No, you didn’t. rebuild-detector is in our repos now. Perhaps your mirrors aren’t up to date?
Then why was it recommended to install it with the link going to the AUR?
I have not done the update yet as it says to do the install before the update.
Same for me with kernel 5.10.
Gnome does not load at all.
I am with AMD.
I’m in a hurry, but trying to figure this out…
Good question. Edited.
Noticed that noto-fonts looks different. And emojis are broken
Kernel 5.10.2.2 not work with my AMD System (Black Screen)
I go back to 5.9
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: GL702ZC v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GL702ZC v: 1.0 serial: <filter> UEFI: American Megatrends v: GL702ZC.306 date: 07/05/2019
Battery: ID-1: BAT0 charge: 61.1 Wh condition: 61.1/74.2 Wh (82%) model: ASUSTeK ASUS Battery status: Not charging
CPU: Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen rev: 1 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 76673
Speed: 1378 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz): 1: 1378 2: 1375 3: 1270 4: 1265 5: 1374
6: 1374 7: 1375 8: 1374 9: 1269 10: 1268 11: 2334 12: 2344
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: ASUSTeK
driver: amdgpu v: kernel bus ID: 0c:00.0
Device-2: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-8:3
Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.3.1
direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0c:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 12:00.3
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: e000
bus ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave driver: rtw_8822be v: N/A port: d000
bus ID: 07:00.0
IF: wlp7s0 state: up mac: <filter>
Drives: Local Storage: total: 1.14 TiB used: 95.14 GiB (8.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB temp: 41.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000LX015-1U7172 size: 931.51 GiB
Partition: ID-1: / size: 211 GiB used: 95.14 GiB (45.1%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 63.9 C mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): cpu: 2300
Info: Processes: 323 Uptime: 20m Memory: 15.64 GiB used: 2.31 GiB (14.8%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1400 Shell: Bash v: 5.1.0 inxi: 3.2.01
See edit to known problems.
I had a a problem wit python 3.9 update
python: error while loading shared libraries: libpython3.8.so.1.0: cannot open shared object file: No such file or directory
Was “solved” linking the library from python 3.9
sudo ln -s /usr/lib/libpython3.9.so.1.0 /usr/lib/libpython3.8.so.1.0
Now works fine
❯ python -V
Python 3.9.1
No it’s not:
Switch to a console using Ctrl+Alt+F2
Log in as Admin user
Execute:
sudo -sto become root
execute:
diff --side-by-side /root/.zshrc.pacnew /root/.zshrc -
See if you need to copy-paste anything from
/root/.zshrc.pacnewto/root/.zshrc. -
If you don’t, just delete the
.pacnew -
if yes, please use your favourite CLI editor to incorporate the changes (
nano,vi,emacs) Not Kate / Gedit / Atom / … -
exitthe root prompt ASAP as that’s the way tototally fùçk upseriously mess up your system.
A post was split to a new topic: Errors after update
Alright!
For all of you having black screen with AMD GPU with kernel 5.10
For GRUB:
- Open a terminal/TTY (alt+f2)
- Enter
sudo nano /etc/default/grub - Find the line:
GRUB_CMDLINE_LINUX_DEFAULT=" - Add
amdgpu.dc=0 - Save, then run
sudo update-grub
For systemd-boot:
- Enter
sudo nano /boot/loader/entries/manjarolinux5.10.conf - Add
amdgpu.dc=0to the end of the lineoptions - Save & reboot!
Hope this helps!
It is a bug in the latest AMD drivers…
Try again from a command line:
pamac upgrade
Kernel 4.14, Xfce.
All fine: I had to do the usual system maintenances to check pac files and rebuild AUR packages; however, now in the journal logs, I see a new warning:
systemd[1004]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
Which seems to need this Grub parameter:
systemd.unified_cgroup_hierarchy=true
https://bbs.archlinux.org/viewtopic.php?id=261330
I will try and report back.
EDIT:
Yes: I needed to add systemd.unified_cgroup_hierarchy=true to grub to get rid of such error, but I’d like to know if it is ok.
Oh, thanks, but already updated… Wouldn’t even be able to run this, as pamac partially uninstalled itself for some reasons…
But sweet, all issues are fixed for me, now!!
Your theme is not compatible any more… Try another one…
Ah, ok, thanks.
Do I get that corrrectly: Commenting out that grub line would prevent the warning to appear, but also prevent the usage of systemd-fsck?
So I can ignore this warning?
5.9 is EOL. Try 5.4 LTS (Long Term Support) Instead…
Works…
Thank You…
same here
