[Stable Update] 2021-07-13 - Kernels, Plasma 5.22, Cinnamon 5, Gnome 40, LibreOffice, Mesa, Nvidia, Pamac
Can’t update here…
this is the output of sudo pamac update -a for me:
Warning: Building packages as root
Warning: Setting build directory to /var/cache/pamac
Preparing...
Refreshing core.db...
Refreshing extra.db...
Refreshing community.db...
Refreshing multilib.db...
Warning: installing pacman (6.0.0-3) breaks dependency 'pacman<5.3' required by pamac-common
Add pamac-common to remove
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing pamac-common breaks dependency 'pamac-common=10.0.6-2' required by pamac-cli,
- if possible, remove pamac-cli and retry
Warning: amd-ucode: local (20210518.r1928.f846292-1) is newer than core (20210511.7685cf4-1)
Warning: bash: local (5.1.008-3) is newer than core (5.1.008-1)
Warning: kpeoplevcard: local (0.1+r38.32d50a9-1) is newer than community (0.1-1)
Warning: libgdm: local (40.0-6) is newer than extra (40.0-1)
Warning: linux-firmware: local (20210518.r1928.f846292-1) is newer than core (20210511.7685cf4-1)
Warning: mkinitcpio: local (30-2) is newer than core (30-1)
Resolving dependencies...
Checking inter-conflicts...
pacman -Syu does similar. pamac-cli seems to be required by too many things to uninstall.
Same issue here, had neither yaourt or package-query installed. using pamac has no difference for me.
Can you update through the GUI?
Nope, same error
Scroll to the bottom of this website: Community Presets · wwmm/easyeffects Wiki · GitHub
for details on converting PulseEffects presets to EasyEffects presets
This seems like an older version of pamac, can you try:
sudo pacman -Rdd pamac-common
The version you actually want is pamac-gtk
Does it happen on the 5.10 LTS kernel?
now I get a new error message:
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade…
resolving dependencies…
Packages (417) alembic-1.8.2-1  alsa-card-profiles-1:0.3.31-1  alsa-lib-1.2.5.1-3
               alsa-topology-conf-1.2.5.1-1  alsa-ucm-conf-1.2.5.1-1  alsa-utils-1.2.5.1-1
               amd-ucode-20210629.r1978.d79c267-1  android-tools-31.0.0-4  aom-3.1.1-1  apm-2.6.4-1
               appstream-0.14.4-1  appstream-glib-0.7.18-3  appstream-qt-0.14.4-1
               archlinux-appstream-data-20210612-1  ark-21.04.3-1  at-spi2-core-2.40.3-1  attica-5.84.0-1
               audit-3.0.2-1  baloo-5.84.0-1  baloo-widgets-21.04.3-1  blas-3.10.0-1  blender-17:2.93.1-2
               bluedevil-1:5.22.3-1  bluez-5.60-1  bluez-libs-5.60-1  bluez-qt-5.84.0-1  boost-libs-1.76.0-1
               breath2-icon-themes-1.0.14-1  breath2-wallpaper-1.0.14-1  breeze-5.22.3-1
               breeze-icons-5.84.0-1  brltty-6.3-3  ca-certificates-20210603-1
               ca-certificates-mozilla-3.67-1  ca-certificates-utils-20210603-1  cblas-3.10.0-1
               ceph-libs-15.2.12-2  clang-12.0.1-1  cmake-3.20.5-1  code-1.58.0-1  compiler-rt-12.0.1-2
               cpupower-5.13-1  cups-filters-1.28.9-1  darktable-2:3.6.0-1  dialog-1:1.3_20210621-1
               dolphin-21.04.3-1  dolphin-plugins-21.04.3-1  downgrade-10.1.0-2  editorconfig-core-c-0.12.5-1
               electron-13.1.6-1  electron12-12.0.14-1  enchant-2.3.0-1  etcher-1.5.120-3  exiv2-0.27.4-2
               faudio-21.07-1  ffmpeg-2:4.4-4  ffmpegthumbs-21.04.3-1  firefox-90.0-1  firejail-0.9.66-1
               fontconfig-2:2.13.94-1  frameworkintegration-5.84.0-1  fuse-common-3.10.4-1  fuse3-3.10.4-1
               game-devices-udev-0.14-1  gd-2.3.2-4  gdbm-1.20-1  gegl-0.4.30-4  gimp-2.10.24-5
               glib2-2.68.3-1  glib2-docs-2.68.3-1  glslang-11.5.0-1  glu-9.0.2-1  gmic-2.9.7-5
               gnome-boxes-40.3-1  gnome-desktop-1:40.2-1  gnome-disk-utility-40.2-1
               gnome-settings-daemon-40.0.1-2  gnome-shell-1:40.3-1  gnupg-2.2.29-0.1  gnuplot-5.4.2-1
               gnutls-3.7.2-2  gpgme-1.16.0-1  gptfdisk-1.0.8-1  graphviz-2.47.3-1  groff-1.22.4-6
               gst-plugin-pipewire-1:0.3.31-1  gst-plugins-bad-1.18.4-8  gst-plugins-bad-libs-1.18.4-8
               gtk3-1:3.24.30-1  gtk4-1:4.2.1-2  gwenview-21.04.3-1  harfbuzz-2.8.2-1  harfbuzz-icu-2.8.2-1
               hdparm-9.62-1  hwids-20210613-1  hwinfo-21.75-1  iana-etc-20210624-1  imagemagick-7.1.0.2-2
               imath-3.0.5-1  intellij-idea-community-edition-4:2021.1.3-1  iproute2-5.13.0-1
               ipython-7.25.0-1  jasper-2.0.32-1  jdk-openjdk-16.0.1.u9-1  jre-openjdk-16.0.1.u9-1
               jre-openjdk-headless-16.0.1.u9-1  kaccounts-integration-21.04.3-1
               kaccounts-providers-21.04.3-1  kactivities-5.84.0-1  kactivities-stats-5.84.0-1
               kactivitymanagerd-5.22.3-1  kamera-21.04.3-1  karchive-5.84.0-1  kate-21.04.3-1
               kauth-5.84.0-1  kbookmarks-5.84.0-1  kcalc-21.04.3-1  kcmutils-5.84.0-1  kcodecs-5.84.0-1
               kcompletion-5.84.0-1  kconfig-5.84.0-1  kconfigwidgets-5.84.0-1  kcontacts-1:5.84.0-1
               kcoreaddons-5.84.0-1  kcrash-5.84.0-1  kdbusaddons-5.84.0-1  kde-cli-tools-5.22.3-1
               kde-gtk-config-5.22.3-1  kdeclarative-5.84.0-1  kdeconnect-21.04.3-1  kdecoration-5.22.3-1
               kded-5.84.0-1  kdegraphics-thumbnailers-21.04.3-1  kdelibs4support-5.84.0-1
               kdenetwork-filesharing-21.04.3-1  kdenlive-21.04.3-1  kdeplasma-addons-5.22.3-1
               kdesu-5.84.0-1  kdnssd-5.84.0-1  kdoctools-5.84.0-1  kdsoap-2.0.0-1
               kdsoap-ws-discovery-client-git20200927-2  keepassxc-2.6.6-1  kemoticons-5.84.0-1
               kfilemetadata-5.84.0-1  kfind-21.04.3-1  kgamma5-5.22.3-1  kglobalaccel-5.84.0-1
               kguiaddons-5.84.0-1  khelpcenter-21.04.3-1  kholidays-1:5.84.0-1  khotkeys-5.22.3-1
               khtml-5.84.0-1  ki18n-5.84.0-1  kiconthemes-5.84.0-1  kidletime-5.84.0-1
               kimageformats-5.84.0-1  kinfocenter-5.22.3-1  kinit-5.84.0-1  kio-5.84.0-1
               kio-extras-21.04.3-1  kio-fuse-5.0.1-1  kirigami2-5.84.0-1  kitemmodels-5.84.0-1
               kitemviews-5.84.0-1  kjobwidgets-5.84.0-1  kjs-5.84.0-1  kmenuedit-5.22.3-1
               knewstuff-5.84.0-1  knotifications-5.84.0-1  knotifyconfig-5.84.0-1  konsole-21.04.3-1
               konversation-21.04.3-1  kpackage-5.84.0-1  kparts-5.84.0-1  kpeople-5.84.0-1
               kpmcore-21.04.3-1  kpty-5.84.0-1  kquickcharts-5.84.0-1  krunner-5.84.0-1  kscreen-5.22.3-1
               kscreenlocker-5.22.3-1  kservice-5.84.0-1  ksshaskpass-5.22.3-1  ksysguard-5.22.0-1
               ksystemlog-21.04.3-1  ksystemstats-5.22.3-1  ktexteditor-5.84.0-1  ktextwidgets-5.84.0-1
               kunitconversion-5.84.0-1  kwallet-5.84.0-1  kwallet-pam-5.22.3-1  kwalletmanager-21.04.3-1
               kwayland-5.84.0-1  kwayland-integration-5.22.3-1  kwayland-server-5.22.3-1
               kwidgetsaddons-5.84.0-1  kwin-5.22.3-1  kwindowsystem-5.84.0-1  kwrited-5.22.3-1
               kxmlgui-5.84.0-1  lapack-3.10.0-1  layer-shell-qt-5.22.3-1  lib32-alsa-lib-1.2.5.1-1
               lib32-faudio-21.07-1  lib32-fontconfig-2:2.13.94-1  lib32-glib2-2.68.3-1
               lib32-harfbuzz-2.8.2-1  lib32-libcanberra-0.30+2+gc0620e4-5  lib32-libcap-2.51-1
               lib32-libdrm-2.4.107-1  lib32-libldap-2.4.59-1  lib32-libnm-1.32.2-1  lib32-libpcap-1.10.1-1
               lib32-libtasn1-4.17.0-1  lib32-libva-mesa-driver-21.1.4-1  lib32-libxcrypt-4.4.23-1
               lib32-llvm-libs-12.0.1-1  lib32-mesa-21.1.4-1  lib32-mesa-vdpau-21.1.4-1
               lib32-mpg123-1.28.1-1  lib32-nspr-4.32-1  lib32-nss-3.67-1  lib32-p11-kit-0.24.0-1
               lib32-pango-1:1.48.7-1  lib32-pipewire-1:0.3.31-2  lib32-sqlite-3.36.0-1
               lib32-vulkan-icd-loader-1.2.182-1  lib32-vulkan-intel-21.1.4-1  lib32-vulkan-radeon-21.1.4-1
               libavif-0.9.2-1  libcanberra-0.30+2+gc0620e4-5  libcap-2.51-1  libcerf-1:1.17-1
               libclc-12.0.1-1  libdrm-2.4.107-1  libgig-4.3.0-3  libgit2-1:1.1.1-1  libhandy-1.2.3-1
               libkdcraw-21.04.3-1  libkexiv2-21.04.3-1  libkipi-21.04.3-1  libksba-1.6.0-1
               libkscreen-5.22.3-1  libksysguard-5.22.3-1  libldap-2.4.59-1  libmfx-21.2.3-1  libnm-1.32.2-1
               libp11-kit-0.24.0-1  libpamac-11.0.1-3  libpcap-1.10.1-1  libplacebo-3.120.3-2
               libsidplayfp-2.2.0-1  libslirp-4.6.1-1  libtorrent-rasterbar-1:1.2.14-1  libva-2.12.0-1
               libva-mesa-driver-21.1.4-1  libvips-8.11.2-1  libvirt-1:7.5.0-1  libwpe-1.10.1-1
               libxcrypt-4.4.23-1  linux-firmware-20210629.r1978.d79c267-1  linux510-5.10.49-1
               linux510-virtualbox-host-modules-6.1.22-20  lld-12.0.1-1  lldb-12.0.1-1  llvm-12.0.1-1
               llvm-libs-12.0.1-1  m4-1.4.19-1  man-db-2.9.4-2  man-pages-5.12-1
               manjaro-application-utility-1.3.3-5  manjaro-release-21.1.0rc1-2  mbedtls-2.26.0-1
               memtest86+-5.31b-1  mercurial-5.8.1-1  mesa-21.1.4-1  mesa-vdpau-21.1.4-1
               mhwd-nvidia-470.42.01-1  milou-5.22.3-1  mkinitcpio-busybox-1.33.1-1  modemmanager-qt-5.84.0-1
               mono-6.12.0.122-1  mtools-1:4.0.32-1  mutter-40.3-1  nano-5.8-1  netpbm-10.73.34-1
               networkmanager-1.32.2-1  networkmanager-qt-5.84.0-1  nfs-utils-2.5.4-1  nfsidmap-2.5.4-1
               node-gyp-8.1.0-2  nodejs-16.4.2-1  nodejs-nopt-5.0.0-2  npm-7.17.0-1  nspr-4.32-1  nss-3.67-1
               obs-studio-27.0.1-1  okular-21.04.3-1  open-vm-tools-6:11.3.0-1  opencl-mesa-21.1.4-1
               opencv-4.5.3-1  openexr-3.0.5-1  openimagedenoise-1.4.1-1  openimageio-2.2.15.1-4
               openmp-12.0.1-1  openmpi-4.1.1-2  openshadinglanguage-1.11.14.0-3  opensubdiv-3.4.4-2
               openvdb-8.1.0-1  openvpn-2.5.3-1  openxr-1.0.17-1  oxygen-5.22.3-1  oxygen-icons-1:5.84.0-1
               p11-kit-0.24.0-1  pacman-6.0.0-1  pamac-cli-10.1.3-3  pamac-gtk-10.1.3-3  pango-1:1.48.7-1
               partitionmanager-21.04.3-1  pcre-8.45-1  perl-file-basedir-0.09-1  perl-libwww-6.55-1
               pipewire-1:0.3.31-1  pipewire-media-session-1:0.3.31-1  plasma-desktop-5.22.3-1
               plasma-framework-5.84.0-1  plasma-integration-5.22.3-1  plasma-nm-5.22.3-1  plasma-pa-5.22.3-1
               plasma-workspace-5.22.3-1  plasma5-themes-breath2-1.0.14-1  polkit-kde-agent-5.22.3-1
               polkit-qt5-0.114.0-1  poppler-21.07.0-1  poppler-glib-21.07.0-1  poppler-qt5-21.07.0-1
               powerdevil-5.22.3-1  prison-5.84.0-1  protobuf-3.17.3-1  ptex-2.4.0-1  purpose-5.84.0-1
               pycharm-community-edition-2021.1.3-1  python-3.9.6-1  python-asgiref-3.4.1-1
               python-backcall-0.2.0-4  python-cffi-1.14.6-1  python-fasteners-0.16-1  python-gpgme-1.16.0-1
               python-pip-20.3.4-1  python-prompt_toolkit-3.0.19-1  python-protobuf-3.17.3-1
               python-resolvelib-0.5.5-1  python-ruamel-yaml-0.17.10-1  python-ruamel.yaml.clib-0.2.4-1
               python-setuptools-1:57.1.0-1  python-tqdm-4.61.2-1  python-urllib3-1.26.6-1
               qbittorrent-4.3.6-1  qqc2-desktop-style-5.84.0-1  qt5-base-5.15.2+kde+r210-1
               qt5-declarative-5.15.2+kde+r29-1  qt5-script-5.15.5-2  qt5-tools-5.15.2+kde+r17-3
               qt5-wayland-5.15.2+kde+r28-1  qt5-webengine-5.15.5-1  ripgrep-13.0.0-2  ruby-irb-1.3.6-1
               rubygems-3.2.21-1  rust-1:1.53.0-2  samba-4.14.5-1  sddm-breath2-theme-1.0.14-1
               sddm-kcm-5.22.3-1  shaderc-2021.1-1  signal-desktop-5.8.0-1
               signon-kwallet-extension-21.04.3-1  smbclient-4.14.5-1  snapd-2.51.1-1  sof-firmware-1.8-1
               solid-5.84.0-1  sonnet-5.84.0-1  source-highlight-3.1.9-5  spectacle-21.04.3-1  spice-0.15.0-1
               sqlite-3.36.0-1  sshfs-3.7.2-1  steam-native-1.0.0.70-2  sudo-1.9.7.p1-1  syndication-5.84.0-1
               syntax-highlighting-5.84.0-1  systemsettings-5.22.3-1  texinfo-6.8-1  threadweaver-5.84.0-1
               tor-0.4.6.6-1  torbrowser-launcher-0.3.4-2  tracker3-3.1.2-1  upower-0.99.12-2
               virtualbox-sdk-6.1.22-3  vlc-3.0.16-2  vulkan-headers-1:1.2.182-1  vulkan-icd-loader-1.2.182-1
               vulkan-intel-21.1.4-1  vulkan-radeon-21.1.4-1  webkit2gtk-2.32.2-1  wine-6.12-1
               wireless-regdb-2021.04.21-1  wpebackend-fdo-1.10.0-1  xapp-2.2.2-1
               xdg-desktop-portal-kde-5.22.3-1  xf86-input-libinput-1.1.0-1  xfsprogs-5.12.0-1
               xkeyboard-config-2.33-1  xorg-xwayland-21.1.2-1  yakuake-21.04.3-1  yay-10.3.0-1  z3-4.8.11-1
               zsh-theme-powerlevel10k-1.15.0-2
Total Download Size:     69.09 MiB
Total Installed Size:  9526.50 MiB
Net Upgrade Size:       211.07 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 firefox-90.0-1-x86_64                  69.1 MiB  16.1 MiB/s 00:04 [####################################] 100%
(417/417) checking keys in keyring                                 [####################################] 100%
(417/417) checking package integrity                               [####################################] 100%
error: alsa-ucm-conf: signature from "David Runge <dvzrv@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/alsa-ucm-conf-1.2.5.1-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: alsa-lib: signature from "David Runge <dvzrv@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/alsa-lib-1.2.5.1-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
sudo rm -R /etc/pacman.d/gnupg/
sudo rm -R /root/.gnupg/
sudo pacman-mirrors -f5
sudo pacman -Syy gnupg archlinux-keyring manjaro-keyring
sudo pacman-key --init && pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
sudo pacman -Syyu
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
https://archived.forum.manjaro.org/t/how-to-solve-keyring-issues-in-manjaro/4020
sudo pacman-key --refresh-keys loops on this error:
gpg: error reading key: Server indicated a failure
Ah, gotta love the key servers going down…
Can you check this? pacman/Package signing - ArchWiki
In particular:
Change keyserver
If you suspect that something is not working right with the keyserver, you could try to switch to the Ubuntu keyserver. To do this, edit /etc/pacman.d/gnupg/gpg.conf and change the keyserver line to:
keyserver hkp://keyserver.ubuntu.com
there is no keyserver line, do I just add it in a new line?
no-greeting
no-permission-warning
lock-never
keyserver-options timeout=10
keyserver-options import-clean
keyserver-options no-self-sigs-only
I believe so, although I’m not sure why this is happening.
same error loop issue, here’s the full output if it’ll help:
[redacted ~]$ sudo pacman-key --refresh-keys
[sudo] password for redacted:
gpg: error retrieving 'jelle@vdwaa.nl' via WKD: Server indicated a failure
gpg: key C06086337C50773E: "Jelle van der Waa <jelle@vdwaa.nl>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
pub   rsa2048 2011-10-08 [SC]
      E499C79F53C96A54E572FEE1C06086337C50773E
uid           [  full  ] Jelle van der Waa <jelle@vdwaa.nl>
uid           [  full  ] Jelle van der Waa <jelle@archlinux.org>
sub   rsa2048 2011-10-08 [E]
gpg: key 4AC5588F941C2A25: "Antonio Rojas <arojas@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-10-21 [SC]
      9D74DF6F91B7BDABD5815CA84AC5588F941C2A25
uid           [  full  ] Antonio Rojas <arojas@archlinux.org>
uid           [  full  ] Antonio Rojas <arojas@us.es>
uid           [  full  ] Antonio Rojas <nqn1976@gmail.com>
uid           [  full  ] Antonio Rojas <nqn76sw@gmail.com>
sub   rsa2048 2014-11-07 [S]
sub   rsa2048 2014-11-07 [E]
gpg: key 51E8B148A9999C34: "Evangelos Foutras <evangelos@foutrelis.com>" not changed
gpg:              unchanged: 1
pub   rsa2048 2010-11-12 [SC]
      86CFFCA918CF3AF47147588051E8B148A9999C34
uid           [  full  ] Evangelos Foutras <evangelos@foutrelis.com>
uid           [  full  ] Evangelos Foutras <foutrelis@archlinux.org>
uid           [  full  ] Evangelos Foutras <foutrelis@gmail.com>
sub   rsa2048 2010-11-12 [E]
gpg: error retrieving 'jan.steffens@gmail.com' via WKD: Server indicated a failure
gpg: key 19802F8B0D70FC30: "Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>" not changed
gpg:              unchanged: 1
pub   ed25519 2020-05-11 [SC]
      A2FF3A36AAA56654109064AB19802F8B0D70FC30
uid           [  undef ] Jan Alexander Steffens (heftig) <jan.steffens@gmail.com>
uid           [  full  ] Jan Alexander Steffens (heftig) <heftig@archlinux.org>
uid           [  undef ] Jan Alexander Steffens (heftig) <jan.steffens@ltnglobal.com>
sub   cv25519 2020-05-11 [E]
sub   ed25519 2020-05-11 [S]
sub   ed25519 2020-05-11 [A]
gpg: error retrieving 'git@rxv.cc' via WKD: Server indicated a failure
gpg: key FE763A64F5E54FD6: "kpcyrd <git@rxv.cc>" not changed
gpg:              unchanged: 1
pub   rsa4096 2018-10-16 [SC] [expires: 2022-10-14]
      64B13F7117D6E07D661BBCE0FE763A64F5E54FD6
uid           [marginal] kpcyrd <git@rxv.cc>
uid           [  full  ] kpcyrd <kpcyrd@archlinux.org>
sub   rsa4096 2018-10-16 [E] [expires: 2022-10-14]
sub   rsa4096 2019-02-07 [S] [expires: 2022-10-14]
gpg: key 7258734B41C31549: "David Runge <dvzrv@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2019-10-01 [SC] [expires: 2023-09-30]
      C7E7849466FE2358343588377258734B41C31549
uid           [  full  ] David Runge <dvzrv@archlinux.org>
sub   cv25519 2019-10-01 [E] [expires: 2023-09-30]
gpg: error retrieving 'tobias.powalowski@googlemail.com' via WKD: Server indicated a failure
gpg: key 771DF6627EDF681F: "Tobias Powalowski <tobias.powalowski@googlemail.com>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-07-18 [SC]
      5B7E3FB71B7F10329A1C03AB771DF6627EDF681F
uid           [  full  ] Tobias Powalowski <tobias.powalowski@googlemail.com>
uid           [  full  ] Tobias Powalowski <tpowa@archlinux.org>
sub   rsa2048 2011-07-18 [E]
gpg: key A6234074498E9CEE: "Christian Hesse <eworm@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-08-12 [SC]
      02FD1C7A934E614545849F19A6234074498E9CEE
uid           [marginal] Christian Hesse <eworm@archlinux.org>
uid           [  full  ] Christian Hesse (Arch Linux Package Signing) <arch@eworm.de>
sub   rsa2048 2011-08-12 [E]
sub   ed25519 2019-08-29 [S]
sub   cv25519 2019-08-29 [E]
gpg: key 786C63F330D7CB92: "Felix Yan <felixonmars@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2012-01-20 [SC]
      B5971F2C5C10A9A08C60030F786C63F330D7CB92
uid           [  full  ] Felix Yan <felixonmars@archlinux.org>
uid           [marginal] Felix Yan <i@felixc.at>
uid           [marginal] Felix Yan <yanran@deepin.com>
uid           [  undef ] Felix Yan <felixonmars@qq.com>
uid           [marginal] Felix Yan <felixonmars@163.com>
uid           [marginal] Felix Yan <felixonmars@nyaa.cat>
uid           [  full  ] Felix Yan <felixonmars@gmail.com>
uid           [marginal] Felix Yan <felixyan@bbtechgroup.com>
uid           [  undef ] Felix Yan <felixonmars@member.fsf.org>
uid           [marginal] Felix Yan <felixonmars@archlinuxcn.org>
uid           [  undef ] Felix Yan <felixonmars@fedoraproject.org>
uid           [marginal] keybase.io/felixonmars <felixonmars@keybase.io>
uid           [marginal] Yan, Ran (Name on Passport) <felixonmars@gmail.com>
uid           [ unknown] Felix Yan <yanran@uniontech.com>
uid           [ unknown] Felix Yan <felixonmars@189.cn>
uid           [ unknown] Felix Yan <felixonmars@ubuntukylin.com>
sub   rsa4096 2012-01-20 [E]
gpg: key 94657AB20F2A092B: "Andreas Radke <andyrtr@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-05-14 [SC]
      ADC8A1FCC15E01D45310419E94657AB20F2A092B
uid           [  full  ] Andreas Radke <andyrtr@archlinux.org>
uid           [marginal] Andreas Radke <andyrtr@mailbox.org>
uid           [marginal] Andreas Radke <andreas.radke@mailbox.org>
sub   rsa2048 2011-05-14 [E]
gpg: error retrieving 'levente@leventepolyak.net' via WKD: Server indicated a failure
gpg: key FC1B547C8D8172C8: "Levente Polyak (anthraxx) <levente@leventepolyak.net>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-11-07 [SC] [expires: 2021-12-30]
      E240B57E2C4630BA768E2F26FC1B547C8D8172C8
uid           [  full  ] Levente Polyak (anthraxx) <levente@leventepolyak.net>
uid           [  full  ] Levente Polyak <anthraxx@archlinux.org>
uid           [  full  ] Levente Polyak <Z3r0.0x00@gmail.com>
uid           [  full  ] Levente Polyak <anthraxx@hamburg.ccc.de>
uid           [  full  ] Levente Polyak <levente@leventepolyak.de>
uid           [marginal] Levente Polyak (Jabber/XMPP only) <anthraxx@jabber.ccc.de>
sub   rsa4096 2011-11-07 [E] [expires: 2021-12-30]
gpg: error retrieving 'alucryd@alucryd.xyz' via WKD: No data
gpg: error reading key: No data
gpg: key AFF5D95098BC6FF5: "Maxime Gauduin <alucryd@alucryd.xyz>" not changed
gpg:              unchanged: 1
pub   rsa2048 2013-01-21 [SC]
      9437DD3815A7A9169E3D3946AFF5D95098BC6FF5
uid           [marginal] Maxime Gauduin <alucryd@alucryd.xyz>
uid           [marginal] Maxime Gauduin <alucryd@archlinux.org>
uid           [  full  ] Maxime Gauduin <alucryd@gmail.com>
sub   rsa2048 2013-01-21 [E]
gpg: key 46F633CBB0EB4BF2: "Filipe Laíns (FFY00) <lains@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2018-04-18 [SC] [expires: 2023-04-17]
      3DCE51D60930EBA47858BA4146F633CBB0EB4BF2
uid           [  full  ] Filipe Laíns (FFY00) <lains@archlinux.org>
uid           [  full  ] Filipe Laíns (FFY00) <lains@aurorafoss.org>
uid           [  full  ] Filipe Laíns (FFY00) <filipe.lains@gmail.com>
uid           [ unknown] Filipe Laíns (FFY00) <lains@riseup.net>
sub   rsa4096 2018-04-18 [E] [expires: 2023-04-17]
sub   rsa4096 2018-07-27 [S] [expires: 2022-04-22]
sub   rsa4096 2018-07-27 [E] [expires: 2022-04-22]
sub   rsa4096 2019-10-13 [A] [expires: 2022-04-22]
gpg: key 9C02FF419FECBE16: "Morten Linderud <morten@linderud.pw>" not changed
gpg:              unchanged: 1
pub   rsa4096 2014-09-05 [SC]
      C100346676634E80C940FB9E9C02FF419FECBE16
uid           [  full  ] Morten Linderud <morten@linderud.pw>
uid           [marginal] Morten Linderud <foxboron@archlinux.org>
uid           [  full  ] Morten Linderud <mcfoxax@gmail.com>
uid           [marginal] Morten Linderud <morten.linderud@fribyte.uib.no>
uid           [marginal] Morten Linderud <morten.linderud@student.uib.no>
sub   rsa4096 2014-09-05 [E]
sub   rsa4096 2018-11-13 [S]
sub   rsa4096 2018-11-26 [A]
gpg: key F83424824B3E4B90: "Orhun Parmaksız <orhun@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2021-01-03 [SC]
      165E0FF7C48C226E1EC363A7F83424824B3E4B90
uid           [  full  ] Orhun Parmaksız <orhun@archlinux.org>
uid           [ unknown] Orhun Parmaksız <orhunparmaksiz@gmail.com>
sub   rsa4096 2021-01-03 [E]
gpg: key EA4F7B321A906AD9: "Daniel M. Capella <polyzen@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-01-03 [SC] [expires: 2022-12-11]
      04DC3FB1445FECA813C27EFAEA4F7B321A906AD9
uid           [  full  ] Daniel M. Capella <polyzen@archlinux.org>
sub   rsa4096 2016-01-03 [E] [expires: 2022-12-11]
gpg: key F22FB1D78A77AEAB: "Giancarlo Razzolini (grazzolini) <grazzolini@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-11-11 [SC]
      ECCAC84C1BA08A6CC8E63FBBF22FB1D78A77AEAB
uid           [  full  ] Giancarlo Razzolini (grazzolini) <grazzolini@archlinux.org>
sub   rsa4096 2016-11-11 [E]
gpg: error retrieving 'mail@jsteel.org' via WKD: Server indicated a failure
gpg: key 332C9C40F40D2072: "Jonathan Steel <mail@jsteel.org>" not changed
gpg:              unchanged: 1
pub   rsa2048 2012-08-12 [SC]
      8742F7535E7B394A1B048163332C9C40F40D2072
uid           [  full  ] Jonathan Steel <mail@jsteel.org>
uid           [marginal] Jonathan Steel <jsteel@archlinux.org>
uid           [marginal] Jonathan Steel <jsteel@aur.archlinux.org>
sub   rsa2048 2012-08-12 [E]
gpg: key 84818A6819AF4A9B: "Eli Schwartz <eschwartz@archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2016-05-04 [SC] [expires: 2022-07-10]
      BD27B07A5EF45C2ADAF70E0484818A6819AF4A9B
uid           [  full  ] Eli Schwartz <eschwartz@archlinux.org>
uid           [  full  ] Eli Schwartz <eschwartz93@gmail.com>
sub   rsa4096 2016-05-04 [E] [expires: 2022-07-10]
sub   rsa4096 2017-01-09 [S] [expires: 2022-07-10]
gpg: key BA1DFB64FFF979E7: "Allan McRae (Arch Linux Master Key) <allan@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2011-11-29 [SC]
      AB19265E5D7D20687D303246BA1DFB64FFF979E7
uid           [  full  ] Allan McRae (Arch Linux Master Key) <allan@master-key.archlinux.org>
gpg: key D6D055F927843F1C: "Levente Polyak (Arch Linux Master Key) <anthraxx@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2018-11-08 [SC]
      D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C
uid           [  full  ] Levente Polyak (Arch Linux Master Key) <anthraxx@master-key.archlinux.org>
sub   rsa4096 2018-11-08 [E]
sub   rsa4096 2018-11-08 [A]
gpg: key 9B729B06A680C281: "Bartłomiej Piotrowski (Arch Linux Master Key) <bpiotrowski@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2017-05-15 [SC]
      DDB867B92AA789C165EEFA799B729B06A680C281
uid           [  full  ] Bartłomiej Piotrowski (Arch Linux Master Key) <bpiotrowski@master-key.archlinux.org>
sub   rsa4096 2017-05-15 [E]
gpg: key 4DC95B6D7BE9892E: "David Runge (Arch Linux Master Key) <dvzrv@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2021-04-26 [SC]
      2AC0A42EFB0B5CBC7A0402ED4DC95B6D7BE9892E
uid           [  full  ] David Runge (Arch Linux Master Key) <dvzrv@master-key.archlinux.org>
sub   cv25519 2021-04-26 [E]
gpg: key A88E23E377514E00: "Florian Pritz (Arch Linux Master Key) <florian@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa4096 2015-12-17 [SC]
      91FFE0700E80619CEB73235CA88E23E377514E00
uid           [  full  ] Florian Pritz (Arch Linux Master Key) <florian@master-key.archlinux.org>
sub   rsa4096 2015-12-17 [E]
gpg: key 3348882F6AC6A4C2: "Pierre Schmitz (Arch Linux Master Key) <pierre@master-key.archlinux.org>" not changed
gpg:              unchanged: 1
pub   rsa3072 2011-11-18 [SC]
      0E8B644079F599DFC1DDC3973348882F6AC6A4C2
uid           [  full  ] Pierre Schmitz (Arch Linux Master Key) <pierre@master-key.archlinux.org>
sub   rsa1024 2011-11-18 [E]
sub   rsa3072 2011-11-18 [A]
gpg: error retrieving 'dan@master-key.archlinux.org' via WKD: No data
gpg: refreshing 1 key from hkp://keyserver.ubuntu.com
gpg: keyserver refresh failed: Server indicated a failure
==> ERROR: Could not update key: A04F9397CDFD6BB0
gpg: error retrieving 'ionut@master-key.archlinux.org' via WKD: No data
==> ERROR: Could not update key: 7EFD567D4C7EA887
gpg: error retrieving 'thomas@master-key.archlinux.org' via WKD: No data
==> ERROR: Could not update key: 5184252D824B18E8
gpg: error retrieving 'gginiu@gmail.com' via WKD: Server indicated a failure
==> ERROR: Could not update key: 40F557B731496106
gpg: error retrieving 'brett@i--b.com' via WKD: Server indicated a failure
==> ERROR: Could not update key: A06B49470F8E620A
gpg: key 6BC26A17B9B7018A: "Alad Wenter <alad@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2017-09-07 [SC] [expires: 2022-11-16]
      DBE7D3DD8C81D58D0A13D0E76BC26A17B9B7018A
uid           [  full  ] Alad Wenter <alad@archlinux.org>
sub   cv25519 2017-09-07 [E] [expires: 2022-11-16]
gpg: error retrieving 'me@allanmcrae.com' via WKD: Server indicated a failure
gpg: key F99FFE0FEAE999BD: "Allan McRae <me@allanmcrae.com>" not changed
gpg:              unchanged: 1
pub   rsa2048 2011-06-03 [SC]
      6645B0A8C7005E78DB1D7864F99FFE0FEAE999BD
uid           [  full  ] Allan McRae <me@allanmcrae.com>
uid           [  full  ] Allan McRae (Developer) <allan@archlinux.org>
sub   rsa2048 2011-06-03 [E]
gpg: error retrieving 'anatol.pomozov@gmail.com' via WKD: Server indicated a failure
==> ERROR: Could not update key: B02854ED753E0F1F
gpg: error retrieving 'andrew@crerar.io' via WKD: Server indicated a failure
gpg: key F6B1610B3ECDBC9F: "Andrew Crerar <andrew@crerar.io>" not changed
gpg:              unchanged: 1
pub   rsa2048 2017-11-17 [SC] [expires: 2029-09-03]
      601F20F1D1BBBF4A78CF5B6DF6B1610B3ECDBC9F
uid           [  full  ] Andrew Crerar <andrew@crerar.io>
uid           [marginal] Andrew Crerar <crerar@archlinux.org>
sub   rsa2048 2017-11-17 [E] [expires: 2029-09-03]
gpg: error retrieving 'bruno.pagani@ens-lyon.org' via WKD: Server indicated a failure
gpg: error retrieving 'pagani@iap.fr' via WKD: Server indicated a failure
gpg: error retrieving 'bruno.pagani@obspm.fr' via WKD: Server indicated a failure
gpg: error retrieving 'bruno.pagani@ens-lyon.fr' via WKD: Server indicated a failure
gpg: error retrieving 'bruno.n.pagani@gmail.com' via WKD: Server indicated a failure
==> ERROR: Could not update key: 9D893EC4DAAF9129
gpg: error retrieving 'rodseth@gmail.com' via WKD: Server indicated a failure
==> ERROR: Could not update key: FCF3C8CB5CF9C8D4
gpg: key E074B83653CBB7BA: "Tim Meusel <bastelfreak@archlinux.org>" not changed
gpg:              unchanged: 1
pub   ed25519 2020-11-15 [SC] [expires: 2025-11-14]
      FE5AFA6D5DE0070ADFA21BC5E074B83653CBB7BA
uid           [  full  ] Tim Meusel <bastelfreak@archlinux.org>
sub   cv25519 2020-11-15 [E] [expires: 2025-11-14]
sub   rsa4096 2020-11-16 [S] [expires: 2025-11-15]
gpg: error retrieving 'ballogyor@gmail.com' via WKD: Server indicated a failure
==> ERROR: Could not update key: B61DBCE10901C163
gpg: error retrieving 'bluewind@xinu.at' via WKD: General error
gpg: error reading key: General error
gpg: error retrieving 'flo@xinu.at' via WKD: General error
^C
gpg: signal 2 caught ... exiting
I temporarily fixed my full screen problems by rolling back Cinnamon. Apparently Cinnamon 5.0 does not work for me.
Continue with the rest of the commands: https://archived.forum.manjaro.org/t/how-to-solve-keyring-issues-in-manjaro/4020
got all the way to sudo pacman -Syyu (with errors) but it ended with this:
(415/415) checking keys in keyring                                 [####################################] 100%
(415/415) checking package integrity                               [####################################] 100%
(415/415) loading package files                                    [####################################] 100%
(415/415) checking for file conflicts                              [####################################] 100%
error: failed to commit transaction (conflicting files)
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/__init__.py exists in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/__pycache__/__init__.cpython-39.pyc exist
s in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/__pycache__/pywintypes.cpython-39.pyc exi
sts in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/__pycache__/win32con.cpython-39.pyc exist
s in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/__pycache__/win32file.cpython-39.pyc exis
ts in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/pywintypes.py exists in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/win32con.py exists in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/pywin32/win32file.py exists in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/tests/__pycache__/test_reader_writer_lock.cpython
-39.pyc exists in filesystem
python-fasteners: /usr/lib/python3.9/site-packages/fasteners/tests/test_reader_writer_lock.py exists in filesy
stem
That’s what happens when you use sudo pip. Don’t do that. Stick to system packages or use a Python virtual environment.
See: pacman - ArchWiki
Warning: Generally avoid using the --overwrite switch. See System maintenance#Avoid certain pacman commands.
sudo pacman -Syu --overwrite '/usr/lib/python3.9/site-packages/fasteners/*'
