Total Download Size: 3248.46 MiB
Total Installed Size: 15354.61 MiB
Net Upgrade Size: 405.57 MiB
:: Proceed with installation? [Y/n] NOOOO
maybe later… need to free some space before
It’s a lot of output but I’ll go for it I guess… Man this is frustrating!!
So I logged in to a tty
ran uname -a
output was
5.4.85-1MANJARO
inxi -G
NVIDIA GP106 GTX 1060 6GB driver: N/A
Loads of other stuff but I think that’s the important bit?
Then I ran
sudo mhwd -a pci nonfree 0300
and now get something different to before…
Installing video-nvidia...
Sourcing /etc/mhwd-x86.conf....
nvida-utils and nvidia-440xx-utils are in conflict
Error: pacman failed!
Error: script failed
I’ve been a member for years on the forum but couldn’t login to my old account so had to make a new one.
I tried
sudo pacman -r nvidia-440xx-utils
but get
Error: failed to initialize alpm library
Have you updated the system now freshly again with the Philm new fix he posted about 19minutes ago?
sudo pacman -Syyu
first. Hopefully there is “nothing to do” but actually some package(s) got updated.
And then try the mhwd thing again.
Yes I have, it said nothing to update.
maybe instead of removing the old try to install the new?
sudo pacman -S nvidia-utils
Ok that did let me remove the 440xx
and now it does look like sudo mhwd -a pci nonfree 0300
is doing something
OMG it worked I am back in a graphical environment!
Thanks so much!
More fixes regarding linux57 and linux58 removal plus some other fixes …
Happy new year
Hello Phil,
I had issues with my Ti1080 Nvidia drivers. Got black screen.
Solution:
sudo mhwd -r pci video-nvidia
and after just following your normal installation:
sudo pacman -S linux-latest
Happy New Year
Thanks that worked perfectly. What is difference between true or false set to that parameter ?
I uninstalled everything “pipewire” except pipewire
and pipewire-docs
and then the update went through correctly. I found on the Arch wiki that pipewire-pulse
and other “pipewire” were not needed if PulseAudio was working properly.
Update on 12 Systems without Problems.
DK3
True mount the File System in read only mode false in Read Write Mode
In normal cases the File System shouldn’t mounted ro (read-only)
Thanks for the info
https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
or the more wordy version
(not that more means better of course)
