf3)
#36 0x00007f609148d792 _ZN23QCoreApplicationPrivate29sendThroughObjectEventFiltersEP7QObjectP6QEvent (libQt5Core.so.5 + 0x28d792)
#37 0x00007f6092978a6c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178a6c)
#38 0x00007f609297d292 _ZN12QApplication6notifyEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x17d292)
#39 0x00007f609148db28 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28db28)
#40 0x00007f60929cdd84 n/a (libQt5Widgets.so.5 + 0x1cdd84)
#41 0x00007f60929cf0ee n/a (libQt5Widgets.so.5 + 0x1cf0ee)
#42 0x00007f6092978a7c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178a7c)
#43 0x00007f609148db28 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28db28)
#44 0x00007f609193f01c _ZN22QGuiApplicationPrivate17processMouseEventEPN29QWindowSystemInterfacePrivate10MouseEventE (libQt5Gui.so.5 + 0x13f01c)
#45 0x00007f6091928965 _ZN22QWindowSystemInterface22sendWindowSystemEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Gui.so.5 + 0x128965)
#46 0x00007f608d930de0 n/a (libQt5XcbQpa.so.5 + 0x63de0)
#47 0x00007f6090c6ec6b g_main_context_dispatch (libglib-2.0.so.0 + 0x54c6b)
#48 0x00007f6090cc5001 n/a (libglib-2.0.so.0 + 0xab001)
#49 0x00007f6090c6c392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#50 0x00007f60914d827c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d827c)
#51 0x00007f60914862ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2862ec)
#52 0x00007f6091490dd9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x290dd9)
#53 0x00005599869fb8f0 main (sqlitebrowser + 0x978f0)
#54 0x00007f6090a29290 n/a (libc.so.6 + 0x29290)
#55 0x00007f6090a2934a __libc_start_main (libc.so.6 + 0x2934a)
#56 0x00005599869fe775 _start (sqlitebrowser + 0x9a775)
Stack trace of thread 551605:
#0 0x00007f6090a89119 n/a (libc.so.6 + 0x89119)
#1 0x00007f6090a8bc24 pthread_cond_timedwait (libc.so.6 + 0x8bc24)
#2 0x00007f60912eb734 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb734)
#3 0x00007f60912e85c7 n/a (libQt5Core.so.5 + 0xe85c7)
#4 0x00007f60912e435a n/a (libQt5Core.so.5 + 0xe435a)
#5 0x00007f6090a8c54d n/a (libc.so.6 + 0x8c54d)
#6 0x00007f6090b11874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 551604:
Stack trace of thread 551603:
#0 0x00007f6090b05c3f __poll (libc.so.6 + 0x105c3f)
#1 0x00007f6090cc4f68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2 0x00007f6090c6c392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3 0x00007f60914d827c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d827c)
#4 0x00007f60914862ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2862ec)
#5 0x00007f60912e752f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe752f)
#6 0x00007f60912e435a n/a (libQt5Core.so.5 + 0xe435a)
#7 0x00007f6090a8c54d n/a (libc.so.6 + 0x8c54d)
#8 0x00007f6090b11874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 551610:
#1 0x00007f6090a8b920 pthread_cond_wait (libc.so.6 + 0x8b920)
#2 0x00007f606ceb28cc n/a (radeonsi_dri.so + 0xb28cc)
#3 0x00007f606ceac05c n/a (radeonsi_dri.so + 0xac05c)
#4 0x00007f6090a8c54d n/a (libc.so.6 + 0x8c54d)
#5 0x00007f6090b11874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 551607:
Stack trace of thread 551606:
Stack trace of thread 551612:
Stack trace of thread 551613:
Stack trace of thread 551615:
Stack trace of thread 551616:
Stack trace of thread 551622:
Stack trace of thread 551602:
#6 0x00007f608dd6675a n/a (libQt5DBus.so.5 + 0x2375a)
#7 0x00007f60912e435a n/a (libQt5Core.so.5 + 0xe435a)
#8 0x00007f6090a8c54d n/a (libc.so.6 + 0x8c54d)
#9 0x00007f6090b11874 __clone (libc.so.6 + 0x111874)
Stack trace of thread 551609:
#2 0x00007f6090eced71 __gthread_cond_wait (libstdc++.so.6 + 0xced71)
#3 0x0000559986adef7c _ZN9RowLoader3runEv (sqlitebrowser + 0x17af7c)
Stack trace of thread 551601:
#1 0x00007f608de7920b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f608de7accd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
#3 0x00007f608d92ea02 n/a (libQt5XcbQpa.so.5 + 0x61a02)
Stack trace of thread 551618:
Stack trace of thread 551617:
Stack trace of thread 551614:
Stack trace of thread 551620:
Stack trace of thread 551619:
Stack trace of thread 551628:
Stack trace of thread 551621:
Stack trace of thread 551623:
Stack trace of thread 551624:
Stack trace of thread 551626:
Stack trace of thread 551627:
Stack trace of thread 551611:
Stack trace of thread 551663:
Stack trace of thread 551625:
Jun 17 22:34:17 Duke-Linux systemd[1]: systemd-coredump@0-551679-0.service: Deactivated successfully.
Jun 17 22:34:17 Duke-Linux kernel: audit: type=1131 audit(1655498057.833:2825): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-551679-0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 17 22:34:17 Duke-Linux audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-551679-0 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jun 17 22:34:17 Duke-Linux systemd[1652]: app-sqlitebrowser-a2b5b114dd714a23861e35709a244bae.scope: Consumed 2.184s CPU time.
Had an Issue with KDE PIM Akonadi and was able to resolve it with the solution posted in the second post.
Due to this upgrade I have an issue with SDDM, which might be due to a broken QT-setup. Created a separate post for it:
After upgrading my manjaro vm to latest stable, the system (guest) is broken. It boots, it shows the login screen briefly but then it disappears. So I cannot login.
What I found is that qt seems to be missing stuff.
[image]
So how do I proceed here?
I don´t have akonadi, nor do I have qt5-styleplugins. The only thing that is somewhat strange is python:
[image]
guest kernel is 5.10
EDIT 1: downgraded python-qt package with sudo pacman -Syyuu. This does not solve the problem however.
Reminded of this old post that might help you… Audio not working - #10 by Daniel-I
Yochanan
Split this topic
20 June 2022 21:02
165
Something in this update fixed my extreme slow boot!
Dolphin still randomly closes itself whenever I try to do anything (start it, change folders, create folders, select files, delete files, focusing the window, …). There is no useful output in my regular setup. When I start it with “\dolphin”, I only get “Segmentation fault (core dumped)”. Downgrading also does not help. Does someone have an idea? Does this happen to anyone else?
j77h
20 June 2022 12:49
168
Actually it has fixed the virtualbox problem .
linux515 5.15.46-1 → 5.15.48-1
linux515-virtualbox-host-modules 6.1.34-14 → 6.1.34-17
EDIT 1 :
I’ve had many unexpected restarts that I don’t think were Windows’ fault.
Looks like we have to wait for vbox 6.1.35 or 36, see this forum .
EDIT 2 (2022-06-22) :
Just realized that vbox 6.1.34 is working OK with linux 5.18
It was mentioned here 6 days ago, but I didn’t notice because the noise to signal ratio is so high
Gnome Boxes can not create new VMs anymore. Existing VMs seem to work fine.
Error message:
(gnome-boxes:12009): Boxes-WARNING **: 21:28:22.340: review-page.vala:44: Box setup failed: Domain konnte nicht erzeugt werden: unsupported configuration: chardev 'spicevmc' not supported without spice graphics
(gnome-boxes:12009): Boxes-CRITICAL **: 21:28:22.340: boxes_assistant_review_page_populate: assertion 'machine != NULL' failed
This is a known issue: Stuck in a Allocating ressources creating vm (#806) · Issues · GNOME / GNOME Boxes · GitLab
Edit: Today’s update to boxes 42.1.1-0 fixed it.
flowblade does not start:
haven’t tried it for a long time, so it might have broken earlier.
CarlLaFong:
beep
This beep occures only on Wayland, not xorg at least on my Gnome-PC
