Is there a way to speedup the mouse pointer more than it’s possible via the UI?
I have the M570 Trackball from logitech and want to speed up the mouse pointer a bit more.
Is there any way to increase it (e.g. via some x11 files)?
Have a look at the xset
command. It can be used to adjust mouse acceleration (amongst other things).
Work out the parameters which suit your needs, then stick the command in your ~/.bashrc / ~/.zshrc / etc. so it’s automatically applied.
Ok, got it.
Do it like this:
Edit: sudo nano /etc/X11/xorg.conf.d/10-evdev.conf
Section "InputClass"
Identifier "Logitech M570"
MatchProduct "Logitech M570"
Driver "evdev"
Option "AccelerationProfile" "2" # 1=Standard, 2=Konstante Beschl., 3=Adaptive Beschl. 4 = Keine Beschl.
Option "AccelerationNumerator" "3" # Erhöhen für schnelle, verringern für langsamer. Default bei 2
Option "AccelerationDenominator" "1"
Option "ConstantDeceleration" "2"
Option "EmulateWheel" "true"
Option "EmulateWheelButton" "9" # Forward-Btn & Trackball = Scrolling
EndSection
Those three Acceleration-Options do the magic.
I’ve also added the Super-Cow-Black-Ninja-Ultra-Pro
scrolling… means if I hold the
forward
button on the mouse, I can scroll with my Trackball.
That are the last two Emulate
-options you see in there.
Some additional settings you can make
Worth to noting: You have to Re-Login to your KDE to make this changes work.
