Since I updated my system I lost wifi. I use an usb wifi adapter from tp-link (TL-WN725N) which worked without a problem until now. Now it’s not recognized. Well, it’s recognized by inxi and under usb devices, but the network widget doesn’t recognize it.
Solved!: Since I updated my system I lost wifi - #10 by Artopal
Hi, @Artopal ,
Welcome to the forum. I wonder whether you could read this post in order to solve the problem.
‘Cannot connect to WIFI! - #4 by Njfamirm ’.
Hope it help, regards.
Hi, thanks for the help.
That sadly didn’t solve my problem.
I hadn’t any package named 8188eu-dkms
to remove.
I tried the mhwd
command, but to no avail. Wifi is still not working.
What baffles me is this: I didn’t have to install any drivers to make it run in the first place. This wifi adapter was plug’n’play since day one. I put it in and the network manager began to work. Only after the update did it stop working. The adapter is detected under USB devices, but there is now no driver for it under Hardware Configuration.
Weird.
Hi @Artopal ,
I cannot give you a better answer unless you could post the output of the following terminal command:
inxi -v7azy
Regards,
Sure. Here. And thanks again for the help.
~ inxi -v7azy ✔
Kernel: 5.18.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=f58aedac-3a7f-4257-be7b-9dc4408c7ca5 rw amdgpu.freesync_video=1
quiet udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: A520M H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: A520M H v: x.x serial: <superuser required>
UEFI: American Megatrends v: F1 date: 06/01/2020
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 20% rechargeable: yes status: discharging
RAM: total: 15.57 GiB used: 2.59 GiB (16.7%)
RAM Report:
Info: model: AMD Ryzen 5 3500X bits: 64 type: MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2399 high: 3593 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2174 2: 2053
3: 3593 4: 2189 5: 2193 6: 2195 bogomips: 43135
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA 1
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 0a:00.0
chip-ID: 1002:7340 class-ID: 0300
Device-2: Logitech C505e HD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-2:3 chip-ID: 046d:08e4
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Gigabyte G34WQC
serial: <filter> built: 2020 res: 3440x1440 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
OpenGL: renderer: AMD Radeon RX 5500 XT (navi14 LLVM 13.0.1 DRM 3.46
5.18.5-1-MANJARO)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 3-2:3 v: kernel pcie: chip-ID: 046d:08e4
gen: 4 class-ID: 0102 speed: 16 GT/s serial: <filter> lanes: 16
bus-ID: 0a:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C505e HD Webcam type: USB
Sound Server-1: ALSA v: k5.18.5-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: N/A bus-ID: 1-4:2 chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
driver: btusb v: 0.8 bus-ID: 3-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 931.51 GiB used: 422.87 GiB (45.4%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 35.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 422.87 GiB (46.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: f58aedac-3a7f-4257-be7b-9dc4408c7ca5
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: C423-1EBF
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-4:2 info: Realtek RTL8188EUS 802.11n Wireless Network Adapter
type: WiFi driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-7:3 info: Logitech Logi TKL Mechanical Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 046d:c345 class-ID: 0300
Device-3: 1-8:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-4: 1-9:5 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 3-2:3 info: Logitech C505e HD Webcam type: Video,Audio
power: 500mA chip-ID: 046d:08e4 class-ID: 0102 serial: <filter>
Device-3: 3-3:4 info: Valve Wireless Steam Controller type: Keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28de:1142 class-ID: 0300
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 39.0 C mem: 0.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1330
Processes: 243 Uptime: 4h 16m wakeups: 14 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1633 lib: 502 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
That device has no driver. But there is one for it in the AUR:
$ pamac search 8188eu-dkms
8188eu-dkms v4.3.0.8_13968-16 AUR
Driver for Realtek RTL8188EUS (RTL8188EUS, RTL8188ETV) WLAN
So try installing it with:
pamac build 8188eu-dkms
Edit:
As @brahma said, trying different kernels might also be a good idea. And yours:
Artopal:
…isn’t LTS. While I’ve personally never encountered it, I have heard that regressions sneak in on non-LTS versions. So that might also be a reason. See
…for more information.
Unknown. ¯\_(ツ)_/¯:
Sadly that didn’t work.
Trying the last LTS also didn’t work.
Oh, well, trying the 5.10 LTS kernel did the trick. With 5.15 LTS and 5.18 the device is just not usable.
Problem solved, I guess.
Thank you all for the help!
