When I installed by Architect after downloading packages:
"error: confuse: signature from Baptiste Jonglez
“baptiste@bitsoftnetworks.org” is marginal trust
File /var/cache/pacman/pkg/confuse-3.3-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)
Do you wants to delete it? [Y/n] error: failed to commit transaction or corrupted package)
Running smoothly apart from telegram-desktop crashing when trying to view chats ever since this update
UPDATE: it runs now, apparently i needed to install telegram-qt now (running on kde plasma). still has the same output about setting the real-time priority
output:
$ telegram-desktop
(process:6481): Telegram-WARNING **: 13:39:53.381: Unfortunately, GTK integration conflicts with qgtk2 platformtheme and style. Therefore, QT_QPA_PLATFORMTHEME and QT_STYLE_OVERRIDE will be unset.
Telegram-Message: 13:39:53.382: This can be ignored by setting TDESKTOP_I_KNOW_ABOUT_GTK_INCOMPATIBILITY environment variable to any value, however, if qgtk2 theme or style is used, this will lead to a crash.
Telegram-Message: 13:39:53.382: GTK integration can be disabled by setting TDESKTOP_DISABLE_GTK_INTEGRATION to any value. Keep in mind that this will lead to clipboard issues and tdesktop will be unable to get settings from GTK (such as decoration layout, dark mode & more).
(process:6481): Telegram-WARNING **: 13:39:53.383: Application was built without embedded fonts, this may lead to font issues.
[ALSOFT] (EE) Failed to set real-time priority for thread: Operation not permitted (1)
error: : cannot open
[1] 6481 abort (core dumped) telegram-desktop
After updating, I’m unable to change screen brightness.
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
Also tried all the solutions mentioned in this post Can't adjust screen brightness (Lenovo Laptop, NVIDIA, XFCE) but none worked.
please help! Thanx
Pretty long thread of possible issues but I am happy to report that the updates went without a hitch. Great work. “Happy” New Year everyone.
AMD RX570
Thanks, solved it for me too, although not sure this is a good “solution”. Something is wrong with grub-vanilla.
In case you are using the manjaro repository application, I would advise you to uninstall it and try by downloading the application from the official telegram website (https://desktop.telegram.org/) and to the tsetup.2.5.1.tar file. xz unzip it in your user folder (where you choose) and run the TELEGRAM file (the launcher will automatically be added to the system and it will update itself to the latest version).
I clarify: I use this version in XFCE and it works perfectly
[/quote]
output:
$ telegram-desktop
[/quote]
Experienced the same problem with noto-fonts other experienced. Downgraded to 20190926 which displays the fonts correctly.
One thing I notice, though I don’t know how it could be related. I was using Chromium snap (from Canonical, I think) - after installing this update (2020-12-30) the bookmark folders in the bookmark toolbar stopped rendering - only an empty drop down was shown. Also when clicking in the toolbar/location bar Chromium was blocking for like 10-15 seconds then starting to work again. The missing bookmarks folders were not rendered, though. I tried to restart the computer - same problem.
I then removed the Chromium snap and installed Manjaro’s Chromium - problem not happening with Manjaro’s build.
I also noticed extra sluggishness with Slack (snap) - startup time seems slower than before (takes up to 15 seconds to show up). Not sure about that one, though.
Exactly the same issue and message. NVIDIA driver was turned on AMD CPU, ASUS board. I had no issues with previous updates. I can’t manage to boot up now with any other Kernel. I’ve tried with 5.7 and 5.4.
Just performed an incremental update on Manjaro XFCE using Ryzen 3600 and RTX 3070 on X570 board. Upgraded from 5.9 kernel to 5.10 after I confirmed the update was successful, and that was also fine. Thanks for the hard work. I was worried this update would cause some issues after seeing threads on Reddit. But happy to confirm it was all fine after all
I already tried france, germany, usa, italy… none of them has worked…
@mikronimo, try this:
sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu
This resets your mirrors and initiates the update process.
Is it the Pamac update/upgrade lately that changed something in the UI? For the second time a big update was sneaked in while I was installing an application, that aborted with an error. After rebooting I was met with an kernel panic.
Now I learned how to fix that, with an update, overwriting an gstreamer file and installing LTS kernel, with chroot and livebooting
… thanks forum!
@RichardF77
Here’s how I fixed it. I was on kernel 5.9.11 before the update
- Restored from Timeshift backup.
- Went into Pamac and uninstalled ALL the Nvidia drivers . This uninstalls the nvidia 450 drivers etc. and mhwd.
- Did an update in Pamac - which installed the new 5.10 kernel and other updates.
- Rebooted - Now it boots into KDE SDDM correctly
- Go back into Pamac and install mhwd
- Then go into Manjaro Settings Manager and auto install proprietary Nvidia drivers. This installs the 455 nvidia drivers etc.
- Reboot and all is good.
Hope this helps.
I published a way on how to compile old Nvidia drivers on your own.
Dear all,
what I can told about my manjaro-kde:
the only possibility to boot is via Grub using only the 5.9x img
I have lost some hours last nght including timeshift. Wasnt funny
Hopefully 2021 will be greater
Same here, exactly the same message. I however don’t use Nvidia graphics, Intel HD here. I am only in my second week of using Manjaro/Linux full time so I am clueless as to what to do. I don’t have a backup (lesson learnt…)
Can anyone give me some pointers on how to resolve this?
Dear darius,
enable timeshift. It will keep your ass
Manjaro XFCE, geforce 210 video card: with this new update and having to uninstall the proprietary driver (version 340), I also decided to uninstall the free driver (video-linux for GT218) because it seems to conflict with GTK3 in some applications ( when the system starts, the title bar and the margin turn white and do not show the maximize, close, etc. buttons, so when uninstalling this video-linux driver the GTK3 style does not suffer problems, but unfortunately when Like video-Linux using kernels 5.9 and 5.10, manjaro suffers from slowing down when opening videos (both in chromium and in firefox) or crashes when using applications for a while (mainly related to configuration or thunar). Fortunately, all this behavior is not observed when using kernel 5.4 (apparently this anomalous behavior may be due to the KWORKER / u processes)
My system completely failed when I next tried to reboot it.
I reinstalled from scratch and now bit by bit trying to remember how to set up all the tools I used to use.
I already discovered some applications hang the computer and I don’t remember seeing that ever before. A power off and back on is the only way I know to get it running again. One was yum and the other is the default web browser. I haven’t done any diagnostics as I have more essential setups yet to go through.
