now what? what does it mean? that I should upgrade all those packages or just that it detected and checked those packages? also there is no help available
edit: testcase⌠started zoom and it started just fine without any rebuild need.
Yeah, that utility just does what itâs name says, it checks. Now I think you have to rebuild those packages. Like in manually reinstalling them the same way you did before.
Also apparently sometimes it flags some packages like needing a rebuild, but it isnât the case. So itâs up to encountering a problem or not I guessâŚ
I have read, somewhere on the forums, that it can happen that they donât disappear. I donât know why this happens. But if they disappear this is what you want and allâs good. (AFAIK anyway.)
Not likely, the approach used to remove all the various versions of nvidia drivers was the ârip the bandaidâ off approach. I was running the latest kernel at the time before this update (5.9 and running the latest nvidia drivers (455 series) and when the update was over all nvidia drivers had been removed and I was on the free drivers. In my case this wasnât a problem other than performance and was then able to easily update to 5.10 and add the nvidia drivers back however on some of the newer nvidia hardware the free drivers donât work in which case being forced onto them will make it so you donât get a desktop and have to switch to a terminal to manually make sure all the old drivers got remvoved properly and then install the new 455 or if you canât run the 455 drivers the legacy nvidia driver.
So basically read these forums as there are excellent step by step directions of what you have to do and make sure you have some time to mess around with it and a good backup before you start and then just do it.
I have a hybrid card intel/Nvidia Quadro T2000 on lenovo thinkpad p1, and ran the update and installed kernel 5.10. I also ran the nvidia driver install command mentioned in the first post using mhwd. The problem is that it wonât load the nvidia driver.
I did not run into any booting trouble. The nvidia driver 455 is installed but somehow did not load.
I found a fixed that worked for me. I unstalled the 390 and 340 drivers in pacmac, then installed mhwd and mhwd-db, and ran the 5.4 kernel. Now I see the hybrid drivers and I can also connect to an external screen via nvidia gpu. Using kernel 5.10 does not seem to work with this hardware or perhaps combined with cinnamon. Itâs strange because it is recent hardware.
