You should replace plasma-desktop-primex
with plasma-desktop
linux59
is long EOL, you should switch the kernel to a newer one, like llinux510
(LTS).
with plasma-desktop
linux59
(LTS).
PipeWire 0.3.28 was released 11 hours ago ( 0.3.28 Release · PipeWire / pipewire · GitLab ) and fixes the serious issues of the volume getting reduced to 0 and being unrecoverable without a restart that Iâve been seeing lately with 0.3.26 and 0.3.27. Can we please get a quick update to 0.3.28 so I can switch back from the -git
packages? Thanks for the update.
It tells you in the output:
Use Manjaro Settings Manager to remove Linux 5.9 and install a stable or LTS (Long Term Support) kernel. 5.9 is EOL (End Of Life) and is no longer in the repos.
Sure, switch to the unstable branch.
The volume getting reset to 0 is not fitting of a âstableâ branch.
No.
You need to keep adding the replacments for the ârequired byâ *-git
packages that keep popping up to the list of packages to replace (kconfigwidgets
in your current case/state):
$ sudo pacman -Syu kguiaddons kconfigwidgets
Rinse and repeat until you got them all stacked up and the package manager will actually start itâs work.
newer local packages
pamac update îČ â îČ 10s ï Preparando... Sincronizando banco de dados de pacotes... Aviso: pamac-cli: local (10.1.2-0.1) Ă© mais novo que extra (10.0.6-2) Aviso: pamac-common: local (10.1.2-0.1) Ă© mais novo que extra (10.0.6-2) Aviso: pamac-gtk: local (10.1.2-0.1) Ă© mais novo que extra (10.0.6-2) Resolvendo dependĂȘncias... Verificando conflito entre pacotes... Aviso: dependĂȘncia cĂclica detectada: Aviso: bashrc-manjaro serĂĄ instalado antes de sua dependĂȘncia bash
âgeoip Brazil and I use manjaro lxqt
T+ = See you later
how to remove Linux 5.9 kernel and how to install the new one if my system not bootable, can i install from Terminal (Alt+F2)? Thank you.
@jdcard do a pacman -Q | grep git
and see which git packages you have. Remove the git suffix from those packages you want to replace and put them into a row to install them via sudo pacman -S <list of packages>
An upstream issue that did not affect everyone has nothing to do with Manjaro. It seems youâve already found a temporary solution.
The Pipewire packages cannot be ported from the unstable branch to the stable branch, they are not standalone.
EDIT: See:
If you need more help, please create a new topic in the appropriate #support category.
Pretty much a wonderful update!.. At the end of the day all is great!.. ButâŠ
Pamac decided to not cooperate so well for this time. First of all, no updates showing⊠I refreshed the mirror lists⊠I updated the software databases⊠Eventually at the 10th tentative some mostly browser related updates showed. Applied them. No more updates⊠Eventually I rebooted the system and hey!.. The usual huge batch came!.. Happily applied them!.. Reboot!..
After log in the system started at ârecovery modeâ with a strongly reduced screen brightness!.. Oh, my God!.. Cinnamon asked me if Iâd like to open it or not⊠Said Yes⊠Another reboot⊠And well⊠All was well again back to normal!..
Have a nice day!..
Iâve got it as well, but it wasnât reversed (stable branch)
But when updating the system, I get the warnings: âpamac-xxx: Local version (10.1.2-0.1) is newer than extra (10.0.6-2)â
BTW, I like the new design
Thank you for Manjaro. It is f***ing brilliant
Hi.
manjaro ornara is very good.
but gnome version in very bad experience.
Please user libreoffice in gnome version pr do not have any office.
arg I tought the Kernel 5.10.36-2 was compiled with that, but it is 5.10.37-2 OopsâŠ
Thanks, that seems to have resolved it. I was on the the right track, just gave up too quickly when confronted with a seeming endless chain of dependencies.
I downloaded those, selected them all in Nemo, updated them with âSoftware Installerâ from the right-click context menu, and rebooted. Then, I checked my process list in ksysguard to make sure pulseeffects was running with my equalizer preset, tested some YouTube videos, tested recording myself and playing it back in Audacity, and tested speaker and mic input levels in Zoom, and everything seems to be working well so far. Thanks, Phil!
That all being said, since the issue happened after going idle for a while and coming back usually, Iâll continue monitoring for issues. I expect that theyâre fixed though, considering my experience with the -git
packages yesterday and today, and the 0.3.28 release notes. If you donât hear back from me about an issue, itâs most likely fixed. I work from home with multiple Zoom meetings per day, so audio issues will be found soon if they exist in this 0.3.28 release.
Thx, keep me updated and if all is fine we push them to the repos. I simply canât push things without testing them first. @Buju
Whatâs the easiest way to prevent installation of the new Nvidia driver when doing a system update? Or is better to just wait until a fix?
Hi, thx for this new stable update. RTX 2070 S here (DP used) + kernel 5.12. Updated in tty, no issue with the 460.80 driver.
