Update works fine. No issues here on three machines.
Now I deleted the flash-plugin and pepperflash because I don´t use it and it will be removed from the repos at the end of 2020.
regards
caho
regards
caho
No problems at all (Manjaro GNOME with Pop-shell from AUR).
Aside from an issue with VirtualBox saying it was not compatible with the kernel (So I just ran pacman -Syuu and also updated via the package manager, and ran the reboot dependency), it all runs just as smoothly as before.
Great job as always. I have never been happier with an OS.
Hi,
Got an issue with my second PC, i can’t connect with TigerVNC. It’s certainly due to this
All fine on my system (XFCE, Kernel 4.14)
I only noticed a warning message on reboot (on console) about fwupd.service, but is displayed for a fraction of second: if I check for fwupd on journal logs, and if I check using systemctl status fwupd.service
, I don’t see any message about.
However is due this update, since fwupd has been updated from 1.4.5-2 to 1.4.6-1
After this update my onboard ethernet was dead, but that was presumably just a coincidence. Luckily my parts bin had an Intel Pro/1000 board, which is anyway better than the Realtek.
libnautilus-extension-typeahead
is only useful on GNOME with nautilus-typeahead
. It includes a patch for find as you type.
Auf meinem Desktop 1 alles ok.
Please open a separate issue for that here and please also provide the usual diagnostics.
Phil pulled an all-nighter apparently…
Not sure what doesn’t work.
As I log in to the desktop(XFCE), I got the message: “Unable to get connection to the message bus seassion. Connection refused”.
Should I open another issue?
Opend: "Unable to get connection to the message bus session" after login
Cinnamon, 5.4, update was good. Thanks for your efforts.
Stable as a rock! A flawless update.
KDE, nvidia 450.66, kernel 5.4 LTS
Thank you!
Super nice 20.1
Working perfectly
Great job
Thanks for the hard work
I create a post for my issue:
Thanks in advance for the help
From the announce above:
I got this error:
sudo usermod --append --groups virtualbox $USER
usermod: group 'virtualbox' does not exist
@bogdancovaciu is helping me there…
And this is the solution (Thanks to @bogdancovaciu):
I’m not able to get to the login screen after this update. could it be my old 340 nvidia driver?
I’m able to ctrl+alt f2, but going back to f1, it’s just a black screen
Did you try ctrl+alt+F7?
Yeah. Not working.
Trying to remove nvidia drivers
Edit:
Yeah, remove nvidia drivers solved it… guess i cant use 340 drivers no more?
