Got an error messages and didn’t upgrade
but after again run upgrade process everything went OK
error: lib32-util-linux: signature from "Christian Hesse <eworm@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/lib32-util-linux-2.36-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: libpgm: signature from "Kyle Keen <keenerd@gmail.com>" is invalid
:: File /var/cache/pacman/pkg/libpgm-5.3.128-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
Had some issues with this one, video stopped working, lost network, and lm_sensors.service fails.
adapter is a Realtek RTL8111H gigabit ethernet controller. The kernel driver wasn’t being loaded, fixed by:
modprobe r8169
Then reinstalled drivers later via the GUI once graphics were re-established (this seems to have installed r8168).
Prior to this update, I had already installed nvidia 450xx. It seems like the cause of this issue was that linux58-nvidia-450xx was not installed in the update from kernel 57 to kernel 58, I fixed this by running
sudo mhwd -f -i pci video-nvidia-450xx
haven’t solved the lm_sensors issue yet, since it is less critical, I will do that when I get the time, if anyone has any suggestions, the error is:
systemd[1]: Starting Initialize hardware monitoring sensors...
sensors[590]: No sensors found!
sensors[590]: Make sure you loaded all the kernel drivers you need.
sensors[590]: Try sensors-detect to find out which these are.
systemd[1]: lm_sensors.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: lm_sensors.service: Failed with result 'exit-code'.
systemd[1]: Failed to start Initialize hardware monitoring sensors.
I have run sensors-detect, and it made no difference.
Edit: fixed, linux58-headers was not installed and so the zenpower module was not updated.
After noticing last night that I couldn’t use Vulcan with the 440xx driver I was able to use the GUI tool to switch it out for the 450xx driver and when I rebooted it worked probably because I had already uninstalled cuda.
Edit:
The above refers to the pervious stable update. I’m not sure I ever actually got this one. I remeber getting a small update of 27 packages. Maybe that was it? All went fine so I’ll mark that
Even updated my mirror list and ran -Syyu but got nothing else.
I have the same problem: linux58-ndiswrapper is a required dependency of linux-latest-ndiswrapper, but linux58-ndiswrapper does not exist. Even upgrading the kernel from Linux 5.7.19 to Linux 5.8.6 does not help, because the upgrade does not supply linux58-ndiswrapper, and it’s not in the repos. I have linux57-ndiswrapper on my computer, but not linux58-ndiswrapper.
This problem was already noted here:
However, a solution to the problem was not provided.
I have many executable python scripts which i usually launch by double-click and choosing execute. On a clean install from iso (manjaro-kde-20.0.3-200606-linux56.iso), this works perfectly.
I did a complete re-install yesterday an did a ‘pacman -Syyu’. Now whenever I click ‘execute’ it opens the script in kate (the open behaviour). I have confirmed this by creating/testing/updating/testing in a vm.
If I right click the script an choose ‘execute in Konsole’ The scripts do execute (- without errors).
I have checked the file associations before and after the update I cannot see any changes.
I know the iso is getting a little bit old - I cannot confirm which of the updates I have installed in the past few weeks broke this. It may not be this one.
Other than that, this distro is brilliant - Many Thanks
This is my first post to the forum I appologize in advance if this is the wrong thread …
Habe auch Probleme mit dem Update. Kernel ist 5.8.6.
Warnung: Kann “linux58-ndiswrapper” nicht auflösen (eine Abhängigkeit von “linux-latest-ndiswrapper”)
:: Das folgende Paket kann aufgrund nicht auflösbarer Abhängigkeiten nicht aktualisiert werden:
linux58-ndiswrapper ist nicht installiert und auch nicht im Repro verfügbar, dafür aber linux57-ndiswrapper.
Boot with Kernel 5.4
Went into tty - pamac checkupdates -a and pamac update all went fine
Shut down- Boot up the new installed Kernel, 5.8.6-1
check: sudo journalctl -p err --since today no errors
