Hi all,
I’ve been a silent manjaro Gnome user for 5 years now, and i recently installed Manjaro KDE on a new laptop (HP Envy x360 2-in-1 Laptop 15-fe0xxx) and i just realized the speakers don’t work, which is a problem. Here is what’s happening :
If i plug in 3.5mm jack earbuds, i can ear the sound from the laptop, but it is faint (even at 150%).
With the earbuds plugged, i can see both the earbuds microphone and the internal microphone picking up sound.
As soon as the jack is unplugged, no sound whatsoever is coming from the speakers
This is my detailed system information :
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=2721f802-59c4-4338-bca1-23b0da1a8bb9 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Envy x360 2-in-1 Laptop 15-fe0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8BE0 v: 69.32 serial: <superuser required> UEFI: Insyde
v: F.03 date: 08/29/2023
ID-1: BAT1 charge: 26.6 Wh (52.0%) condition: 51.2/55.7 Wh (91.9%)
power: 7.9 W volts: 15.2 min: 15.1 model: 333-AC-31-A SA04055XL type: Li-ion
serial: <filter> status: discharging
Device-1: hid-0018:04F3:4164.0002-battery model: ELAN2513:00 04F3:4164
serial: N/A charge: N/A status: N/A
System RAM: total: 16 GiB note: est. available: 15.34 GiB
used: 6.07 GiB (39.5%)
Info: model: 13th Gen Intel Core i7-1355U bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x411C
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 62688
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:a7a1 class-ID: 0300
Device-2: Luxvisions Innotech HP Wide Vision 5MP Camera
driver: hid-sensor-hub,usbhid,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 30c9:00ab class-ID: fe01
serial: <filter>
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: Samsung 0x416c built: 2020 res: 1920x1080 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-U)
device-ID: 8086:a7a1 memory: 14.98 GiB unified: yes
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (RPL-U) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:a7a1 surfaces: xcb,xlib
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 476.94 GiB used: 42.78 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZH
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS1 temp: 22.9 C scheme: GPT
ID-1: / raw-size: 97.76 GiB size: 95.67 GiB (97.86%) used: 12.31 GiB (12.9%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 2721f802-59c4-4338-bca1-23b0da1a8bb9
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 86.8 MiB (33.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 1E8D-1595
ID-3: /home/<filter>/Data raw-size: 273.44 GiB size: 273.43 GiB (100.00%)
used: 30.39 GiB (11.1%) fs: exfat dev: /dev/nvme0n1p5 maj-min: 259:5
label: Data uuid: B899-E86C
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 104.83 GiB fs: ntfs
label: Windows uuid: 6A4AF2494AF21195
ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 642 MiB fs: ntfs
label: Windows RE tools uuid: FC002F77002F3852
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:4 info: Sunplus Innovation Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Device-2: 3-7:2 info: Luxvisions Innotech HP Wide Vision 5MP Camera
type: video,HID driver: hid-sensor-hub,usbhid,uvcvideo interfaces: 6 rev: 2.0
chip-ID: 30c9:00ab class-ID: fe01 serial: <filter>
Device-3: 3-10:3 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Processes: 269 Uptime: 1h 47m wakeups: 0 Init: systemd v: 254
Packages: pm: pacman pkgs: 1134 libs: 315 tools: pamac Shell: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
i have read a few topics about sound issues on similar laptops, but i don’t have the knowledge to actually understand anything deep enough to fix my problem.
http://alsa-project.org/db/?f=6606820d1f899236369d6b8d1ac8c319fcaf5f94
Any help is appreciated ![]()
nikgnomic: post edited to show inactive link in preformatted text format. Forum does not allow new users to post active links
