Was this update a large one for everyone else too?
Usually it’s about 1.9GB with my setup, but this time it’s 2.9.
KB is it connected directly to the pc – or via some dock/hub? PS/2 or USB?
Attempting to install this update produced an error about unable to install nvidia drivers utils, it kept saying kernel required this version, which was all my kernels so uninstalling all the kernels and letting the update complete and then I reinstalled two kernels 517 and 515 and I am met with infinite loading screen of / now how I fixed it was by using this key combo to enter tty3 ctrl + alt + 3 and I was able to see that some how the nvidia kernel module wasnt installed, installing that fixed it, took me 30 minutes though so im not happy…
I just updated and since, a ls -l
or running flatpak app is very long (around 30s vs immediate for a normal ls
). I am using a LUKS filesystem
> time ls
real 0m0,002s
user 0m0,002s
sys 0m0,000s
> time ls -l
real 1m30,297s
user 0m0,007s
sys 0m0,001s
Hi Team,
Some of you might face issues as I did, with Postgres upgrading to major version 14.
Please follow this link.
Yeah, it’s 5.9 GB for me this time. Seems like quite the chonky update.
Packages both in AUR and in repositories should prefer the repository package.
You can check the package version in the repositories at: Packages
If there is no result for a package, it is unavailable/dropped from the repositories.
You should open a dedicated thread for your issue: [HowTo] Request support
This usually happens when trying to update while keeping an EOL kernel installed. The EOL kernel should be removed first – after switching to a supported (newer or LTS) kernel beforehand.
Now it is gone, but one time over two I cannot login. I can’t see an obvious diff between a successful login and when I can’t (GDM shows the loading icon, until it freezes). I have notice that the package tuxedo-keyboard was replaced by tuxedo-keyboard-dkms, maybe there is an issue with my hardware and the kernel (5.15)
4 posts were merged into an existing topic: I cannot upgrade libkipi
Hi, thanks for the update and your hard work.
I’m getting these errors:
Fehler: at-spi2-core: Signatur von "Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>" ist ungültig
:: Datei /var/cache/pacman/pkg/at-spi2-core-2.44.1-1-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Soll die Datei entfernt werden? [J/n] j
Fehler: gtk3: Signatur von "Philip Müller (Called Little) <philm@manjaro.org>" ist ungültig
:: Datei /var/cache/pacman/pkg/gtk3-1:3.24.33-3.0-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Fehler: Der Vorgang konnte nicht durchgeführt werden (Ungültiges oder beschädigtes Paket)
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
Edit: Solved by updating the keys manually. Thanks a lot, brahma & stormschip. Have a great weekend!
try running this:
sudo pacman-key --refresh-keys
then try updating
hopefully it is not going to be a keyring hell like it was with latest stable update
You could try updating the keys; hope it helps
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
sudo pacman -Syu
:: Replace lib32-sdl with multilib/lib32-sdl12-compat? [Y/n] y
:: Replace qemu-headless with extra/qemu-base? [Y/n] y
:: Replace qemu-headless-arch-extra with extra/qemu-emulators-full? [Y/n] y
:: Replace sdl with community/sdl12-compat? [Y/n] y
resolving dependencies...
:: There are 3 providers available for nodejs<18.1.0:
:: Repository community
1) nodejs-lts-erbium 2) nodejs-lts-fermium 3) nodejs-lts-gallium
How can I determine what requires an older nodejs
? And if so, which version do you suggest to install, since nodejs
and these LTS versions are in conflict.
I still got the problem with my ASUS Zenbook UM325UAZ : the keyboard doesn’t work on cold boot. It can be fixed by applying this solution : create a custom mkinitpcio.conf following this arch fix , then generate the initramfs for the kernel you’re using. And it’ll work.
I encountered the following dependency problem while trying to upgrade:
:: Replace manjaro-gnome-assets with community/manjaro-gnome-settings? [Y/n]
:: manjaro-gnome-settings and manjaro-gdm-theme are in conflict. Remove manjaro-gdm-theme? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
My mirrors are synced.
XFCE, the update has made somethig with font rendering. All system fonts become narrower.
Everything went smoothly so far and the new packages installed without any issue. Thanks for the good work.
But I have a question about the “Bluetooth disabled by default” thing. I read through the linked forum posts and understood that I could simply throw “AutoEnable=true” into /etc/bluetooth/main.conf and get it going. But as disabling Bluetooth by default due to GNOME 42 seems very intentional, my question is, if this would be a good idea and if I could run into any bad side effects in doing so?
→ Yes.
Had my bluetooth mouse not working anymore on boot, found the solution with a quick google search.
After login the “Oh no! Something has gone wrong.” screen pops up and nothing else, rendering the system completely unusable.
After running journalctl
I see this log with crash and core dump of gone-shell
May 13 11:45:30 device systemd[1837]: Starting D-Bus User Message Bus...
May 13 11:45:30 device systemd[1837]: Started D-Bus User Message Bus.
May 13 11:45:30 device gdm-x-session[1853]: Gdm: session message bus already running, not starting another one
May 13 11:45:30 device dbus-daemon[1878]: [session uid=1000 pid=1878] Successfully activated service 'org.freedesktop.systemd1'
May 13 11:45:30 device gdm[972]: Gdm: GdmManager: trying to register new display
May 13 11:45:30 device gdm[972]: Gdm: GdmCommon: Found session 3 for PID 1853, using
May 13 11:45:30 device gdm[972]: Gdm: GdmSession: Setting display device: tty2
May 13 11:45:30 device gdm[972]: Gdm: using ut_user user
May 13 11:45:30 device gdm[972]: Gdm: Writing login record
May 13 11:45:30 device gdm[972]: Gdm: using ut_type USER_PROCESS
May 13 11:45:30 device gdm[972]: Gdm: using ut_tv time 1652435130
May 13 11:45:30 device gdm[972]: Gdm: using ut_pid 1853
May 13 11:45:30 device gdm[972]: Gdm: using ut_host :1
May 13 11:45:30 device gdm[972]: Gdm: using ut_line :1
May 13 11:45:30 device gdm[972]: Gdm: Writing wtmp session record to /var/log/wtmp
May 13 11:45:30 device gdm[972]: Gdm: Adding or updating utmp record for login
May 13 11:45:30 device gdm[972]: Gdm: GdmLocalDisplayFactory: display status changed: 2
May 13 11:45:30 device gdm-x-session[1853]: Gdm: Running X session
May 13 11:45:30 device gdm-x-session[1853]: Gdm: gdm-x-session: Session will register itself
May 13 11:45:30 device /usr/lib/gdm-x-session[1880]: /etc/gdm/Xsession: Beginning session setup...
May 13 11:45:31 device /usr/lib/gdm-x-session[1890]: localuser:user being added to access control list
May 13 11:45:31 device /usr/lib/gdm-x-session[1880]: /etc/gdm/Xsession: Setup done, will execute: /usr/bin/gnome-session
May 13 11:45:31 device dbus-daemon[1878]: [session uid=1000 pid=1878] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.3' (uid=1000 pid=1896 comm="/usr/lib/gnome-session-check-accelerated")
May 13 11:45:31 device systemd[1837]: Starting Accessibility services bus...
May 13 11:45:31 device dbus-daemon[1878]: [session uid=1000 pid=1878] Successfully activated service 'org.a11y.Bus'
May 13 11:45:31 device systemd[1837]: Started Accessibility services bus.
May 13 11:45:31 device systemd[1837]: Created slice Slice /app/gnome-session-manager.
May 13 11:45:31 device systemd[1837]: Reached target GNOME X11 Session.
May 13 11:45:31 device systemd[1837]: Reached target Session services which should run early before the graphical session is brought up.
May 13 11:45:31 device systemd[1837]: Reached target GNOME Shell.
May 13 11:45:31 device systemd[1837]: Starting Monitor Session leader for GNOME Session...
May 13 11:45:31 device systemd[1837]: Started Monitor Session leader for GNOME Session.
May 13 11:45:31 device systemd[1837]: Reached target Tasks to be run before GNOME Session starts.
May 13 11:45:31 device systemd[1837]: Starting GNOME Session Manager (session: gnome)...
May 13 11:45:31 device gnome-session[1949]: gnome-session-binary[1949]: WARNING: Could not parse desktop file caffeine.desktop or it references a not found TryExec binary
May 13 11:45:31 device gnome-session-binary[1949]: WARNING: Could not parse desktop file caffeine.desktop or it references a not found TryExec binary
May 13 11:45:31 device systemd[1837]: Started Application launched by gnome-session-binary.
May 13 11:45:31 device gnome-keyring-ssh.desktop[1959]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
May 13 11:45:31 device systemd[1837]: Started GNOME Session Manager (session: gnome).
May 13 11:45:31 device gnome-keyring-pkcs11.desktop[1961]: SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
May 13 11:45:31 device systemd[1837]: Reached target GNOME Session Manager is ready.
May 13 11:45:31 device systemd[1837]: Starting GNOME Shell on Wayland...
May 13 11:45:31 device systemd[1837]: Starting GNOME Shell on X11...
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@wayland.service: Skipped due to 'exec-condition'.
May 13 11:45:31 device systemd[1837]: Condition check resulted in GNOME Shell on Wayland being skipped.
May 13 11:45:31 device gnome-shell[1966]: Running GNOME Shell (using mutter 42.1) as a X11 window and compositing manager
May 13 11:45:31 device gnome-shell[1966]: Settings schema 'org.gnome.desktop.privacy' does not contain a key named 'privacy-screen'
May 13 11:45:31 device audit[1966]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=1966 comm="gnome-shell" exe="/usr/bin/gnome-shell" sig=5 res=1
May 13 11:45:31 device kernel: show_signal: 11 callbacks suppressed
May 13 11:45:31 device kernel: traps: gnome-shell[1966] trap int3 ip:7f99ccb06540 sp:7fff1e1c2520 error:0 in libglib-2.0.so.0.7200.1[7f99ccac7000+92000]
May 13 11:45:31 device kernel: audit: type=1701 audit(1652435131.277:184): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=1966 comm="gnome-shell" exe="/usr/bin/gnome-shell" sig=5 res=1
May 13 11:45:31 device systemd[1]: Created slice Slice /system/systemd-coredump.
May 13 11:45:31 device audit: BPF prog-id=28 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=29 op=LOAD
May 13 11:45:31 device kernel: audit: type=1334 audit(1652435131.314:185): prog-id=28 op=LOAD
May 13 11:45:31 device kernel: audit: type=1334 audit(1652435131.314:186): prog-id=29 op=LOAD
May 13 11:45:31 device kernel: audit: type=1334 audit(1652435131.317:187): prog-id=30 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=30 op=LOAD
May 13 11:45:31 device audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1972-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device systemd[1]: Started Process Core Dump (PID 1972/UID 0).
May 13 11:45:31 device kernel: audit: type=1130 audit(1652435131.317:188): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1972-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device systemd-coredump[1973]: Process 1966 (gnome-shell) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id d3d3a1ec103a73e5e70f3a001cc6ee89a7e7deb9
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libtss2-sys.so.1 with build-id 1498ac4b48b90c1d3ac0f5f8f4d27d667bfc4771
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libplc4.so with build-id e194130401ccec0067df40f72affdde25bb9a383
Module libplds4.so with build-id d91a9c5ee69e8a373b87bfc3eec221b5c1e2950c
Module libnssutil3.so with build-id 1a64415cbb9d33b86f22e1bc4028411fd5bd9484
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libevdev.so.2 with build-id 09eb82a0dfca98325f54b3918875cff09a5c1428
Module libmtdev.so.1 with build-id 0cea2a842ae9a0ef02a08477076caab0e5ac5e42
Module libuuid.so.1 with build-id 032a21acd159ee3902605e9911be5f86a7df7df9
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-util.so.1 with build-id 4188ebc629b472b560849c5792a69c1803c3d1a4
Module libltdl.so.7 with build-id d2c1c93609da7fc11a1c40381fea72634ad714ed
Module libtdb.so.1 with build-id 6c9ccf6d9a22d117d984d1666842a49fd7669f09
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libxml2.so.2 with build-id 6b0ec2acdbc8f1a2255cc5e3e1258472cd99e272
Module libsqlite3.so.0 with build-id a72506b3923739d1974e02062460a2720d4b3958
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libseccomp.so.2 with build-id 898097fd5a5d3469526739a834457be46bebedc4
Module libxkbregistry.so.0 with build-id 5399cfc9f0fcab753caa3ce5846829f282b27b12
Module libtss2-tctildr.so.0 with build-id d45a42b5bc06ce0bc08516ee688eb690cd8c5c91
Module libtss2-rc.so.0 with build-id 683cdb1ae9b98aca4ccd4080b6f418bdd95d7b59
Module libtss2-mu.so.0 with build-id ddbc7a4374d0d9ccb2132b2d7497074920f6b65c
Module libtss2-esys.so.0 with build-id 964b48ed1a288f436f7b22b1d5d765765238bde4
Module libnspr4.so with build-id 0fcca981168b16e07684217e645e9b3b716a0c57
Module libnss3.so with build-id 63b30181a431facad7300e8fa3855db13d822da1
Module libsmime3.so with build-id 2950ba6b2aa311f260d83a6f27ea82f51205c57a
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libgck-1.so.0 with build-id bf4564176ebb323df30329f302d4a9f4565ecd5b
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libjpeg.so.8 with build-id 324d9d66f01707241e31af5cc104db3c9122f4c4
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libwayland-egl.so.1 with build-id ac45e227422559ff92c4d04851fffb8452874713
Module libwayland-cursor.so.0 with build-id 647d92328111682fb15bff1c20a4c9368414857c
Module libwayland-client.so.0 with build-id 95e7368b400dd57e3db2a5c385de71c7dca08879
Module libGLESv2.so.2 with build-id ecba6a192965463cb000c68b97e51a1c760457de
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libgbm.so.1 with build-id db6b1ee6abbf947245bc04cad40a6732ed6440d9
Module libinput.so.10 with build-id 2dae1736f9a02020c3932f0ceb476474463a5c07
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libSM.so.6 with build-id ac7b055fd3f16b4f29373285ab04ed52eebb632d
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libX11-xcb.so.1 with build-id f6beacd41cd16a23f53e5e56bb599e98f039d0d6
Module libxkbcommon-x11.so.0 with build-id c942fd85702bc7165a42bcb102660f9413376572
Module libxkbfile.so.1 with build-id de5e415879c20263a8dd42f8cf2dd88107c2bfb2
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libICE.so.6 with build-id af53458a64fe1e62a4d95606f7b03c210b2b098c
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libpipewire-0.3.so.0 with build-id 4f6546c98a998ecbe671647afdf63c4548c0555c
Module libstartup-notification-1.so.0 with build-id c31cad1791f13615a8f6c9ec025e1a3c3eef7736
Module libudev.so.1 with build-id 00aef0aeab17dca76ebdbe76e845712bf97b9d0c
Module libgudev-1.0.so.0 with build-id 460465b63a086d945124662363191903c0002793
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libwacom.so.9 with build-id dab3ab00bae4a88ba3bd0d2e9262a9d5bf59187b
Module libXtst.so.6 with build-id 96411faea62997274e362f263e65082e601a787b
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libEGL.so.1 with build-id 30b30de54f2f848a7b8bed469349c9a7ab1b7c22
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libreadline.so.8 with build-id 03c124180216a8077784ca035346856bd16060b9
Module libmozjs-91.so with build-id 35746a3fa29000e1480f3d1be28259b10c84b0c1
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtracker-sparql-3.0.so.0 with build-id d03c91051f78975ac3f1d4732d1fecf70b32e709
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id c2c09f789578900f61b7fca4a4311d8b94d9a750
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libgnome-desktop-3.so.19 with build-id e85021d4fd1d1093bb460631811b80fbd82af0d9
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libsecret-1.so.0 with build-id 0cc692dc5ac19d1147a9846a00821b6687102386
Module libnm.so.0 with build-id b40594792683de30b1a6326b21b78b2be75dfd87
Module libsystemd.so.0 with build-id cdfc45d8f96e3af51b3d041c32f7899a93b86706
Module libgcr-base-3.so.1 with build-id b877460db7e7f44e691890517ffff43d53da8975
Module libpolkit-gobject-1.so.0 with build-id 6d189be4e9d8f711bdde061c6b5c4f8741201136
Module libpolkit-agent-1.so.0 with build-id b4d61b73d503ec970ba9bae7e99f741b00f913e6
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libwayland-server.so.0 with build-id 5526cec43774a83c7ab8c7ff820eea8b28880d51
Module libgraphene-1.0.so.0 with build-id 146fd1d0593533b7842d16bc96e114e80c183ec3
Module libmutter-cogl-10.so.0 with build-id 1def5ff7af5f167adc35830d4479c0d0f8affea1
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libgdk-3.so.0 with build-id a5ab221b5bcc72cfbe848530bb952bddccccc654
Module libst-1.0.so with build-id c2aba930fb5da77cb0f15584916524be32a424ea
Module libgnome-shell-menu.so with build-id 218941e20f166cfdbc949f8ac84f1f3ee976d009
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libmutter-10.so.0 with build-id e7950c996c37a7713c1dece6d47e7488528d4d9a
Module libgirepository-1.0.so.1 with build-id e90459be4a81e316d337c7be79d5c32e53e7c9c8
Module libmutter-cogl-pango-10.so.0 with build-id 14b25e5ad01b0e2654c78af12221b803db17a59b
Module libmutter-clutter-10.so.0 with build-id 618b8e5e91613894f7f9719295336b8550ed3cc7
Module libgjs.so.0 with build-id 057357275491a7c12c80e5385af229cca4a4226a
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libpangocairo-1.0.so.0 with build-id b65f507d9e33adfbd19369acef5e5a0a2422c6d1
Module libgtk-3.so.0 with build-id 650fd204299b7ee234f3152032bbc8ebc54a7e1d
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libgnome-shell.so with build-id d55d1f6bcb6b2a71a4fc21f0e2f0d5a841b8b610
Module gnome-shell with build-id f70f9a6ceebceb06fd8c3a49609069aa479bfd30
Stack trace of thread 1966:
#0 0x00007f99ccb06540 g_log_structured_array (libglib-2.0.so.0 + 0x5c540)
#1 0x00007f99ccb0680a g_log_default_handler (libglib-2.0.so.0 + 0x5c80a)
#2 0x00007f99ccb07cdd g_logv (libglib-2.0.so.0 + 0x5dcdd)
#3 0x00007f99ccb07fe4 g_log (libglib-2.0.so.0 + 0x5dfe4)
#4 0x00007f99ccd2d66a n/a (libgio-2.0.so.0 + 0xe666a)
#5 0x00007f99ccd2ebaf g_settings_get_value (libgio-2.0.so.0 + 0xe7baf)
#6 0x00007f99ccd2ffe1 g_settings_get_boolean (libgio-2.0.so.0 + 0xe8fe1)
#7 0x00007f99cbddb36c n/a (libmutter-10.so.0 + 0x8236c)
#8 0x00007f99ccc2501a g_type_create_instance (libgobject-2.0.so.0 + 0x3d01a)
#9 0x00007f99ccc0bcee n/a (libgobject-2.0.so.0 + 0x23cee)
#10 0x00007f99ccc0cf35 g_object_new_with_properties (libgobject-2.0.so.0 + 0x24f35)
#11 0x00007f99ccc0da9a g_object_new (libgobject-2.0.so.0 + 0x25a9a)
#12 0x00007f99cbdb8bf2 n/a (libmutter-10.so.0 + 0x5fbf2)
#13 0x00007f99cccb9ca1 g_initable_new_valist (libgio-2.0.so.0 + 0x72ca1)
#14 0x00007f99cccb9d5e g_initable_new (libgio-2.0.so.0 + 0x72d5e)
#15 0x00007f99cbe3ef55 n/a (libmutter-10.so.0 + 0xe5f55)
#16 0x00007f99cbe3ce49 n/a (libmutter-10.so.0 + 0xe3e49)
#17 0x00007f99cbe43dae n/a (libmutter-10.so.0 + 0xeadae)
#18 0x00007f99cbe444b3 meta_context_setup (libmutter-10.so.0 + 0xeb4b3)
#19 0x0000563a7294d14a n/a (gnome-shell + 0x214a)
#20 0x00007f99cbb5f310 __libc_start_call_main (libc.so.6 + 0x2d310)
#21 0x00007f99cbb5f3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#22 0x0000563a7294d745 n/a (gnome-shell + 0x2745)
Stack trace of thread 1971:
#0 0x00007f99cbc45ffb connect (libc.so.6 + 0x113ffb)
#1 0x00007f99ccce01d7 g_socket_connect (libgio-2.0.so.0 + 0x991d7)
#2 0x00007f99ccce75da g_socket_client_connect (libgio-2.0.so.0 + 0xa05da)
#3 0x00007f99ccd3b0c4 n/a (libgio-2.0.so.0 + 0xf40c4)
#4 0x00007f99ccd3b5d5 g_dbus_address_get_stream_sync (libgio-2.0.so.0 + 0xf45d5)
#5 0x00007f99ccd415e5 n/a (libgio-2.0.so.0 + 0xfa5e5)
#6 0x00007f99ccd4c33d g_bus_get_sync (libgio-2.0.so.0 + 0x10533d)
#7 0x00007f99c476f9e0 n/a (libdconfsettings.so + 0x69e0)
#8 0x00007f99c476fbbc n/a (libdconfsettings.so + 0x6bbc)
#9 0x00007f99ccaff163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#10 0x00007f99ccb559e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#11 0x00007f99ccafc6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#12 0x00007f99c476eebe n/a (libdconfsettings.so + 0x5ebe)
#13 0x00007f99ccb2eda5 n/a (libglib-2.0.so.0 + 0x84da5)
#14 0x00007f99cbbbf5c2 start_thread (libc.so.6 + 0x8d5c2)
#15 0x00007f99cbc44584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1970:
#0 0x00007f99cbc382af __poll (libc.so.6 + 0x1062af)
#1 0x00007f99ccb55976 n/a (libglib-2.0.so.0 + 0xab976)
#2 0x00007f99ccafe6a3 g_main_loop_run (libglib-2.0.so.0 + 0x546a3)
#3 0x00007f99ccd516dc n/a (libgio-2.0.so.0 + 0x10a6dc)
#4 0x00007f99ccb2eda5 n/a (libglib-2.0.so.0 + 0x84da5)
#5 0x00007f99cbbbf5c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f99cbc44584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1968:
#2 0x00007f99ccafc6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#3 0x00007f99ccafc712 n/a (libglib-2.0.so.0 + 0x52712)
Stack trace of thread 1969:
#0 0x00007f99cbc3da9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007f99ccb4f85f g_cond_wait_until (libglib-2.0.so.0 + 0xa585f)
#2 0x00007f99ccacda83 n/a (libglib-2.0.so.0 + 0x23a83)
#3 0x00007f99ccb31f3b n/a (libglib-2.0.so.0 + 0x87f3b)
May 13 11:45:31 device systemd[1]: systemd-coredump@0-1972-0.service: Deactivated successfully.
May 13 11:45:31 device kernel: audit: type=1131 audit(1652435131.437:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1972-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1972-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Main process exited, code=dumped, status=5/TRAP
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Failed with result 'core-dump'.
May 13 11:45:31 device systemd[1837]: Failed to start GNOME Shell on X11.
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Scheduled restart job, restart counter is at 1.
May 13 11:45:31 device systemd[1837]: Stopped GNOME Shell on X11.
May 13 11:45:31 device gnome-shell[1981]: Running GNOME Shell (using mutter 42.1) as a X11 window and compositing manager
May 13 11:45:31 device gnome-shell[1981]: Settings schema 'org.gnome.desktop.privacy' does not contain a key named 'privacy-screen'
May 13 11:45:31 device audit[1981]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=1981 comm="gnome-shell" exe="/usr/bin/gnome-shell" sig=5 res=1
May 13 11:45:31 device kernel: traps: gnome-shell[1981] trap int3 ip:7f0a17057540 sp:7ffd07e1de70 error:0 in libglib-2.0.so.0.7200.1[7f0a17018000+92000]
May 13 11:45:31 device kernel: audit: type=1701 audit(1652435131.484:190): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=1981 comm="gnome-shell" exe="/usr/bin/gnome-shell" sig=5 res=1
May 13 11:45:31 device audit: BPF prog-id=31 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=32 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=33 op=LOAD
May 13 11:45:31 device systemd[1]: Started Process Core Dump (PID 1987/UID 0).
May 13 11:45:31 device audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-1987-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device kernel: audit: type=1334 audit(1652435131.487:191): prog-id=31 op=LOAD
May 13 11:45:31 device gdm-password][1818]: accountsservice: ActUserManager: sending user-changed signal for user user
May 13 11:45:31 device gdm-password][1818]: accountsservice: ActUserManager: sent user-changed signal for user user
May 13 11:45:31 device gdm-password][1818]: accountsservice: ActUserManager: updating user user
May 13 11:45:31 device audit: BPF prog-id=0 op=UNLOAD
May 13 11:45:31 device systemd-coredump[1988]: Process 1981 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 1981:
#0 0x00007f0a17057540 g_log_structured_array (libglib-2.0.so.0 + 0x5c540)
#1 0x00007f0a1705780a g_log_default_handler (libglib-2.0.so.0 + 0x5c80a)
#2 0x00007f0a17058cdd g_logv (libglib-2.0.so.0 + 0x5dcdd)
#3 0x00007f0a17058fe4 g_log (libglib-2.0.so.0 + 0x5dfe4)
#4 0x00007f0a1727e66a n/a (libgio-2.0.so.0 + 0xe666a)
#5 0x00007f0a1727fbaf g_settings_get_value (libgio-2.0.so.0 + 0xe7baf)
#6 0x00007f0a17280fe1 g_settings_get_boolean (libgio-2.0.so.0 + 0xe8fe1)
#7 0x00007f0a1632c36c n/a (libmutter-10.so.0 + 0x8236c)
#8 0x00007f0a1717601a g_type_create_instance (libgobject-2.0.so.0 + 0x3d01a)
#9 0x00007f0a1715ccee n/a (libgobject-2.0.so.0 + 0x23cee)
#10 0x00007f0a1715df35 g_object_new_with_properties (libgobject-2.0.so.0 + 0x24f35)
#11 0x00007f0a1715ea9a g_object_new (libgobject-2.0.so.0 + 0x25a9a)
#12 0x00007f0a16309bf2 n/a (libmutter-10.so.0 + 0x5fbf2)
#13 0x00007f0a1720aca1 g_initable_new_valist (libgio-2.0.so.0 + 0x72ca1)
#14 0x00007f0a1720ad5e g_initable_new (libgio-2.0.so.0 + 0x72d5e)
#15 0x00007f0a1638ff55 n/a (libmutter-10.so.0 + 0xe5f55)
#16 0x00007f0a1638de49 n/a (libmutter-10.so.0 + 0xe3e49)
#17 0x00007f0a16394dae n/a (libmutter-10.so.0 + 0xeadae)
#18 0x00007f0a163954b3 meta_context_setup (libmutter-10.so.0 + 0xeb4b3)
#19 0x0000563df2e4814a n/a (gnome-shell + 0x214a)
#20 0x00007f0a160b0310 __libc_start_call_main (libc.so.6 + 0x2d310)
#21 0x00007f0a160b03c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#22 0x0000563df2e48745 n/a (gnome-shell + 0x2745)
Stack trace of thread 1986:
#0 0x00007f0a1611fdad _int_malloc (libc.so.6 + 0x9cdad)
#1 0x00007f0a1612024f _int_memalign (libc.so.6 + 0x9d24f)
#2 0x00007f0a1612093a _mid_memalign.constprop.0 (libc.so.6 + 0x9d93a)
#3 0x00007f0a16122013 posix_memalign (libc.so.6 + 0x9f013)
#4 0x00007f0a1706f7a8 n/a (libglib-2.0.so.0 + 0x747a8)
#5 0x00007f0a170710cb g_slice_alloc (libglib-2.0.so.0 + 0x760cb)
#6 0x00007f0a1707116f g_slice_alloc0 (libglib-2.0.so.0 + 0x7616f)
#7 0x00007f0a17175f85 g_type_create_instance (libgobject-2.0.so.0 + 0x3cf85)
#8 0x00007f0a1715ccee n/a (libgobject-2.0.so.0 + 0x23cee)
#9 0x00007f0a1715e503 g_object_new_valist (libgobject-2.0.so.0 + 0x25503)
#10 0x00007f0a1715ea6e g_object_new (libgobject-2.0.so.0 + 0x25a6e)
#11 0x00007f0a17238579 g_socket_client_connect (libgio-2.0.so.0 + 0xa0579)
#12 0x00007f0a1728c0c4 n/a (libgio-2.0.so.0 + 0xf40c4)
#13 0x00007f0a1728c5d5 g_dbus_address_get_stream_sync (libgio-2.0.so.0 + 0xf45d5)
#14 0x00007f0a172925e5 n/a (libgio-2.0.so.0 + 0xfa5e5)
#15 0x00007f0a1729d33d g_bus_get_sync (libgio-2.0.so.0 + 0x10533d)
#16 0x00007f0a0dcbe9e0 n/a (libdconfsettings.so + 0x69e0)
#17 0x00007f0a0dcbebbc n/a (libdconfsettings.so + 0x6bbc)
#18 0x00007f0a17050163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#19 0x00007f0a170a69e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#20 0x00007f0a1704d6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#21 0x00007f0a0dcbdebe n/a (libdconfsettings.so + 0x5ebe)
#22 0x00007f0a1707fda5 n/a (libglib-2.0.so.0 + 0x84da5)
#23 0x00007f0a161105c2 start_thread (libc.so.6 + 0x8d5c2)
#24 0x00007f0a16195584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1984:
#0 0x00007f0a1618ea9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007f0a170a085f g_cond_wait_until (libglib-2.0.so.0 + 0xa585f)
#2 0x00007f0a1701ea83 n/a (libglib-2.0.so.0 + 0x23a83)
#3 0x00007f0a17082f3b n/a (libglib-2.0.so.0 + 0x87f3b)
#4 0x00007f0a1707fda5 n/a (libglib-2.0.so.0 + 0x84da5)
#5 0x00007f0a161105c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f0a16195584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1983:
#0 0x00007f0a161892af __poll (libc.so.6 + 0x1062af)
#1 0x00007f0a170a6976 n/a (libglib-2.0.so.0 + 0xab976)
#2 0x00007f0a1704d6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#3 0x00007f0a1704d712 n/a (libglib-2.0.so.0 + 0x52712)
Stack trace of thread 1985:
#2 0x00007f0a1704f6a3 g_main_loop_run (libglib-2.0.so.0 + 0x546a3)
#3 0x00007f0a172a26dc n/a (libgio-2.0.so.0 + 0x10a6dc)
May 13 11:45:31 device systemd[1]: systemd-coredump@1-1987-0.service: Deactivated successfully.
May 13 11:45:31 device audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-1987-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Scheduled restart job, restart counter is at 2.
May 13 11:45:31 device gnome-shell[1996]: Running GNOME Shell (using mutter 42.1) as a X11 window and compositing manager
May 13 11:45:31 device gnome-shell[1996]: Settings schema 'org.gnome.desktop.privacy' does not contain a key named 'privacy-screen'
May 13 11:45:31 device audit[1996]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=1996 comm="gnome-shell" exe="/usr/bin/gnome-shell" sig=5 res=1
May 13 11:45:31 device audit: BPF prog-id=34 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=35 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=36 op=LOAD
May 13 11:45:31 device systemd[1]: Started Process Core Dump (PID 2003/UID 0).
May 13 11:45:31 device audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2003-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device kernel: [UFW BLOCK] IN=enp4s0f4u1u1 OUT= MAC=01:00:5e:00:00:01:bc:99:11:8b:f7:74:08:00 SRC=192.168.1.2 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=15778 PROTO=2
May 13 11:45:31 device kernel: [UFW BLOCK] IN=wlp1s0 OUT= MAC=14:85:7f:d5:dd:24:bc:99:11:8b:f7:74:08:00 SRC=192.168.1.2 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=15778 PROTO=2
May 13 11:45:31 device systemd-coredump[2004]: Process 1996 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 1996:
#0 0x00007f441588b540 g_log_structured_array (libglib-2.0.so.0 + 0x5c540)
#1 0x00007f441588b80a g_log_default_handler (libglib-2.0.so.0 + 0x5c80a)
#2 0x00007f441588ccdd g_logv (libglib-2.0.so.0 + 0x5dcdd)
#3 0x00007f441588cfe4 g_log (libglib-2.0.so.0 + 0x5dfe4)
#4 0x00007f4415ab266a n/a (libgio-2.0.so.0 + 0xe666a)
#5 0x00007f4415ab3baf g_settings_get_value (libgio-2.0.so.0 + 0xe7baf)
#6 0x00007f4415ab4fe1 g_settings_get_boolean (libgio-2.0.so.0 + 0xe8fe1)
#7 0x00007f4414b6036c n/a (libmutter-10.so.0 + 0x8236c)
#8 0x00007f44159aa01a g_type_create_instance (libgobject-2.0.so.0 + 0x3d01a)
#9 0x00007f4415990cee n/a (libgobject-2.0.so.0 + 0x23cee)
#10 0x00007f4415991f35 g_object_new_with_properties (libgobject-2.0.so.0 + 0x24f35)
#11 0x00007f4415992a9a g_object_new (libgobject-2.0.so.0 + 0x25a9a)
#12 0x00007f4414b3dbf2 n/a (libmutter-10.so.0 + 0x5fbf2)
#13 0x00007f4415a3eca1 g_initable_new_valist (libgio-2.0.so.0 + 0x72ca1)
#14 0x00007f4415a3ed5e g_initable_new (libgio-2.0.so.0 + 0x72d5e)
#15 0x00007f4414bc3f55 n/a (libmutter-10.so.0 + 0xe5f55)
#16 0x00007f4414bc1e49 n/a (libmutter-10.so.0 + 0xe3e49)
#17 0x00007f4414bc8dae n/a (libmutter-10.so.0 + 0xeadae)
#18 0x00007f4414bc94b3 meta_context_setup (libmutter-10.so.0 + 0xeb4b3)
#19 0x00005577861a214a n/a (gnome-shell + 0x214a)
#20 0x00007f44148e4310 __libc_start_call_main (libc.so.6 + 0x2d310)
#21 0x00007f44148e43c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#22 0x00005577861a2745 n/a (gnome-shell + 0x2745)
Stack trace of thread 2002:
#0 0x00007f44159a38c7 g_type_class_peek_static (libgobject-2.0.so.0 + 0x368c7)
#1 0x00007f4415992420 g_object_new_valist (libgobject-2.0.so.0 + 0x25420)
#2 0x00007f4415a3ec8f g_initable_new_valist (libgio-2.0.so.0 + 0x72c8f)
#3 0x00007f4415a3ed5e g_initable_new (libgio-2.0.so.0 + 0x72d5e)
#4 0x00007f4415a5fbcc g_socket_new (libgio-2.0.so.0 + 0x93bcc)
#5 0x00007f4415a69b74 n/a (libgio-2.0.so.0 + 0x9db74)
#6 0x00007f4415a6c52b g_socket_client_connect (libgio-2.0.so.0 + 0xa052b)
#7 0x00007f4415ac00c4 n/a (libgio-2.0.so.0 + 0xf40c4)
#8 0x00007f4415ac05d5 g_dbus_address_get_stream_sync (libgio-2.0.so.0 + 0xf45d5)
#9 0x00007f4415ac65e5 n/a (libgio-2.0.so.0 + 0xfa5e5)
#10 0x00007f4415ad133d g_bus_get_sync (libgio-2.0.so.0 + 0x10533d)
#11 0x00007f440c4f29e0 n/a (libdconfsettings.so + 0x69e0)
#12 0x00007f440c4f2bbc n/a (libdconfsettings.so + 0x6bbc)
#13 0x00007f4415884163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#14 0x00007f44158da9e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#15 0x00007f44158816c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#16 0x00007f440c4f1ebe n/a (libdconfsettings.so + 0x5ebe)
#17 0x00007f44158b3da5 n/a (libglib-2.0.so.0 + 0x84da5)
#18 0x00007f44149445c2 start_thread (libc.so.6 + 0x8d5c2)
#19 0x00007f44149c9584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 2000:
#0 0x00007f44149c2a9d syscall (libc.so.6 + 0x10ba9d)
#1 0x00007f44158d485f g_cond_wait_until (libglib-2.0.so.0 + 0xa585f)
#2 0x00007f4415852a83 n/a (libglib-2.0.so.0 + 0x23a83)
#3 0x00007f44158b6f3b n/a (libglib-2.0.so.0 + 0x87f3b)
#4 0x00007f44158b3da5 n/a (libglib-2.0.so.0 + 0x84da5)
#5 0x00007f44149445c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f44149c9584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1999:
#0 0x00007f44149bd2af __poll (libc.so.6 + 0x1062af)
#1 0x00007f44158da976 n/a (libglib-2.0.so.0 + 0xab976)
#2 0x00007f44158816c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#3 0x00007f4415881712 n/a (libglib-2.0.so.0 + 0x52712)
Stack trace of thread 2001:
#2 0x00007f44158836a3 g_main_loop_run (libglib-2.0.so.0 + 0x546a3)
#3 0x00007f4415ad66dc n/a (libgio-2.0.so.0 + 0x10a6dc)
May 13 11:45:31 device systemd[1]: systemd-coredump@2-2003-0.service: Deactivated successfully.
May 13 11:45:31 device audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2003-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Scheduled restart job, restart counter is at 3.
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Start request repeated too quickly.
May 13 11:45:31 device systemd[1837]: org.gnome.Shell@x11.service: Triggering OnFailure= dependencies.
May 13 11:45:31 device systemd[1837]: Reached target GNOME Session is initialized.
May 13 11:45:31 device systemd[1837]: Reached target GNOME session X11 services.
May 13 11:45:31 device systemd[1837]: Reached target GNOME Session (session: gnome).
May 13 11:45:31 device systemd[1837]: Started GNOME Session Failed lockdown screen (user).
May 13 11:45:31 device systemd[1837]: Reached target GNOME Session Failed.
May 13 11:45:31 device systemd[1837]: Starting Signal initialization done to GNOME Session Manager...
May 13 11:45:31 device systemd[1837]: Starting IBus Daemon for GNOME...
May 13 11:45:31 device systemd[1837]: Starting GNOME accessibility service...
May 13 11:45:31 device systemd[1837]: Starting GNOME color management service...
May 13 11:45:31 device systemd[1837]: Starting GNOME date & time service...
May 13 11:45:31 device systemd[1837]: Starting GNOME maintenance of expirable data service...
May 13 11:45:31 device systemd[1837]: Starting GNOME keyboard configuration service...
May 13 11:45:31 device systemd[1837]: Starting GNOME keyboard shortcuts service...
May 13 11:45:31 device systemd[1837]: Starting GNOME power management service...
May 13 11:45:31 device systemd[1837]: Starting GNOME printer notifications service...
May 13 11:45:31 device systemd[1837]: Starting GNOME RFKill support service...
May 13 11:45:31 device systemd[1837]: Starting GNOME FreeDesktop screensaver service...
May 13 11:45:31 device systemd[1837]: Starting GNOME file sharing service...
May 13 11:45:31 device systemd[1837]: Starting GNOME smartcard service...
May 13 11:45:31 device systemd[1837]: Starting GNOME sound sample caching service...
May 13 11:45:31 device systemd[1837]: Starting GNOME USB protection service...
May 13 11:45:31 device systemd[1837]: Starting GNOME Wacom tablet support service...
May 13 11:45:31 device systemd[1837]: Starting GNOME XSettings service...
May 13 11:45:31 device systemd[1837]: Disable GNOME Shell extensions after failure was skipped because of a failed condition check (ConditionPathExists=/run/user/1000/gnome-shell-disable-extensions).
May 13 11:45:31 device gnome-session-binary[1949]: Entering running state
May 13 11:45:31 device dbus-daemon[932]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.84' (uid=1000 pid=2024 comm="/usr/lib/gsd-disk-utility-notify")
May 13 11:45:31 device systemd[1837]: Finished Signal initialization done to GNOME Session Manager.
May 13 11:45:31 device dbus-daemon[1878]: [session uid=1000 pid=1878] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.20' (uid=1000 pid=2023 comm="/usr/lib/gsd-housekeeping")
May 13 11:45:31 device systemd[1]: Starting Disk Manager...
May 13 11:45:31 device dbus-daemon[932]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.85' (uid=1000 pid=2035 comm="/usr/lib/gsd-rfkill")
May 13 11:45:31 device audit: BPF prog-id=37 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=38 op=LOAD
May 13 11:45:31 device audit: BPF prog-id=39 op=LOAD
May 13 11:45:31 device systemd[1]: Starting Hostname Service...
May 13 11:45:31 device udisksd[2079]: udisks daemon version 2.9.4 starting
May 13 11:45:31 device touchegg.desktop[2039]: Touchégg v2.0.14.
May 13 11:45:31 device touchegg.desktop[2039]: Starting Touchégg in client mode
May 13 11:45:31 device touchegg.desktop[2039]: Parsing your configuration file...
May 13 11:45:31 device touchegg.desktop[2039]: Using configuration file "/home/user/.config/touchegg/touchegg.conf"
May 13 11:45:31 device dbus-daemon[932]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.89' (uid=1000 pid=2033 comm="/usr/lib/gsd-print-notifications")
May 13 11:45:31 device dbus-daemon[932]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
May 13 11:45:31 device touchegg.desktop[2039]: Configuration parsed successfully
May 13 11:45:31 device touchegg.desktop[2039]: Connecting to Touchégg daemon...
May 13 11:45:31 device gnome-session[1949]: gnome-session-binary[1949]: GnomeDesktop-WARNING: Could not create transient scope for PID 2061: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2061 does not exist.
May 13 11:45:31 device gnome-session-binary[1949]: GnomeDesktop-WARNING: Could not create transient scope for PID 2061: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 2061 does not exist.
May 13 11:45:31 device systemd[1837]: Started GNOME FreeDesktop screensaver service.
May 13 11:45:31 device touchegg.desktop[2039]: Error connecting to Touchégg daemon: Could not connect: Connection refused
May 13 11:45:31 device touchegg.desktop[2039]: Reconnecting in 5 seconds...
May 13 11:45:31 device systemd[1837]: Started GNOME smartcard service.
May 13 11:45:31 device dbus-daemon[1878]: [session uid=1000 pid=1878] Activating service name='org.gnome.ScreenSaver' requested by ':1.30' (uid=1000 pid=2054 comm="/usr/lib/gsd-usb-protection")
May 13 11:45:31 device systemd[1837]: Started GNOME accessibility service.
May 13 11:45:31 device systemd[1837]: Started GNOME file sharing service.
May 13 11:45:31 device systemd[1837]: Started GNOME USB protection service.
